[GRASS-SVN] r30875 - grass/trunk/macosx/app
svn_grass at osgeo.org
Sat Apr 5 23:21:21 EDT 2008
Author: kyngchaos
Date: 2008-04-05 23:21:21 -0400 (Sat, 05 Apr 2008)
New Revision: 30875
grass/trunk/macosx/app/grass.sh.in
avoid unnecessary focus shift to X11 on startup; return focus to starting term app (if not Terminal.app)
Modified: grass/trunk/macosx/app/grass.sh.in
--- grass/trunk/macosx/app/grass.sh.in 2008-04-06 01:28:04 UTC (rev 30874)
+++ grass/trunk/macosx/app/grass.sh.in 2008-04-06 03:21:21 UTC (rev 30875)
@@ -75,14 +75,31 @@
fi
export GRASS_FONT_CAP
+# default xterm Terminal emulator
+# note: only app startup defaults this way, CLI build still defaults to xterm
+if [ ! "$GRASS_XTERM" ] ; then
+ GRASS_XTERM="$GISBASE/etc/grass-xterm-mac"
+ export GRASS_XTERM
+fi
+# determine current term application (when grass.sh is run directly by the user)
+# use osascript so we can get name of term app, not shell process
+USERTERM=`osascript -e 'tell application "System Events" to item 1 of (get name of processes whose frontmost is true)'`
+if [ ! "$USERTERM" ] ; then
+ USERTERM="Terminal"
+fi
### X11 stuff
-# start X11 if not running - no need to check if running when using 'open'
+# start X11 if not running
# some users may be annoyed by this, but X11 required for some stuff for now
if [ -d "/Applications/Utilities/X11.app" ] ; then
# no need to start Leopard X11.app
if [ ! -d "/usr/X11" ] ; then
- open /Applications/Utilities/X11.app
+ # check if running anyways, even though not necessary with "open"
+ if [ ! "`ps -axc | grep 'X11$'`" ] ; then
+ open /Applications/Utilities/X11.app
+ fi
fi
fi
@@ -98,13 +115,6 @@
fi
fi
-# default xterm Terminal emulator
-# note: only app startup defaults this way, CLI build still defaults to xterm
-if [ ! "$GRASS_XTERM" ] ; then
- GRASS_XTERM="$GISBASE/etc/grass-xterm-mac"
- export GRASS_XTERM
-fi
# default to internal X11 Tcl/Tk
@TCLTK_INTERNAL at if [ ! "$GRASS_TCLSH" ] ; then
GRASS_TCLSH="$GISBASE/bin/tclsh at TCLTKVER@"
@@ -125,19 +135,22 @@
DISPLAY=:0.0
export DISPLAY
fi
### end X11 block
# if gisrc has text startup, switch back to Terminal (gotta duplicate some init.sh stuff)
# eventually, when TclTk optional, can run appropriate apps per GUI here (ie X11)
GISRCRC="$HOME/.grassrc6"
-if [ -f "$GISRCRC" ] ; then
- GRASS_GUI=`awk '/GRASS_GUI/ {print $2}' "$GISRCRC"`
-fi
if [ ! "$GRASS_GUI" ] ; then
- GRASS_GUI="tcltk"
+ if [ -f "$GISRCRC" ] ; then
+ GRASS_GUI=`awk '/GRASS_GUI/ {print $2}' "$GISRCRC"`
+ fi
+ if [ ! "$GRASS_GUI" ] ; then
+ GRASS_GUI="tcltk"
+ fi
fi
if [ "$GRASS_GUI" = "text" ] ; then
- osascript -e 'tell application "Terminal" to activate'
+ osascript -e "tell application \"$USERTERM\" to activate"
fi
exec "$GISBASE/etc/Init.sh" "$@"
