[geos-devel] [GEOS] #888: Fix check-local failure when quilt patches are applied
GEOS geos-trac at osgeo.org
Thu Jun 14 06:13:41 PDT 2018
 Reporter:  Bas Couwenberg  |       Owner:  geos-devel@…
     Type:  defect          |      Status:  closed
 Priority:  major           |   Milestone:  3.7.0
Component:  Default         |     Version:  3.6.2
 Severity:  Unassigned      |  Resolution:  fixed
 Keywords:                  |
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"9eb81524a0619b71d095dc0b54a7fafa70722b4a/git" 9eb8152/git]:
 #!CommitTicketReference repository="git"
 revision="9eb81524a0619b71d095dc0b54a7fafa70722b4a"
 Better skip external sources from checking blanks
 Patch by Bas Couwenberg
 Closes #888
Ticket URL: <https://trac.osgeo.org/geos/ticket/888#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
