[GRASS-SVN] r32492 - grass/branches/develbranch_6
Sun Aug 3 08:01:20 EDT 2008
Author: martinl
Date: 2008-08-03 08:01:20 -0400 (Sun, 03 Aug 2008)
New Revision: 32492
   grass/branches/develbranch_6/SUBMITTING
list of svn mime-types (sorted) mentioned in SUBMITTING (merge from trunk, r32488, 32490)
Modified: grass/branches/develbranch_6/SUBMITTING
--- grass/branches/develbranch_6/SUBMITTING	2008-08-03 11:59:00 UTC (rev 32491)
+++ grass/branches/develbranch_6/SUBMITTING	2008-08-03 12:01:20 UTC (rev 32492)
@@ -390,7 +390,7 @@
     To set a property:
-      svn propset svn:keywords 'Author Date Id' <directory>
+      svn propset svn:keywords 'Author Date Id' <file>
       svn propset svn:mime-type text/x-sh grass_shellscript.sh
     To edit the svn:ignore property using your default text editor:
@@ -407,6 +407,22 @@
       svn propset -F ignore.txt svn:ignore <directory>
+    List of mime-type:
+      C++ files (.cpp): text/x-c++src
+      C files (.c): text/x-csrc
+      DTD files (.dtd): application/xml-dtd
+      GIF files (.gif): image/gif
+      Header files (.h): text/x-chdr
+      HTML files (.html): text/html
+      JPEG files (.jpg): image/jpeg
+      Makefiles: text/x-makefile
+      PNG files (.png): image/png
+      Python files (.py): text/x-python
+      Text files (.txt): text/plain
+      XML files (.xml): application/xml
+      (please update the list...)
 30. Use doxygen style for source code documentation. It is required
     for GRASS libraries, but also recommended for GRASS modules.
@@ -441,13 +457,13 @@
        For details see Vect_snap_lines_list()
-       \param[in] Map input vector map
-       \param[in] type type of lines to be snap
-       \param[in] thresh threshold value for snapping
-       \param[out] Err vector map where lines representing snap are written or NULL
+       \param Map pointer to input vector map
+       \param type filter features of given type to be snap
+       \param thresh threshold value for snapping
+       \param[out] Err pointer to vector map where lines representing snap are written or NULL
        \param[out] msgout file pointer where messages will be written or NULL
-       \return
+       \return 1
