[GRASS-SVN] r29509 - grass/trunk/lib/init
Wed Dec 26 11:27:43 EST 2007
Author: pkelly
Date: 2007-12-26 11:27:42 -0500 (Wed, 26 Dec 2007)
New Revision: 29509
   grass/trunk/lib/init/gis_set.tcl
Remove and rearrange some Tk layout hints to make translated
messages display better. Fix scrollbar so it doesn't cover
path to GISDBASE, make padding and spacing more even.
Remove newlines from some messages to give -wraplength a chance
to do its job. (First test SVN commit)
Modified: grass/trunk/lib/init/gis_set.tcl
--- grass/trunk/lib/init/gis_set.tcl	2007-12-26 14:53:48 UTC (rev 29508)
+++ grass/trunk/lib/init/gis_set.tcl	2007-12-26 16:27:42 UTC (rev 29509)
@@ -222,9 +222,8 @@
     	-borderwidth {2}
     label .frame0.frameDB.left.label \
-    	-anchor {n} \
     	-justify right \
-	-wraplength 110 \
+    	-wraplength 200 \
     	-text [G_msg "GIS Data Directory: "]
     entry .frame0.frameDB.mid.entry \
@@ -236,11 +235,10 @@
     scrollbar .frame0.frameDB.mid.hscrollbar \
     	-command { .frame0.frameDB.mid.entry xview} \
     	-relief {sunken} \
-    	-width 12 \
     	-orient {horizontal}
 	button .frame0.frameDB.right.button \
-		-text [G_msg "Browse..."] -bd 1 \
+		-text [G_msg "Browse..."] -padx 10 -bd 1 \
 		-command { set tmp [tk_chooseDirectory -initialdir $database \
 			-parent .frame0 -title [G_msg "New GIS data directory"] -mustexist true]
 			if {$tmp != ""} {
@@ -250,12 +248,12 @@
     pack .frame0.frameDB.left.label -side top
-    pack .frame0.frameDB.mid.entry -side top -fill x
+    pack .frame0.frameDB.mid.entry -side top
     pack .frame0.frameDB.mid.hscrollbar -side bottom -fill x
-    pack .frame0.frameDB.right.button -side left -fill x
-    pack .frame0.frameDB.left -side left  -anchor n -fill x
-    pack .frame0.frameDB.mid -side left -fill x
-    pack .frame0.frameDB.right -side left -anchor n -fill x
+    pack .frame0.frameDB.right.button -side left
+    pack .frame0.frameDB.left -side left -anchor n
+    pack .frame0.frameDB.mid -side left -anchor n
+    pack .frame0.frameDB.right -side left -anchor n -padx 10
     # build .frame0.frameLOC - middle, left section for location selection listbox
@@ -264,9 +262,8 @@
     	-borderwidth {2}
     label .frame0.frameLOC.label \
-    	-anchor {w} \
 	-wraplength 170 \
-    	-text [G_msg "Project Location\n(projection/coordinate system)"]
+    	-text [G_msg "Project Location (projection/coordinate system)"]
     listbox .frame0.frameLOC.listbox \
     	-relief {sunken} \
@@ -275,11 +272,11 @@
     	-xscrollcommand {.frame0.frameLOC.hscrollbar set} \
     	-selectmode single
-    scrollbar .frame0.frameLOC.vscrollbar -width 12 \
+    scrollbar .frame0.frameLOC.vscrollbar \
     	-command {.frame0.frameLOC.listbox yview} \
     	-relief {sunken}
-    scrollbar .frame0.frameLOC.hscrollbar -width 12 \
+    scrollbar .frame0.frameLOC.hscrollbar \
     	-command {.frame0.frameLOC.listbox xview} \
     	-orient {horizontal} \
     	-relief {sunken}
@@ -298,9 +295,8 @@
     	-borderwidth {2}
     label .frame0.frameMS.label \
-    	-anchor {w} \
-	-wraplength 150 \
-    	-text [G_msg "Accessible Mapsets\n(directories of GIS files)"]
+	-wraplength 170 \
+    	-text [G_msg "Accessible Mapsets (directories of GIS files)"]
     listbox .frame0.frameMS.listbox \
     	-relief {sunken} \
@@ -309,11 +305,11 @@
     	-xscrollcommand {.frame0.frameMS.hscrollbar set} \
     	-selectmode single
-    scrollbar .frame0.frameMS.vscrollbar -width 12 \
+    scrollbar .frame0.frameMS.vscrollbar \
     	-command {.frame0.frameMS.listbox yview} \
     	-relief {sunken}
-    scrollbar .frame0.frameMS.hscrollbar -width 12 \
+    scrollbar .frame0.frameMS.hscrollbar \
     	-command {.frame0.frameMS.listbox xview} \
     	-relief {sunken}
@@ -340,6 +336,9 @@
     frame .frame0.frameNMS.third \
     	-borderwidth {2}
+    frame .frame0.frameNMS.spacer \
+    	-borderwidth {2} -height {10}
     frame .frame0.frameNMS.fourth \
     	-borderwidth {2}
@@ -353,9 +352,8 @@
     	-borderwidth {2}
     label .frame0.frameNMS.first.label \
-    	-anchor {n} \
-	-wraplength 160 \
-    	-text [G_msg "Create new mapset\nin selected location"]
+	-wraplength 200 \
+    	-text [G_msg "Create new mapset in selected location"]
     entry .frame0.frameNMS.second.entry \
     	-relief {sunken} \
@@ -364,7 +362,7 @@
     button .frame0.frameNMS.third.button \
     	-text [G_msg "Create new mapset"] \
-    	-width 20 -bd 1 -wraplength 160 \
+    	-padx 10 -bd 1 -wraplength 150 \
      	-command {
      	    set mymapset [ string trim $mymapset ]
      	    if { [file exists $mymapset] } {
@@ -409,14 +407,13 @@
     label .frame0.frameNMS.fourth.label \
-    	-anchor {n} \
-	-wraplength 160 \
+	-wraplength 200 \
     	-text [G_msg "Define new location with..."]
     button .frame0.frameNMS.fifth.button \
     	-text [G_msg "Georeferenced file"] \
-    	-width 20 -bd 1 -wraplength 160\
+    	-width 22 -bd 1 -wraplength 150\
     	-relief raised \
     	-command {putGRASSRC $gisrc_name
 		fileOpt::fileLocCom
@@ -429,7 +426,7 @@
     button .frame0.frameNMS.sixth.button \
     	-text [G_msg "EPSG codes"] \
     	-relief raised \
     	-command { putGRASSRC $gisrc_name
 		if { [epsgOpt::epsgLocCom] } {
@@ -442,7 +439,7 @@
     button .frame0.frameNMS.seventh.button \
     	-text [G_msg "Projection values"] \
     	-relief raised \
     	-command {
 			if { $mingw == "1" } {
@@ -455,20 +452,21 @@
     pack append .frame0.frameNMS
-    pack .frame0.frameNMS.first.label -side top
-    pack .frame0.frameNMS.second.entry -side top -fill x
-    pack .frame0.frameNMS.third.button -side top -fill x
-    pack .frame0.frameNMS.fifth.button -side bottom -fill x
-    pack .frame0.frameNMS.sixth.button -side bottom -fill x
-    pack .frame0.frameNMS.seventh.button -side bottom -fill x
-    pack .frame0.frameNMS.fourth.label -side bottom
-    pack .frame0.frameNMS.first -side top  -anchor n
-    pack .frame0.frameNMS.second -side top -expand yes
-    pack .frame0.frameNMS.third -side top -anchor n -expand yes
-    pack .frame0.frameNMS.seventh -side bottom -anchor s -expand yes
-    pack .frame0.frameNMS.sixth -side bottom -anchor s -expand yes
-    pack .frame0.frameNMS.fifth -side bottom -anchor s -expand yes
-    pack .frame0.frameNMS.fourth -side bottom -anchor s -expand yes
+    pack .frame0.frameNMS.first.label
+    pack .frame0.frameNMS.second.entry
+    pack .frame0.frameNMS.third.button
+    pack .frame0.frameNMS.fourth.label
+    pack .frame0.frameNMS.fifth.button
+    pack .frame0.frameNMS.sixth.button
+    pack .frame0.frameNMS.seventh.button
+    pack .frame0.frameNMS.spacer
     # build .frame0.frameBUTTONS
@@ -479,7 +477,7 @@
     button .frame0.frameBUTTONS.ok \
      	-text [G_msg "Enter GRASS"] \
-    	-width 10 -bd 1 -fg green4 -default active -wraplength 100 \
+    	-padx 10 -bd 1 -fg green4 -default active -wraplength 100 \
      	-command {
             if {[CheckLocation] == 0} {
 				DialogGen .wrnDlg [G_msg "WARNING: invalid location"] warning \
@@ -506,7 +504,7 @@
     button .frame0.frameBUTTONS.help \
     	-text [G_msg "Help"] \
-    	-width 10 -bd 1 -wraplength 100 \
+    	-padx 10 -bd 1 -wraplength 100 \
     	-bg honeydew2 \
 		-command {
 			if { [winfo exists .help] } {
@@ -524,7 +522,7 @@
     button .frame0.frameBUTTONS.cancel \
     	-text [G_msg "Exit"] \
     	-command { exit 2 }
@@ -539,10 +537,14 @@
     # packed it all
+    frame .frame0.frameSpacer \
+    	-borderwidth {2} -height {5}
     # pack widget .frame0
     pack append .frame0 \
-    	.frame0.frameDB { top expand fill } \
+    	.frame0.frameDB { top } \
     	.frame0.frameBUTTONS { bottom expand fill } \
+    	.frame0.frameSpacer { bottom } \
     	.frame0.frameLOC { left expand  } \
     	.frame0.frameMS { left expand  } \
      	.frame0.frameNMS { left expand fill }
