[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Mon Jun 19 02:43:58 PDT 2017
 Reporter:  rashadkm               |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  reopened
 Priority:  major                  |   Milestone:  3.6.2
Component:  Build/Install (cmake)  |     Version:  3.6.1
 Severity:  Unassigned             |  Resolution:
 Keywords:                         |
Changes (by manuelgrizonnet):
 * status:  closed => reopened
 * cc: manuelgrizonnet (added)
 * component:  Default => Build/Install (cmake)
 * version:  3.5.0 => 3.6.1
 * milestone:  3.5.1 => 3.6.2
 * resolution:  fixed =>
Comment:
 The file cmake/modules/GenerateSourceGroups.cmake is not available in geos
 3.6.1 source archive (http://download.osgeo.org/geos/geos-3.6.1.tar.bz2)
 which prevent to compile it using cmake on Linux.
 This bug was discussing several problems which where fixed in trunk and
 branch 3.5 but I'm not sure what prevent to add this macro to geos source
 package. I'm perhaps missing something here.
 Regards,
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:16>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
