[GRASS-CVS] markus: grass6/include proto_dbmi.h, 1.29, 1.29.2.1 pbmplus.h, 2.1, NONE
grass at intevation.de grass at intevation.de
Sun Nov 18 14:58:13 EST 2007
Author: markus
Update of /grassrepository/grass6/include
In directory doto:/tmp/cvs-serv23153
Modified Files:
      Tag: releasebranch_6_3
	proto_dbmi.h
Removed Files:
	pbmplus.h
Log Message:
Remove cruft from headers (merge from HEAD)
Index: proto_dbmi.h
RCS file: /grassrepository/grass6/include/proto_dbmi.h,v
retrieving revision 1.29
retrieving revision 1.29.2.1
diff -u -d -r1.29 -r1.29.2.1
--- proto_dbmi.h	15 Oct 2007 05:24:16 -0000	1.29
+++ proto_dbmi.h	18 Nov 2007 19:58:10 -0000	1.29.2.1
@@ -1,26 +1,23 @@
-#ifdef __STDC__
-# define	P(s) s
-#else
-# define P(s) ()
-#endif
+#ifndef _PROTO_DBMI_H_
+#define _PROTO_DBMI_H_
-void        db_Cstring_to_lowercase   P((char *s ));
-void        db_Cstring_to_uppercase   P((char *s ));
-int         db_add_column             P((dbDriver *driver , dbString *tableName , dbColumn *column ));
-void        db__add_cursor_to_driver_state P((dbCursor *cursor ));
-int         db_alloc_cursor_column_flags P((dbCursor *cursor ));
-int         db_alloc_cursor_table     P((dbCursor *cursor , int ncols ));
-dbDirent *  db_alloc_dirent_array     P((int count ));
-dbHandle *  db_alloc_handle_array     P((int count ));
-dbIndex *   db_alloc_index_array      P((int count ));
-int         db_alloc_index_columns    P((dbIndex *index , int ncols ));
-dbString *  db_alloc_string_array     P((int count ));
-dbTable *   db_alloc_table            P((int ncols ));
-int         db_append_string          P((dbString *x , char *s ));
-void        db_auto_print_errors      P((int flag ));
-void        db_auto_print_protocol_errors P((int flag ));
-int         db_bind_update            P((dbCursor *cursor ));
-void *      db_calloc                 P((int n , int m ));
+void        db_Cstring_to_lowercase   (char *s );
+void        db_Cstring_to_uppercase   (char *s );
+int         db_add_column             (dbDriver *driver , dbString *tableName , dbColumn *column );
+void        db__add_cursor_to_driver_state (dbCursor *cursor );
+int         db_alloc_cursor_column_flags (dbCursor *cursor );
+int         db_alloc_cursor_table     (dbCursor *cursor , int ncols );
+dbDirent *  db_alloc_dirent_array     (int count );
+dbHandle *  db_alloc_handle_array     (int count );
+dbIndex *   db_alloc_index_array      (int count );
+int         db_alloc_index_columns    (dbIndex *index , int ncols );
+dbString *  db_alloc_string_array     (int count );
+dbTable *   db_alloc_table            (int ncols );
+int         db_append_string          (dbString *x , char *s );
+void        db_auto_print_errors      (int flag );
+void        db_auto_print_protocol_errors (int flag );
+int         db_bind_update            (dbCursor *cursor );
+void *      db_calloc                 (int n , int m );
 int         db_CatValArray_alloc( dbCatValArray *arr, int n );
 int         db_CatValArray_realloc( dbCatValArray *arr, int n );
 void        db_CatValArray_free( dbCatValArray *arr);
@@ -30,347 +27,347 @@
 int         db_CatValArray_get_value ( dbCatValArray *arr, int key, dbCatVal ** );
 int         db_CatValArray_get_value_int ( dbCatValArray *arr, int key, int *val );
 int         db_CatValArray_get_value_double ( dbCatValArray *arr, int key, double *val );
-void        db_char_to_lowercase      P((char *s ));
-void        db_char_to_uppercase      P((char *s ));
-void        db_clear_error            P((void ));
-void        db__close_all_cursors     P((void ));
-int         db_close_cursor           P((dbCursor *cursor ));
-int         db_close_database         P((dbDriver *driver ));
-int         db_close_database_shutdown_driver P((dbDriver *driver ));
-int         db_column_sqltype         P((dbDriver *driver, char *tab, char *col ));
-int         db_column_Ctype         P((dbDriver *driver, char *tab, char *col ));
-int         db_convert_Cstring_to_column_default_value P((char *Cstring , dbColumn *column ));
-int         db_convert_Cstring_to_column_value P((char *Cstring , dbColumn *column ));
-int         db_convert_Cstring_to_value P((char *Cstring , int sqltype , dbValue *value ));
-int         db_convert_Cstring_to_value_datetime P((char *buf , int sqltype , dbValue *value ));
-int         db_convert_column_default_value_to_string P((dbColumn *column , dbString *string ));
-int         db_convert_column_value_to_string P((dbColumn *column , dbString *string ));
-int         db_convert_value_datetime_into_string P((dbValue *value , int sqltype , dbString *string ));
-int         db_convert_value_to_string P((dbValue *value , int sqltype , dbString *string ));
-void        db_copy_dbmscap_entry     P((dbDbmscap *dst , dbDbmscap *src ));
-int         db_copy_string            P((dbString *dst , dbString *src ));
+void        db_char_to_lowercase      (char *s );
+void        db_char_to_uppercase      (char *s );
+void        db_clear_error            (void );
+void        db__close_all_cursors     (void );
+int         db_close_cursor           (dbCursor *cursor );
+int         db_close_database         (dbDriver *driver );
+int         db_close_database_shutdown_driver (dbDriver *driver );
+int         db_column_sqltype         (dbDriver *driver, char *tab, char *col );
+int         db_column_Ctype         (dbDriver *driver, char *tab, char *col );
+int         db_convert_Cstring_to_column_default_value (char *Cstring , dbColumn *column );
+int         db_convert_Cstring_to_column_value (char *Cstring , dbColumn *column );
+int         db_convert_Cstring_to_value (char *Cstring , int sqltype , dbValue *value );
+int         db_convert_Cstring_to_value_datetime (char *buf , int sqltype , dbValue *value );
+int         db_convert_column_default_value_to_string (dbColumn *column , dbString *string );
+int         db_convert_column_value_to_string (dbColumn *column , dbString *string );
+int         db_convert_value_datetime_into_string (dbValue *value , int sqltype , dbString *string );
+int         db_convert_value_to_string (dbValue *value , int sqltype , dbString *string );
+void        db_copy_dbmscap_entry     (dbDbmscap *dst , dbDbmscap *src );
+int         db_copy_string            (dbString *dst , dbString *src );
 int         db_table_to_sql ( dbTable *, dbString *);
 int         db_copy_table ( char *, char *, char *, char *, char *, char *);
 int         db_copy_table_where ( char *, char *, char *, char *, char *, char *, char *);
 int         db_copy_table_select ( char *, char *, char *, char *, char *, char *, char *);
 int         db_copy_table_by_ints ( char *, char *, char *, char *, char *, char *, char *, int *, int);
-void        db_copy_value             P((dbValue *dst , dbValue *src ));
-int         db_create_database        P((dbDriver *driver , dbHandle *handle ));
-int         db_create_index           P((dbDriver *driver , dbIndex *index ));
+void        db_copy_value             (dbValue *dst , dbValue *src );
+int         db_create_database        (dbDriver *driver , dbHandle *handle );
+int         db_create_index           (dbDriver *driver , dbIndex *index );
 int         db_create_index2          (dbDriver *driver, char *table_name, char *column_name );
-int         db_create_table           P((dbDriver *driver , dbTable *table ));
-int         db_d_add_column           P((void ));
-int         db_d_bind_update          P((void ));
-char *      db_dbmscap_filename       P((void ));
-int         db_d_close_cursor         P((void ));
-int         db_d_close_database       P((void ));
-int         db_d_create_database      P((void ));
-int         db_d_create_index         P((void ));
-int         db_d_create_table         P((void ));
-int         db_d_delete               P((void ));
-int         db_d_delete_database      P((void ));
-int         db_d_describe_table       P((void ));
-int         db_d_drop_column          P((void ));
-int         db_d_drop_index           P((void ));
-int         db_d_drop_table           P((void ));
-void        db_debug                  P((char *s ));
-void        db_debug_off              P((void ));
-void        db_debug_on               P((void ));
-int         db_delete                 P((dbCursor *cursor ));
-int         db_delete_database        P((dbDriver *driver , dbHandle *handle ));
+int         db_create_table           (dbDriver *driver , dbTable *table );
+int         db_d_add_column           (void );
+int         db_d_bind_update          (void );
+char *      db_dbmscap_filename       (void );
+int         db_d_close_cursor         (void );
+int         db_d_close_database       (void );
+int         db_d_create_database      (void );
+int         db_d_create_index         (void );
+int         db_d_create_table         (void );
+int         db_d_delete               (void );
+int         db_d_delete_database      (void );
+int         db_d_describe_table       (void );
+int         db_d_drop_column          (void );
+int         db_d_drop_index           (void );
+int         db_d_drop_table           (void );
+void        db_debug                  (char *s );
+void        db_debug_off              (void );
+void        db_debug_on               (void );
+int         db_delete                 (dbCursor *cursor );
+int         db_delete_database        (dbDriver *driver , dbHandle *handle );
 int         db_delete_table           ( char *, char *, char *);
-int         db_describe_table         P((dbDriver *driver , dbString *name , dbTable **table ));
-int         db_d_execute_immediate    P((void ));
-int         db_d_begin_transaction    P((void ));
-int         db_d_commit_transaction   P((void ));
-int         db_d_fetch                P((void ));
-int         db_d_find_database        P((void ));
-int         db_d_get_num_rows         P((void ));
-int         db_d_grant_on_table       P((void ));
-int         db_d_insert               P((void ));
-dbDirent *  db_dirent                 P((char *dirname , int *n ));
-int         db_d_list_databases       P((void ));
-int         db_d_list_indexes         P((void ));
-int         db_d_list_tables          P((void ));
-int         db_d_open_database        P((void ));
-int         db_d_open_insert_cursor   P((void ));
-int         db_d_open_select_cursor   P((void ));
-int         db_d_open_update_cursor   P((void ));
+int         db_describe_table         (dbDriver *driver , dbString *name , dbTable **table );
+int         db_d_execute_immediate    (void );
+int         db_d_begin_transaction    (void );
+int         db_d_commit_transaction   (void );
+int         db_d_fetch                (void );
+int         db_d_find_database        (void );
+int         db_d_get_num_rows         (void );
+int         db_d_grant_on_table       (void );
+int         db_d_insert               (void );
+dbDirent *  db_dirent                 (char *dirname , int *n );
+int         db_d_list_databases       (void );
+int         db_d_list_indexes         (void );
+int         db_d_list_tables          (void );
+int         db_d_open_database        (void );
+int         db_d_open_insert_cursor   (void );
+int         db_d_open_select_cursor   (void );
+int         db_d_open_update_cursor   (void );
 void        db_double_quote_string    ( dbString *src );
-int         db_driver                 P((int argc , char *argv []));
+int         db_driver                 (int argc , char *argv []);
-int         db_driver_mkdir           P((char *path , int mode , int parentdirs ));
-int         db_drop_column            P((dbDriver *driver , dbString *tableName , dbString *columnName ));
-void        db__drop_cursor_from_driver_state P((dbCursor *cursor ));
-int         db_drop_index             P((dbDriver *driver , dbString *name ));
-int         db_drop_table             P((dbDriver *driver , dbString *name ));
-void        db_drop_token             P((dbToken token ));
-int         db_d_update               P((void ));
-int         db_d_version              P((void ));
-int         db_enlarge_string         P((dbString *x , int len ));
-void        db_error                  P((char *s ));
-int         db_execute_immediate      P((dbDriver *driver , dbString *SQLstatement ));
-int         db_begin_transaction      P((dbDriver *driver));
-int         db_commit_transaction     P((dbDriver *driver));
-int         db_fetch                  P((dbCursor *cursor , int position , int *more ));
-int         db_find_database          P((dbDriver *driver , dbHandle *handle , int *found ));
-dbAddress   db_find_token             P((dbToken token ));
-void        db_free_column            P((dbColumn *column ));
-void        db_free_cursor            P((dbCursor *cursor ));
-void        db_free_cursor_column_flags P((dbCursor *cursor ));
-void        db_free_dbmscap           P((dbDbmscap *list ));
-void        db_free_dirent_array      P((dbDirent *dirent , int count ));
-void        db_free_handle            P((dbHandle *handle ));
-void        db_free_handle_array      P((dbHandle *handle , int count ));
-void        db_free_index             P((dbIndex *index ));
-void        db_free_index_array       P((dbIndex *list , int count ));
-void        db_free_string            P((dbString *x ));
-void        db_free_string_array      P((dbString *a , int n ));
-void        db_free_table             P((dbTable *table ));
-int         db_get_column             P(( dbDriver *Driver, char *tname, char *cname, dbColumn **Column ));
-dbValue *   db_get_column_default_value P((dbColumn *column ));
-char *      db_get_column_description P((dbColumn *column ));
-int         db_get_column_host_type   P((dbColumn *column ));
-int         db_get_column_length      P((dbColumn *column ));
-char *      db_get_column_name        P((dbColumn *column ));
-int         db_get_column_precision   P((dbColumn *column ));
-int         db_get_column_scale       P((dbColumn *column ));
-int         db_get_column_select_priv P((dbColumn *column ));
-int         db_get_column_sqltype     P((dbColumn *column ));
-int         db_get_column_update_priv P((dbColumn *column ));
-dbValue *   db_get_column_value       P((dbColumn *column ));
-int         db_get_connection         P((dbConnection *connection ));
-int         db_get_cursor_number_of_columns P((dbCursor *cursor ));
-dbTable *   db_get_cursor_table       P((dbCursor *cursor ));
-dbToken     db_get_cursor_token       P((dbCursor *cursor ));
+int         db_driver_mkdir           (char *path , int mode , int parentdirs );
+int         db_drop_column            (dbDriver *driver , dbString *tableName , dbString *columnName );
+void        db__drop_cursor_from_driver_state (dbCursor *cursor );
+int         db_drop_index             (dbDriver *driver , dbString *name );
+int         db_drop_table             (dbDriver *driver , dbString *name );
+void        db_drop_token             (dbToken token );
+int         db_d_update               (void );
+int         db_d_version              (void );
+int         db_enlarge_string         (dbString *x , int len );
+void        db_error                  (char *s );
+int         db_execute_immediate      (dbDriver *driver , dbString *SQLstatement );
+int         db_begin_transaction      (dbDriver *driver);
+int         db_commit_transaction     (dbDriver *driver);
+int         db_fetch                  (dbCursor *cursor , int position , int *more );
+int         db_find_database          (dbDriver *driver , dbHandle *handle , int *found );
+dbAddress   db_find_token             (dbToken token );
+void        db_free_column            (dbColumn *column );
+void        db_free_cursor            (dbCursor *cursor );
+void        db_free_cursor_column_flags (dbCursor *cursor );
+void        db_free_dbmscap           (dbDbmscap *list );
+void        db_free_dirent_array      (dbDirent *dirent , int count );
+void        db_free_handle            (dbHandle *handle );
+void        db_free_handle_array      (dbHandle *handle , int count );
+void        db_free_index             (dbIndex *index );
+void        db_free_index_array       (dbIndex *list , int count );
+void        db_free_string            (dbString *x );
+void        db_free_string_array      (dbString *a , int n );
+void        db_free_table             (dbTable *table );
+int         db_get_column             ( dbDriver *Driver, char *tname, char *cname, dbColumn **Column );
+dbValue *   db_get_column_default_value (dbColumn *column );
+char *      db_get_column_description (dbColumn *column );
+int         db_get_column_host_type   (dbColumn *column );
+int         db_get_column_length      (dbColumn *column );
+char *      db_get_column_name        (dbColumn *column );
+int         db_get_column_precision   (dbColumn *column );
+int         db_get_column_scale       (dbColumn *column );
+int         db_get_column_select_priv (dbColumn *column );
+int         db_get_column_sqltype     (dbColumn *column );
+int         db_get_column_update_priv (dbColumn *column );
+dbValue *   db_get_column_value       (dbColumn *column );
+int         db_get_connection         (dbConnection *connection );
+int         db_get_cursor_number_of_columns (dbCursor *cursor );
+dbTable *   db_get_cursor_table       (dbCursor *cursor );
+dbToken     db_get_cursor_token       (dbCursor *cursor );
 char *      db_get_default_driver_name ( void );
 char *      db_get_default_database_name ( void );
 char *      db_get_default_schema_name ( void );
 char *      db_get_default_group_name ( void );
-dbDriverState * db__get_driver_state      P((void ));
-int         db_get_error_code         P((void ));
-char *      db_get_error_msg          P((void ));
-char *      db_get_error_who          P((void ));
-char *      db_get_handle_dbname      P((dbHandle *handle ));
-char *      db_get_handle_dbschema    P((dbHandle *handle ));
-char *      db_get_index_column_name  P((dbIndex *index , int column_num ));
-char *      db_get_index_name         P((dbIndex *index ));
-int         db_get_index_number_of_columns P((dbIndex *index ));
-char *      db_get_index_table_name   P((dbIndex *index ));
-int         db_get_num_rows           P((dbCursor *cursor ));
-char *      db_get_string             P((dbString *x ));
-dbColumn *  db_get_table_column       P((dbTable *table , int n ));
-int         db_get_table_delete_priv  P((dbTable *table ));
-char *      db_get_table_description  P((dbTable *table ));
-int         db_get_table_insert_priv  P((dbTable *table ));
-char *      db_get_table_name         P((dbTable *table ));
-int         db_get_table_number_of_columns P((dbTable *table ));
-int         db_get_table_number_of_rows P((dbDriver *driver, dbString *sql));
-int         db_get_table_select_priv  P((dbTable *table ));
-int         db_get_table_update_priv  P((dbTable *table ));
-double      db_get_value_as_double    P((dbValue *value, int ctype ));
-int         db_get_value_day          P((dbValue *value ));
-double      db_get_value_double       P((dbValue *value ));
-int         db_get_value_hour         P((dbValue *value ));
-int         db_get_value_int          P((dbValue *value ));
-int         db_get_value_minute       P((dbValue *value ));
-int         db_get_value_month        P((dbValue *value ));
-double      db_get_value_seconds      P((dbValue *value ));
-char *      db_get_value_string       P((dbValue *value ));
-int         db_get_value_year         P((dbValue *value ));
-int         db_grant_on_table         P((dbDriver *driver , char *tableName, int priv, int to ));
-int         db_has_dbms               P((void ));
-void        db_init_column            P((dbColumn *column ));
-void        db_init_cursor            P((dbCursor *cursor ));
-void        db__init_driver_state     P((void ));
-void        db_init_handle            P((dbHandle *handle ));
-void        db_init_index             P((dbIndex *index ));
-void        db_init_string            P((dbString *x ));
-void        db_init_table             P((dbTable *table ));
-int         db_insert                 P((dbCursor *cursor ));
-void        db_interval_range         P((int sqltype , int *from , int *to ));
-int         db_isdir                  P((char *path ));
-int         db_legal_tablename        P((char *s ));
-int         db_list_databases         P((dbDriver *driver , dbString *path , int npaths , dbHandle **handles , int *count ));
-char *      db_list_drivers           P((void ));
-int         db_list_indexes           P((dbDriver *driver , dbString *table_name , dbIndex **list , int *count ));
-int         db_list_tables            P((dbDriver *driver , dbString **names , int *count , int system ));
-void *      db_malloc                 P((int n ));
-void        db__mark_database_closed  P((void ));
-void        db__mark_database_open    P((char *dbname , char *dbpath ));
-void        db_memory_error           P((void ));
-dbToken     db_new_token              P((dbAddress address ));
-int         db_nocase_compare         P((char *a , char *b ));
-void        db_noproc_error           P((int procnum ));
-int         db_open_database          P((dbDriver *driver , dbHandle *handle ));
-int         db_open_insert_cursor     P((dbDriver *driver , dbCursor *cursor ));
-int         db_open_select_cursor     P((dbDriver *driver , dbString *select , dbCursor *cursor , int mode ));
-int         db_open_update_cursor     P((dbDriver *driver , dbString *table_name , dbString *select , dbCursor *cursor , int mode ));
-void        db_print_column_definition P((FILE *fd , dbColumn *column ));
-void        db_print_error            P((void ));
-void        db_print_index            P((FILE *fd , dbIndex *index ));
-void        db_print_table_definition P((FILE *fd , dbTable *table ));
-void        db_procedure_not_implemented P((char *name ));
-void        db_protocol_error         P((void ));
-dbDbmscap * db_read_dbmscap           P((void ));
-void *      db_realloc                P((void *s , int n ));
-int         db__recv_char             P((char *d ));
-int         db__recv_column_default_value P((dbColumn *column ));
-int         db__recv_column_definition P((dbColumn *column ));
-int         db__recv_column_value     P((dbColumn *column ));
-int         db__recv_datetime         P((dbDateTime *t ));
-int         db__recv_double           P((double *d ));
-int         db__recv_double_array     P((double **x , int *n ));
-int         db__recv_float            P((float *d ));
-int         db__recv_float_array      P((float **x , int *n ));
-int         db__recv_handle           P((dbHandle *handle ));
-int         db__recv_index            P((dbIndex *index ));
-int         db__recv_index_array      P((dbIndex **list , int *count ));
-int         db__recv_int              P((int *n ));
-int         db__recv_int_array        P((int **x , int *n ));
-int         db__recv_procnum          P((int *n ));
-int         db__recv_return_code      P((int *ret_code ));
-int         db__recv_short            P((short *n ));
-int         db__recv_short_array      P((short **x , int *n ));
-int         db__recv_string           P((dbString *x ));
-int         db__recv_string_array     P((dbString **a , int *n ));
-int         db__recv_table_data       P((dbTable *table ));
-int         db__recv_table_definition P((dbTable **table ));
-int         db__recv_token            P((dbToken *token ));
-int         db__recv_value            P((dbValue *value , int Ctype ));
-int         db__send_Cstring          P((char *s ));
-int         db__send_char             P((int d ));
-int         db__send_column_default_value P((dbColumn *column ));
-int         db__send_column_definition P((dbColumn *column ));
-int         db__send_column_value     P((dbColumn *column ));
-int         db__send_datetime         P((dbDateTime *t ));
-int         db__send_double           P((double d ));
-int         db__send_double_array     P((const double *x , int n ));
-int         db__send_failure          P((void ));
-int         db__send_float            P((float d ));
-int         db__send_float_array      P((const float *x , int n ));
-int         db__send_handle           P((dbHandle *handle ));
-int         db__send_index            P((dbIndex *index ));
-int         db__send_index_array      P((dbIndex *list , int count ));
-int         db__send_int              P((int n ));
-int         db__send_int_array        P((const int *x , int n ));
-int         db__send_procedure_not_implemented P((int n ));
-int         db__send_procedure_ok     P((int n ));
-int         db__send_short            P((int n ));
-int         db__send_short_array      P((const short *x , int n ));
-int         db__send_string           P((dbString *x ));
-int         db__send_string_array     P((dbString *a , int count ));
-int         db__send_success          P((void ));
-int         db__send_table_data       P((dbTable *table ));
-int         db__send_table_definition P((dbTable *table ));
-int         db__send_token            P((dbToken *token ));
-int         db__send_value            P((dbValue *value , int Ctype ));
+dbDriverState * db__get_driver_state      (void );
+int         db_get_error_code         (void );
+char *      db_get_error_msg          (void );
+char *      db_get_error_who          (void );
+char *      db_get_handle_dbname      (dbHandle *handle );
+char *      db_get_handle_dbschema    (dbHandle *handle );
+char *      db_get_index_column_name  (dbIndex *index , int column_num );
+char *      db_get_index_name         (dbIndex *index );
+int         db_get_index_number_of_columns (dbIndex *index );
+char *      db_get_index_table_name   (dbIndex *index );
+int         db_get_num_rows           (dbCursor *cursor );
+char *      db_get_string             (dbString *x );
+dbColumn *  db_get_table_column       (dbTable *table , int n );
+int         db_get_table_delete_priv  (dbTable *table );
+char *      db_get_table_description  (dbTable *table );
+int         db_get_table_insert_priv  (dbTable *table );
+char *      db_get_table_name         (dbTable *table );
+int         db_get_table_number_of_columns (dbTable *table );
+int         db_get_table_number_of_rows (dbDriver *driver, dbString *sql);
+int         db_get_table_select_priv  (dbTable *table );
+int         db_get_table_update_priv  (dbTable *table );
+double      db_get_value_as_double    (dbValue *value, int ctype );
+int         db_get_value_day          (dbValue *value );
+double      db_get_value_double       (dbValue *value );
+int         db_get_value_hour         (dbValue *value );
+int         db_get_value_int          (dbValue *value );
+int         db_get_value_minute       (dbValue *value );
+int         db_get_value_month        (dbValue *value );
+double      db_get_value_seconds      (dbValue *value );
+char *      db_get_value_string       (dbValue *value );
+int         db_get_value_year         (dbValue *value );
+int         db_grant_on_table         (dbDriver *driver , char *tableName, int priv, int to );
+int         db_has_dbms               (void );
+void        db_init_column            (dbColumn *column );
+void        db_init_cursor            (dbCursor *cursor );
+void        db__init_driver_state     (void );
+void        db_init_handle            (dbHandle *handle );
+void        db_init_index             (dbIndex *index );
+void        db_init_string            (dbString *x );
+void        db_init_table             (dbTable *table );
+int         db_insert                 (dbCursor *cursor );
+void        db_interval_range         (int sqltype , int *from , int *to );
+int         db_isdir                  (char *path );
+int         db_legal_tablename        (char *s );
+int         db_list_databases         (dbDriver *driver , dbString *path , int npaths , dbHandle **handles , int *count );
+char *      db_list_drivers           (void );
+int         db_list_indexes           (dbDriver *driver , dbString *table_name , dbIndex **list , int *count );
+int         db_list_tables            (dbDriver *driver , dbString **names , int *count , int system );
+void *      db_malloc                 (int n );
+void        db__mark_database_closed  (void );
+void        db__mark_database_open    (char *dbname , char *dbpath );
+void        db_memory_error           (void );
+dbToken     db_new_token              (dbAddress address );
+int         db_nocase_compare         (char *a , char *b );
+void        db_noproc_error           (int procnum );
+int         db_open_database          (dbDriver *driver , dbHandle *handle );
+int         db_open_insert_cursor     (dbDriver *driver , dbCursor *cursor );
+int         db_open_select_cursor     (dbDriver *driver , dbString *select , dbCursor *cursor , int mode );
+int         db_open_update_cursor     (dbDriver *driver , dbString *table_name , dbString *select , dbCursor *cursor , int mode );
+void        db_print_column_definition (FILE *fd , dbColumn *column );
+void        db_print_error            (void );
+void        db_print_index            (FILE *fd , dbIndex *index );
+void        db_print_table_definition (FILE *fd , dbTable *table );
+void        db_procedure_not_implemented (char *name );
+void        db_protocol_error         (void );
+dbDbmscap * db_read_dbmscap           (void );
+void *      db_realloc                (void *s , int n );
+int         db__recv_char             (char *d );
+int         db__recv_column_default_value (dbColumn *column );
+int         db__recv_column_definition (dbColumn *column );
+int         db__recv_column_value     (dbColumn *column );
+int         db__recv_datetime         (dbDateTime *t );
+int         db__recv_double           (double *d );
+int         db__recv_double_array     (double **x , int *n );
+int         db__recv_float            (float *d );
+int         db__recv_float_array      (float **x , int *n );
+int         db__recv_handle           (dbHandle *handle );
+int         db__recv_index            (dbIndex *index );
+int         db__recv_index_array      (dbIndex **list , int *count );
+int         db__recv_int              (int *n );
+int         db__recv_int_array        (int **x , int *n );
+int         db__recv_procnum          (int *n );
+int         db__recv_return_code      (int *ret_code );
+int         db__recv_short            (short *n );
+int         db__recv_short_array      (short **x , int *n );
+int         db__recv_string           (dbString *x );
+int         db__recv_string_array     (dbString **a , int *n );
+int         db__recv_table_data       (dbTable *table );
+int         db__recv_table_definition (dbTable **table );
+int         db__recv_token            (dbToken *token );
+int         db__recv_value            (dbValue *value , int Ctype );
+int         db__send_Cstring          (char *s );
+int         db__send_char             (int d );
+int         db__send_column_default_value (dbColumn *column );
+int         db__send_column_definition (dbColumn *column );
+int         db__send_column_value     (dbColumn *column );
+int         db__send_datetime         (dbDateTime *t );
+int         db__send_double           (double d );
+int         db__send_double_array     (const double *x , int n );
+int         db__send_failure          (void );
+int         db__send_float            (float d );
+int         db__send_float_array      (const float *x , int n );
+int         db__send_handle           (dbHandle *handle );
+int         db__send_index            (dbIndex *index );
+int         db__send_index_array      (dbIndex *list , int count );
+int         db__send_int              (int n );
+int         db__send_int_array        (const int *x , int n );
+int         db__send_procedure_not_implemented (int n );
+int         db__send_procedure_ok     (int n );
+int         db__send_short            (int n );
+int         db__send_short_array      (const short *x , int n );
+int         db__send_string           (dbString *x );
+int         db__send_string_array     (dbString *a , int count );
+int         db__send_success          (void );
+int         db__send_table_data       (dbTable *table );
+int         db__send_table_definition (dbTable *table );
+int         db__send_token            (dbToken *token );
+int         db__send_value            (dbValue *value , int Ctype );
 int         db_select_CatValArray     ( dbDriver *driver, char *tab, char *key, char *col, char *where,
 	                                                  dbCatValArray *Cvarr );
 int         db_select_int (dbDriver *driver, char *table, char *column, char *where, int **pval);
 int         db_select_value (dbDriver *driver, char *table, char *key, int id, char *column, dbValue *value);
-int         db_set_column_description P((dbColumn *column , char *description ));
-void        db_set_column_has_defined_default_value P((dbColumn *column ));
-void        db_set_column_has_undefined_default_value P((dbColumn *column ));
-void        db_set_column_host_type   P((dbColumn *column , int type ));
-void        db_set_column_length      P((dbColumn *column , int length ));
-int         db_set_column_name        P((dbColumn *column , char *name ));
-void        db_set_column_null_allowed P((dbColumn *column ));
-void        db_set_column_precision   P((dbColumn *column , int precision ));
-void        db_set_column_scale       P((dbColumn *column , int scale ));
-void        db_set_column_select_priv_granted P((dbColumn *column ));
-void        db_set_column_select_priv_not_granted P((dbColumn *column ));
-void        db_set_column_sqltype     P((dbColumn *column , int sqltype ));
-void        db_set_column_update_priv_granted P((dbColumn *column ));
-void        db_set_column_update_priv_not_granted P((dbColumn *column ));
-void        db_set_column_use_default_value P((dbColumn *column ));
-int         db_set_connection         P((dbConnection *connection ));
-void        db_set_cursor_column_flag P((dbCursor *cursor , int col ));
-void        db_set_cursor_column_for_update P((dbCursor *cursor , int col ));
-void        db_set_cursor_mode        P((dbCursor *cursor , int mode ));
-void        db_set_cursor_mode_insensitive P((dbCursor *cursor ));
-void        db_set_cursor_mode_scroll P((dbCursor *cursor ));
-void        db_set_cursor_table       P((dbCursor *cursor , dbTable *table ));
-void        db_set_cursor_token       P((dbCursor *cursor , dbToken token ));
-void        db_set_cursor_type_insert P((dbCursor *cursor ));
-void        db_set_cursor_type_readonly P((dbCursor *cursor ));
-void        db_set_cursor_type_update P((dbCursor *cursor ));
-void        db_set_error_who          P((char *me ));
-int         db_set_handle             P((dbHandle *handle , char *dbName , char *dbPath ));
-int         db_set_index_column_name  P((dbIndex *index , int column_num , char *name ));
-int         db_set_index_name         P((dbIndex *index , char *name ));
-int         db_set_index_table_name   P((dbIndex *index , char *name ));
-int         db_set_index_type_non_unique P((dbIndex *index ));
-int         db_set_index_type_unique  P((dbIndex *index ));
-void        db__set_protocol_fds      P((FILE *send , FILE *recv ));
-int         db_set_string             P((dbString *x , char *s ));
-int         db_set_string_no_copy     P((dbString *x , char *s ));
-void        db_set_table_delete_priv_granted P((dbTable *table ));
-void        db_set_table_delete_priv_not_granted P((dbTable *table ));
-int         db_set_table_description  P((dbTable *table , char *description ));
-void        db_set_table_insert_priv_granted P((dbTable *table ));
-void        db_set_table_insert_priv_not_granted P((dbTable *table ));
-int         db_set_table_name         P((dbTable *table , char *name ));
-void        db_set_table_select_priv_granted P((dbTable *table ));
-void        db_set_table_select_priv_not_granted P((dbTable *table ));
-void        db_set_table_update_priv_granted P((dbTable *table ));
-void        db_set_table_update_priv_not_granted P((dbTable *table ));
-void        db_set_value_datetime_current P((dbValue *value ));
-void        db_set_value_datetime_not_current P((dbValue *value ));
-void        db_set_value_day          P((dbValue *value , int day ));
-void        db_set_value_double       P((dbValue *value , double d ));
-void        db_set_value_hour         P((dbValue *value , int hour ));
-void        db_set_value_int          P((dbValue *value , int i ));
-void        db_set_value_minute       P((dbValue *value , int minute ));
-void        db_set_value_month        P((dbValue *value , int month ));
-void        db_set_value_not_null     P((dbValue *value ));
-void        db_set_value_null         P((dbValue *value ));
-void        db_set_value_seconds      P((dbValue *value , double seconds ));
-int         db_set_value_string       P((dbValue *value , char *s ));
-void        db_set_value_year         P((dbValue *value , int year ));
-int         db_shutdown_driver        P((dbDriver *driver ));
-char *      db_sqltype_name           P((int sqltype ));
-int         db_sqltype_to_Ctype       P((int sqltype ));
-dbDriver *  db_start_driver           P((char *name ));
-dbDriver *  db_start_driver_open_database  P((char *drvname, char *dbname ));
-int         db__start_procedure_call  P((int procnum ));
-char *      db_store                  P((char *s ));
-void        db_strip                  P((char *buf ));
-void        db_syserror               P((char *s ));
-int         db_table_exists P((char* drvname, char *dbname, char *tabname));
-int         db_test_column_has_default_value P((dbColumn *column ));
-int         db_test_column_has_defined_default_value P((dbColumn *column ));
-int         db_test_column_has_undefined_default_value P((dbColumn *column ));
-int         db_test_column_null_allowed P((dbColumn *column ));
-int         db_test_column_use_default_value P((dbColumn *column ));
-int         db_test_cursor_any_column_flag P((dbCursor *cursor ));
-int         db_test_cursor_any_column_for_update P((dbCursor *cursor ));
-int         db_test_cursor_column_flag P((dbCursor *cursor , int col ));
-int         db_test_cursor_column_for_update P((dbCursor *cursor , int col ));
-int         db_test_cursor_mode_insensitive P((dbCursor *cursor ));
-int         db_test_cursor_mode_scroll P((dbCursor *cursor ));
-int         db_test_cursor_type_fetch P((dbCursor *cursor ));
-int         db_test_cursor_type_insert P((dbCursor *cursor ));
-int         db_test_cursor_type_update P((dbCursor *cursor ));
-int         db__test_database_open    P((void ));
-int         db_test_index_type_unique P((dbIndex *index ));
-int         db_test_value_datetime_current P((dbValue *value ));
-int         db_test_value_isnull      P((dbValue *value ));
-void        db_unset_column_has_default_value P((dbColumn *column ));
-void        db_unset_column_null_allowed P((dbColumn *column ));
-void        db_unset_column_use_default_value P((dbColumn *column ));
-void        db_unset_cursor_column_flag P((dbCursor *cursor , int col ));
-void        db_unset_cursor_column_for_update P((dbCursor *cursor , int col ));
-void        db_unset_cursor_mode      P((dbCursor *cursor ));
-void        db_unset_cursor_mode_insensitive P((dbCursor *cursor ));
-void        db_unset_cursor_mode_scroll P((dbCursor *cursor ));
-int         db_update                 P((dbCursor *cursor ));
-int         db_gversion                P((dbDriver *driver , dbString *client_version , dbString *driver_version ));
-char *      db_whoami                 P((void ));
-void        db_zero                   P((void *s , int n ));
-void         db_zero_string            P((dbString *x ));
-unsigned    int                       db_sizeof_string P((dbString *x ));
+int         db_set_column_description (dbColumn *column , char *description );
+void        db_set_column_has_defined_default_value (dbColumn *column );
+void        db_set_column_has_undefined_default_value (dbColumn *column );
+void        db_set_column_host_type   (dbColumn *column , int type );
+void        db_set_column_length      (dbColumn *column , int length );
+int         db_set_column_name        (dbColumn *column , char *name );
+void        db_set_column_null_allowed (dbColumn *column );
+void        db_set_column_precision   (dbColumn *column , int precision );
+void        db_set_column_scale       (dbColumn *column , int scale );
+void        db_set_column_select_priv_granted (dbColumn *column );
+void        db_set_column_select_priv_not_granted (dbColumn *column );
+void        db_set_column_sqltype     (dbColumn *column , int sqltype );
+void        db_set_column_update_priv_granted (dbColumn *column );
+void        db_set_column_update_priv_not_granted (dbColumn *column );
+void        db_set_column_use_default_value (dbColumn *column );
+int         db_set_connection         (dbConnection *connection );
+void        db_set_cursor_column_flag (dbCursor *cursor , int col );
+void        db_set_cursor_column_for_update (dbCursor *cursor , int col );
+void        db_set_cursor_mode        (dbCursor *cursor , int mode );
+void        db_set_cursor_mode_insensitive (dbCursor *cursor );
+void        db_set_cursor_mode_scroll (dbCursor *cursor );
+void        db_set_cursor_table       (dbCursor *cursor , dbTable *table );
+void        db_set_cursor_token       (dbCursor *cursor , dbToken token );
+void        db_set_cursor_type_insert (dbCursor *cursor );
+void        db_set_cursor_type_readonly (dbCursor *cursor );
+void        db_set_cursor_type_update (dbCursor *cursor );
+void        db_set_error_who          (char *me );
+int         db_set_handle             (dbHandle *handle , char *dbName , char *dbPath );
+int         db_set_index_column_name  (dbIndex *index , int column_num , char *name );
+int         db_set_index_name         (dbIndex *index , char *name );
+int         db_set_index_table_name   (dbIndex *index , char *name );
+int         db_set_index_type_non_unique (dbIndex *index );
+int         db_set_index_type_unique  (dbIndex *index );
+void        db__set_protocol_fds      (FILE *send , FILE *recv );
+int         db_set_string             (dbString *x , char *s );
+int         db_set_string_no_copy     (dbString *x , char *s );
+void        db_set_table_delete_priv_granted (dbTable *table );
+void        db_set_table_delete_priv_not_granted (dbTable *table );
+int         db_set_table_description  (dbTable *table , char *description );
+void        db_set_table_insert_priv_granted (dbTable *table );
+void        db_set_table_insert_priv_not_granted (dbTable *table );
+int         db_set_table_name         (dbTable *table , char *name );
+void        db_set_table_select_priv_granted (dbTable *table );
+void        db_set_table_select_priv_not_granted (dbTable *table );
+void        db_set_table_update_priv_granted (dbTable *table );
+void        db_set_table_update_priv_not_granted (dbTable *table );
+void        db_set_value_datetime_current (dbValue *value );
+void        db_set_value_datetime_not_current (dbValue *value );
+void        db_set_value_day          (dbValue *value , int day );
+void        db_set_value_double       (dbValue *value , double d );
+void        db_set_value_hour         (dbValue *value , int hour );
+void        db_set_value_int          (dbValue *value , int i );
+void        db_set_value_minute       (dbValue *value , int minute );
+void        db_set_value_month        (dbValue *value , int month );
+void        db_set_value_not_null     (dbValue *value );
+void        db_set_value_null         (dbValue *value );
+void        db_set_value_seconds      (dbValue *value , double seconds );
+int         db_set_value_string       (dbValue *value , char *s );
+void        db_set_value_year         (dbValue *value , int year );
+int         db_shutdown_driver        (dbDriver *driver );
+char *      db_sqltype_name           (int sqltype );
+int         db_sqltype_to_Ctype       (int sqltype );
+dbDriver *  db_start_driver           (char *name );
+dbDriver *  db_start_driver_open_database  (char *drvname, char *dbname );
+int         db__start_procedure_call  (int procnum );
+char *      db_store                  (char *s );
+void        db_strip                  (char *buf );
+void        db_syserror               (char *s );
+int         db_table_exists (char* drvname, char *dbname, char *tabname);
+int         db_test_column_has_default_value (dbColumn *column );
+int         db_test_column_has_defined_default_value (dbColumn *column );
+int         db_test_column_has_undefined_default_value (dbColumn *column );
+int         db_test_column_null_allowed (dbColumn *column );
+int         db_test_column_use_default_value (dbColumn *column );
+int         db_test_cursor_any_column_flag (dbCursor *cursor );
+int         db_test_cursor_any_column_for_update (dbCursor *cursor );
+int         db_test_cursor_column_flag (dbCursor *cursor , int col );
+int         db_test_cursor_column_for_update (dbCursor *cursor , int col );
+int         db_test_cursor_mode_insensitive (dbCursor *cursor );
+int         db_test_cursor_mode_scroll (dbCursor *cursor );
+int         db_test_cursor_type_fetch (dbCursor *cursor );
+int         db_test_cursor_type_insert (dbCursor *cursor );
+int         db_test_cursor_type_update (dbCursor *cursor );
+int         db__test_database_open    (void );
+int         db_test_index_type_unique (dbIndex *index );
+int         db_test_value_datetime_current (dbValue *value );
+int         db_test_value_isnull      (dbValue *value );
+void        db_unset_column_has_default_value (dbColumn *column );
+void        db_unset_column_null_allowed (dbColumn *column );
+void        db_unset_column_use_default_value (dbColumn *column );
+void        db_unset_cursor_column_flag (dbCursor *cursor , int col );
+void        db_unset_cursor_column_for_update (dbCursor *cursor , int col );
+void        db_unset_cursor_mode      (dbCursor *cursor );
+void        db_unset_cursor_mode_insensitive (dbCursor *cursor );
+void        db_unset_cursor_mode_scroll (dbCursor *cursor );
+int         db_update                 (dbCursor *cursor );
+int         db_gversion                (dbDriver *driver , dbString *client_version , dbString *driver_version );
+char *      db_whoami                 (void );
+void        db_zero                   (void *s , int n );
+void         db_zero_string            (dbString *x );
+unsigned    int                       db_sizeof_string (dbString *x );
 int         db_set_login ( char *, char *, char *, char * );
 int         db_get_login ( char *, char *, char **, char ** );
-#undef P
+#endif
--- pbmplus.h DELETED ---
