[GRASS-SVN] r29435 - grass/trunk/imagery/i.ortho.photo/photo.rectify
    svn_grass at osgeo.org
    Fri Dec 14 13:45:29 EST 2007
Author: bdouglas
Date: 2007-12-14 13:45:29 -0500 (Fri, 14 Dec 2007)
New Revision: 29435
   grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c
- Improved temp file check
- Better wording for error strings
Modified: grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c
--- grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c	2007-12-14 14:41:50 UTC (rev 29434)
+++ grass/trunk/imagery/i.ortho.photo/photo.rectify/write.c	2007-12-14 18:45:29 UTC (rev 29435)
@@ -11,11 +11,11 @@
 int write_matrix (int row, int col)
     int n;
-    off_t offset;
     select_target_env();
-    if(!temp_fd)
+    /* create temp file if it doesn't eexist */
+    if (!temp_fd || (fcntl (temp_fd, F_GETFD) == -1))
         temp_name = G_tempfile();
         temp_fd = creat(temp_name,0660);
@@ -23,6 +23,8 @@
     for (n=0; n < matrix_rows; n++)
+        off_t offset;
         offset = ((off_t) row++ * target_window.cols + col) * G_raster_size(map_type);
         lseek(temp_fd,offset,SEEK_SET);
@@ -30,9 +32,10 @@
                                 != G_raster_size(map_type)*matrix_cols)
            unlink(temp_name);
-           G_fatal_error (_("error while writing to temp file: %s"), strerror(errno));
+           G_fatal_error (_("Unable to write temp file: %s"), strerror(errno));
     select_current_env();
     return 0;
@@ -48,17 +51,17 @@
    rast = G_allocate_raster_buf(map_type);
    close(temp_fd);
-   temp_fd = open(temp_name,0);
+   temp_fd = open (temp_name, F_DUPFD);
    fd = G_open_raster_new(name,map_type);
    if(fd <=0)
-       G_fatal_error (_("Can't open map %s"), name);
+       G_fatal_error (_("Unable to open map %s"), name);
    for(row = 0; row < target_window.rows; row++)
        if(read(temp_fd,rast,target_window.cols * G_raster_size(map_type))
                     != target_window.cols * G_raster_size(map_type))
-          G_fatal_error (_("error writing row %d"), row);
+          G_fatal_error (_("Unable to write row %d"), row);
        if(G_put_raster_row(fd,rast, map_type) < 0)
@@ -68,7 +71,6 @@
    close(temp_fd);
-   temp_fd = NULL;
    unlink(temp_name);
    G_close_cell(fd);
