[GRASS-SVN] r30834 - grass/trunk/gui/wxpython/gui_modules
Tue Apr 1 13:22:09 EDT 2008
Author: martinl
Date: 2008-04-01 13:22:09 -0400 (Tue, 01 Apr 2008)
New Revision: 30834
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: fixing (partially) 'zoom to computational region does not respect resolution set with g.region', trac #106
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-04-01 15:39:28 UTC (rev 30833)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-04-01 17:22:09 UTC (rev 30834)
@@ -527,9 +527,8 @@
         Updates the canvas anytime there is a change to the underlaying images
         or to the geometry of the canvas.
-        @param render render map layer composition
-        @param renderVector render vector map layer (digitizer)
-        @param counter reference to layer counter (progress bar)
+        @param render re-render map composition
+        @param renderVector re-render vector map layer enabled for editing (used for digitizer)
         start = time.clock()
@@ -557,7 +556,11 @@
         if render:
             self.Map.ChangeMapSize(self.GetClientSize())
-            self.mapfile = self.Map.Render(force=True, mapWindow=self.parent)
+            windres = False
+            if self.parent.compResolution.GetValue():
+                # use computation region resolution for rendering
+                windres = True
+            self.mapfile = self.Map.Render(force=True, mapWindow=self.parent, windres=windres)
             self.img = self.GetImage() # id=99
@@ -632,7 +635,7 @@
         # update statusbar
-        self.Map.SetRegion()
+        ### self.Map.SetRegion()
         self.parent.StatusbarUpdate()
         Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
@@ -1997,8 +2000,8 @@
         else:
             return
-        self.Map.AlignExtentFromDisplay()
+        ### self.Map.AlignExtentFromDisplay()
         self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
                          self.Map.region['e'], self.Map.region['w'])
@@ -2012,9 +2015,8 @@
         Set display geometry to match computational
         region settings (set with g.region)
         self.Map.region = self.Map.GetRegion()
+        ### self.Map.SetRegion(windres=True)
@@ -2248,9 +2250,10 @@
         self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
                                       choices = ["Coordinates",
                                                  "Extent",
-                                                 "Comp. extent",
                                                  "Comp. region",
-                                                 "Geometry",
+                                                 "Show comp. extent",
+                                                 "Display mode",
+                                                 "Display geometry",
                                                  "Map scale"])
         self.statusText = "Coordinates"
 	self.toggleStatus.SetStringSelection(self.statusText)
@@ -2265,6 +2268,7 @@
         self.showRegion = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
                                       label=_("Show computational extent"))
         self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.showRegion)
         self.showRegion.SetValue(False)
         self.showRegion.Hide()
         self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
@@ -2273,6 +2277,16 @@
                                                  "computational region, "
                                                  "computational region inside a display region "
                                                  "as a red box).")))
+        # set resolution
+        self.compResolution = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                         label=_("Constrain display resolution to computational settings"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.compResolution)
+        self.compResolution.SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+        self.compResolution.Hide()
+        self.compResolution.SetToolTip(wx.ToolTip (_("Constrain display resolution "
+                                                     "to computational region settings. "
+                                                     "Default value for new map displays can "
+                                                     "be set up in 'User GUI settings' dialog.")))
         # map scale
         self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
                                     value="", style=wx.TE_PROCESS_ENTER,
@@ -2475,8 +2489,8 @@
         Track mouse motion and update status bar
         # update statusbar if required
-        e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
         if self.statusText == "Coordinates":
+            e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
             self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
         event.Skip()
@@ -2501,6 +2515,9 @@
             self.Map.DeleteLayer(layer)
         self.MapWindow.UpdateMap(render=True)
+        # update statusbar
+        self.StatusbarUpdate()
     def OnPointer(self, event):
         """Pointer button clicked"""
@@ -2615,7 +2632,13 @@
         if self.autoRender.GetValue():
             self.OnRender(None)
+    def OnToggleResolution(self, event):
+        """Use resolution of computation region settings
+        for redering image instead of display resolution"""
+        # redraw map if auto-rendering is enabled
+        if self.autoRender.GetValue():
+            self.OnRender(None)
     def OnToggleStatus(self, event):
         """Toggle status text"""
         self.statusText = event.GetString()
@@ -2651,6 +2674,7 @@
         """Update statusbar content"""
         self.mapScale.Hide()
         self.mapScaleValue = self.ppm = None
@@ -2662,11 +2686,7 @@
                                          (self.Map.region["w"], self.Map.region["e"],
                                           self.Map.region["s"], self.Map.region["n"]), 0)
-        elif self.statusText == "Comp. extent":
-            compregion = self.Map.GetRegion()
-            # self.statusbar.SetStatusText("%.2f-%.2f,%.2f-%.2f" %
-            #                             (compregion["w"], compregion["e"],
-            #                              compregion["s"], compregion["n"]), 0)
+        elif self.statusText == "Show comp. extent":
             self.statusbar.SetStatusText("", 0)
             self.showRegion.Show()
@@ -2676,8 +2696,12 @@
                                           compregion["s"], compregion["n"],
                                           compregion["ewres"], compregion["nsres"]), 0)
+        elif self.statusText == "Display mode":
+            self.statusbar.SetStatusText("", 0)
+            self.compResolution.Show()
-        elif self.statusText == "Geometry":
+        elif self.statusText == "Display geometry":
             self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
                                          (self.Map.region["rows"], self.Map.region["cols"],
                                           self.Map.region["nsres"], self.Map.region["ewres"]), 0)
@@ -2730,6 +2754,7 @@
         """Reposition checkbox in statusbar"""
         # reposition checkbox
         widgets = [(0, self.showRegion),
+                   (0, self.compResolution),
                    (0, self.mapScale),
                    (0, self.onRenderGauge),
                    (1, self.toggleStatus),
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-04-01 15:39:28 UTC (rev 30833)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-04-01 17:22:09 UTC (rev 30834)
@@ -63,6 +63,7 @@
             'display': {
                 'displayFont' : { 'value' : '' },
                 'driver': { 'type': 'default' },
+                'compResolution' : { 'enabled' : False },
             # advanced
@@ -492,8 +493,8 @@
                                label=_("Set font"), size=(100, -1))
         gridSizer.Add(item=fontButton,
                       flag=wx.ALIGN_RIGHT |
-                       wx.ALIGN_CENTER_VERTICAL,
-                       pos=(row, 1))
+                      wx.ALIGN_CENTER_VERTICAL,
+                      pos=(row, 1))
         # display driver
@@ -518,9 +519,23 @@
         self.winId['display:driver:type'] = driver.GetId()
         gridSizer.Add(item=driver,
+                      flag=wx.ALIGN_RIGHT,
                       pos=(row, 1))
+        # display mode (use computation resolution?)
+        row += 1
+        compResolution = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                    label=_("Constrain display resolution to computational settings"),
+                                    name="IsChecked")
+        compResolution.SetValue(self.settings.Get(group='display', key='compResolution', subkey='enabled'))
+        self.winId['display:compResolution:enabled'] = compResolution.GetId()
+        gridSizer.Add(item=compResolution,
+                      pos=(row, 0), span=(1, 2))
         sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
         border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-04-01 15:39:28 UTC (rev 30833)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-04-01 17:22:09 UTC (rev 30834)
@@ -353,8 +353,7 @@
         return new
     def AlignExtentFromDisplay(self):
-        """Sets display extents (n,s,e,w) to even multiple of
-        current display resolution from center point"""
+        """Align region extent based on display size from center point"""
         # calculate new bounding box based on center of display
         if self.region["ewres"] > self.region["nsres"]:
@@ -396,9 +395,9 @@
     def GetRegion(self, rast=None, vect=None,
                   n=None, s=None, e=None, w=None, default=False):
-        Get region settings
+        Get region settings (g.region -upgc)
-        Optionaly raster or vector map layer can be given.
+        Optionaly extent, raster or vector map layer can be given.
         @param rast raster name or None
         @param vect vector name or None
@@ -471,8 +470,7 @@
         Render string for GRASS_REGION env. variable, so that the images will be rendered
         from desired zoom level.
-        @param windres If windres set to True, uses resolution from
-        WIND file rather than display (for modules that require set
+        @param windres uses resolution from WIND file rather than display (for modules that require set
         resolution like d.rast.num)
         @return String usable for GRASS_REGION variable or None
@@ -480,7 +478,8 @@
         grass_region = ""
         # adjust region settings to match monitor
-        self.region = self.AdjustRegion()
+        if not windres:
+            self.region = self.AdjustRegion()
         #        newextents = self.AlignResolution()
         #        self.region['n'] = newextents['n']
@@ -517,11 +516,11 @@
                     continue
                 elif key == "cols":
                     grass_region += 'cols: %d; ' % \
-                        (self.width)
+                        self.region['cols']
                     continue
                 elif key == "rows":
                     grass_region += 'rows: %d; ' % \
-                        (self.height)
+                        self.region['rows']
                     continue
                 else:
                     grass_region += key + ": "  + self.wind[key] + "; "
@@ -611,7 +610,7 @@
         return selected
-    def Render(self, force=False, mapWindow=None):
+    def Render(self, force=False, mapWindow=None, windres=False):
         Creates final image composite
@@ -620,6 +619,7 @@
         @param force force rendering
         @param reference for MapFrame instance (for progress bar)
+        @param windres use region resolution (True) otherwise display resolution
         @return name of file with rendered image or None
@@ -631,7 +631,7 @@
         opacities = []
         tmp_region = os.getenv("GRASS_REGION")
-        os.environ["GRASS_REGION"] = self.SetRegion()
+        os.environ["GRASS_REGION"] = self.SetRegion(windres)
         os.environ["GRASS_WIDTH"]  = str(self.width)
         os.environ["GRASS_HEIGHT"] = str(self.height)
         if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
