[GRASS-SVN] r30984 - in grass/trunk/gui/wxpython: . gui_modules xml
Mon Apr 14 07:24:25 EDT 2008
Author: martinl
Date: 2008-04-14 07:24:25 -0400 (Mon, 14 Apr 2008)
New Revision: 30984
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/workspace.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/grass-gxw.dtd
wxGUI: save basic properties of map display window (auto-render, statusbar mode, show computational extent) to workspace file"
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-04-14 11:19:39 UTC (rev 30983)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-04-14 11:24:25 UTC (rev 30984)
@@ -3411,6 +3411,14 @@
         self.PopupMenu(zoommenu)
         zoommenu.Destroy()
+    def SetProperties(self, render=False, mode=0, showCompExtent=False):
+        """Set properies of map display window"""
+        self.autoRender.SetValue(render)
+        self.toggleStatus.SetSelection(mode)
+        self.statusText = self.toggleStatus.GetStringSelection()
+        self.StatusbarUpdate()
+        self.showRegion.SetValue(showCompExtent)
 # end of class MapFrame
 class MapApp(wx.App):
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py	2008-04-14 11:19:39 UTC (rev 30983)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py	2008-04-14 11:24:25 UTC (rev 30984)
@@ -45,8 +45,9 @@
         self.inValue     = False
         self.inGroup     = False
         self.inDisplay   = False
         # list of layers
+        self.displays = []
         self.layers = []
         self.cmd    = []
         self.displayIndex = -1 # first display has index '0'
@@ -58,18 +59,22 @@
         elif name == 'display':
             self.inDisplay = True
             self.displayIndex += 1
+            self.displays.append({
+                "render"         : bool(attrs.get('render', False)),
+                "mode"           : int(attrs.get('mode', 0)),
+                "showCompExtent" : bool(attrs.get('showCompExtent', False))})
         elif name == 'group':
             self.groupName    = attrs.get('name', None)
             self.groupChecked = attrs.get('checked', None)
             self.layers.append({
-                    "type"    : 'group',
-                    "name"    : self.groupName,
-                    "checked" : int(self.groupChecked),
-                    "opacity" : None,
-                    "cmd"     : None,
-                    "group"   : self.inGroup,
-                    "display" : self.displayIndex})
+                "type"    : 'group',
+                "name"    : self.groupName,
+                "checked" : int(self.groupChecked),
+                "opacity" : None,
+                "cmd"     : None,
+                "group"   : self.inGroup,
+                "display" : self.displayIndex})
             self.inGroup = True
         elif name == 'layer':
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-04-14 11:19:39 UTC (rev 30983)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-04-14 11:24:25 UTC (rev 30984)
@@ -606,9 +606,13 @@
                 if layer['display'] >= self.disp_idx:
                     # start new map display if no display is available
                     self.NewDisplay()
                 maptree = self.gm_cb.GetPage(layer['display']).maptree
+                mapdisplay = maptree.mapdisplay
+                mapdisplay.SetProperties(render=gxwXml.displays[layer['display']]['render'],
+                                         mode=gxwXml.displays[layer['display']]['mode'],
+                                         showCompExtent=gxwXml.displays[layer['display']]['showCompExtent'])
                 if not maptree.mapdisplay.IsShown():
                     # show map display
                     maptree.mapdisplay.Show()
@@ -844,9 +848,16 @@
             file.write('%s<gxw>\n' % (' ' * self.indent))
             # list of displays
             for page in range(0, self.gm_cb.GetPageCount()):
+                mapTree = self.gm_cb.GetPage(page).maptree
                 self.indent =+ 4
-                file.write('%s<display>\n' % (' ' * self.indent))
-                mapTree = self.gm_cb.GetPage(page).maptree
+                file.write('%s<display render="%d" '
+                           'mode="%d" showCompExtent="%d">\n' % (' ' * self.indent,
+        int(mapTree.mapdisplay.autoRender.IsChecked()),
+        mapTree.mapdisplay.toggleStatus.GetSelection(),
+        int(mapTree.mapdisplay.showRegion.IsChecked()),
                 # list of layers
                 item = mapTree.GetFirstChild(mapTree.root)[0]
                 self.WriteLayersToWorkspaceFile(file, mapTree, item)
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2008-04-14 11:19:39 UTC (rev 30983)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd	2008-04-14 11:24:25 UTC (rev 30984)
@@ -18,8 +18,13 @@
 <!--    a display element defines map layer connected to given
 	map display widnow
+        render, mode and showCompExtent (added 2004/08)
-<!ELEMENT display (group*, layer*)>
+<!ELEMENT display ((group|layer)*)>
+<!ATTLIST display  render	   CDATA #IMPLIED>
+<!ATTLIST display  mode            CDATA #IMPLIED>
+<!ATTLIST display  showCompExtent  CDATA #IMPLIED>
 <!--    group of map layers
@@ -41,7 +46,7 @@
 <!ELEMENT task	        (flag*, parameter*)>
 <!ATTLIST task	name	CDATA #REQUIRED>
-<!--	layer selected
+<!--	layer selected (added 2008/04)
 <!ELEMENT selected      EMPTY>
