[geos-devel] Optimization
Amanda Osvaldo lambdasoftware at yahoo.es
Fri May 5 04:59:38 PDT 2017
Hi, thanks very much Kurt. :D
Can I exchange an idea with you?
I’m starting a research to map all Debian packages to determine which
are using optimization resources for Intel processors in their source.
It’s started with a question to know how it’s the best usage for Intel
processors and I believe it can allow insights for the community.
Did you like to comment something or indicate a place where I can share
the idea with others?
-- Amanda Osvaldo
On Thu, 2017-05-04 at 13:30 -0700, Kurt Schwehr wrote:
> Amanda,
> You can take a look at GDAL if you want to see an example of what a
> different project has done, you can take a look at:
> https://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdalwarpkernel.cpp
> Search for USE_SSE and _mm.  Being that this is open source, this
> typically boils down to:
> 1. Someone has the time / $ to implement it including tests
> 2. The project is willing to accept the contribution and the overhead
> it may add to the project
> There are a good number of issues hidden in #2.
> On Tue, May 2, 2017 at 6:48 PM, Stephen Woodbridge <woodbri at swoodbrid
> ge.com> wrote:
> > I can't speak for the developers, but I think it is highly unlikely
> > that they would do anything along these lines if it is not
> > compatible across multiple architectures. There are lots of high
> > performance CPUs/GPUs/etc out there each with their own special
> > requirements. Who is going to fund development, ongoing support,
> > debugging and bug fixing. And you have to have systems with these
> > chips in them to support that. It is costly and time consuming to
> > do this for even one of them. This also puts multiple different
> > execution paths in the code that makes it harder to maintain.
> > I think the community would rather the developers make really good,
> > portable, well tested code that works on all platforms, and it
> > release in regular stable way with new geospatial features rather
> > than focus on support one platform in some specialized way instead
> > of doing new feature development.
> > My 2 cents anyway.
> >   -Steve
> > On 5/2/2017 5:51 PM, Amanda Osvaldo wrote:
> > > Hi Steve, more than the compiler it is necessary for the data to
> > > fit into the processor correctly.
> > > And more, I don't have found GPU code yet.
> > > I don't know if it's will take some advantage, however for a
> > > large scale processing it should be necessary.
> > > *Tell me, I not confounding the things?*
> > > I see Geos has a geometry engine, however, it doesn't mean that
> > > it's a high-performance engine or designed for massive
> > > computation.
> > > -- Amanda Osvaldo
> > > On Tue, 2017-05-02 at 14:02 -0400, Stephen Woodbridge wrote:
> > > > On 5/2/2017 1:53 PM, Amanda Osvaldo wrote:
> > > > > Hi everybody. I'm reading the Geos source code and have no
> > > > > found any low-level optimization, like the use AVX2
> > > > > instruction set for Intel processors. It's an important
> > > > > question because without these and others optimization I have
> > > > > no significant difference between a Intel Core and Intel Xeon
> > > > > processors. Can someone tell me if the lack of optimization
> > > > > is intentional or just a lack of programmers? -- Amanda
> > > > > Osvaldo
> > > > Amanda,
> > > > I would think that this is the responsibility of the compiler,
> > > > not the
> > > > application. I believe you can get an Intel compiler that is
> > > > designed to
> > > > optimize for these various HW differences.
> > > > https://software.intel.com/en-us/blogs/2013/01/03/free-intel-c-
> > > > compilers-for-students-and-related-parallel-programming-tools
> > > > -Steve W
> > > > This email has been checked for viruses by Avast antivirus
> > > > software.
> > > > https://www.avast.com/antivirus
> > > > _______________________________________________
> > > > geos-devel mailing list
> > > > geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
> > > > https://lists.osgeo.org/mailman/listinfo/geos-devel
> > software.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20170505/71f98dfb/attachment.html>
