[GRASS-SVN] r29417 - grass-addons
Wed Dec 12 07:53:15 EST 2007
Author: martinl
Date: 2007-12-12 07:53:13 -0500 (Wed, 12 Dec 2007)
New Revision: 29417
Removed:
   grass-addons/Makefile
   grass-addons/SVN_HOWTO.txt
Cosmetics: How-to fix (itc.it->osgeo), remove unused Makefile
Deleted: grass-addons/Makefile
--- grass-addons/Makefile	2007-12-12 11:17:54 UTC (rev 29416)
+++ grass-addons/Makefile	2007-12-12 12:53:13 UTC (rev 29417)
@@ -1,183 +0,0 @@
-MODULE_TOPDIR = ..
-include $(MODULE_TOPDIR)/include/Make/Dir.make
-SUBDIRS = \
-	r.albedo \
-	r.average \
-	r.basins.fill \
-	r.bilinear \
-	r.biomass \
-	r.bitpattern \
-	r.buffer \
-	r.carve \
-	r.cats \
-	r.circle \
-	r.clump \
-	r.coin \
-	r.colors \
-	r.composite \
-	r.compress \
-	r.contour \
-	r.cost \
-	r.covar \
-	r.cross \
-	r.describe \
-	r.digit \
-	r.distance \
-	r.drain \
-	r.dn2full.l7 \
-	r.dn2potrad.l7 \
-	r.dn2ref.ast \
-	r.dn2ref.l7 \
-	r.eb.disp \
-	r.eb.deltat \
-	r.eb.eta \
-	r.eb.evapfr \
-	r.eb.g0 \
-	r.eb.h0 \
-	r.eb.h_iter \
-	r.eb.molength \
-	r.eb.netrad \
-	r.eb.psi \
-	r.eb.rah \
-	r.eb.ublend \
-	r.eb.ustar \
-	r.eb.z0m \
-	r.evapo.potrad \
-	r.evapo.PM \
-	r.fill.dir \
-	r.flow \
-	r.gaswap.serial \
-	r.grow2 \
-	r.gwflow \
-	r.his \
-	r.in.arc \
-	r.in.ascii \
-	r.in.bin \
-	r.info \
-	r.in.gridatb \
-	r.in.mat \
-	r.in.poly \
-	r.in.xyz \
-	r.kappa \
-	r.lake \
-	r.latitude \
-	r.le \
-	r.li \
-	r.los \
-	r.mapcalc \
-	r.median \
-	r.mfilter \
-	r.mode \
-	r.neighbors \
-	r.null \
-	r.nullwest \
-	r.out.arc \
-	r.out.ascii \
-	r.out.bin \
-	r.out.gdal \
-	r.out.gridatb \
-	r.out.mat \
-	r.out.mpeg \
-	r.out.pov \
-	r.out.ppm \
-	r.out.ppm3 \
-	r.out.vrml \
-	r.out.vtk \
-	r.param.scale \
-	r.patch \
-	r.profile \
-	r.proj \
-	r.proj.seg \
-	r.quant \
-	r.random \
-	r.random.cells \
-	r.random.surface \
-	r.reclass \
-	r.recode \
-	r.region \
-	r.report \
-	r.resample \
-	r.resamp.interp \
-	r.resamp.rst \
-	r.resamp.stats \
-	r.rescale \
-	r.rescale.eq \
-	r.series \
-	r.slope.aspect \
-	r.statistics \
-	r.stats \
-	r.sum \
-	r.sun \
-	r.sunmask \
-	r.support \
-	r.support.stats \
-	r.surf.area \
-	r.surf.contour \
-	r.surf.idw \
-	r.surf.idw2 \
-	r.surf.random \
-	r.surf.gauss \
-	r.texture \
-	r.thin \
-	r.timestamp \
-	r.to.rast3 \
-	r.to.rast3elev \
-	r.to.vect \
-	r.topidx \
-	r.topmodel \
-	r.transect \
-	r.univar2 \
-	r.uslek \
-	r.usler \
-	r.vi \
-	r.vi.mpi \
-	r.volume \
-	r.walk \
-	r.water.outlet \
-	r.watershed \
-	r.what \
-	simwe \
-	wildfire
-GDALBASED = r.in.gdal
-FFTWBASED = r.surf.fractal
-CXXBASED = r.terraflow
-TIFFBASED = r.out.tiff
-#compile if GDAL present:
-ifneq ($(USE_GDAL),)
-    SUBDIRS += $(GDALBASED)
-endif
-#compile if FFTW present:
-ifneq ($(strip $(FFTWLIB)),)
-    SUBDIRS += $(FFTWBASED)
-endif
-#compile if PNG present:
-ifneq ($(strip $(PNGLIB)),)
-    SUBDIRS += $(PNGBASED)
-endif
-#compile if C++ compiler present:
-ifneq ($(strip $(CXX)),)
-    SUBDIRS += $(CXXBASED)
-endif
-#compile if TIFF present:
-ifneq ($(strip $(TIFFLIB)),)
-    SUBDIRS += $(TIFFBASED)
-endif
-default: subdirs htmldir
-clean: cleansubdirs
-PGM = rasterintro
Modified: grass-addons/SVN_HOWTO.txt
--- grass-addons/SVN_HOWTO.txt	2007-12-12 11:17:54 UTC (rev 29416)
+++ grass-addons/SVN_HOWTO.txt	2007-12-12 12:53:13 UTC (rev 29417)
@@ -1,9 +1,9 @@
-GRASS Addons SVN: Subversion repository at grasssvn.itc.it
+GRASS Addons Subversion repository at osgeo.org
 0. Install the svn client software
-    Linux:   * 'subversion' package (RPM for your distro, should
+    Linux:   * 'subversion' package (RPM/DEB for your distro, should
                be on the CDROMs/DVD)
     MacOSX:  * http://subversion.tigris.org/
@@ -25,31 +25,29 @@
 http-proxy-host = proxy.yourdomain.xyz
 http-proxy-port = 3128
-1. How to get the grassaddons from the SVN repository
+1. How to get the grass-addons from the SVN repository
 1a) Command line:
- svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons grassaddons
+ svn checkout https://svn.osgeo.org/grass/grass-addons grass-addons
  -> first it shows you the certificate (not validated which is ok),
     enter 'p' to accept it permanently
- -> then enter your password (get from Markus)
 1b) TortoiseSVN:
  Just enter this url:
-    https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons
+      https://svn.osgeo.org/grass/grass-addons
  and your user/password combination.
+2. This will check out the grass-addons into the directory grass-addons/
-2. This will check out the grassaddons into the directory grassaddons/
+3. cd grass-addons/
-3. cd grassaddons/
 4. Now work on the repository (see below).
 We also have a nice Web interface for *reading* (not submitting):
- https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/
+   http://trac.osgeo.org/grass/browser/grass-addons
 If you want a graphical tool for SVN, get it here:
  http://en.wikipedia.org/wiki/Subversion_%28software%29#GUI_front-ends.2Fclients
@@ -173,4 +171,3 @@
  http://svnbook.red-bean.com/nightly/en/index.html
  Version Control with Subversion
