[GRASS-SVN] r32464 - grass/trunk/gui/wxpython/gui_modules
Sat Aug 2 09:49:48 EDT 2008
Author: martinl
Date: 2008-08-02 09:49:47 -0400 (Sat, 02 Aug 2008)
New Revision: 32464
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: fix map layer position in stack, update r32463
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-08-02 13:09:36 UTC (rev 32463)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-08-02 13:49:47 UTC (rev 32464)
@@ -797,7 +797,7 @@
                (not os.path.isfile(layer.mapfile) or not os.path.getsize(layer.mapfile)):
                 if not layer.Render():
                     continue
             # update process bar
             if mapWindow is not None:
                 mapWindow.onRenderCounter += 1
@@ -862,7 +862,8 @@
         return self.mapfile
     def AddLayer(self, type, command, name=None,
-                 l_active=True, l_hidden=False, l_opacity=1.0, l_render=False):
+                 l_active=True, l_hidden=False, l_opacity=1.0, l_render=False,
+                 pos=-1):
         Adds generic map layer to list of layers
@@ -873,6 +874,7 @@
         @param l_hidden layer not displayed in layer tree if True
         @param l_opacity opacity level range from 0(transparent) - 1(not transparent)
         @param l_render render an image if True
+        @param pos position in layer list (-1 for append)
         @return new layer on success
         @return None on failure
@@ -886,14 +888,17 @@
                          active=l_active, hidden=l_hidden, opacity=l_opacity)
         # add maplayer to the list of layers
-        self.layers.append(layer)
+        if pos > -1:
+            self.layers.insert(pos, layer)
+        else:
+            self.layers.append(layer)
         Debug.msg (3, "Map.AddLayer(): layer=%s" % layer.name)
         if l_render:
                 raise gcmd.GStdError(_("Unable to render map layer <%s>.") % (name))
-        return self.layers[-1]
+        return layer
     def DeleteLayer(self, layer, overlay=False):
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-02 13:09:36 UTC (rev 32463)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-02 13:49:47 UTC (rev 32464)
@@ -566,10 +566,6 @@
         self.CheckItem(layer, checked=checked)
-        # select new item
-        self.SelectItem(layer, select=True)
-        self.layer_selected = layer
         # add text and icons for each layer ltype
         if ltype == 'raster':
             self.SetItemImage(layer, self.rast_icon)
@@ -651,7 +647,23 @@
                                     'prowin' : None},
                                    None))
-            maplayer = self.Map.AddLayer(type=ltype, command=self.GetPyData(layer)[0]['cmd'], name=name,
+            # find previous map layer instance
+            prevItem = self.GetLastChild(self.root)
+            prevMapLayer = None
+            while prevItem and prevItem.IsOk() and \
+                    prevItem != layer:
+                if self.GetPyData(prevItem)[0]['maplayer']:
+                    prevMapLayer = self.GetPyData(prevItem)[0]['maplayer']
+                prevItem = self.GetPrevSibling(prevItem)
+            if prevMapLayer:
+                pos = self.Map.GetLayerIndex(prevMapLayer) + 1
+            else:
+                pos = -1
+            maplayer = self.Map.AddLayer(pos=pos,
+                                         type=ltype, command=self.GetPyData(layer)[0]['cmd'], name=name,
                                          l_active=checked, l_hidden=False,
                                          l_opacity=opacity, l_render=render)
             self.GetPyData(layer)[0]['maplayer'] = maplayer
@@ -679,6 +691,10 @@
         if checked is True:
             self.mapdisplay.onRenderGauge.SetRange(len(self.Map.GetListOfLayers(l_active=True)))
+        # select new item
+        self.SelectItem(layer, select=True)
+        self.layer_selected = layer
         # layer.SetHeight(TREE_ITEM_HEIGHT)
         return layer
