[geos-devel] [GEOS] #866: OffsetCurve failure
GEOS geos-trac at osgeo.org
Tue Apr 24 04:26:28 PDT 2018
 Reporter:  komzpa      |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.6.3
Component:  Default     |    Version:  3.6.2
 Severity:  Unassigned  |   Keywords:
 Originally in https://trac.osgeo.org/postgis/ticket/4072
 SELECT ST_OffsetCurve(ST_GeomFromText('LINESTRING(362194.505
 5649993.044,362197.451 5649994.125,362194.624 5650001.876,362189.684
 5650000.114,362192.542 5649992.324,362194.505 5649993.044)', 25832),
 -0.045, 'join=mitre');
 FEHLER: GEOSOffsetCurve: TopologyException?: assigned depths do not match
 at 362194.48950385087 5649993.0862477142 SQL Status:XX000
Ticket URL: <https://trac.osgeo.org/geos/ticket/866>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
