[geos-devel] [GEOS] #1035: VoronoiLines and VoronoiPolygons hangs indefinitely on multipoint
geos-trac at osgeo.org
Tue Nov 3 13:45:50 PST 2020
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.9.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mdavis):
Found the fix for this. See https://github.com/libgeos/geos/pull/342
The problem is caused by two bugs in the `QuadEdgeSubdivision::remove`
method:
* Since the method argument can be an edge in either base or sym
orientation, the code to remove the corresponding `QuadEdgeQuartet` needs
to check if the quartet base matches the arg edge OR its sym
* The lambda capture clause must specify the edge parameter as `e`, not
`&e`, since it is already a reference
Ticket URL: <https://trac.osgeo.org/geos/ticket/1035#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
