[GRASS-SVN] r32454 - grass/trunk/gui/wxpython/gui_modules
    svn_grass at osgeo.org
    Sat Aug  2 06:45:27 EDT 2008
Author: martinl
Date: 2008-08-02 06:45:27 -0400 (Sat, 02 Aug 2008)
New Revision: 32454
   grass/trunk/gui/wxpython/gui_modules/gcmd.py
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/gui/wxpython/gui_modules/preferences.py
   grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: optionally add created map (raster, vector) into layer tree when running command
some goutput fixes (\r)
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-08-02 10:03:23 UTC (rev 32453)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py	2008-08-02 10:45:27 UTC (rev 32454)
@@ -488,9 +488,9 @@
         self._want_abort = False
         self.aborted = False
         self.setDaemon(True)
         # set message formatting
         self.message_format = os.getenv("GRASS_MESSAGE_FORMAT")
         os.environ["GRASS_MESSAGE_FORMAT"] = "gui"
@@ -519,7 +519,7 @@
         if self.stdin: # read stdin if requested ...
             self.module.stdin.write(self.stdin)
             self.module.stdin.close()
         # redirect standard outputs...
         if self.stdout or self.stderr:
             self.__redirect_stream()
@@ -545,7 +545,7 @@
             if self._want_abort: # abort running process
                 self.module.kill()
                 self.aborted = True
-                return
+                return
             if self.stdout:
                 line = recv_some(self.module, e=0, stderr=0)
                 self.stdout.write(line)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-08-02 10:03:23 UTC (rev 32453)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2008-08-02 10:45:27 UTC (rev 32454)
@@ -31,6 +31,7 @@
 import globalvar
 import gcmd
+import utils
 from debug import Debug as Debug
 wxCmdOutput,   EVT_CMD_OUTPUT   = NewEvent()
@@ -41,7 +42,7 @@
 def GrassCmd(cmd, stdout, stderr):
     """Return GRASS command thread"""
-    return gcmd.CommandThread(cmd=cmd,
+    return gcmd.CommandThread(cmd,
                               stdout=stdout, stderr=stderr)
 class CmdThread(threading.Thread):
@@ -108,7 +109,9 @@
         self.parent          = parent # GMFrame
         self.lineWidth       = 80
         self.pageid          = pageid
+        # remember position of line begining (used for '\r')
+        self.linePos         = -1
         # create queues
@@ -253,10 +256,10 @@
             curr_disp = None
         # switch to 'Command output'
-        if hasattr(self.parent, "curr_page"):
+        # if hasattr(self.parent, "curr_page"):
             # change notebook page only for Layer Manager
-            if self.parent.notebook.GetSelection() != 1:
-                self.parent.notebook.SetSelection(1)
+            # if self.parent.notebook.GetSelection() != 1:
+            # self.parent.notebook.SetSelection(1)
         # command given as a string ?
         try:
@@ -309,7 +312,8 @@
                 else:
                     # process GRASS command with argument
                     self.cmdThread.RunCmd(GrassCmd,
-                                          cmdlist, self.cmd_stdout, self.cmd_stderr)
+                                          cmdlist,
+                                          self.cmd_stdout, self.cmd_stderr)
                     self.cmd_output_timer.Start(50)
@@ -371,6 +375,7 @@
         """Print command output"""
         message = event.text
         type  = event.type
         # message prefix
         if type == 'warning':
             messege = 'WARNING: ' + message
@@ -378,10 +383,10 @@
             message = 'ERROR: ' + message
         p1 = self.cmd_output.GetCurrentPos()
-        message = message.replace('\r', '')
+        self.linePos = self.cmd_output.GetCurrentPos()
         pc = -1
         if '\b' in message:
             pc = p1
             last_c = ''
@@ -389,22 +394,26 @@
                 if c == '\b':
                     pc -= 1
                 else:
-                    self.cmd_output.SetCurrentPos(pc)
+                    if c == '\r':
+                        self.cmd_output.SetCurrentPos(self.linePos)
+                    else:
+                        self.cmd_output.SetCurrentPos(pc)
                     self.cmd_output.ReplaceSelection(c)
                     pc = self.cmd_output.GetCurrentPos()
                     if c != ' ':
                         last_c = c
             if last_c not in ('0123456789'):
-                self.cmd_output.AddText('\n')
+                self.cmd_output.AddTextWrapped('\n', wrap=None)
                 pc = -1
         else:
             if os.linesep not in message:
                 self.cmd_output.AddTextWrapped(message, wrap=60)
             else:
-                self.cmd_output.AddText(message)
+                self.cmd_output.AddTextWrapped(message, wrap=None)
         p2 = self.cmd_output.GetCurrentPos()
         self.cmd_output.StartStyling(p1, 0xff)
         if type == 'error':
             self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleError)
         elif type == 'warning':
@@ -470,6 +479,24 @@
             dialog.btn_run.Enable(True)
+            if not event.aborted and hasattr(dialog, "addbox") and \
+                    dialog.addbox.IsChecked():
+                # add new map into layer tree
+                if dialog.outputType in ('raster', 'vector'):
+                    # add layer into layer tree
+                    cmd = dialog.notebookpanel.createCmd(ignoreErrors = True)
+                    name = utils.GetLayerNameFromCmd(cmd, fullyQualified=True, param='output')
+                    mapTree = self.parent.parent.parent.parent.curr_page.maptree
+                    if dialog.outputType == 'raster':
+                        lcmd = ['d.rast',
+                                'map=%s' % name]
+                    else:
+                        lcmd = ['d.vect',
+                                'map=%s' % name]
+                    mapTree.AddLayer(ltype=dialog.outputType,
+                                     lcmd=lcmd,
+                                     lname=name)
             if dialog.get_dcmd is None and \
                    dialog.closebox.IsChecked():
                 time.sleep(1)
@@ -525,7 +552,7 @@
         self.type = ''
         self.message = ''
         self.printMessage = False
     def write(self, s):
         s = s.replace('\n', os.linesep)
         # remove/replace escape sequences '\b' or '\r' from stream
@@ -534,6 +561,7 @@
         for line in s.split(os.linesep):
             if len(line) == 0:
                 continue
             if 'GRASS_INFO_PERCENT' in line:
                 value = int(line.rsplit(':', 1)[1].strip())
                 if value >= 0 and value < 100:
@@ -589,7 +617,6 @@
     def __init__(self, parent, id, margin=False, wrap=None):
         wx.stc.StyledTextCtrl.__init__(self, parent, id)
-        self.wrap = wrap
         # styles
@@ -662,25 +689,24 @@
         String is wrapped and linesep is also added to the end
         of the string"""
-        if wrap is None and self.wrap:
-            wrap = self.wrap
-        if wrap is not None:
+        if wrap:
             txt = textwrap.fill(txt, wrap) + os.linesep
         else:
             txt += os.linesep
-        self.AddText(txt)
-    def SetWrap(self, wrap):
-        """Set wrapping value
-        @param wrap wrapping value
-        @return current wrapping value
-        if wrap > 0:
-            self.wrap = wrap
-        return self.wrap
+        if '\r' in txt:
+            self.linePos = -1
+            for seg in txt.split('\r'):
+                if self.linePos > -1:
+                    self.cmd_output.SetCurrenPos()
+                    self.ReplaceText(iseg) + ' ' * (self.lineWidth - len(iseg))
+                else:
+                    self.AddText(iseg)
+                self.linePos = self.GetCurrentPos()
+                iseg += 1
+        else:
+            self.AddText(txt)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-08-02 10:03:23 UTC (rev 32453)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-08-02 10:45:27 UTC (rev 32454)
@@ -708,6 +708,21 @@
         guisizer.Add(item=btnsizer, proportion=0, flag=wx.ALIGN_CENTER)
+        if self.parent is not None:
+            self.outputType = None
+            for p in self.task.params:
+                if p.get('name', '') == 'output':
+                    self.outputType = p.get('prompt', None)
+                    break
+            if self.outputType:
+                # add newly created map into layer tree
+                self.addbox = wx.CheckBox(parent=self.panel,
+                                          label=_('Add created map into layer tree'), style = wx.NO_BORDER)
+                self.addbox.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
+                guisizer.Add(item=self.addbox, proportion=0,
+                             flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
+                             border=5)
         if self.get_dcmd is None:
             # close dialog when command is terminated
             self.closebox = wx.CheckBox(parent=self.panel,
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-08-02 10:03:23 UTC (rev 32453)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2008-08-02 10:45:27 UTC (rev 32454)
@@ -145,6 +145,9 @@
                 'rasterOverlay' : {
                     'enabled' : False
+                'addNewLayer' : {
+                    'enabled' : False
             # Workspace
@@ -1053,6 +1056,16 @@
         gridSizer.Add(item=close,
                       pos=(row, 0), span=(1, 2))
         row += 1
+        # add layer
+        add = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                          label=_("Add created map into layer tree"),
+                          name="IsChecked")
+        add.SetValue(self.settings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
+        self.winId['cmd:addNewLayer:enabled'] = add.GetId()
+        gridSizer.Add(item=add,
+                      pos=(row, 0), span=(1, 2))
+        row += 1
         # verbosity
         gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
                                          label=_("Verbosity level:")),
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py	2008-08-02 10:03:23 UTC (rev 32453)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py	2008-08-02 10:45:27 UTC (rev 32454)
@@ -57,12 +57,12 @@
     except:
         return None
-def GetLayerNameFromCmd(dcmd, fullyQualified=False):
+def GetLayerNameFromCmd(dcmd, fullyQualified=False, param=None):
     """Get map name from GRASS command
     @param dcmd GRASS command (given as list)
     @param fullyQualified change map name to be fully qualified
+    @param force parameter otherwise 'input'/'map'
     @return map name
     @return '' if no map name found in command
@@ -78,12 +78,15 @@
         mapname = dcmd[idx].split('=')[1]+' labels'
     else:
         for idx in range(len(dcmd)):
-            if 'map=' in dcmd[idx] or \
-                    'input=' in dcmd[idx] or \
-                    'red=' in dcmd[idx] or \
-                    'h_map=' in dcmd[idx] or \
-                    'reliefmap' in dcmd[idx]:
+            if param and param in dcmd[idx]:
                 break
+            elif not param:
+                if 'map=' in dcmd[idx] or \
+                        'input=' in dcmd[idx] or \
+                        'red=' in dcmd[idx] or \
+                        'h_map=' in dcmd[idx] or \
+                        'reliefmap' in dcmd[idx]:
+                    break
         if idx < len(dcmd):
