[GRASS-SVN] r29448 - grass/trunk/lib/init
Sun Dec 16 06:48:42 EST 2007
Author: martinl
Date: 2007-12-16 06:48:41 -0500 (Sun, 16 Dec 2007)
New Revision: 29448
   grass/trunk/lib/init/init.sh
Update init.sh for -wx
Modified: grass/trunk/lib/init/init.sh
--- grass/trunk/lib/init/init.sh	2007-12-16 11:47:45 UTC (rev 29447)
+++ grass/trunk/lib/init/init.sh	2007-12-16 11:48:41 UTC (rev 29448)
@@ -72,14 +72,18 @@
     	# Check if the user asked for help
 	help|-h|-help|--help)
 	    echo "Usage:"
-	    echo "  $CMD_NAME [-h | -help | --help] [-text | -gui] [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]"
+	    echo "  $CMD_NAME [-h | -help | --help] [-text | -gui | -tcltk | -wx] [[[<GISDBASE>/]<LOCATION_NAME>/]<MAPSET>]"
 	    echo
             echo "Flags:"
             echo "  -h or -help or --help          print this help message"
-            echo "  -text                          use text based interface and set as default"
+            echo "  -text                          use text based interface"
+            echo "                                   and set as default"
             echo "  -gui (or -tcltk)               use Tcl/Tk based graphical user interface"
-	    echo "  -oldgui                        use the old GUI interface and set as default"
+	    echo "  -oldgui                        use the old Tcl/Tk GUI interface "
+            echo "  -wx                            use wxPython based graphical user interface"
             echo
             echo "Parameters:"
             echo "  GISDBASE                       initial database (path to GIS data)"
@@ -576,7 +580,7 @@
          	    # The gis_set.tcl script printed an error message so wait
 		    # for user to read it
-		    echo "Error in Tcl/Tk startup. If necessary, please"
+		    echo "Error in GUI startup. If necessary, please"
 		    echo "report this error to the GRASS developers."
 		    echo "Switching to text mode now."
 		    echo "Hit RETURN to continue..."
@@ -766,7 +770,6 @@
     wx)
-        # coming soon, see ^
         "$GISBASE/scripts/wxgrass" &
@@ -801,7 +804,7 @@
 	cat "$ETC/welcome"
 fi
-echo "GRASS homepage:                          http://grass.itc.it/"
+echo "GRASS homepage:                          http://grass.osgeo.org/"
 echo "This version running thru:               $shellname ($SHELL)"
 echo "Help is available with the command:      g.manual -i"
 echo "See the licence terms with:              g.version -c"
