[GRASS-SVN] r30926 - grass/trunk/vector/v.reclass
Thu Apr 10 10:40:25 EDT 2008
Author: martinl
Date: 2008-04-10 10:40:25 -0400 (Thu, 10 Apr 2008)
New Revision: 30926
v.reclass: minor manual page cleaning (syntax)
Modified: grass/trunk/vector/v.reclass/description.html
--- grass/trunk/vector/v.reclass/description.html	2008-04-10 14:21:51 UTC (rev 30925)
+++ grass/trunk/vector/v.reclass/description.html	2008-04-10 14:40:25 UTC (rev 30926)
@@ -3,9 +3,11 @@
 <EM>v.reclass</EM> allows user to create a new vector map based on the reclassification
 of an existing vector map.
-Rules file may contain on each row either pair: <BR>
-<I>keyword&nbsp;value</I> <BR>
+Rules file may contain on each row either pair:
+<div class="code"><pre>
 (separated by space) or comment beginning by #(hash).
 Definition of new category begins with keyword <I>cat</I> followed by new category value.
 Keyword <I>where</I> specifies SQL where condition.
@@ -15,7 +17,7 @@
 v.reclass input=land output=land_u type=boundary rules=land.rcl
 the rules file contains :
@@ -33,25 +35,23 @@
 values selected from database by SQL select statement: <br>
 <I>select id from tland where use = 'E14' </I> changed to category 2.
 No table is created for reclassed layer if <B>column</B> option is used and column type is
 integer (there is nothing which could be written to the table).
-For dissolving common boundaries, see <em>v.extract</em>.
+For dissolving common boundaries, see <em><a href="v.dissolve.html">v.dissolve</a></em>.
 No table is created for reclassed layer if <B>rules</B> option is used.
 <H2>SEE ALSO</H2>
-<em><a HREF="v.dissolve.html">v.dissolve</a></em>,
-<em><A HREF="v.extract.html">v.extract</A></em>,
-<em><a HREF="v.reclass.html">v.reclass</a></em>,
+<a HREF="v.dissolve.html">v.dissolve</a>,
+<A HREF="v.extract.html">v.extract</A>
 <em><a HREF="sql.html">GRASS SQL interface</a></em>
@@ -59,4 +59,5 @@
 from v.reclass to v.db.reclass and later to v.reclass in 5.7 rewritten by Radim Blazek
-<p><i>Last changed: $Date$</i>
+<i>Last changed: $Date$</i>
