[GRASS-SVN] r32446 - grass/trunk/vector/v.in.dxf
Fri Aug 1 09:35:00 EDT 2008
Author: martinl
Date: 2008-08-01 09:35:00 -0400 (Fri, 01 Aug 2008)
New Revision: 32446
   grass/trunk/vector/v.in.dxf/add_3dface.c
   grass/trunk/vector/v.in.dxf/add_arc.c
   grass/trunk/vector/v.in.dxf/add_circle.c
   grass/trunk/vector/v.in.dxf/add_line.c
   grass/trunk/vector/v.in.dxf/add_lwpolyline.c
   grass/trunk/vector/v.in.dxf/add_point.c
   grass/trunk/vector/v.in.dxf/add_polyline.c
   grass/trunk/vector/v.in.dxf/add_text.c
   grass/trunk/vector/v.in.dxf/global.h
   grass/trunk/vector/v.in.dxf/layer_list.c
   grass/trunk/vector/v.in.dxf/main.c
   grass/trunk/vector/v.in.dxf/write_vect.c
v.in.dxf: message cleaning, -l flag: print also GRASS compliant name (used by wxGUI)
Modified: grass/trunk/vector/v.in.dxf/add_3dface.c
--- grass/trunk/vector/v.in.dxf/add_3dface.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_3dface.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -26,8 +26,7 @@
 		if (flag_list) {
 		    if (!is_layer_in_list(dxf_buf)) {
 			add_layer_to_list(dxf_buf);
-			fprintf(stdout, _("Layer %d: %s\n"), num_layers,
-				dxf_buf);
+			print_layer(dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_arc.c
--- grass/trunk/vector/v.in.dxf/add_arc.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_arc.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -33,8 +33,7 @@
 		if (flag_list) {
-				dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_circle.c
--- grass/trunk/vector/v.in.dxf/add_circle.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_circle.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -29,8 +29,7 @@
 		if (flag_list) {
-				dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_line.c
--- grass/trunk/vector/v.in.dxf/add_line.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_line.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -25,8 +25,7 @@
 		if (flag_list) {
-				dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_lwpolyline.c
--- grass/trunk/vector/v.in.dxf/add_lwpolyline.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_lwpolyline.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -29,8 +29,7 @@
 		if (flag_list) {
-				dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_point.c
--- grass/trunk/vector/v.in.dxf/add_point.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_point.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -24,8 +24,7 @@
 		if (flag_list) {
-				dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_polyline.c
--- grass/trunk/vector/v.in.dxf/add_polyline.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_polyline.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -72,8 +72,9 @@
 	    if (polyline_flag & 8 || polyline_flag & 16 || polyline_flag & 17 ||
 		polyline_flag & 32)
 		if (warn_flag70) {
-		    G_warning(_("3-d data in dxf file. Polyline_flag: %d"),
-			      polyline_flag);
+		    if (!flag_list)
+			G_warning(_("3-d data in dxf file. Polyline_flag: %d"),
+				  polyline_flag);
 		    warn_flag70 = 0;
 	    break;
@@ -102,8 +103,7 @@
 			if (flag_list) {
-					dxf_buf);
 			    return 0;
Modified: grass/trunk/vector/v.in.dxf/add_text.c
--- grass/trunk/vector/v.in.dxf/add_text.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/add_text.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -32,8 +32,7 @@
 		if (flag_list) {
-				dxf_buf);
 		    return 0;
Modified: grass/trunk/vector/v.in.dxf/global.h
--- grass/trunk/vector/v.in.dxf/global.h	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/global.h	2008-08-01 13:35:00 UTC (rev 32446)
@@ -43,6 +43,7 @@
 void add_layer_to_list(char *);
 int is_layer_in_list(char *);
 void init_list(void);
+void print_layer(const char*);
 /* read_dxf.c */
 struct dxf_file *dxf_open(char *);
Modified: grass/trunk/vector/v.in.dxf/layer_list.c
--- grass/trunk/vector/v.in.dxf/layer_list.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/layer_list.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -51,3 +51,22 @@
     return;
+void print_layer(const char* layer_name)
+    char *grass_name;
+    grass_name = G_store(layer_name);
+    G_str_to_lower(grass_name);
+    G_str_to_sql(grass_name);
+    fprintf(stdout, _("Layer %d: %s (%s)\n"), num_layers,
+	    layer_name, grass_name);
+    fflush(stdout);
+    G_free((void *) grass_name);
+    return;
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/main.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -121,6 +121,7 @@
 	num_layers = 0;
 	layers = NULL;
 	Map = NULL;
+	G_verbose_message(_("Layer number: layer name (GRASS compliant name)"));
     else {
 	/* make vector map name SQL compliant */
Modified: grass/trunk/vector/v.in.dxf/write_vect.c
--- grass/trunk/vector/v.in.dxf/write_vect.c	2008-08-01 11:46:30 UTC (rev 32445)
+++ grass/trunk/vector/v.in.dxf/write_vect.c	2008-08-01 13:35:00 UTC (rev 32446)
@@ -55,7 +55,7 @@
 	db_set_string(&sql, buf);
 	if (db_execute_immediate(driver, &sql) != DB_OK)
-	    G_fatal_error(_("Cannot execute: %s"), db_get_string(&sql));
+	    G_fatal_error(_("Unable to insert new record: %s"), db_get_string(&sql));
 	db_free_string(&sql);
     else
@@ -182,7 +182,7 @@
 	    db_start_driver_open_database(Fi[i]->driver,
 					  Vect_subst_var(Fi[i]->database, Map));
 	if (!driver)
-	    G_fatal_error(_("Cannot open database %s by driver %s"),
+	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			  Vect_subst_var(Fi[i]->database, Map), Fi[i]->driver);
 	db_begin_transaction(driver);
@@ -201,18 +201,20 @@
-	G_fatal_error(_("Cannot create table: %s"), db_get_string(&sql));
+	G_fatal_error(_("Unable to create table: %s"), db_get_string(&sql));
     if (db_grant_on_table
 	(driver, Fi[i]->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
-	G_fatal_error(_("Cannot grant privileges on table %s"), Fi[i]->table);
+	G_fatal_error(_("Unable to grant privileges on table <%s>"), Fi[i]->table);
     if (db_create_index2(driver, Fi[i]->table, Fi[i]->key) != DB_OK)
-	G_warning(_("Cannot create index"));
+	G_warning(_("Unable to create index for table <%s>, key <%s>"),
+		  Fi[i]->table, Fi[i]->key);
     if (Vect_map_add_dblink(Map, *field, field_name, Fi[i]->table, "cat",
 			    Fi[i]->database, Fi[i]->driver))
-	G_warning(_("Cannot link table: %s"), Fi[i]->table);
+	G_warning(_("Unable to add database link for vector map <%s>"),
+		  Vect_get_full_name(Map));
     return i;
