[geos-devel] [postgis-devel] GEOS C++ API deprecated? (was: PostGIS 2.5 what should be minimum requirements?)
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Oct 1 13:17:55 PDT 2017
On 10/01/2017 10:05 PM, Mateusz Loskot wrote:
> On 1 October 2017 at 21:47, Sebastiaan Couwenberg <sebastic at xs4all.nl> wrote:
>> On 10/01/2017 09:33 PM, Mateusz Loskot wrote:
>>> Unless, Sandro, your aim is to eventually mark C++ API deprecated
>>> and stop installing C++ API libraries and headers.
>>> That will require RFC and that is what I'm debating about.
>> To end this debate once and for all,
> Mind you, that does not ends anything, it starts it.
Yes, you seem to want to keep this debate alive.
>> I'd love for the C++ API to be officially deprecated and no longer installed soon after.
> As member of GEOS development team, I'm deeply concerned about
> taking such comments seriously, by rest of GEOS team.
>> As long as libgeos is provided alongside libgeos_c, C++ projects will be tempted to
>> keep using it.
> So what.
You don't seem to understand the pain it causes downstream.
>> And from my perspective as a package maintainer, I would
>> like for those projects to stop doing that and have them all use the C
>> API instead.
> Just stop accepting such GEOS-based software for packaging
> and keep nagging authors of such projects to switch to GEOS C API,
> but do not delegate your problem to GEOS.
The projects in question have been nagged, but that doesn't solve the
issue. It did cause the libosmium & osm2pgsql authors to drop support
for GEOS. It did not convince the OSSIM developers to switch to the C API.
Not accepting such software for packaging is a disservice to our users
and hence undesirable. Packages are part of a larger ecosystem which is
affected by removals down the tree, e.g. the removal of OSSIM causes the
removal of OTB.
> It is not GEOS problem that someone uses GEOS C++ API.
> GEOS is C/C++ library.
It is however a problem that slows adoption of newer GEOS releases, and
by extension newer PostGIS releases when they depend on features in
those releases.
> Having said enough, I'm not going to participate in the debate any longer.
> I only ask Sandro, as the GEOS leader/PSC member to answer one question:
> Do you plan to practically deprecate GEOS C++ API and stop installing
> GEOS C++ headers?
Why do you care so much about the C++ API? What keeps you from using the
C API?
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
