[GRASS-CVS] markus: grass6/lib/proj convert.c, 1.32, 1.32.2.1 get_proj.c, 1.12, 1.12.2.1
grass at intevation.de grass at intevation.de
Sun Nov 18 15:00:41 EST 2007
Author: markus
Update of /grassrepository/grass6/lib/proj
In directory doto:/tmp/cvs-serv23299
Modified Files:
      Tag: releasebranch_6_3
	convert.c get_proj.c
Log Message:
Portability and warning fixes; Don't use C99 features
Index: convert.c
RCS file: /grassrepository/grass6/lib/proj/convert.c,v
retrieving revision 1.32
retrieving revision 1.32.2.1
diff -u -d -r1.32 -r1.32.2.1
--- convert.c	15 Jul 2007 11:14:19 -0000	1.32
+++ convert.c	18 Nov 2007 20:00:39 -0000	1.32.2.1
@@ -169,7 +169,7 @@
 	char *paramkey, *paramvalue;
 	paramkey = strtok(params, "=");
 	paramvalue = params + strlen(paramkey) + 1;
-	if (strcasecmp(paramkey, "towgs84") == 0)
+	if (G_strcasecmp(paramkey, "towgs84") == 0)
 	    G_asprintf(&towgs84, ",TOWGS84[%s]", paramvalue);
 	else
 	    towgs84 = "";
@@ -194,7 +194,7 @@
 	osrunit = OSRGetAttrValue(hSRS, "UNIT", 0);
 	osrunfact = OSRGetAttrValue(hSRS, "UNIT", 1);
-	if ((unfact == NULL) || (strcasecmp(osrunit, "unknown") != 0))
+	if ((unfact == NULL) || (G_strcasecmp(osrunit, "unknown") != 0))
 	    end = "";
 	else {
 	    double unfactf = atof(unfact);
@@ -221,7 +221,7 @@
     OSRDestroySpatialReference(hSRS);
     G_free(modwkt);
-    G_free(wkt);
+    CPLFree(wkt);
     if (proj4 != proj4mod)
 	G_free(proj4);
     G_free(proj4mod);
@@ -416,7 +416,7 @@
             list = listhead = read_datum_table();
             while (list != NULL) {
-    	        if (strcasecmp(pszDatumName, list->longname) == 0) {
+    	        if (G_strcasecmp(pszDatumName, list->longname) == 0) {
     	            datum = G_store(list->name);
 	            break;
@@ -608,7 +608,7 @@
         dfToMeters = OSRGetLinearUnits( hSRS, &pszUnitsName );
         /* Workaround for the most obvious case when unit name is unknown */
-        if( (strcasecmp(pszUnitsName, "unknown") == 0) && (dfToMeters == 1.) )
+        if( (G_strcasecmp(pszUnitsName, "unknown") == 0) && (dfToMeters == 1.) )
 	    G_asprintf( &pszUnitsName, "meter" );
         G_set_key_value( "unit", pszUnitsName, *projunits );
@@ -618,13 +618,13 @@
         pszUnitsPlural = G_malloc( strlen(pszUnitsName) + 3 );
         strcpy(pszUnitsPlural, pszUnitsName);
         pszStringEnd = pszUnitsPlural + strlen(pszUnitsPlural) - 4;
-        if( strcasecmp(pszStringEnd, "foot") == 0 )
+        if( G_strcasecmp(pszStringEnd, "foot") == 0 )
             /* Special case for foot - change two o's to e's */
             pszStringEnd[1] = 'e';
             pszStringEnd[2] = 'e';
-        else if( strcasecmp(pszStringEnd, "inch") == 0 )
+        else if( G_strcasecmp(pszStringEnd, "inch") == 0 )
             /* Special case for inch - add es */
             pszStringEnd[4] = 'e';
Index: get_proj.c
RCS file: /grassrepository/grass6/lib/proj/get_proj.c,v
retrieving revision 1.12
retrieving revision 1.12.2.1
diff -u -d -r1.12 -r1.12.2.1
--- get_proj.c	31 Aug 2007 13:27:38 -0000	1.12
+++ get_proj.c	18 Nov 2007 20:00:39 -0000	1.12.2.1
@@ -228,8 +228,8 @@
     if (!(pj = pj_init(nopt1, opt_in))) {
 	strcpy(buffa, _("Unable to initialise PROJ.4 with the following parameter list:"));
-	char err[50];
 	for (i = 0; i < nopt1; i++) {
+	    char err[50];
 	    sprintf (err, " +%s", opt_in[i]);
 	    strcat (buffa, err);
@@ -366,7 +366,7 @@
     const char *gisbase = G_gisbase();
     static char *buf = NULL;
-    static int buf_len;
+    static size_t buf_len;
     size_t len = strlen(gisbase) + sizeof(GRIDDIR) + strlen(name) + 1;
     if (buf_len < len) {
