[GRASS-CVS] hamish: grass6/display/drivers/cairo description.html, 1.1, 1.2
grass at intevation.de grass at intevation.de
Fri Nov 23 21:58:39 EST 2007
Author: hamish
Update of /grassrepository/grass6/display/drivers/cairo
In directory doto:/tmp/cvs-serv2966
Modified Files:
	description.html
Log Message:
waiting for a --with-cairo switch to be added to ./configure
Index: description.html
RCS file: /grassrepository/grass6/display/drivers/cairo/description.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- description.html	24 Nov 2007 02:45:13 -0000	1.1
+++ description.html	24 Nov 2007 02:58:37 -0000	1.2
@@ -127,7 +127,9 @@
 <H2>NOTES</H2>
-<P>To enable Cairo driver support, build grass with
+<P>
+The driver is still in development. Currently the way to enable Cairo driver
+support is to build grass with
 <div class="code"><PRE>
 make USE_CAIRO=1
 </PRE></div>
