[GRASS-CVS] markus: grass6/lib/vector/Vlib break_lines.c, 1.4, 1.4.6.1 cindex.c, 1.14, 1.14.2.1 field.c, 1.41, 1.41.6.1 snap.c, 1.8, 1.8.2.1
grass at intevation.de grass at intevation.de
Sun Nov 18 14:54:41 EST 2007
Author: markus
Update of /grassrepository/grass6/lib/vector/Vlib
In directory doto:/tmp/cvs-serv23033
Modified Files:
      Tag: releasebranch_6_3
	break_lines.c cindex.c field.c snap.c
Log Message:
Portability and warning fixes; Don't use C99 features
Index: break_lines.c
RCS file: /grassrepository/grass6/lib/vector/Vlib/break_lines.c,v
retrieving revision 1.4
retrieving revision 1.4.6.1
diff -u -d -r1.4 -r1.4.6.1
--- break_lines.c	9 Feb 2006 03:08:58 -0000	1.4
+++ break_lines.c	18 Nov 2007 19:54:38 -0000	1.4.6.1
@@ -1,46 +1,84 @@
+ * \file break_lines.c
- * MODULE:       vector library
- * AUTHOR(S):    Radim Blazek
- * PURPOSE:      Clean lines
- * COPYRIGHT:    (C) 2001 by the GRASS Development Team
+ * \brief Vector library - Clean vector map (break lines)
- *               This program is free software under the
- *               GNU General Public License (>=v2).
- *               Read the file COPYING that comes with GRASS
- *               for details.
+ * \author Radim Blazek
+ * (C) 2001 by the GRASS Development Team
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
 #include <stdlib.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
- \fn void Vect_break_lines ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout)
- \brief Break lines in vector map.
+ \brief Break lines in vector map at each intersection.
- Breaks lines specified by type in vector map. Points at intersections may be optionaly
- written to error map. Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
+ For details see Vect_break_lines_list().
- The function also breaks lines forming collapsed loop, for example 0,0;1,0;0,0 is broken at 1,0.
+ \param[in] Map input vector map where lines will be broken
+ \param[in] type type of line to be broken
+ \param[out] Err vector map where points at intersections will be written or NULL
+ \param[out] msgout file pointer where messages will be written or NULL
- \param Map input map where lines will be broken
- \param type type of line to be broken
- \param Err vector map where points at intersections will be written or NULL
- \param msgout file pointer where messages will be written or NULL
  \return
 void
 Vect_break_lines ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout )
+    int line, nlines;
+    struct ilist *List;
+    List = Vect_new_list();
+    nlines = Vect_get_num_lines(Map);
+    for (line = 1; line <= nlines; line++) {
+	Vect_list_append (List, line);
+    Vect_break_lines_list (Map, List, type, Err, msgout);
+    Vect_destroy_list(List);
+    return;
+ \brief Break selected lines in vector map at each intersection.
+ Breaks selected lines specified by type in vector map. Points at
+ intersections may be optionaly written to error map. Input vector map
+ must be opened on level 2 for update at least on GV_BUILD_BASE.
+ The function also breaks lines forming collapsed loop, for example
+ 0,0;1,0;0,0 is broken at 1,0.
+ \param[in] List_break list of lines
+ \return
+int
+Vect_break_lines_list ( struct Map_info *Map, struct ilist *List_break,
+			int type, struct Map_info *Err, FILE *msgout )
     struct line_pnts *APoints, *BPoints, *Points;
     struct line_pnts **AXLines, **BXLines;
     struct line_cats *ACats, *BCats, *Cats;
-    int    j, k, l, ret, atype, btype, aline, bline, found;
-    int    nlines, naxlines, nbxlines, nx;
+    int    j, k, l, ret, atype, btype, aline, bline, found, iline;
+    int    naxlines, nbxlines, nx;
     double *xx=NULL, *yx=NULL, *zx=NULL;
     BOUND_BOX  ABox, BBox;
     struct ilist *List;
@@ -60,28 +98,35 @@
     Cats = Vect_new_cats_struct ();
     List = Vect_new_list ();
-    nlines = Vect_get_num_lines (Map);
     is3d = Vect_is_3d ( Map );
-    G_debug (3, "nlines =  %d", nlines );
+    G_debug (3, "nlines =  %d", List_break->n_values );
     /* To find intersection of two lines (Vect_line_intersection) is quite slow.
      * Fortunately usual lines/boundaries in GIS often forms a network where lines
      * are connected by end points, and touch by MBR. This function checks and occasionaly
-     * skips such cases. This is currently done for 2D only */
+     * skips such cases. This is currently done for 2D only
     /* Go through all lines in vector, for each select lines which overlap MBR of
-    *  this line exclude those connected by one endpoint (see above)
-    *  and try to intersect, if lines intersect write new lines at the end of
-    *  the file, and process next line (remainining lines overlaping box are skipped) */
+     * this line exclude those connected by one endpoint (see above)
+     * and try to intersect, if lines intersect write new lines at the end of
+     * the file, and process next line (remainining lines overlaping box are skipped)
     nbreaks = 0;
     printed = 0;
-    if (msgout) fprintf (msgout, "Intersections: %5d", nbreaks );
-    for ( aline = 1; aline <= nlines; aline++ ){
+    if (msgout)
+	fprintf (msgout, "Intersections: %5d", nbreaks );
+    for ( iline = 0; iline < List_break->n_values; iline++ ){
+	aline = List_break->value[iline];
 	G_debug (3, "aline =  %d", aline);
-	if ( !Vect_line_alive ( Map, aline ) ) continue;
+	if ( !Vect_line_alive ( Map, aline ) )
+	    continue;
 	atype = Vect_read_line (Map, APoints, ACats, aline);
-	if ( !(atype & type) ) continue;
+	if ( !(atype & type) )
+	    continue;
 	Vect_get_line_box ( Map, aline, &ABox );
@@ -136,7 +181,8 @@
 			 ( node == anode1 && nodex == ABox.W && !touch1_w && nodex == BBox.E ) ||
 			 ( node == anode2 && nodex == ABox.W && !touch2_w && nodex == BBox.E ) )
-			G_debug(3, "lines %d and %d touching by end nodes only -> no intersection", aline, bline);
+			G_debug(3, "lines %d and %d touching by end nodes only -> no intersection",
+				aline, bline);
 			continue;
@@ -192,6 +238,7 @@
 		    if ( (atype & GV_POINTS) || AXLines[k]->n_points > 1 ) {
 			ret = Vect_write_line ( Map, atype, AXLines[k], ACats );
 			G_debug (3, "Line %d written, npoints = %d", ret, AXLines[k]->n_points);
+			Vect_list_append(List_break, ret);
 		    /* Write intersection points */
@@ -219,6 +266,7 @@
 		        if ( (btype & GV_POINTS) || BXLines[k]->n_points > 1 ) {
 			    ret = Vect_write_line ( Map, btype, BXLines[k], BCats );
 			    G_debug (5, "Line %d written", ret);
@@ -270,10 +318,13 @@
 	    printed++;
 	    if ( naxlines > 0 ) break; /* first line was broken and deleted -> take the next one */
-	G_debug (3, "nlines =  %d\n", nlines );
+	G_debug (3, "nlines =  %d\n", List_break->n_values);
-    if (msgout) fprintf (msgout, "\rIntersections: %5d                         \n", nbreaks );
+    if (msgout)
+	fprintf (msgout, "\rIntersections: %5d                         \n", nbreaks );
     Vect_destroy_list ( List );
+    return nbreaks;
Index: cindex.c
RCS file: /grassrepository/grass6/lib/vector/Vlib/cindex.c,v
retrieving revision 1.14
retrieving revision 1.14.2.1
diff -u -d -r1.14 -r1.14.2.1
--- cindex.c	11 Oct 2007 16:14:51 -0000	1.14
+++ cindex.c	18 Nov 2007 19:54:38 -0000	1.14.2.1
@@ -105,8 +105,9 @@
 Vect_cidx_get_num_unique_cats_by_index ( struct Map_info *Map, int index )
     check_status ( Map );
-    if ( index >= Map->plus.n_cidx )
-	G_fatal_error(_("Invalid layer index (index >= number of layers)"));
+    if ( index < 0 || index >= Map->plus.n_cidx )
+	G_fatal_error(_("Invalid layer index (index < 0 or index >= number of layers)"));
     return ( Map->plus.cidx[index].n_ucats );
@@ -339,9 +340,10 @@
       int type, line;
       struct Cat_index *ci;
+      int field_index, idx;
       Vect_reset_list ( lines );
-      int field_index = Vect_cidx_get_field_index ( Map, layer );
+      field_index = Vect_cidx_get_field_index ( Map, layer );
       if (field_index == -1) {
 	  /* not found */
@@ -349,7 +351,7 @@
       ci = &(Map->plus.cidx[field_index]);
-      int idx = Vect_cidx_find_next ( Map, field_index, cat,
+      idx = Vect_cidx_find_next ( Map, field_index, cat,
                                   type_mask, 0, &type, &line );
       if ( idx == -1 )
Index: field.c
RCS file: /grassrepository/grass6/lib/vector/Vlib/field.c,v
retrieving revision 1.41
retrieving revision 1.41.6.1
diff -u -d -r1.41 -r1.41.6.1
--- field.c	8 Jul 2006 17:05:56 -0000	1.41
+++ field.c	18 Nov 2007 19:54:38 -0000	1.41.6.1
@@ -384,7 +384,7 @@
     if ( Map->format == GV_FORMAT_OGR ) {
 #if GDAL_VERSION_NUM > 1320 /* seems to be fixed after 1320 release */
-	int i, layer, nLayers;
+	int layer, nLayers;
 	OGRDataSourceH Ogr_ds;
 	OGRLayerH Ogr_layer=NULL;
 	OGRFeatureDefnH Ogr_featuredefn;
Index: snap.c
RCS file: /grassrepository/grass6/lib/vector/Vlib/snap.c,v
retrieving revision 1.8
retrieving revision 1.8.2.1
diff -u -d -r1.8 -r1.8.2.1
--- snap.c	18 Jul 2007 10:13:09 -0000	1.8
+++ snap.c	18 Nov 2007 19:54:38 -0000	1.8.2.1
@@ -1,31 +1,7 @@
- * MODULE:       Vector library
- *               for details.
-#include <stdlib.h>
-#include <math.h>
-#include <grass/gis.h>
-#include <grass/Vect.h>
-#include <grass/glocale.h>
  * \file snap.c
- * \brief Vector library
- * Clean lines
+ * \brief Vector library - Clean vector map (snap lines)
@@ -36,6 +12,10 @@
  * for details.
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
 /* function prototypes */
 static int sort_new(const void *pa, const void *pb);
@@ -56,8 +36,8 @@
 /* This function is called by  RTreeSearch() to add selected node/line/area/isle to thelist */
 int add_item(int id, struct ilist *list)
-        dig_list_add ( list, id );
-	    return 1;
+    dig_list_add ( list, id );
+    return 1;
@@ -98,7 +78,7 @@
     struct line_pnts *Points, *NPoints;
     struct line_cats *Cats;
-    int    nlines, line, ltype, line_idx;
+    int    line, ltype, line_idx;
     double thresh2;
     int    printed;
@@ -126,8 +106,6 @@
     RTree = RTreeNewIndex();
     thresh2 = thresh * thresh;
     /* Go through all lines in vector, and add each point to structure of points */
     apoints = 0;
@@ -416,9 +394,9 @@
  * \fn void Vect_snap_lines (struct Map_info *Map, int type, double thresh, struct Map_info *Err, FILE *msgout )
- * \brief Snap all lines to existing vertex in threshold.
+ * \brief Snap lines in vector map to existing vertex in threshold.
- * See Vect_snap_lines_list()
+ * For details see Vect_snap_lines_list()
  * \param[in] Map input map where vertices will be snapped
  * \param[in] type type of lines to snap
@@ -434,12 +412,7 @@
     struct ilist* List;
-    struct line_pnts *Points;
-    struct line_cats *Cats;
-    Points = Vect_new_line_struct();
-    Cats   = Vect_new_cats_struct();
@@ -449,7 +422,7 @@
 	if (!Vect_line_alive (Map, line))
 	    continue;
-	ltype = Vect_read_line (Map, Points, Cats, line);
+	ltype = Vect_read_line (Map, NULL, NULL, line);
 	if (!(ltype & type))
 	    continue;
@@ -459,8 +432,6 @@
     Vect_snap_lines_list (Map, List, thresh, Err, msgout);
-    Vect_destroy_cats_struct (Cats);
-    Vect_destroy_line_struct (Points);
     Vect_destroy_list (List);
     return;
