[GRASS-SVN] r29490 - grass/trunk/gui/tcltk/gis.m
Thu Dec 20 22:42:32 EST 2007
Author: cmbarton
Date: 2007-12-20 22:42:32 -0500 (Thu, 20 Dec 2007)
New Revision: 29490
   grass/trunk/gui/tcltk/gis.m/mapprint.tcl
Code cleanup cosmetics. Test of commit privileges 2.
Modified: grass/trunk/gui/tcltk/gis.m/mapprint.tcl
--- grass/trunk/gui/tcltk/gis.m/mapprint.tcl	2007-12-21 01:22:17 UTC (rev 29489)
+++ grass/trunk/gui/tcltk/gis.m/mapprint.tcl	2007-12-21 03:42:32 UTC (rev 29490)
@@ -95,7 +95,7 @@
 		set cmd "gs"
-    #enable additional printing options if Ghostscript available
+	#enable additional printing options if Ghostscript available
 	if {![catch {set input [exec $cmd -help]} error]} {
 		regexp ".*Available devices:(.*)Search path:" $input string gsdevices
 		set gsstate "normal"
@@ -105,7 +105,7 @@
 	} else {
 		set gsdevices "none available"
 		set gsstate "disabled"
-	#	set printmode "eps"
+		#set printmode "eps"
 		tk_messageBox -type ok -icon error -message [G_msg "Ghostscript not available"]
@@ -125,7 +125,7 @@
 	variable docht
 	variable orient
-    # set paper dimensions
+	# set paper dimensions
 	if { $paper == "preset" } {
 		switch $paper_preset {
 			"11x17" {
@@ -237,135 +237,135 @@
 	variable gsstate
 	global mon
-    set mon $cm
+	set mon $cm
+	# check if opened
+	if { [winfo exists .printwin] } {
+	    wm deiconify .printwin
+	    raise .printwin
+	    return
-    # check if opened
-    if { [winfo exists .printwin] } {
-        wm deiconify .printwin
-        raise .printwin
-        return
-    set PW [toplevel .printwin]
-    wm title $PW [G_msg "Postscript and LPR printing of map display"]
-    # Left part paper + output
-    set PWid(left) [ frame $PW.left -padx 5 -pady 5]
-    pack $PWid(left) -side left -anchor w
-    # paper size, scale
-    set PWid(paper) [ frame $PWid(left).paper]
-    pack $PWid(paper) -side top -anchor w
-	# preset paper sizes (from ghostscript)
-    set row [ frame $PWid(paper).row1 ]
-    radiobutton $row.a -variable psprint::paper -value "preset" \
-		-highlightthickness 0
-    Label $row.b -anchor w -text [G_msg "Preset paper type"]
-    ComboBox $row.c -label "" -width 20  -textvariable psprint::paper_preset \
-		-values {"letter" "a4" "legal" "11x17" "a3" "ledger" "a0" "a1" "a2" } \
-		-modifycmd psprint::paper
-    pack $row.a $row.b $row.c -side left;
-    pack $row -side top -fill x -expand no -anchor n
-	# custom paper sizes
-    set row [ frame $PWid(paper).row2 ]
-    radiobutton $row.a -variable psprint::paper -value "custom" \
-    Label $row.b -anchor w -text [G_msg "Custom paper size"]
-    Label $row.c -anchor w -text [G_msg "width:"]
-    Entry $row.d -width 10 -textvariable psprint::pgwd
-    Label $row.e -anchor w -text [G_msg "  height:"]
-    Entry $row.f -width 10 -textvariable psprint::pght
-    pack $row.a $row.b $row.c $row.d $row.e $row.f -side left;
+	set PW [toplevel .printwin]
+	wm title $PW [G_msg "Postscript and LPR printing of map display"]
+	# Left part paper + output
+	set PWid(left) [ frame $PW.left -padx 5 -pady 5]
+	pack $PWid(left) -side left -anchor w
+	# paper size, scale
+	set PWid(paper) [ frame $PWid(left).paper]
+	pack $PWid(paper) -side top -anchor w
+	    # preset paper sizes (from ghostscript)
+	set row [ frame $PWid(paper).row1 ]
+	radiobutton $row.a -variable psprint::paper -value "preset" \
+		    -highlightthickness 0
+	Label $row.b -anchor w -text [G_msg "Preset paper type"]
+	ComboBox $row.c -label "" -width 20  -textvariable psprint::paper_preset \
+		    -values {"letter" "a4" "legal" "11x17" "a3" "ledger" "a0" "a1" "a2" } \
+		    -modifycmd psprint::paper
+	pack $row.a $row.b $row.c -side left;
+	pack $row -side top -fill x -expand no -anchor n
+	    # custom paper sizes
+	set row [ frame $PWid(paper).row2 ]
+	radiobutton $row.a -variable psprint::paper -value "custom" \
+	Label $row.b -anchor w -text [G_msg "Custom paper size"]
+	Label $row.c -anchor w -text [G_msg "width:"]
+	Entry $row.d -width 10 -textvariable psprint::pgwd
+	Label $row.e -anchor w -text [G_msg "  height:"]
+	Entry $row.f -width 10 -textvariable psprint::pght
+	pack $row.a $row.b $row.c $row.d $row.e $row.f -side left;
 	#margins
-    set row [ frame $PWid(paper).row3]
-    Label $row.a -anchor w -text [G_msg "Margins  left:"]
-    Entry $row.b -width 10 -textvariable psprint::mleft
-    Label $row.c -anchor w -text [G_msg " right:"]
-    Entry $row.d -width 10 -textvariable psprint::mright
-    Label $row.e -anchor w -text [G_msg " top:"]
-    Entry $row.f -width 10 -textvariable psprint::mtop
-    Label $row.g -anchor w -text [G_msg " bottom:"]
-    Entry $row.h -width 10 -textvariable psprint::mbottom
-    pack $row.a $row.b $row.c $row.d $row.e $row.f $row.g $row.h -side left;
+	set row [ frame $PWid(paper).row3]
+	Label $row.a -anchor w -text [G_msg "Margins  left:"]
+	Entry $row.b -width 10 -textvariable psprint::mleft
+	Label $row.c -anchor w -text [G_msg " right:"]
+	Entry $row.d -width 10 -textvariable psprint::mright
+	Label $row.e -anchor w -text [G_msg " top:"]
+	Entry $row.f -width 10 -textvariable psprint::mtop
+	Label $row.g -anchor w -text [G_msg " bottom:"]
+	Entry $row.h -width 10 -textvariable psprint::mbottom
+	pack $row.a $row.b $row.c $row.d $row.e $row.f $row.g $row.h -side left;
-    # portrait or landscape
-    set row [ frame $PWid(paper).row4 ]
-	LabelEntry $row.a -label [G_msg "Resolution (dpi) for printing and PDF "] \
+	# portrait or landscape
+	set row [ frame $PWid(paper).row4 ]
+	    LabelEntry $row.a -label [G_msg "Resolution (dpi) for printing and PDF "] \
 		-textvariable psprint::res -width 4
-    Label $row.b -anchor w -text "  "
-    radiobutton $row.c -variable psprint::orient -value "landscape" \
+	Label $row.b -anchor w -text "  "
+	radiobutton $row.c -variable psprint::orient -value "landscape" \
 		-text "landscape mode" -highlightthickness 0
-    radiobutton $row.d -variable psprint::orient -value "portrait" \
+	radiobutton $row.d -variable psprint::orient -value "portrait" \
 		-text "portrait mode  " -highlightthickness 0
-    pack $row.a $row.b $row.c $row.d -side left;
-    # output options
-    set PWid(output) [ frame $PWid(left).output ]
-    pack $PWid(output) -side top -anchor w
-    # LPR printer
-    set row [ frame $PWid(output).lpr ]
-    radiobutton $row.a -variable psprint::printmode -value "lpr" \
-    Label $row.b -anchor w -text [G_msg "Print on LPR printer"]
-    pack $row.a $row.b -side left;
-    # Postscript printer
-    set row [ frame $PWid(output).psprinter ]
-    radiobutton $row.a -variable psprint::printmode -value "psprint" \
-    	-state $psprint::gsstate -highlightthickness 0
-    Label $row.b -anchor w -text [G_msg "Print on postscript device* "] \
-    ComboBox $row.c -width 20 -textvariable psprint::printer  \
-    	-values $psprint::gsdevices -editable 0 -entrybg white
-    # PDF file
-    set row [ frame $PWid(output).pdffile]
-    radiobutton $row.a -variable psprint::printmode -value "pdf" \
-    Label $row.b -anchor w -text [G_msg "Save to PDF file*              "]  \
-    Entry $row.c -width 30 -textvariable psprint::pdffile  -state $gsstate
-    Button $row.d -text [G_msg "Browse"]  -command { set psprint::pdffile \
+	pack $row.a $row.b $row.c $row.d -side left;
+	# output options
+	set PWid(output) [ frame $PWid(left).output ]
+	pack $PWid(output) -side top -anchor w
+	# LPR printer
+	set row [ frame $PWid(output).lpr ]
+	radiobutton $row.a -variable psprint::printmode -value "lpr" \
+	Label $row.b -anchor w -text [G_msg "Print on LPR printer"]
+	pack $row.a $row.b -side left;
+	# Postscript printer
+	set row [ frame $PWid(output).psprinter ]
+	radiobutton $row.a -variable psprint::printmode -value "psprint" \
+		-state $psprint::gsstate -highlightthickness 0
+	Label $row.b -anchor w -text [G_msg "Print on postscript device* "] \
+	ComboBox $row.c -width 20 -textvariable psprint::printer  \
+		-values $psprint::gsdevices -editable 0 -entrybg white
+	# PDF file
+	set row [ frame $PWid(output).pdffile]
+	radiobutton $row.a -variable psprint::printmode -value "pdf" \
+	Label $row.b -anchor w -text [G_msg "Save to PDF file*              "]  \
+	Entry $row.c -width 30 -textvariable psprint::pdffile  -state $gsstate
+	Button $row.d -text [G_msg "Browse"]  -command { set psprint::pdffile \
 		[tk_getSaveFile -title "Output PDF file" -defaultextension ".pdf"]} \
-    # EPS file
-    set row [ frame $PWid(output).epsfile ]
-    radiobutton $row.a -variable psprint::printmode -value "eps" \
-    Label $row.b -anchor w -text [G_msg "Save to EPS file               "]
-    Entry $row.c -width 30 -textvariable psprint::epsfile
-    Button $row.d -text [G_msg "Browse"] -command { set psprint::epsfile \
-           [ tk_getSaveFile -title "Output EPS file" -defaultextension ".eps"] }
+	# EPS file
+	set row [ frame $PWid(output).epsfile ]
+	radiobutton $row.a -variable psprint::printmode -value "eps" \
+	Label $row.b -anchor w -text [G_msg "Save to EPS file               "]
+	Entry $row.c -width 30 -textvariable psprint::epsfile
+	Button $row.d -text [G_msg "Browse"] -command { set psprint::epsfile \
+	       [ tk_getSaveFile -title "Output EPS file" -defaultextension ".eps"] }
 	set row [ frame $PWid(output).gsmessage ]
-    Label $row.a -anchor w -text [G_msg "*requires ghostscript to be installed and in path"]
-    pack $row.a -side bottom;
-    pack $row -side top -fill x -expand yes -anchor center
+	Label $row.a -anchor w -text [G_msg "*requires ghostscript to be installed and in path"]
+	pack $row.a -side bottom;
+	pack $row -side top -fill x -expand yes -anchor center
+	# Buttons
+	set but [ frame $PWid(left).buttons ]
+	pack $but -side top
+	Button $but.print -text [G_msg "Print"] -command "update; psprint::print $cv"
+	Button $but.close -text [G_msg "Close"] -command { destroy .printwin }
+	pack $but.print $but.close -side left
-#    Buttons
-    set but [ frame $PWid(left).buttons ]
-    pack $but -side top
-    Button $but.print -text [G_msg "Print"] -command "update; psprint::print $cv"
-    Button $but.close -text [G_msg "Close"] -command { destroy .printwin }
-    pack $but.print $but.close -side left
 proc psprint::print { cv } {
