[geos-devel] geos-3.6.1 released
Mateusz Loskot mateusz at loskot.net
Tue Mar 14 09:19:18 PDT 2017
On 14 March 2017 at 16:59, Rashad Kanavath <mohammedrashadkm at gmail.com> wrote:
> On Sat, Dec 24, 2016 at 6:21 PM, Sandro Santilli <strk at kbt.io> wrote:
>> On Sat, Dec 24, 2016 at 05:39:34PM +0100, Sebastiaan Couwenberg wrote:
>> > If your elves are not to busy, could you have them send a PR to fix:
>> >  https://github.com/ossimlabs/ossim/issues/79
>> Your cookies and milk moved me a bit, enough to start some work which
>> you can see here: https://github.com/strk/ossim/tree/geos-capi
>> But I could not configure the OSSIM source and the milk finished
>> before the C-API port completed. It didn't help to see that your
>> original report on ossim trac was left unanswered for 2+ months
>> and that the "cmake" call failed by not finding itself ?!
>>   -- OSSIM_INCLUDE_DIR=OSSIM_INCLUDE_DIR-NOTFOUND
>>   -- OSSIM_LIBRARY=OSSIM_LIBRARY-NOTFOUND
>>   CMake Error at apps/CMakeLists.txt:16 (message):
> currently a bug/strange behaviour in ossim cmake.
> try building ossim using ./scripts/build.sh
> or disable apps with cmake -DBUILD_OSSIM_APPS=OFF
This has nothing to do with GEOS, so please post to OSSIM folks.
Or, if you still think it is GEOS issue, try to report the problem more
clearly, detailed explanation where/how GEOS failed.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
