[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Tue Jun 20 04:48:02 PDT 2017
 Reporter:  rashadkm               |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  major                  |   Milestone:  3.6.2
Component:  Build/Install (cmake)  |     Version:  3.6.1
 Severity:  Unassigned             |  Resolution:  fixed
 Keywords:                         |
Comment (by manuelgrizonnet):
 Replying to [comment:17 mloskot]:
 > > I'm perhaps missing something here.
 > Just do not use CMake to build GEOS, especially if 0) you don't want to
 use experimental build configuration 1) it is not working for you 2) you
 are not able to patch & fix it.
 > It is indicated in red that  **The official build system is the GNU
 Automake** - https://trac.osgeo.org/geos/wiki/BuildingOnUnixWithCMake
 Sorry I did not put much context to explain why I reopened the discussion.
 I was updating the geos version from 3.5 to 3.6 in the orfeo toolbox
 superbuild which compiles geos using cmake.
 I was able to patch & fix the issue by just adding the cmake macro
 GenerateSourceGroups to the geos source tree:
 https://github.com/orfeotoolbox/OTB/blob/update_superbuild_6.2/SuperBuild/patches/GEOS/geos-1
 -fixes-all.diff
 geos 3.6.1 compiles with cmake without error now. Let me know if there is
 something I can contribute upstream to improve the support of cmake.
 Best,
 Manuel
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:19>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
