[GRASS-announce] GRASS 7: New pygrass API is integrated
Markus Neteler neteler at osgeo.org
Wed Oct 10 06:31:03 PDT 2012
Dear GRASS users,
I am pleased to announce that the pygrass library, developed during
the Google Summer of Code 2012, is now on GRASS trunk and need to be tested.
The pygrass library has been developed take into account three main aspects,
in the order:
    1. *simplicity*, GIS it's an already complex subject, and we want to make
       the API as simple/natural/intuitive as possible but at the same time
       trying to respect the GRASS work-flow and nomenclature to make it easier
       to find information on the GRASS developer manual;
    2. *flexibility* even if pygrass want to provide an high level map
       interaction, internally used some classes that work with the
       GRASS API at very low level, such as Segment, Bbox, Ilist classes.
       Every time that a C struct has been used by a class, to leave the user
       free to implement their own logic, the ctypes pointer of the C strct
       it's available under the attribute name that start with "c_*";
    3. *performance* pygrass makes heavy use of the C GRASS functions
       every time that this is possible.
The pygrass library is divided in three main parts: Raster, Vector, and Modules.
You can find some simple samples here:
https://gist.github.com/3864411
and the documentation:
http://www.ing.unitn.it/~zambelli/projects/pygrass
Any hints are more than welcome.
Best regards.
Pietro
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
More information about the grass-announce mailing list
