[GRASS-SVN] r32509 - in grass/trunk: include include/Make
include/iostream lib lib/iostream raster/r.terraflow
svn_grass at osgeo.org
Mon Aug 4 08:21:12 EDT 2008
Author: pkelly
Date: 2008-08-04 08:21:11 -0400 (Mon, 04 Aug 2008)
New Revision: 32509
Added:
grass/trunk/include/iostream/
grass/trunk/include/iostream/ami.h
grass/trunk/include/iostream/ami_config.h
grass/trunk/include/iostream/ami_sort.h
grass/trunk/include/iostream/ami_sort_impl.h
grass/trunk/include/iostream/ami_stream.h
grass/trunk/include/iostream/embuffer.h
grass/trunk/include/iostream/empq.h
grass/trunk/include/iostream/empq_adaptive.h
grass/trunk/include/iostream/empq_adaptive_impl.h
grass/trunk/include/iostream/empq_impl.h
grass/trunk/include/iostream/imbuffer.h
grass/trunk/include/iostream/mem_stream.h
grass/trunk/include/iostream/minmaxheap.h
grass/trunk/include/iostream/mm.h
grass/trunk/include/iostream/mm_utils.h
grass/trunk/include/iostream/pqheap.h
grass/trunk/include/iostream/queue.h
grass/trunk/include/iostream/quicksort.h
grass/trunk/include/iostream/replacementHeap.h
grass/trunk/include/iostream/replacementHeapBlock.h
grass/trunk/include/iostream/rtimer.h
grass/trunk/lib/iostream/
grass/trunk/lib/iostream/Makefile
grass/trunk/lib/iostream/ami_stream.cc
grass/trunk/lib/iostream/minmaxheap_test.cc
grass/trunk/lib/iostream/mm.cc
grass/trunk/lib/iostream/mm_utils.cc
grass/trunk/lib/iostream/rtimer.cc
Removed:
grass/trunk/raster/r.terraflow/IOStream/
grass/trunk/include/Make/Grass.make.in
grass/trunk/lib/Makefile
grass/trunk/raster/r.terraflow/3scan.h
grass/trunk/raster/r.terraflow/Makefile
grass/trunk/raster/r.terraflow/ccforest.h
grass/trunk/raster/r.terraflow/common.h
grass/trunk/raster/r.terraflow/direction.h
grass/trunk/raster/r.terraflow/fill.h
grass/trunk/raster/r.terraflow/filldepr.cc
grass/trunk/raster/r.terraflow/filldepr.h
grass/trunk/raster/r.terraflow/genericWindow.h
grass/trunk/raster/r.terraflow/grass2str.h
grass/trunk/raster/r.terraflow/grid.h
grass/trunk/raster/r.terraflow/nodata.cc
grass/trunk/raster/r.terraflow/nodata.h
grass/trunk/raster/r.terraflow/plateau.cc
grass/trunk/raster/r.terraflow/plateau.h
grass/trunk/raster/r.terraflow/sortutils.h
grass/trunk/raster/r.terraflow/stats.h
grass/trunk/raster/r.terraflow/streamutils.h
grass/trunk/raster/r.terraflow/sweep.cc
grass/trunk/raster/r.terraflow/sweep.h
grass/trunk/raster/r.terraflow/water.cc
Move iostream library to lib/iostream and includes to include/iostream,
and update r.terraflow to use it - in preparation for introducing
r.viewshed.
Modified: grass/trunk/include/Make/Grass.make.in
--- grass/trunk/include/Make/Grass.make.in 2008-08-04 09:36:34 UTC (rev 32508)
+++ grass/trunk/include/Make/Grass.make.in 2008-08-04 12:21:11 UTC (rev 32509)
@@ -112,6 +112,7 @@
ICON_LIBNAME = grass_icon
IMAGERY_LIBNAME = grass_imagery
IORTHO_LIBNAME = grass_Iortho
+IOSTREAM_LIBNAME = grass_iostream
ISMAP_LIBNAME = grass_ismap
LINKM_LIBNAME = grass_linkm
LOCK_LIBNAME = grass_lock
@@ -209,6 +210,7 @@
ICONLIB = -l$(ICON_LIBNAME)
IMAGERYLIB = -l$(IMAGERY_LIBNAME) $(GISLIB)
IORTHOLIB = -l$(IORTHO_LIBNAME) $(IMAGERYLIB) $(GISLIB)
+IOSTREAMLIB = -l$(IOSTREAM_LIBNAME)
ISMAPLIB = -l$(ISMAP_LIBNAME)
LINKMLIB = -l$(LINKM_LIBNAME)
LOCKLIB = -l$(LOCK_LIBNAME)
@@ -307,6 +309,7 @@
ICONDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ICON_LIBNAME)$(LIB_SUFFIX)
IMAGERYDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IMAGERY_LIBNAME)$(LIB_SUFFIX)
IORTHODEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IORTHO_LIBNAME)$(LIB_SUFFIX)
+IOSTREAMDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IOSTREAM_LIBNAME)$(LIB_SUFFIX)
LINKMDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LINKM_LIBNAME)$(LIB_SUFFIX)
LOCKDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LOCK_LIBNAME)$(LIB_SUFFIX)
RASTERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(RASTER_LIBNAME)$(LIB_SUFFIX)
Copied: grass/trunk/include/iostream/ami.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/ami.h)
--- grass/trunk/include/iostream/ami.h (rev 0)
+++ grass/trunk/include/iostream/ami.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,46 @@
+ * MODULE: r.terraflow
+ * COPYRIGHT (C) 2007 Laura Toma
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+#ifndef _AMI_H
+#define _AMI_H
+//debug flags
+#include "ami_config.h"
+//typedefs, stream
+#include "ami_stream.h"
+//memory manager
+#include "mm.h"
+#include "mm_utils.h"
+#include "ami_sort.h"
+//data structures
+#include "queue.h"
+#include "pqheap.h"
+//#include "empq.h"
+#include "empq_impl.h"
+//#include "empq_adaptive.h"
+#include "empq_adaptive_impl.h"
+//timer
+#include "rtimer.h"
+#endif // _AMI_H
Copied: grass/trunk/include/iostream/ami_config.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/ami_config.h)
--- grass/trunk/include/iostream/ami_config.h (rev 0)
+++ grass/trunk/include/iostream/ami_config.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,43 @@
+#ifndef _ami_config_h
+#define _ami_config_h
+//CHOOSE PQUEUE IMPLEMENTATION
+//#define IM_PQUEUE
+//#define EM_PQUEUE
+#define EMPQ_ADAPTIVE
+//maximize memory usage by keeping streams on disk
+#if (defined EM_PQUEUE || defined EMPQ_ADAPTIVE)
+//enables keeping streams on disk, rather than in memory;
+#define SAVE_MEMORY
+#endif
+#if (defined EMPQ_ADAPTIVE && !defined SAVE_MEMORY)
+#error EMPQ_ADAPTIVE requires SAVE_MEMORY set
+#endif
+#endif
Copied: grass/trunk/include/iostream/ami_sort.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/ami_sort.h)
--- grass/trunk/include/iostream/ami_sort.h (rev 0)
+++ grass/trunk/include/iostream/ami_sort.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,165 @@
+#ifndef _AMI_SORT_H
+#define _AMI_SORT_H
+#include "ami_sort_impl.h"
+#define SORT_DEBUG if(0)
+// A version of AMI_sort that takes an input streamof elements of type
+// T, creates an output stream and and uses the < operator to sort
+// instream is allocated; *outstream is created
+// template<class T>
+// AMI_err
+// AMI_sort(AMI_STREAM<T> *instream, AMI_STREAM<T> **outstream) {
+// cout << "Not implemented yet!\n";
+// exit(1);
+// return AMI_ERROR_NO_ERROR;
+// A version of AMI_sort that takes an input stream of elements of
+// type T, creates an output stream, and a user-specified comparison
+// function
+// AMI_err AMI_sort(AMI_STREAM<T> *instream, AMI_STREAM<T> **outstream,
+// int (*cmp)(const T&, const T&)) {
+// exit(1);
+// object.
+//The comparison object "cmp", of (user-defined) class represented by
+//CMPR, must have a member function called "compare" which is used for
+//sorting the input stream.
+// create *outstream
+template<class T, class Compare>
+AMI_err
+AMI_sort(AMI_STREAM<T> *instream, AMI_STREAM<T> **outstream, Compare *cmp,
+ int deleteInputStream = 0) {
+ char* name;
+ queue<char*>* runList;
+ int instreamLength;
+ assert(instream && outstream && cmp);
+ instreamLength = instream->stream_len();
+ if (instreamLength == 0) {
+ *outstream = new AMI_STREAM<T>();
+ if (deleteInputStream) {
+ delete instream;
+ return AMI_ERROR_NO_ERROR;
+ SORT_DEBUG {
+ instream->name(&name);
+ cout << "AMI_sort: sorting stream" << name <<", len="
+ << instreamLength << endl;
+ delete name;
+ MM_manager.print();
+ //run formation
+ runList = runFormation(instream, cmp);
+ assert(runList && runList->length() > 0);
+ delete instream;
+ if (runList->length() == 1) {
+ //if 1 run only
+ runList->dequeue(&name);
+ *outstream = new AMI_STREAM<T>(name);
+ delete name; //should be safe, stream makes its own copy
+ } else {
+ *outstream = multiMerge<T,Compare>(runList, cmp);
+ //i thought the templates are not needed in the call, but seems to
+ //help the compiler..laura
+ assert(runList->length() == 0);
+ delete runList;
+ SORT_DEBUG {
+ cout << "AMI_sort: done" << endl << endl;
+ assert(*outstream);
+ assert((*outstream)->stream_len() == instreamLength);
+int
+isSorted(AMI_STREAM<T> *str, Compare cmp) {
+ T *prev, *crt;
+ AMI_err ae;
+ assert(str);
+ str->seek(0);
+ if (str->stream_len() <2) return 1;
+ ae = str->read_item(&crt);
+ cout << "reading: " << *crt << endl;
+ prev = new T (*crt);
+ while (ae == AMI_ERROR_NO_ERROR) {
+ if (cmp.compare(*prev, *crt) != -1)
+ assert(0);
+ return 0;
+ prev = crt;
+ return 1;
+#endif // _AMI_SORT_H
Copied: grass/trunk/include/iostream/ami_sort_impl.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/ami_sort_impl.h)
--- grass/trunk/include/iostream/ami_sort_impl.h (rev 0)
+++ grass/trunk/include/iostream/ami_sort_impl.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,362 @@
+#ifndef AMI_SORT_IMPL_H
+#define AMI_SORT_IMPL_H
+#include "mem_stream.h"
+#include "mm.h"
+#include "quicksort.h"
+#include "queue.h"
+#include "replacementHeap.h"
+#include "replacementHeapBlock.h"
+#define SDEBUG if(0)
+/* if this flag is defined, a run will be split into blocks, each
+ block sorted and then all blocks merged */
+#define BLOCKED_RUN
+//set run_size, last_run_size and nb_runs depending on how much memory
+//is available
+template<class T>
+static void
+initializeRunFormation(AMI_STREAM<T> *instream,
+ size_t &run_size, size_t &last_run_size,
+ unsigned int &nb_runs) {
+ off_t strlen = instream->stream_len();
+ size_t mm_avail = MM_manager.memory_available();
+#ifdef BLOCKED_RUN
+ // not in place, can only use half memory
+ mm_avail = mm_avail/2;
+#endif
+ run_size = mm_avail/sizeof(T);
+ if (strlen == 0) {
+ nb_runs = last_run_size = 0;
+ } else {
+ if (strlen % run_size == 0) {
+ nb_runs = strlen/run_size;
+ last_run_size = run_size;
+ } else {
+ nb_runs = strlen/run_size + 1;
+ last_run_size = strlen % run_size;
+ SDEBUG cout << "nb_runs=" << nb_runs
+ << ", run_size=" << run_size
+ << ", last_run_size=" << last_run_size
+ << "\n";
+/* data is allocated; read run_size elements from stream into data and
+ sort them using quicksort */
+void makeRun_Block(AMI_STREAM<T> *instream, T* data,
+ unsigned int run_size, Compare *cmp) {
+ AMI_err err;
+ //read next run from input stream
+ err = instream->read_array(data, run_size);
+ assert(err == AMI_ERROR_NO_ERROR);
+ //sort it in memory in place
+ quicksort(data, run_size, *cmp);
+ sort them using quicksort; instead of reading the whole chunk at
+ once, it reads it in blocks, sorts each block and then merges the
+ blocks together. Note: it is not in place! it allocates another
+ array of same size as data, writes the sorted run into it and
+ deteles data, and replaces data with outdata */
+void makeRun(AMI_STREAM<T> *instream, T* &data,
+ int run_size, Compare *cmp) {
+ unsigned int nblocks, last_block_size, crt_block_size, block_size;
+ block_size = STREAM_BUFFER_SIZE;
+ if (run_size % block_size == 0) {
+ nblocks = run_size / block_size;
+ last_block_size = block_size;
+ } else {
+ nblocks = run_size / block_size + 1;
+ last_block_size = run_size % block_size;
+ //create queue of blocks waiting to be merged
+ queue<MEM_STREAM<T> *> *blockList;
+ MEM_STREAM<T>* str;
+ blockList = new queue<MEM_STREAM<T> *>(nblocks);
+ for (unsigned int i=0; i < nblocks; i++) {
+ crt_block_size = (i == nblocks-1) ? last_block_size: block_size;
+ makeRun_Block(instream, &(data[i*block_size]), crt_block_size, cmp);
+ str = new MEM_STREAM<T>( &(data[i*block_size]), crt_block_size);
+ blockList->enqueue(str);
+ assert(blockList->length() == nblocks);
+ //now data consists of sorted blocks: merge them
+ ReplacementHeapBlock<T,Compare> rheap(blockList);
+ SDEBUG rheap.print(cerr);
+ int i = 0;
+ T elt;
+ T* outdata = new T [run_size];
+ while (!rheap.empty()) {
+ elt = rheap.extract_min();
+ outdata[i] = elt;
+ //SDEBUG cerr << "makeRun: written " << elt << endl;
+ i++;
+ assert( i == run_size && blockList->length() == 0);
+ delete blockList;
+ T* tmp = data;
+ delete [] tmp;
+ data = outdata;
+//partition instream in streams that fit in main memory, sort each
+//stream, remember its name, make it persistent and store it on
+//disk. if entire stream fits in memory, sort it and store it and
+//return it.
+//assume instream is allocated prior to the call.
+// set nb_runs and allocate runNames.
+//Compare, must have a member function called "compare" which is used
+//for sorting the input stream.
+queue<char*>*
+runFormation(AMI_STREAM<T> *instream, Compare *cmp) {
+ size_t run_size,last_run_size, crt_run_size;
+ unsigned int nb_runs;
+ T* data;
+ AMI_STREAM<T>* str;
+ char* strname;
+ assert(instream && cmp);
+ SDEBUG cout << "runFormation: ";
+ SDEBUG MM_manager.print();
+ //rewind file
+ instream->seek(0); //should check error xxx
+ //estimate run_size, last_run_size and nb_runs
+ initializeRunFormation(instream, run_size, last_run_size, nb_runs);
+ //create runList
+ runList = new queue<char*>(nb_runs);
+ //allocate space for a run
+ if (nb_runs <= 1) {
+ //don't waste space if input stream is smaller than run_size
+ data = new T[last_run_size];
+ } else {
+ data = new T[run_size];
+ for (size_t i=0; i< nb_runs; i++) {
+ crt_run_size = (i == nb_runs-1) ? last_run_size: run_size;
+ //SDEBUG cout << "i=" << i << ": runsize=" << crt_run_size << ", ";
+#ifdef BLOCKED_RUN
+ makeRun(instream, data, crt_run_size, cmp);
+#else
+ makeRun_Block(instream, data, crt_run_size, cmp);
+#endif
+ //err = instream->read_array(data, crt_run_size);
+ //assert(err == AMI_ERROR_NO_ERROR);
+ //quicksort(data, crt_run_size, *cmp);
+ //create a new stream to hold this run
+ str = new AMI_STREAM<T>();
+ str->write_array(data, crt_run_size);
+ assert(str->stream_len() == crt_run_size);
+ //remember this run's name
+ str->name(&strname);
+ runList->enqueue(strname);
+ //delete the stream -- should not keep too many streams open
+ str->persist(PERSIST_PERSISTENT);
+ delete str;
+ //release the run memory!
+ delete [] data;
+ SDEBUG cout << "runFormation: done.\n";
+ return runList;
+//this is one pass of merge; estimate max possible merge arity <ar>
+//and merge the first <ar> streams from runList ; create and return
+//the resulting stream (does not add it to the queue -- the calling
+//function will do that)
+//input streams are assumed to be sorted, and are not necessarily of
+//the same length.
+//streamList does not contains streams, but names of streams, which
+//must be opened in order to be merged
+AMI_STREAM<T>*
+singleMerge(queue<char*>* streamList, Compare *cmp) {
+ AMI_STREAM<T>* mergedStr;
+ size_t mm_avail, blocksize;
+ unsigned int arity, max_arity;
+ T elt;
+ assert(streamList && cmp);
+ SDEBUG cout << "singleMerge: ";
+ //estimate max possible merge arity with available memory (approx M/B)
+ mm_avail = MM_manager.memory_available();
+ blocksize = getpagesize();
+ //should use AMI function, but there's no stream at this point
+ // AMI_STREAM<T>::main_memory_usage(&blocksize, MM_STREAM_USAGE_BUFFER);
+ max_arity = mm_avail/blocksize;
+ arity = (streamList->length() < max_arity) ?
+ streamList->length() : max_arity;
+ SDEBUG cout << "arity=" << arity << " (max_arity=" <<max_arity<< ")\n";
+ //create output stream
+ mergedStr = new AMI_STREAM<T>();
+ ReplacementHeap<T,Compare> rheap(arity, streamList);
+ int i = 0;
+ //mergedStr->write_item( rheap.extract_min() );
+ //xxx should check error here
+ mergedStr->write_item(elt);
+ //SDEBUG cerr << "smerge: written " << elt << endl;
+ i++;
+ SDEBUG cout << "..done\n";
+ return mergedStr;
+//merge runs whose names are given by runList; this may entail
+//multiple passes of singleMerge();
+//return the resulting output stream
+//the same length.
+AMI_STREAM<T>*
+multiMerge(queue<char*>* runList, Compare *cmp) {
+ AMI_STREAM<T> * mergedStr= NULL;
+ char* path;
+ assert(runList && runList->length() > 1 && cmp);
+ SDEBUG cout << "multiMerge: " << runList->length() << " runs" << endl;
+ while (runList->length() > 1) {
+ //merge streams from streamlist into mergedStr
+ mergedStr = singleMerge<T,Compare>(runList, cmp);
+ assert(mergedStr);
+ //if more runs exist, delete this stream and add it to list
+ if (runList->length() > 0) {
+ mergedStr->name(&path);
+ runList->enqueue(path);
+ mergedStr->persist(PERSIST_PERSISTENT);
+ delete mergedStr;
+ return mergedStr;
+#endif
Copied: grass/trunk/include/iostream/ami_stream.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/ami_stream.h)
--- grass/trunk/include/iostream/ami_stream.h (rev 0)
+++ grass/trunk/include/iostream/ami_stream.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,554 @@
+#ifndef _AMI_STREAM_H
+#define _AMI_STREAM_H
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <fcntl.h>
+#include <errno.h>
+#include <unistd.h>
+#include <iostream>
+#include <cstring>
+using namespace std;
+#include "mm.h" // Get the memory manager.
+#ifdef __MINGW32__
+#define getpagesize() (4096)
+#endif
+#define DEBUG_DELETE if(0)
+// The name of the environment variable which keeps the name of the
+// directory where streams are stored
+#define STREAM_TMPDIR "STREAM_DIR"
+// All streams will be names STREAM_*****
+#define BASE_NAME "STREAM"
+#define STREAM_BUFFER_SIZE (1<<15)
+// AMI error codes are returned using the AMI_err type.
+enum AMI_err {
+ AMI_ERROR_NO_ERROR = 0,
+ AMI_ERROR_IO_ERROR,
+ AMI_ERROR_END_OF_STREAM,
+ AMI_ERROR_OUT_OF_RANGE,
+ AMI_ERROR_READ_ONLY,
+ AMI_ERROR_OS_ERROR,
+ AMI_ERROR_MM_ERROR,
+ AMI_ERROR_OBJECT_INITIALIZATION,
+ AMI_ERROR_PERMISSION_DENIED,
+ AMI_ERROR_INSUFFICIENT_MAIN_MEMORY,
+ AMI_ERROR_INSUFFICIENT_AVAILABLE_STREAMS,
+ AMI_ERROR_ENV_UNDEFINED,
+ AMI_ERROR_NO_MAIN_MEMORY_OPERATION,
+// AMI stream types passed to constructors
+enum AMI_stream_type {
+ AMI_READ_STREAM = 1, // Open existing stream for reading
+ AMI_WRITE_STREAM, // Open for writing. Create if non-existent
+ AMI_APPEND_STREAM, // Open for writing at end. Create if needed.
+ AMI_READ_WRITE_STREAM // Open to read and write.
+enum persistence {
+ // Delete the stream from the disk when it is destructed.
+ PERSIST_DELETE = 0,
+ // Do not delete the stream from the disk when it is destructed.
+ PERSIST_PERSISTENT,
+ // Delete each block of data from the disk as it is read.
+ PERSIST_READ_ONCE
+template<class T>
+class AMI_STREAM {
+private:
+ FILE * fp;
+ //int fd; //descriptor of file
+ AMI_stream_type access_mode;
+ char path[BUFSIZ];
+ persistence per;
+ //0 for streams, positive for substreams
+ unsigned int substream_level;
+ // If this stream is actually a substream, these will be set to
+ // indicate the portion of the file that is part of this stream. If
+ // the stream is the whole file, they will be set to -1. Both are in
+ // T units.
+ off_t logical_bos;
+ off_t logical_eos;
+ //stream buffer passed in the call to setvbuf when file is opened
+ char* buf;
+protected:
+ unsigned int get_block_length();
+public:
+ T read_tmp;
+ // An AMI_stream with default name
+ AMI_STREAM();
+ // An AMI stream based on a specific path name.
+ AMI_STREAM(const char *path_name,
+ // AMI_stream_type st = AMI_READ_WRITE_STREAM);
+ AMI_stream_type st);
+ // A psuedo-constructor for substreams.
+ AMI_err new_substream(AMI_stream_type st, off_t sub_begin, off_t sub_end,
+ AMI_STREAM<T> **sub_stream);
+ // Destructor
+ ~AMI_STREAM(void);
+ // Read and write elements.
+ AMI_err read_item(T **elt);
+ AMI_err write_item(const T &elt);
+ AMI_err read_array(T *data, off_t len);
+ AMI_err write_array(const T *data, off_t len);
+ // Return the number of items in the stream.
+ off_t stream_len(void);
+ // Return the path name of this stream.
+ AMI_err name(char **stream_name);
+ // Move to a specific item in the stream.
+ AMI_err seek(off_t offset);
+ // Query memory usage
+ AMI_err main_memory_usage(size_t *usage,
+ //MM_stream_usage usage_type= MM_STREAM_USAGE_OVERHEAD);
+ MM_stream_usage usage_type);
+ void persist(persistence p);
+ char *sprint();
+template<class T>
+unsigned int AMI_STREAM<T>::get_block_length() {
+ return getpagesize();
+/* creates a random file name, opens the file for reading and writing
+ and and returns a file descriptor */
+int ami_single_temp_name(const std::string& base, char* tmp_path);
+/* given fd=fide descriptor, associates with it a stream aopened in
+ access_mode and returns it */
+FILE* open_stream(int fd, AMI_stream_type st);
+/* open the file whose name is pathname in access mode */
+FILE* open_stream(char* pathname, AMI_stream_type st);
+// An AMI stream with default name.
+template<class T>
+AMI_STREAM<T>::AMI_STREAM() {
+ access_mode = AMI_READ_WRITE_STREAM;
+ int fd = ami_single_temp_name(BASE_NAME, path);
+ fp = open_stream(fd, access_mode);
+ /* a stream is by default buffered with a buffer of size BUFSIZ=1K */
+ buf = new char[STREAM_BUFFER_SIZE];
+ if (setvbuf(fp, buf, _IOFBF, STREAM_BUFFER_SIZE) != 0) {
+ cerr << "setvbuf failed (stream " << path << ")" << endl;
+ exit(1);
+ // By default, all streams are deleted at destruction time.
+ per = PERSIST_DELETE;
+ // Not a substream.
+ substream_level = 0;
+ logical_bos = logical_eos = -1;
+ seek(0);
+ // Register memory usage before returning.
+ //size_t usage;
+ //main_memory_usage(&usage, MM_STREAM_USAGE_CURRENT);
+ //MM_manager.register_allocation(usage);
+// An AMI stream based on a specific path name.
+template<class T>
+AMI_STREAM<T>::AMI_STREAM(const char *path_name,
+ AMI_stream_type st = AMI_READ_WRITE_STREAM) {
+ access_mode = st;
+ strcpy(path, path_name);
+ fp = open_stream(path, st);
+ exit(1);
+ seek(0);
+ //size_t usage;
+template<class T>
+AMI_err AMI_STREAM<T>::new_substream(AMI_stream_type st,
+ off_t sub_begin,
+ off_t sub_end,
+ AMI_STREAM<T> **sub_stream) {
+ //assume this for now
+ assert(st == AMI_READ_STREAM);
+ //check range
+ if (substream_level) {
+ if( (sub_begin >= (logical_eos - logical_bos)) ||
+ (sub_end >= (logical_eos - logical_bos)) ) {
+ return AMI_ERROR_OUT_OF_RANGE;
+ } else {
+ off_t len = stream_len();
+ if (sub_begin > len || sub_end > len) {
+ //reopen the file
+ AMI_STREAM<T> *substr = new AMI_STREAM<T>(path, st);
+ // Set up the beginning and end positions.
+ substr->logical_bos = logical_bos + sub_begin;
+ substr->logical_eos = logical_bos + sub_end + 1;
+ } else {
+ substr->logical_bos = sub_begin;
+ substr->logical_eos = sub_end + 1;
+ // Set the current position.
+ substr->seek(0);
+ //set substream level
+ substr->substream_level = substream_level + 1;
+ //set persistence
+ substr->per = per;
+ //*sub_stream = (AMI_base_stream < T > *)substr;
+ *sub_stream = substr;
+// Return the number of items in the stream.
+template<class T>
+off_t AMI_STREAM<T>::stream_len(void) {
+ fflush(fp);
+ struct stat buf;
+ if (stat(path, &buf) == -1) {
+ perror("AMI_STREAM::stream_len(): fstat failed ");
+ assert(0);
+ exit(1);
+ //fprintf(stderr, "%s: length = %lld\n", path, buf.st_size);
+ return (buf.st_size / sizeof(T));
+// Return the path name of this stream.
+template<class T>
+AMI_err AMI_STREAM<T>::name(char **stream_name) {
+ *stream_name = new char [strlen(path) + 1];
+ strcpy(*stream_name, path);
+// Move to a specific offset within the (sub)stream.
+template<class T>
+AMI_err AMI_STREAM<T>::seek(off_t offset) {
+ off_t seek_offset;
+ //substream
+ if (offset > (unsigned) (logical_eos - logical_bos)) {
+ //offset out of range
+ cerr << "AMI_STREAM::seek bos=" << logical_bos << ", eos=" << logical_eos
+ << ", offset " << offset << " out of range.\n";
+ assert(0);
+ exit(1);
+ } else {
+ //offset in range
+ seek_offset = (logical_bos + offset) * sizeof(T);
+ } else {
+ //not a substream
+ seek_offset = offset * sizeof(T);
+ if (fseek(fp, seek_offset, SEEK_SET) == -1) {
+ cerr << "AMI_STREAM::seek offset=" << seek_offset << "failed.\n";
+ assert(0);
+ exit(1);
+// Query memory usage
+template<class T>
+AMI_err AMI_STREAM<T>::main_memory_usage(size_t *usage,
+ MM_stream_usage usage_type= MM_STREAM_USAGE_OVERHEAD) {
+ switch (usage_type) {
+ case MM_STREAM_USAGE_OVERHEAD:
+ *usage = sizeof (*this);
+ break;
+ case MM_STREAM_USAGE_BUFFER:
+ // *usage = get_block_length();
+ *usage = STREAM_BUFFER_SIZE*sizeof(char);
+ break;
+ case MM_STREAM_USAGE_CURRENT:
+ case MM_STREAM_USAGE_MAXIMUM:
+ // *usage = sizeof (*this) + get_block_length();
+ *usage = sizeof (*this) + STREAM_BUFFER_SIZE*sizeof(char);
+ break;
+template<class T>
+AMI_STREAM<T>::~AMI_STREAM(void) {
+ DEBUG_DELETE cerr << "~AMI_STREAM: " << path << "(" << this << ")\n";
+ delete buf;
+ assert(fp);
+ fclose(fp);
+ // Get rid of the file if not persistent and if not substream.
+ if ((per != PERSIST_PERSISTENT) && (substream_level == 0)) {
+ if (remove(path) == -1) {
+ cerr << "AMI_STREAM: failed to unlink " << path << endl;
+ perror("cannot unlink ");
+ assert(0);
+ exit(1);
+ // Register memory deallocation before returning.
+ //size_t usage;
+ //MM_manager.register_deallocation(usage);
+template<class T>
+AMI_err AMI_STREAM<T>::read_item(T **elt) {
+ assert(fp);
+ //if we go past substream range
+ if ((logical_eos >= 0) && ftell(fp) >= sizeof(T) * logical_eos) {
+ return AMI_ERROR_END_OF_STREAM;
+ } else {
+ if (fread((char *) (&read_tmp), sizeof(T), 1, fp) < 1) {
+ //cerr << "file=" << path << ":";
+ //perror("cannot read!");
+ //assume EOF --should fix this XXX
+ *elt = &read_tmp;
+template<class T>
+AMI_err AMI_STREAM<T>::read_array(T *data, off_t len) {
+ assert(fp);
+ } else {
+ if (fread((void*)data, sizeof(T), len, fp) < len) {
+ cerr << "file=" << path << ":";
+ perror("cannot read!");
+template<class T>
+AMI_err AMI_STREAM<T>::write_item(const T &elt) {
+ assert(fp);
+ } else {
+ if (fwrite((char*)(&elt), sizeof(T), 1,fp) < 1) {
+ cerr << "AMI_STREAM::write_item failed.\n";
+ assert(0);
+ exit(1);
+template<class T>
+AMI_err AMI_STREAM<T>::write_array(const T *data, off_t len) {
+ assert(fp);
+ } else {
+ if (fwrite(data, sizeof(T), len,fp) < len) {
+ assert(0);
+ exit(1);
+template<class T>
+void AMI_STREAM<T>::persist(persistence p) {
+ per = p;
+// sprint()
+// Return a string describing the stream
+// This function gives easy access to the file name, length.
+// It is not reentrant, but this should not be too much of a problem
+// if you are careful.
+template<class T>
+char *AMI_STREAM<T>::sprint() {
+ static char buf[BUFSIZ];
+ sprintf(buf, "[AMI_STREAM %s %ld]", path, (long)stream_len());
+ return buf;
+#endif // _AMI_STREAM_H
Copied: grass/trunk/include/iostream/embuffer.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/embuffer.h)
--- grass/trunk/include/iostream/embuffer.h (rev 0)
+++ grass/trunk/include/iostream/embuffer.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,1311 @@
+#ifndef __EMBUFFER_H
+#define __EMBUFFER_H
+#include <stdio.h>
+#include <math.h>
+#include "ami_config.h" //for SAVE_MEMORY
+#include "mm.h"
+#define MY_LOG_DEBUG_ID(x) //inhibit debug printing
+//#define MY_LOG_DEBUG_ID(x) LOG_DEBUG_ID(x)
+ DEBUGGING FLAGS
+//setting this enables checking that the streams/arrays inserted in
+//buffers are sorted in increasing order
+//#define EMBUF_CHECK_INSERT
+//enable checking that stream name is the same as the one stored in
+//the buffer name[]
+//#define EMBUF_CHECK_NAME
+//enable printing names as they are checked
+//#define EMBUF_CHECK_NAME_PRINT
+//enable printing when streams in a buffer are shifted left to
+//check that names are shifted accordingly
+//#define EMBUF_DELETE_STREAM_PRINT
+//enable printing the name of the stream which is inserted in buff
+//#define EMBUF_PRINT_INSERT
+//enable printing the stream names/sizes in cleanup()
+//#define EMBUF_CLEANUP_PRINT
+//enable printing when get/put_stream is called (for each stream)
+//#define EMBUF_PRINT_GETPUT_STREAM
+//enable printing when get/put_streams is called
+//#define EMBUF_PRINT_GETPUT_STREAMS
+/* encapsulation of the key together with stream_id; used during
+ stream merging to save space;
+template<class KEY>
+class merge_key {
+public:
+ KEY k;
+ unsigned int str_id; //id of the stream where key comes from
+public:
+ merge_key(): str_id(0) {}
+ merge_key(const KEY &x, const unsigned int sid):
+ k(x), str_id(sid) {}
+ ~merge_key() {}
+ void set(const KEY &x, const unsigned int sid) {
+ k = x;
+ str_id = sid;
+ KEY key() const {
+ return k;
+ unsigned int stream_id() const {
+ return str_id;
+ KEY getPriority() const {
+ return k;
+ friend ostream& operator<<(ostream& s, const merge_key<KEY> &x) {
+ return s << "<str_id=" << x.str_id << "> " << x.k << " ";
+ friend int operator < (const merge_key &x,
+ const merge_key &y) {
+ return (x.k < y.k);
+ friend int operator <= (const merge_key &x,
+ return (x.k <= y.k);
+ friend int operator > (const merge_key &x,
+ return (x.k > y.k);
+ friend int operator >= (const merge_key &x,
+ return (x.k >= y.k);
+ friend int operator != (const merge_key &x,
+ return (x.k != y.k);
+ friend int operator == (const merge_key &x,
+ return (x.k == y.k);
+ friend merge_key operator + (const merge_key &x,
+ assert(0);
+ return x;
+ // Key sum = x.k + y.k;
+ // merge_key f(sum, x.str_id);
+ // return f;
+ external_memory buffer
+ Each level-i buffer can store up to <arity>^i * <basesize> items,
+ where tipically <arity> is \theta(m) and <basesize> is \theta(M);
+ therefore log_m{n/m} buffers are needed to store N items, one
+ buffer for each level 1..log_m{n/m}. All buffers must have same
+ values or <arity> and <basesize>.
+ Functionality:
+ A level-i on-disk buffer stores <arity>^i * <basesize> items of
+ data, organized in <arity> streams of <arity>^{i-1} items each;
+ <basesize> is same for all buffers and equal to the size of the
+ level 0 buffer (in memory buffer).
+ Invariant: all the <arity> streams of a level-i buffer are in
+ sorted order; in this way sorting the buffer is done by merging the
+ <arity> streams in linear time.
+ Items are inserted in level i-buffer only a whole stream at a time
+ (<arity>^{i-1}*<basesize> items). When all the <arity> streams of
+ the buffer are full, the buffer is sorted and emptied into a stream
+ of a level (i+1)-buffer.
+ The <arity> streams of a buffer are allocated contigously from left
+ to r ight. The unused streams are NULL; The buffer keeps the index of
+ the last used(non-NULL) stream. When a buffer becomes full and is
+ empty, all its buffers are set to NULL.
+/* T is a type with priority of type K and method getPriority() */
+template<class T, class Key>
+class em_buffer {
+private:
+ //number of streams in a buffer;
+ unsigned int arity;
+ //level of buffer: between 1 and log_arity{n/arity}; (level-0 buffer
+ //has a slightly different behaviour so it is implemented as a
+ //different class <im_buffer>)
+ unsigned short level;
+ //level-i buffer contains m streams of data, each of size
+ //arity^{i-1}*basesize;
+ AMI_STREAM<T>** data;
+ //the buffers can be depleted to fill the internal pq;
+ //keep an array which counts, for each stream, how many elements
+ //have been deleted (implicitely from the begining of stream)
+ long* deleted;
+ //nb of items in each substream; this can be found out by calling
+ //stream_len() on the stream, but it is more costly esp in the case
+ //when streams are on disk and must be moved in and out just to find
+ //stream length; streamsize is set only at stream creation, and the
+ //actual size must substract the number of iteme deleted from the
+ //bos
+ unsigned long* streamsize;
+ //index of the next available(empty) stream (out of the total m
+ //streams in the buffer);
+ unsigned int index;
+ //nb of items in a stream of level_1 buffer
+ unsigned long basesize;
+public:
+ //create a level-i buffer of given basesize;
+ em_buffer(const unsigned short i, const unsigned long bs,
+ const unsigned int ar);
+ //copy constructor;
+ em_buffer(const em_buffer &buf);
+ //free the stream array and the streams pointers
+ ~em_buffer();
+ //return the level of the buffer;
+ unsigned short get_level() const { return level;}
+ //return the ith stream (load stream in memory)
+ AMI_STREAM<T>* get_stream(unsigned int i);
+ //return a pointer to the streams of the buffer (loads streams in
+ //memory)
+ AMI_STREAM<T>** get_streams();
+ //put the ith stream back to disk
+ void put_stream(unsigned int i);
+ //called in pair with get_streams to put all streams back to disk
+ void put_streams();
+ //return a pointer to the array of deletion count for each stream
+ long* get_bos() const { return deleted;}
+ //return the index of the last stream in buffer which contains data;
+ unsigned int laststream() const { return index -1;}
+ //return the index of the next available stream in the buffer
+ unsigned int nextstream() const { return index;}
+ //increment the index of the next available stream in the buffer
+ void incr_nextstream() { ++index;}
+ //return nb of (non-empty) streams in buffer
+ unsigned int get_nbstreams() const { return index;}
+ //return arity
+ unsigned int get_arity() const { return arity;}
+ //return total nb of deleted elements in all active streams of the buffer
+ long total_deleted() const {
+ long tot = 0;
+ for (unsigned int i=0; i< index; i++) {
+ tot += deleted[i];
+ return tot;
+ //mark as deleted one more element from i'th stream
+ void incr_deleted(unsigned int i) {
+ assert(i<index);
+ deleted[i]++;
+ //return the nominal size of a stream (nb of items):
+ //arity^{level-1}*basesize;
+ unsigned long get_stream_maxlen() const {
+ return (unsigned long)pow((double)arity,(double)level-1)*basesize;
+ //return the actual size of stream i; i must be the index of a valid
+ //stream
+ unsigned long get_stream_len(unsigned int i) {
+ //assert(i>= 0 && i<index);
+ return streamsize[i] - deleted[i];
+ //return the total current size of the buffer; account for the
+ //deleted elements;
+ unsigned long get_buf_len() {
+ unsigned long tot = 0;
+ tot += get_stream_len(i);
+ return tot;
+ //return the total maximal capacity of the buffer
+ unsigned long get_buf_maxlen() {
+ return arity * get_stream_maxlen();
+ //return true if buffer is empty (all streams are empty)
+ bool is_empty() {
+ return ((nextstream() == 0) || (get_buf_len() == 0));
+ //return true if buffer is full(all streams are full)
+ bool is_full() const {
+ return (nextstream() == arity);
+ //reset
+ void reset();
+ //clean buffer: in case some streams have been emptied by deletion
+ //delete them and shift streams left;
+ void cleanup();
+ //create and return a stream which contains all elements of all
+ //streams of the buffer in sorted ascending order of their
+ //keys(priorities);
+ AMI_STREAM<T>* sort();
+ // insert an array into the buffer; can only insert one
+ // level-i-full-stream-len nb of items at a time; assume the length
+ // of the array is precisely the streamlen of level-i buffer n =
+ // (pow(arity,level-1)*basesize); assume array is sorted; return the
+ // number of items actually inserted
+ long insert(T* a, long n);
+ // insert a stream into the buffer; assume the length of the stream
+ // is precisely the streamlen of level-i buffer n =
+ // (pow(arity,level-1)*basesize); the <nextstream> pointer of buffer
+ // is set to point to the argument stream; (in this way no stream
+ // copying is done, just one pointer copy). The user should be aware
+ // the the argument stream is 'lost' - that is a stream cannot be
+ // inserted repeatedly into many buffers because this would lead to
+ // several buffers pointing to the same stream.
+ // stream is assumed sorted; bos = how many elements are deleted
+ // from the begining of stream;
+ // return the number of items actually inserted
+ long insert(AMI_STREAM<T>* str,
+ //long bos=0);
+ long bos);
+ //print range of elements in buffer
+ void print_range();
+ //print all elements in buffer
+ void print();
+ //prints the sizes of the streams in the buffer
+ void print_stream_sizes();
+ //print the elements in the buffer
+ friend ostream& operator<<(ostream& s, em_buffer &b) {
+ s << "BUFFER_" << b.level << ": ";
+ if (b.index ==0) {
+ s << "[]";
+ s << "\n";
+ b.get_streams();
+ for (unsigned int i=0; i < b.index; i++) {
+ b.print_stream(s, i);
+ b.put_streams();
+ return s;
+private:
+ // merge the input streams; there are <arity> streams in total;
+ // write output in <outstream>; the input streams are assumed sorted
+ // in increasing order of their keys;
+ AMI_err substream_merge(AMI_STREAM<T>** instreams,
+ AMI_STREAM<T> *outstream);
+ //print to stream the elements in i'th stream
+ void print_stream(ostream& s, unsigned int i);
+#ifdef SAVE_MEMORY
+ //array of names of streams;
+ char** name;
+ //return the designated name for stream i
+ char* get_stream_name(unsigned int i) const;
+ //print all stream names in buffer
+ void print_stream_names();
+ //checks that name[i] is the same as stream name; stream i must be in
+ //memory (by a previous get_stream call, for instance) in order to
+ //find its length
+ void check_name(unsigned int i);
+#endif
+//create a level-i buffer of given basesize;
+template <class T, class Key>
+em_buffer<T,Key>::em_buffer(const unsigned short i, const unsigned long bs,
+ const unsigned int ar) :
+ arity(ar), level(i), basesize(bs) {
+ assert((level>=1) && (basesize >=0));
+ char str[100];
+ sprintf(str, "em_buffer: allocate %d AMI_STREAM*, total %ld\n",
+ arity, (long)(arity*sizeof(AMI_STREAM<T>*)));
+ MEMORY_LOG(str);
+ //allocate STREAM* array
+ //GCC-3.4 does not allow (TYPE)[array]
+ //use TYPE[array]
+ data = new AMI_STREAM<T>*[arity];
+ //allocate deleted array
+ sprintf(str, "em_buffer: allocate deleted array: %ld\n",
+ (long)(arity*sizeof(long)));
+ MEMORY_LOG(str);
+ deleted = new long[arity];
+ //allocate streamsize array
+ sprintf(str, "em_buffer: allocate streamsize array: %ld\n",
+ MEMORY_LOG(str);
+ streamsize = new unsigned long[arity];
+#ifdef SAVE_MEMORY
+ //allocate name array
+ sprintf(str, "em_buffer: allocate name array: %ld\n",
+ (long)(arity*sizeof(char*)));
+ MEMORY_LOG(str);
+ //use TYPE[array]
+ //name = new (char*)[arity];
+ name = new char*[arity];
+ assert(name);
+#endif
+ //assert data
+ if ((!data) || (!deleted) || (!streamsize)) {
+ cerr << "em_buffer: cannot allocate\n";
+ exit(1);
+ //initialize the <arity> streams to NULL, deleted[], streamsize[]
+ //and name[]
+ for (unsigned int i=0; i< arity; i++) {
+ data[i] = NULL;
+ deleted[i] = 0;
+ streamsize[i] = 0;
+#ifdef SAVE_MEMORY
+ name[i] = NULL;
+#endif
+ //set index
+ index = 0;
+#ifdef SAVE_MEMORY
+ //streams_in_memory = false;
+#endif
+//copy constructor;
+em_buffer<T,Key>::em_buffer(const em_buffer &buf):
+ level(buf.level), basesize(buf.basesize),
+ index(buf.index), arity(buf.arity) {
+ assert(0);//should not get called
+ MEMORY_LOG("em_buffer: copy constr start\n");
+ get_streams();
+ assert(data[i]);
+ delete data[i]; //delete old stream if existing
+ data[i] = NULL;
+ //call copy constructor; i'm not sure that it actually duplicates
+ //the stream and copies the data; should that in the BTE
+ //sometimes..
+ data[i] = new AMI_STREAM<T>(*buf.data[i]);
+ deleted[i] = buf.deleted[i];
+ streamsize[i] = buf.streamsize[i];
+#ifdef SAVE_MEMORY
+ assert(name[i]);
+ delete name[i];
+ name[i] = NULL;
+ name[i] = buf.name[i];
+#endif
+ put_streams();
+ MEMORY_LOG("em_buffer: copy constr end\n");
+//free the stream array and the streams pointers
+em_buffer<T,Key>::~em_buffer() {
+ assert(data);
+ //delete the m streams in the buffer
+ get_streams();
+ for (unsigned int i=0; i<index; i++) {
+ assert(data[i]);
+#ifdef SAVE_MEMORY
+ check_name(i);
+ delete name[i];
+#endif
+ delete data[i];
+ data[i] = NULL;
+ delete [] data;
+ delete [] deleted;
+ delete [] streamsize;
+#ifdef SAVE_MEMORY
+ delete [] name;
+#endif
+#ifdef SAVE_MEMORY
+//checks that name[i] is the same as stream name; stream i must be in
+//memory (by a previous get_stream call, for instance) in order to
+//find its length
+void em_buffer<T,Key>::check_name(unsigned int i) {
+#ifdef EMBUF_CHECK_NAME
+ assert(i>=0 && i < index);
+ assert(data[i]);
+ char* fooname;
+ data[i]->name(&fooname);//name() allocates the string
+#ifdef EMBUF_CHECK_NAME_PRINT
+ cout << "::check_name: checking stream [" << level << "," << i << "] name:"
+ << fooname << endl;
+ cout.flush();
+#endif
+ if (strcmp(name[i], fooname) != 0) {
+ cerr << "name[" << i << "]=" << name[i]
+ << ", streamname=" << fooname << endl;
+ assert(strcmp(fooname, name[i]) == 0);
+ delete fooname;
+#endif
+#endif
+//if SAVE_MEMORY flag is set, load the stream in memory; return the
+//ith stream
+AMI_STREAM<T>* em_buffer<T,Key>::get_stream(unsigned int i) {
+#ifdef SAVE_MEMORY
+ MY_LOG_DEBUG_ID("em_buffer::get_stream");
+ MY_LOG_DEBUG_ID(i);
+ if (data[i] == NULL) {
+ //stream is on disk, load it in memory
+ assert(name[i]);
+ MY_LOG_DEBUG_ID("load stream in memory");
+ MY_LOG_DEBUG_ID(name[i]);
+#ifdef EMBUF_PRINT_GETPUT_STREAM
+ cout << "get_stream:: name[" << i << "]=" << name[i] << " from disk\n";
+ cout.flush();
+#endif
+ //assert that file exists
+ FILE* fp;
+ if ((fp = fopen(name[i],"rb")) == NULL) {
+ cerr << "get_stream: checking that stream " << name[i] << "exists\n";
+ perror(name[i]);
+ assert(0);
+ exit(1);
+ fclose(fp);
+ //create an AMI_STREAM from file
+ data[i] = new AMI_STREAM<T>(name[i]);
+ assert(data[i]);
+ } else {
+ //if data[i] not NULL, stream must be already in memory
+ MY_LOG_DEBUG_ID("stream not NULL");
+ MY_LOG_DEBUG_ID(data[i]->sprint());
+#endif
+ //NOW STREAM IS IN MEMORY
+ //some assertion checks
+ assert(data[i]);
+ assert(data[i]->stream_len() == streamsize[i]);
+#ifdef SAVE_MEMORY
+ check_name(i);
+#endif
+ return data[i];
+//if SAVE_MEMORY flag is set, put the i'th stream back on disk
+void em_buffer<T,Key>::put_stream(unsigned int i) {
+#ifdef SAVE_MEMORY
+ MY_LOG_DEBUG_ID("em_buffer::put_stream");
+ if (data[i] != NULL) {
+ //stream is in memory, put it on disk
+ MY_LOG_DEBUG_ID("stream put to disk");
+ check_name(i);
+ cout << "put_stream:: name[" << i << "]=" << name[i] << " to disk\n";
+ cout.flush();
+#endif
+ //make stream persistent and delete it
+ data[i]->persist(PERSIST_PERSISTENT);
+ delete data[i];
+ data[i] = NULL;
+ } else {
+ //data[i] is NULL, so stream must be already put on disk
+ MY_LOG_DEBUG_ID("stream is NULL");
+#endif
+//return a pointer to the streams of the buffer
+AMI_STREAM<T>** em_buffer<T,Key>::get_streams() {
+#ifdef SAVE_MEMORY
+ MY_LOG_DEBUG_ID("em_buffer::get_streams: reading streams from disk");
+#ifdef EMBUF_PRINT_GETPUT_STREAMS
+ cout << "em_buffer::get_streams (buffer " << level <<")";
+ cout << ": index = " << index << "(arity=" << arity << ")\n";
+ cout.flush();
+#endif
+ get_stream(i);
+ assert(data[i]);
+#endif
+ return data;
+//called in pair with load_streams to store streams on disk
+//and release the memory
+void em_buffer<T,Key>::put_streams() {
+#ifdef SAVE_MEMORY
+ MY_LOG_DEBUG_ID("em_buffer::put_streams: writing streams on disk");
+ cout << "em_buffer::put_streams (buffer " << level <<")";
+ cout.flush();
+#endif
+ put_stream(i);
+ assert(data[i] == NULL);
+#endif
+#ifdef SAVE_MEMORY
+//return the name of the ith stream
+char* em_buffer<T,Key>::get_stream_name(unsigned int i) const {
+ assert(i>=0 && i<index);
+ assert(name[i]);
+ return name[i];
+#endif
+#ifdef SAVE_MEMORY
+void em_buffer<T,Key>::print_stream_names() {
+ unsigned int i;
+ for (i=0; i<index; i++) {
+ assert(name[i]);
+ cout << "stream " << i << ": " << name[i] << endl;
+ cout.flush();
+#endif
+//clean buffer in case some streams have been emptied by deletion
+void em_buffer<T,Key>::cleanup() {
+ MY_LOG_DEBUG_ID("em_buffer::cleanup()");
+#ifdef EMBUF_CLEANUP_PRINT
+#ifdef SAVE_MEMORY
+ if (index>0) {
+ cout << "before cleanup:\n";
+ print_stream_names();
+ print_stream_sizes();
+ cout.flush();
+#endif
+#endif
+ //load all streams in memory
+ get_streams();
+ //count streams of size=0
+ unsigned int i, empty=0;
+ if (get_stream_len(i) == 0) {
+ //printing..
+#ifdef EMBUF_DELETE_STREAM_PRINT
+ cout<<"deleting stream [" << level << "," << i <<"]:" ;
+#ifdef SAVE_MEMORY
+ cout << name[i];
+#endif
+ cout << endl;
+ cout.flush();
+#endif
+#ifdef SAVE_MEMORY
+ //stream is empty ==> delete its name
+ delete name[i];
+ name[i] = NULL;
+#endif
+ //stream is empty ==> reset data
+ assert(data[i]);
+ //data[i]->persist(PERSIST_DELETE); //this is done automatically..
+ delete data[i];
+ data[i] = NULL;
+ deleted[i] = 0;
+ empty++;
+ //streams are in memory; all streams which are NULL must have been
+ //deleted
+ //shift streams to the left in case holes were introduced
+ unsigned int j=0;
+ if (empty) {
+ cout << "em_buffer::cleanup: shifting streams\n"; cout.flush();
+#endif
+ //if i'th stream is not empty, shift it left if necessary
+ if (data[i]) {
+ if (i!=j) {
+ //set j'th stream to point to i'th stream
+ //cout << j << " set to " << i << endl; cout.flush();
+ data[j] = data[i];
+ deleted[j] = deleted[i];
+ streamsize[j] = streamsize[i];
+ //set i'th stream to point to NULL
+ data[i] = NULL;
+ deleted[i] = 0;
+#ifdef SAVE_MEMORY
+ //fix the names
+ delete name[j];
+ name[j] = name[i];
+ name[i] = NULL;
+ check_name(j);
+#endif
+ } else {
+ //cout << i << " left the same" << endl;
+ j++;
+ } //if data[i] != NULL
+ }//for i
+ //set the index
+ assert(index == j + empty);
+ index = j;
+ cout << "em_buffer::cleanup: index set to " << index << endl;
+ cout.flush();
+#endif
+ } //if empty
+ //put streams back to disk
+ put_streams();
+#ifdef SAVE_MEMORY
+ if (index >0) {
+ cout << "after cleanup:\n";
+ cout.flush();
+#endif
+#endif
+//delete all streams
+void em_buffer<T,Key>::reset() {
+ get_streams();
+ //make streams not-persistent and delete them
+ assert(data[i]);
+ assert(streamsize[i] == data[i]->stream_len());
+#ifdef SAVE_MEMORY
+ check_name(i);
+ delete name[i];
+ name[i] = NULL;
+#endif
+ data[i]->persist(PERSIST_DELETE);
+ delete data[i];
+ data[i] = NULL;
+ deleted[i] = 0;
+ index = 0;
+//create and return a stream which contains all elements of
+//all streams of the buffer in sorted ascending order of
+//their keys (priorities);
+AMI_STREAM<T>* em_buffer<T,Key>::sort() {
+ //create stream
+ MEMORY_LOG("em_buffer::sort: allocate new AMI_STREAM\n");
+ AMI_STREAM<T>* sorted_stream = new AMI_STREAM<T>();
+ assert(sorted_stream);
+ //merge the streams into sorted stream
+ AMI_err aerr;
+ //Key dummykey;
+ //must modify this to seek after deleted[i] elements!!!!!!!!!!!!!
+ // aerr = MIAMI_single_merge_Key(data, arity, sorted_stream,
+ // 0, dummykey);
+ //could not use AMI_merge so i had to write my own..
+ get_streams();
+ aerr = substream_merge(data, arity, sorted_stream);
+ assert(aerr == AMI_ERROR_NO_ERROR);
+ put_streams();
+ return sorted_stream;
+/* merge the input streams; there are <arity> streams in total; write
+ output in <outstream>;
+ the input streams are assumed sorted in increasing order of their
+ keys;
+ assumes the instreams are in memory (no need for get_streams()) */
+AMI_err em_buffer<T,Key>::substream_merge(AMI_STREAM<T>** instreams,
+ AMI_STREAM<T> *outstream) {
+ unsigned int i, j;
+ assert(instreams);
+ assert(outstream);
+ for (i = 0; i < arity ; i++ ) {
+ assert(instreams[i]);
+#ifdef SAVE_MEMORY
+ check_name(i);
+#endif
+ T* in_objects[arity]; //pointers to current leading elements of streams
+ AMI_err ami_err;
+ char str[200];
+ sprintf(str, "em_buffer::substream_merge: allocate keys array, total %ldB\n",
+ (long)((long)arity * sizeof(merge_key<Key>)));
+ MEMORY_LOG(str);
+ //keys array is initialized with smallest key from each stream (only
+ //non-null keys must be included)
+ merge_key<Key>* keys;
+ //merge_key<Key>* keys = new (merge_key<Key>)[arity];
+ typedef merge_key<Key> footype;
+ keys = new footype[arity];
+ assert(keys);
+ //count number of non-empty streams
+ j = 0;
+ //rewind and read the first item from every stream initializing
+ //in_objects and keys
+ //rewind stream
+ if ((ami_err = instreams[i]->seek(deleted[i])) != AMI_ERROR_NO_ERROR) {
+ return ami_err;
+ //read first item from stream
+ if ((ami_err = instreams[i]->read_item(&(in_objects[i]))) !=
+ AMI_ERROR_NO_ERROR) {
+ if (ami_err == AMI_ERROR_END_OF_STREAM) {
+ in_objects[i] = NULL;
+ } else {
+ return ami_err;
+ } else {
+ //include this key in the array of keys
+ Key k = in_objects[i]->getPriority();
+ keys[j].set(k, i);
+ j++;
+ unsigned int NonEmptyRuns = j;
+ //build heap from the array of keys
+ pqheap_t1<merge_key<Key> > mergeheap(keys, NonEmptyRuns);
+ //repeatedly extract_min from heap, write it to output stream and
+ //insert next element from same stream
+ merge_key<Key> minelt;
+ //rewind output buffer
+ ami_err = outstream->seek(0);
+ assert(ami_err == AMI_ERROR_NO_ERROR);
+ while (!mergeheap.empty()) {
+ //find min key and id of the stream from whereit comes
+ mergeheap.min(minelt);
+ i = minelt.stream_id();
+ //write min item to output stream
+ if ((ami_err = outstream->write_item(*in_objects[i]))
+ != AMI_ERROR_NO_ERROR) {
+ return ami_err;
+ //read next item from same input stream
+ if (ami_err != AMI_ERROR_END_OF_STREAM) {
+ return ami_err;
+ //extract the min from the heap and insert next key from same stream
+ mergeheap.delete_min();
+ } else {
+ merge_key<Key> nextit(k, i);
+ mergeheap.delete_min_and_insert(nextit);
+ } //while
+ //delete [] keys;
+ //!!! KEYS BELONGS NOW TO MERGEHEAP, AND WILL BE DELETED BY THE
+ //DESTRUCTOR OF MERGEHEAP (CALLED AUUTOMATICALLY ON FUNCTION EXIT) IF
+ //I DELETE KEYS EXPLICITELY, THEY WILL BE DELETED AGAIN BY DESTRUCTOR,
+ //AND EVERYTHING SCREWS UP..
+// insert an array into the buffer; assume array is sorted; return the
+// number of items actually inserted; if SAVE_MEMORY FLAG is on, put
+// stream on disk and release its memory
+long em_buffer<T,Key>::insert(T* a, long n) {
+ assert(a);
+ if (is_full()) {
+ cout << "em_buffer::insert: buffer full\n";
+ return 0;
+ //can only insert one full stream at a time
+ //relaxed..
+ //assert(n == get_stream_maxlen());
+ //create the stream
+ MEMORY_LOG("em_buffer::insert(from array): allocate AMI_STREAM\n");
+ AMI_STREAM<T>* str = new AMI_STREAM<T>();
+ assert(str);
+ //write the array to stream
+ AMI_err ae;
+ for (long i=0; i< n; i++) {
+ ae = str->write_item(a[i]);
+ assert(ae == AMI_ERROR_NO_ERROR);
+ assert(n == str->stream_len());
+ //insert the stream in the buffer
+ return insert(str);
+/* insert a stream into the buffer; the next free entry in the buffer
+ is set to point to the stream; if SAVE_MEMORY flag is on, the
+ stream is put to disk;
+ the <nextstream> pointer of buffer is set to point to the argument
+ stream; (in this way no stream copying is done, just one pointer
+ copy). The user should be aware the the argument stream is 'lost' -
+ that is a stream cannot be inserted repeatedly into many buffers
+ because this would lead to several buffers pointing to the same
+ stream.
+ stream is assume stream is sorted; bos = how many elements must be
+ skipped (were deleted) from the begining fo stream;
+ return the number of items actually inserted */
+long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
+ assert(str);
+ if (is_full()) {
+ return 0;
+ //can only insert one level-i-full-stream at a time;
+ //relaxed..can specify bos;
+ //not only that, but the length of the stream can be smaller
+ //than nominal length, because a stream is normally obtained by
+ //merging streams which can be shorter;
+ //assert(str->stream_len() == get_stream_len() - bos);
+#ifdef EMBUF_CHECK_INSERT
+ //check that stream is sorted
+ cout << "CHECK_INSERT: checking stream is sorted\n";
+ AMI_err ae;
+ str->seek(0);
+ T *crt=NULL, *prev=NULL;
+ while (str->read_item(&crt)) {
+ if (prev) assert(*prev <= *crt);
+#endif
+ //nextstream must be empty
+ assert(str);
+ assert(data[nextstream()] == NULL);
+ assert(deleted[nextstream()] == 0);
+ assert(streamsize[nextstream()] == 0);
+#ifdef SAVE_MEMORY
+ assert(name[nextstream()] == NULL);
+#endif
+ //set next entry i the buffer to point to this stream
+ data[nextstream()] = str;
+ deleted[nextstream()] = bos;
+ streamsize[nextstream()] = str->stream_len();
+#ifdef SAVE_MEMORY
+ //set next name entry in buffer to point to this stream's name
+ char* s;
+ str->name(&s); //name() allocates the string
+ name[nextstream()] = s;
+ //put stream on disk and release its memory
+ delete str; //stream should be persistent; just delete it
+ data[nextstream()] = NULL;
+#ifdef EMBUF_PRINT_INSERT
+ cout << "insert stream " << s << " at buf [" << level
+ << "," << nextstream() << "]" << endl;
+#endif
+#endif
+ //increment the index of next available stream in buffer
+ incr_nextstream();
+#endif
+#ifdef SAVE_MEMORY
+ MY_LOG_DEBUG_ID("em_buffer::insert(): inserted stream ");
+ MY_LOG_DEBUG_ID(name[nextstream()-1]);
+#endif
+ //return nb of items inserted
+ return get_stream_len(nextstream()-1);
+//print the elements of the i'th stream of the buffer to a stream;
+//assumes stream is in memory;
+void em_buffer<T,Key>::print_stream(ostream& s, unsigned int i) {
+ assert(data[i]);
+ assert((i>=0) && (i<index));
+ AMI_err ae;
+ T* x;
+ s << "STREAM " << i << ": [";
+ ae = data[i]->seek(deleted[i]);
+ for (long j = 0; j < get_stream_len(i); j++) {
+ ae = data[i]->read_item(&x);
+ s << *x << ",";
+ s << "]\n";
+//print elements range in buffer (read first and last element in each
+//substream and find global min and max)
+void em_buffer<T,Key>::print_range() {
+ T *min, *max;
+ AMI_err ae;
+ get_streams();
+ cout << "[";
+ //read min element in substream i
+ ae = data[i]->read_item(&min);
+ cout << min->getPriority() << "..";
+ //read max element in substream i
+ ae = data[i]->seek(streamsize[i] - 1);
+ ae = data[i]->read_item(&max);
+ cout << max->getPriority()
+ << " (sz=" << get_stream_len(i) << ")] ";
+ for (unsigned int i=index; i< arity; i++) {
+ cout << "[] ";
+ put_streams();
+//print all elements in buffer
+void em_buffer<T,Key>::print() {
+ T *x;
+ AMI_err ae;
+ get_streams();
+ cout << " [";
+ for (unsigned long j=0; j<get_stream_len(i); j++) {
+ cout << x->getPriority() << ",";
+ cout << "]" << endl;
+ cout << "[] ";
+ put_streams();
+//print the sizes of the substreams in the buffer
+void em_buffer<T,Key>::print_stream_sizes() {
+ cout << "(streams=" << index << ") sizes=[";
+ cout << get_stream_len(i) << ",";
+ cout.flush();
+#endif
Copied: grass/trunk/include/iostream/empq.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/empq.h)
--- grass/trunk/include/iostream/empq.h (rev 0)
+++ grass/trunk/include/iostream/empq.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,294 @@
+#ifndef __EMPQ_H
+#define __EMPQ_H
+#include <stdio.h>
+#include "mm.h"
+#include "mm_utils.h" //for MEMORY_LOG, getAvailableMemory
+#include "imbuffer.h"
+#include "embuffer.h"
+#include "minmaxheap.h"
+template<class T,class Key> class ExtendedEltMergeType;
+#define ExtendedMergeStream AMI_STREAM<ExtendedEltMergeType<T,Key> >
+ DEBUGGING FLAGS
+//enables printing messages when buffers are emptied
+//#define EMPQ_EMPTY_BUF_PRINT
+//enables printing when pq gets filled from buffers
+//#define EMPQ_PQ_FILL_PRINT
+//enables priting inserts
+//#define EMPQ_PRINT_INSERT
+//enables printing deletes
+//#define EMPQ_PRINT_EXTRACTALL
+//enables printing the empq on insert/extract_all_min
+//#define EMPQ_PRINT_EMPQ
+//enable priting the size of the EMPQ and nb of active streams
+//on fillpq() amd on empty_buff_0
+//#define EMPQ_PRINT_SIZE
+//enable printing 'fill pq from B0' in extract_min()
+//#define EMPQ_PRINT_FILLPQ_FROM_BUFF0
+//enable expensive size asserts
+//#define EMPQ_ASSERT_EXPENSIVE
+/* external memory priority queue
+ Functionality:
+ Keep a pqueue PQ of size \theta(M) in memory. Keep a buffer B0 of
+ size \theta(M) in memory. keep an array of external-memory
+ buffers, one for each level 1..log_m{n/m} (where N is the maximum
+ number of items in pqueue at any time).
+ invariants:
+ 1. PQ contains the smallest items in the structure.
+ 2. each stream of any external memory buffers is sorted in
+ increasing order.
+ insert(x): if (x < maximum_item(PQ) exchange x with
+ maximum_item(PQ); if buffer B0 is full, empty it; insert x in B0;
+ extract_min():
+ analysis:
+ 1. inserts: once the buffer B0 is empty, the next sizeof(B0)
+ inserts are free; one insert can cause many I/Os if cascading
+ emptying of external buffers Bi occurs. Emptying level-i buffer
+ costs <arity>^i*sizeof(B0)/B I/Os and occurs every
+ N/<arity>^i*sizeof(B0) inserts (or less, if deletes too). It can be
+ proved that the amortized time of 1 insert is 1/B*maxnb_buffers.
+T is assumed to be a class for which getPriority() and getValue()
+are implemented; for simplicity it is assumed that the comparison
+operators have been overloaded on T such that
+x < y <==> x.getPriority() < y.getPriority()
+class em_pqueue {
+private:
+ //in memory priority queue
+ MinMaxHeap<T> *pq;
+ //pqueue size
+ unsigned long pqsize;
+ //in-memory buffer
+ im_buffer<T> *buff_0;
+ //in-memory buffer size
+ unsigned long bufsize;
+ //external memory buffers
+ em_buffer<T,Key>** buff;
+ /* number of external memory buffers statically allocated in the
+ beginning; since the number of buffers needed is \log_m{n/m}, we
+ cannot know it in advance; estimate it roughly and then reallocate
+ it dynamically on request;
+ TO DO: dynamic reallocation with a bigger nb of external buffer
+ if structure becomes full */
+ unsigned short max_nbuf;
+ //index of next external buffer entry available for use (i.e. is NULL)
+ unsigned short crt_buf;
+ //external buffer arity
+ unsigned int buf_arity;
+public:
+ //create an em_pqueue of specified size
+ em_pqueue(long pq_sz, long buf_sz, unsigned short nb_buf,
+ unsigned int buf_ar);
+ //create an em_pqueue capable to store <= N elements
+ em_pqueue();
+ em_pqueue(long N) { em_pqueue(); }; // N not used
+#ifdef SAVE_MEMORY
+ // create an empq, initialize its pq with im and insert amis in
+ // buff[0]; im should not be used/deleted after that outside empq
+ em_pqueue(MinMaxHeap<T> *im, AMI_STREAM<T> *amis);
+#endif
+ em_pqueue(const em_pqueue &ep);
+ //clean up
+ ~em_pqueue();
+ //return the nb of elements in the structure
+ unsigned long size();
+ //return true if empty
+ bool is_empty();
+ //return true if full
+ bool is_full() {
+ cout << "em_pqueue::is_full(): sorry not implemented\n";
+ exit(1);
+ //return the element with minimum priority in the structure
+ bool min(T& elt);
+ //delete the element with minimum priority in the structure;
+ //return false if pq is empty
+ bool extract_min(T& elt);
+ //extract all elts with min key, add them and return their sum
+ bool extract_all_min(T& elt);
+ //insert an element; return false if insertion fails
+ bool insert(const T& elt);
+ //return maximum capacity of i-th external buffer
+ long maxlen(unsigned short i);
+ //return maximum capacity of em_pqueue
+ long maxlen();
+ //print structure
+ void print();
+ //print the detailed size of empq (pq, buf_0, buff[i])
+ void print_size();
+ friend ostream& operator<<(ostream& s, const em_pqueue &empq) {
+ s << "EM_PQ: pq size=" << empq.pqsize
+ << ", buff_0 size=" << empq.bufsize
+ << ", ext_bufs=" << empq.crt_buf
+ << "(max " << empq.max_nbuf << ")\n";
+ s << "IN_MEMORY PQ: \n" << *(empq.pq) << "\n";
+ s << "IN_MEMORY BUFFER: \n" << *(empq.buff_0) << "\n";
+ for (unsigned short i=0; i < empq.crt_buf; i++) {
+ //s << "EM_BUFFER " << i << ":\n" ;
+ s << *(empq.buff[i]);
+ return s;
+protected:
+ //return the nb of active streams in the buffer
+ int active_streams() {
+ int totstr = 0;
+ for (unsigned short i = 0; i< crt_buf; i++) {
+ totstr+= buff[i]->get_nbstreams();
+ return totstr;
+ //called when buff_0 is full to empty it on external level_1 buffer;
+ //can produce cascading emptying
+ bool empty_buff_0();
+ //sort and empty buffer i into buffer (i+1) recursively;
+ //called recursively by empty_buff_0() to empty subsequent buffers
+ //i must be a valid (i<crt_buf) full buffer
+ void empty_buff(unsigned short i);
+ /* merge the first <K> elements of the streams of input buffer,
+ starting at position <buf.deleted[i]> in each stream; there are
+ <buf.arity> streams in total; write output in <outstream>; the
+ items written in outstream are of type <merge_output_type> which
+ extends T with the stream nb and buffer nb the item comes from;
+ this information is needed later to distribute items back; do not
+ delete the K merged elements from the input streams; <bufid> is the
+ id of the buffer whose streams are being merged;
+ the input streams are assumed sorted in increasing order of keys; */
+ AMI_err merge_buffer(em_buffer<T,Key> *buf,
+ ExtendedMergeStream *outstr, long K);
+ /* merge the first <K> elements of the input streams; there are
+ <arity> streams in total; write output in <outstream>;
+ keys; */
+ AMI_err merge_streams(ExtendedMergeStream** instr,
+ unsigned short arity,
+ //deletes one element from <buffer, stream>
+ void delete_str_elt(unsigned short buf_id,
+ unsigned int stream_id);
+ /* copy the minstream in the internal pqueue while merging with
+ buff_0; the smallest <pqsize> elements between minstream and
+ buff_0 will be inserted in internal pqueue; also, the elements
+ from minstram which are inserted in pqueue must be marked as
+ deleted in the source streams; */
+ void merge_bufs2pq(ExtendedMergeStream *minstream);
+ //clean buffers in case some streams have been emptied
+ void cleanup();
+ //called when pq must be filled from external buffers
+ bool fillpq();
+ //print the nb of elements in each stream
+#endif
Copied: grass/trunk/include/iostream/empq_adaptive.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/empq_adaptive.h)
--- grass/trunk/include/iostream/empq_adaptive.h (rev 0)
+++ grass/trunk/include/iostream/empq_adaptive.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,82 @@
+#ifndef __EMPQ_ADAPTIVE_H
+#define __EMPQ_ADAPTIVE_H
+#include "empq.h"
+#define EMPQAD_DEBUG if(0)
+enum regim_type {
+ INMEM = 0,
+ EXTMEM,
+ EXTMEM_DEBUG
+class EMPQueueAdaptive {
+private:
+ //dictates if the structure works in the internal/external memory regim;
+ regim_type regim;
+ MinMaxHeap<T> *im;
+ em_pqueue<T,Key> *em;
+ UnboundedMinMaxHeap<T> *dim; // debug, internal memory pq
+public:
+ /* start in INMEM regim by allocating im of size precisely twice the
+ size of the (pqueue within) the em_pqueue; */
+ EMPQueueAdaptive(long N) : EMPQueueAdaptive() {};
+ EMPQueueAdaptive();
+ ~EMPQueueAdaptive();
+ void makeExternal();
+ void makeExternalDebug();
+ long maxlen() const; //return the maximum nb of elts that can fit
+ bool is_empty() const; //return true if empty
+ bool is_full() const; //return true if full
+ bool min(T& elt); //return the element with min priority XXX
+ //extract all elts with min key, add them and return their sum XXX
+ /* insert an element; if regim == INMEM, try insert it in im, and if
+ it is full, extract_max pqsize/2 elements of im into a stream,
+ switch to EXTMEM and insert the stream into em; if regim is
+ EXTMEM, insert in em; */
+ long size() const; //return the nb of elements in the structure
+ void verify();
+#endif
Copied: grass/trunk/include/iostream/empq_adaptive_impl.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/empq_adaptive_impl.h)
--- grass/trunk/include/iostream/empq_adaptive_impl.h (rev 0)
+++ grass/trunk/include/iostream/empq_adaptive_impl.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,431 @@
+#ifndef __EMPQ_ADAPTIVE_IMPL_H
+#define __EMPQ_ADAPTIVE_IMPL_H
+#include <stdio.h>
+#include "mm.h"
+#include "empq_adaptive.h"
+//defined in "empqAdaptive.H"
+//#define EMPQAD_DEBUG if(0)
+//allocate an internal pqueue of size precisely twice
+//the size of the pqueue within the em_pqueue;
+EMPQueueAdaptive<T,Key>::EMPQueueAdaptive() {
+ regim = INMEM;
+ EMPQAD_DEBUG cout << "EMPQUEUEADAPTIVE: starting in-memory pqueue"
+ << endl;
+ //set the size precisely as in empq constructor since we cannot
+ //really call the em__pqueue constructor, because we don't want
+ //the space allocated; we just want the sizes;
+ AMI_err ae;
+ size_t mm_avail = getAvailableMemory();
+ EMPQAD_DEBUG cout << "EMPQUEUEADAPTIVE: available memory: "
+ << ( (float)mm_avail/ (1<< 20)) << "MB" << endl;
+ /* same calculations as empq constructor in order to estimate
+ overhead memory; this is because we want to allocate a pqueue of
+ size exactly double the size of the pqueue inside the empq;
+ switching from this pqueue to empq when the memory fills up will
+ be simple */
+ //AMI_STREAM memory usage
+ size_t sz_stream;
+ AMI_STREAM<T> dummy;
+ if ((ae = dummy.main_memory_usage(&sz_stream,
+ MM_STREAM_USAGE_MAXIMUM)) !=
+ cerr << "EMPQueueAdaptive constr: failing to get stream_usage\n";
+ exit(1);
+ //account for temporary memory usage
+ unsigned short max_nbuf = 2;
+ unsigned int buf_arity = mm_avail/(2 * sz_stream);
+ unsigned long mm_overhead = buf_arity*sizeof(merge_key<Key>) +
+ max_nbuf * sizeof(em_buffer<T,Key>) +
+ 2*sz_stream + max_nbuf*sz_stream;
+ mm_overhead *= 8; //overestimate..this should be fixed with
+ //a precise accounting of the extra memory required
+ EMPQAD_DEBUG cout << "EMPQUEUEADAPTIVE: memory overhead set to "
+ << ((float)mm_overhead / (1 << 20)) << "MB" << endl;
+ if (mm_overhead > mm_avail) {
+ cerr << "overhead bigger than available memory ("<< mm_avail << "); "
+ << "increase -m and try again\n";
+ exit(1);
+ mm_avail -= mm_overhead;
+ long pqsize = mm_avail/sizeof(T);
+ EMPQAD_DEBUG cout << "EMPQUEUEADAPTIVE: pqsize set to " << pqsize << endl;
+ //initialize in memory pqueue and set em to NULL
+ im = new MinMaxHeap<T>(pqsize);
+ assert(im);
+ em = NULL;
+EMPQueueAdaptive<T,Key>::~EMPQueueAdaptive() {
+ switch(regim) {
+ case INMEM:
+ delete im;
+ break;
+ case EXTMEM:
+ delete em;
+ break;
+ case EXTMEM_DEBUG:
+ delete dim;
+ delete em;
+ break;
+//return the maximum nb of elts that can fit
+long
+EMPQueueAdaptive<T,Key>::maxlen() const {
+ long m;
+ switch(regim) {
+ case INMEM:
+ assert(im);
+ m = im->get_maxsize();
+ break;
+ case EXTMEM:
+ assert(em);
+ m = em->maxlen();
+ break;
+ m = em->maxlen();
+ break;
+ return m;
+//return true if empty
+bool
+EMPQueueAdaptive<T,Key>::is_empty() const {
+ bool v = false;
+ switch(regim) {
+ case INMEM:
+ assert(im);
+ v = im->empty();
+ break;
+ case EXTMEM:
+ assert(em);
+ v = em->is_empty();
+ break;
+ assert(dim->empty() == em->is_empty());
+ break;
+ return v;
+//return true if full
+bool
+EMPQueueAdaptive<T,Key>::is_full() const {
+ cerr << "EMPQueueAdaptive::is_full(): sorry not implemented\n";
+ assert(0);
+ exit(1);
+//return the element with minimum priority in the structure
+bool
+EMPQueueAdaptive<T,Key>::min(T& elt) {
+ bool v=false, v1;
+ T tmp;
+ switch(regim) {
+ case INMEM:
+ assert(im);
+ v = im->min(elt);
+ break;
+ case EXTMEM:
+ assert(em);
+ v = em->min(elt);
+ break;
+ v1 = dim->min(tmp);
+ v = em->min(elt);
+ //dim->verify();
+ if(!(tmp==elt)) {
+ cerr << "------------------------------" << endl;
+ cerr << dim << endl;
+ em->print();
+ cerr << "tmp=" << tmp << endl;
+ cerr << "elt=" << elt << endl;
+ dim->destructiveVerify();
+ assert(v == v1);
+ assert(tmp == elt);
+ break;
+ return v;
+void
+EMPQueueAdaptive<T,Key>::verify() {
+ switch(regim) {
+ case INMEM:
+ im->verify();
+ break;
+ case EXTMEM:
+ break;
+ dim->verify();
+ break;
+//extract all elts with min key, add them and return their sum
+bool
+EMPQueueAdaptive<T,Key>::extract_all_min(T& elt) {
+ bool v=false, v1;
+ T tmp;
+ switch(regim) {
+ case INMEM:
+ assert(im);
+ v = im->extract_all_min(elt);
+ break;
+ case EXTMEM:
+ assert(em);
+ v = em->extract_all_min(elt);
+ break;
+ v1 = dim->extract_all_min(tmp);
+ assert(dim->BasicMinMaxHeap<T>::size() == em->size());
+ assert(v == v1);
+ break;
+ return v;
+//return the nb of elements in the structure
+long
+EMPQueueAdaptive<T,Key>::size() const {
+ long v=0, v1;
+ switch(regim) {
+ case INMEM:
+ assert(im);
+ v = im->size();
+ break;
+ case EXTMEM:
+ assert(em);
+ v = em->size();
+ break;
+ v1 = dim->BasicMinMaxHeap<T>::size();
+ v = em->size();
+ assert(v == v1);
+ break;
+ return v;
+bool
+EMPQueueAdaptive<T,Key>::extract_min(T& elt) {
+ bool v=false, v1;
+ T tmp;
+ switch(regim) {
+ case INMEM:
+ assert(im);
+ v = im->extract_min(elt);
+ break;
+ case EXTMEM:
+ assert(em);
+ v = em->extract_min(elt);
+ break;
+ v1 = dim->extract_min(tmp);
+ assert(v == v1);
+ break;
+ return v;
+bool
+EMPQueueAdaptive<T,Key>::insert(const T& elt) {
+ bool v=false;
+ switch(regim) {
+ case INMEM:
+ if (!im->full()) {
+ im->insert(elt);
+ v = true;
+ } else {
+ makeExternal();
+ v = em->insert(elt); //insert the element
+ break;
+ case EXTMEM:
+ break;
+ dim->insert(elt);
+ break;
+ return v;
+void
+EMPQueueAdaptive<T,Key>::makeExternalDebug() {
+ assert(size() == 0);
+ switch(regim) {
+ case INMEM:
+ makeExternal();
+ break;
+ case EXTMEM:
+ break;
+ assert(0);
+ break;
+ dim = new UnboundedMinMaxHeap<T>();
+ regim = EXTMEM_DEBUG;
+template<class T>
+class baseCmpType {
+public:
+ static int compare(const T& x, const T& y) {
+ return (x < y ? -1 : (x > y ? 1 : 0));
+/* switch over to using an external priority queue */
+void
+EMPQueueAdaptive<T,Key>::makeExternal() {
+ AMI_err ae;
+#ifndef NDEBUG
+ long sizeCheck;
+ sizeCheck = size();
+#endif
+ assert(regim == INMEM);
+ regim = EXTMEM;
+ EMPQAD_DEBUG cout << endl
+ << "EMPQUEUEADAPTIVE: memory full: "
+ << "switching to external-memory pqueue " << endl;
+ //create an AMI_stream and write in it biggest half elts of im;
+ AMI_STREAM<T> *amis0 = new AMI_STREAM<T>();
+ AMI_STREAM<T> *amis1;
+ assert(amis0 && amis1);
+ unsigned long pqsize = im->size();
+ //assert(im->size() == im->get_maxsize());
+ T x;
+ for (unsigned long i=0; i< pqsize/2; i++) {
+ int z = im->extract_max(x);
+ assert(z);
+ ae = amis0->write_item(x);
+ assert(amis0->stream_len() == pqsize/2);
+ EMPQAD_DEBUG { cout << "written " << pqsize/2
+ << " elts to stream\n"; cout.flush(); }
+ assert(im->size() == pqsize/2 + (pqsize % 2));
+ EMPQAD_DEBUG LOG_avail_memo();
+ //sort the stream
+ baseCmpType<T> fun;
+ AMI_sort(amis0, &amis1, &fun); //XXX laura: replaced this to use a cmp obj
+ delete amis0;
+ EMPQAD_DEBUG { cout << "sorted the stream\n"; cout.flush(); }
+ //set im to NULL and initialize em from im and amis1
+ em = new em_pqueue<T,Key>(im, amis1);
+ im = NULL;
+ assert(em);
+ EMPQAD_DEBUG { cout << "empq initialized from im\n"; cout.flush(); }
+ EMPQAD_DEBUG {em->print_size();}
+#ifndef NDEBUG
+ assert(sizeCheck == size());
+#endif
+#endif
Copied: grass/trunk/include/iostream/empq_impl.h (from rev 32508, grass/trunk/raster/r.terraflow/IOStream/include/empq_impl.h)
--- grass/trunk/include/iostream/empq_impl.h (rev 0)
+++ grass/trunk/include/iostream/empq_impl.h 2008-08-04 12:21:11 UTC (rev 32509)
@@ -0,0 +1,1511 @@
+ * MODULE: r.terraflow
+ * COPYRIGHT (C) 2007 Laura Toma
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+#ifndef __EMPQ_IMPL_H
+#define __EMPQ_IMPL_H
+#include <stdio.h>
+#if __GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 1)
+#include <ostream>
+#else
+#include <ostream.h>
+#endif
+#include "empq.h"
+#if(0)
+#include "option.H"
+#define MY_LOG_DEBUG_ID(x) \
+ if(GETOPT("debug")) cerr << __FILE__ << ":" << __LINE__<< " " << x << endl;
+#endif
+#undef XXX
+#define XXX if(0)
+/* encapsulation of the element=<key/prio, data> together with <buffer_id>
+ and <stream_id>; used during stream merging to remember where each
+ key comes from;
+ assumes that class T implements: Key getPriority()
+ implements operators {<, <=, ...} such that a< b iff a.x.prio < b.x.prio
+class ExtendedEltMergeType {
+private:
+ T x;
+ unsigned short buf_id;
+public:
+ ExtendedEltMergeType() {}
+ ExtendedEltMergeType(T &e, unsigned short bid, unsigned int sid):
+ x(e), buf_id(bid), str_id(sid) {}
+ ~ExtendedEltMergeType() {}
+ void set (T &e, unsigned short bid, unsigned int sid) {
+ x = e;
+ buf_id = bid;
+ str_id = sid;
+ T elt() const {
+ return x;
+ unsigned short buffer_id() const {
+ return buf_id;
+ return str_id;
+ Key getPriority() const {
+ return x.getPriority();
+ //print
+ const ExtendedEltMergeType<T,Key> &elt) {
+ return s << "<buf_id=" << elt.buf_id
+ << ",str_id=" << elt.str_id << "> "
+ << elt.x << " ";
+ friend int operator < (const ExtendedEltMergeType<T,Key> &e1,
+ const ExtendedEltMergeType<T,Key> &e2) {
+ return (e1.getPriority() < e2.getPriority());
+ friend int operator <= (const ExtendedEltMergeType<T,Key> &e1,
+ return (e1.getPriority() <= e2.getPriority());
+ friend int operator > (const ExtendedEltMergeType<T,Key> &e1,
+ return (e1.getPriority() > e2.getPriority());
+ friend int operator >= (const ExtendedEltMergeType<T,Key> &e1,
+ return (e1.getPriority() >= e2.getPriority());
+ friend int operator != (const ExtendedEltMergeType<T,Key> &e1,
+ return (e1.getPriority() != e2.getPriority());
+ friend int operator == (const ExtendedEltMergeType<T,Key> &e1,
+ return (e1.getPriority() == e2.getPriority());
+//create an em_pqueue
+ em_pqueue<T,Key>::em_pqueue(long pq_sz, long buf_sz ,
+ unsigned short nb_buf,
+ unsigned int buf_ar):
+ pqsize(pq_sz), bufsize(buf_sz), max_nbuf(nb_buf),
+ crt_buf(0), buf_arity(buf_ar) {
+ //____________________________________________________________
+ //ESTIMATE AVAILABLE MEMORY BEFORE ALLOCATION
+ AMI_err ae;
+ printf("EM_PQUEUE:available memory before allocation: %.2fMB\n",
+ mm_avail/(float)(1<<20));
+ printf("EM_PQUEUE:available memory before allocation: %ldB\n",
+ mm_avail);
+ //ALLOCATE STRUCTURE
+ //some dummy checks..
+ assert(pqsize > 0 && bufsize > 0);
+ MEMORY_LOG("em_pqueue: allocating int pqueue\n");
+ pq = new MinMaxHeap<T>(pqsize);
+ assert(pq);
+ MEMORY_LOG("em_pqueue: allocating buff_0\n");
+ //initialize in memory buffer
+ buff_0 = new im_buffer<T>(bufsize);
+ assert(buff_0);
+ char str[200];
+ sprintf(str, "em_pqueue: allocating array of %ld buff pointers\n",
+ (long)max_nbuf);
+ MEMORY_LOG(str);
+ //allocate ext memory buffers array
+ buff = new em_buffer<T,Key>* [max_nbuf];
+ assert(buff);
+ for (unsigned short i=0; i<max_nbuf; i++) {
+ buff[i] = NULL;
+ //some memory checks- make sure the empq fits in memory !!
+ //estimate available memory after allocation
+ mm_avail = getAvailableMemory();
+ printf("EM_PQUEUE: available memory after allocation: %.2fMB\n",
+ //estimate AMI_STREAM memory usage
+ size_t sz_stream;
+ cout << "em_pqueue constructor: failing to get stream_usage\n";
+ exit(1);
+ cout << "EM_PQUEUE:AMI_stream memory usage: " << sz_stream << endl;
+ cout << "EM_PQUEUE: item size=" << sizeof(T) << endl;
+ //estimate memory overhead
+ long mm_overhead = buf_arity*sizeof(merge_key<Key>) +
+ cout << "EM_PQUEUE: mm_overhead estimated as " << mm_overhead << endl;
+ cout << "overhead bigger than available memory"
+ exit(1);
+ //arity*sizeof(AMI_STREAM) < memory
+ cout << "pqsize=" << pqsize
+ << ", bufsize=" << bufsize
+ << ", maximum allowed arity=" << mm_avail/sz_stream << endl;
+ if (buf_arity * sz_stream > mm_avail) {
+ cout << "sorry - empq excedes memory limits\n";
+ cout << "try again decreasing arity or pqsize/bufsize\n";
+ cout.flush();
+//create an em_pqueue capable to store <= N elements
+em_pqueue<T,Key>::em_pqueue() {
+ MY_LOG_DEBUG_ID("em_pqueue constructor");
+ //available memory
+ AMI_err ae;
+ cout.flush();
+ size_t sz_stream;
+ cout << "em_pqueue constructor: failing to get main_memory_usage\n";
+ exit(1);
+ cout.flush();
+ //assume max_nbuf=2 suffices; check after arity is computed
+ max_nbuf = 2;
+ //account for temporary memory usage (set up a preliminary arity)
+ buf_arity = mm_avail/(2 * sz_stream);
+ exit(1);
+#ifdef SAVE_MEMORY
+ //assign M/2 to pq
+ pqsize = mm_avail/(2*sizeof(T));
+ //assign M/2 to buff_0
+ bufsize = mm_avail/(2*sizeof(T));
+#else
+ //assign M/4 to pq
+ pqsize = mm_avail/(4*sizeof(T));
+ //assign M/4 to buff_0
+ bufsize = mm_avail/(4*sizeof(T));
+#endif
+ cout << "EM_PQUEUE: pqsize set to " << pqsize << endl;
+ cout << "EM_PQUEUE: bufsize set to " << bufsize << endl;
+ cout << "EM_PQUEUE: nb buffers set to " << max_nbuf << endl;
+ //assign M/2 to AMI_STREAMS and compute arity
+ /* arity is mainly constrained by the size of an AMI_STREAM; the
+ rest of the memory must accomodate for arity * max_nbuf
+ *sizeof(AMI_STREAM); there are some temporary stuff like arity *
+ sizeof(long) (the deleted array), arity * sizeof(T) (the array of
+ keys for merging) and so on, but the main factor is the
+ AMI_STREAM size which is roughly B * LBS * 2 (each AMI_STREAM
+ allocates 2 logical blocks) */
+#ifdef SAVE_MEMORY
+#else
+ buf_arity = mm_avail/(2 * max_nbuf * sz_stream);
+#endif
+ //overestimate usage
+ if (buf_arity > 3) {
+ buf_arity -= 3;
+ } else {
+ buf_arity = 1;
+ cout << "EM_PQUEUE: arity set to " << buf_arity << endl;
+ crt_buf = 0;
+ assert(pq);
+ assert(buff_0);
+ char str[200];
+ sprintf(str,"em_pqueue: allocating array of %ld buff pointers\n",
+ (long)max_nbuf);
+ MEMORY_LOG(str);
+ assert(buff);
+ buff[i] = NULL;
+ //max nb of items the structure can accomodate (constrained by max_nbuf)
+ cout << "EM_PQUEUE: maximum length is " << maxlen() << "\n";
+ cout.flush();
+ //check that structure can accomodate N elements
+ // assert(N < buf_arity * (buf_arity + 1) * bufsize);
+ //assert(N < maxlen());
+#ifdef SAVE_MEMORY
+// create an empq, initialize its pq with im and insert amis in
+// buff[0]; im should not be used/deleted after that outside empq;
+// assumption: im was allocated such that maxsize = mm_avail/T;
+// when this constructor is called im is only half full, so we must
+// free half of its space and give to buff_0
+em_pqueue<T,Key>::em_pqueue(MinMaxHeap<T> *im, AMI_STREAM<T> *amis) {
+ AMI_err ae;
+ int pqcapacity; /* amount of memory we can use for each of new
+ minmaxheap, and em-buffer */
+ unsigned int pqcurrentsize; /* number of elements currently in im */
+ assert(im && amis);
+ pqcapacity = im->get_maxsize()/2; // we think this memory is now available
+ pqcurrentsize = im->size();
+ pqsize = pqcapacity;
+ LOG_avail_memo();
+ /* at this point im is allocated all memory, but it is only at most
+ half full; we need to relocate im to half space and to allocate
+ buff_0 the other half; since we use new, there is no realloc, so
+ we will copy to a file...*/
+ //copy im to a stream and free its memory
+ T x;
+ AMI_STREAM<T> tmpstr;
+ for (unsigned int i=0; i<pqcurrentsize; i++) {
+ im->extract_min(x);
+ ae = tmpstr.write_item(x);
+ delete im;
+ LOG_avail_memo();
+ //allocate pq and buff_0 half size
+ bufsize = pqcapacity;
+ cout << "EM_PQUEUE: allocating im_buffer size=" << bufsize
+ << " total " << (float)bufsize*sizeof(T)/(1<<20) << "MB\n";
+ cout.flush();
+ assert(buff_0);
+ cout << "EM_PQUEUE: allocating pq size=" << pqcapacity
+ << " total " << (float)pqcapacity*sizeof(T)/(1<<20) << "MB\n";
+ cout.flush();
+ pq = new MinMaxHeap<T>(pqcapacity);
+ assert(pq);
+ //fill pq from tmp stream
+ ae = tmpstr.seek(0);
+ T *elt;
+ ae = tmpstr.read_item(&elt);
+ pq->insert(*elt);
+ assert(pq->size() == pqcurrentsize);
+ //estimate buf_arity
+ size_t sz_stream;
+ exit(1);
+ cout << "EM_PQUEUE: AMI_stream memory usage: " << sz_stream << endl;
+ max_nbuf = 2;
+ buf_arity = pqcapacity * sizeof(T) / sz_stream;
+ //should account for some overhead
+ if (buf_arity == 0) {
+ cout << "EM_PQUEUE: arity=0 (not enough memory..)\n";
+ exit(1);
+ buf_arity -= 3;
+ } else {
+ buf_arity = 1;
+ //allocate ext memory buffer array
+ char str[200];
+ (long)max_nbuf);
+ MEMORY_LOG(str);
+ assert(buff);
+ buff[i] = NULL;
+ crt_buf = 0;
+ cout << "EM_PQUEUE: new pqsize set to " << pqcapacity << endl;
+ cout << "EM_PQUEUE: buf arity set to " << buf_arity << endl;
+ cout.flush();
+ //estimate available remaining memory
+ //last thing: insert the input stream in external buffers
+ //allocate buffer if necessary
+ //assert(crt_buf==0 && !buff[0]);// given
+ if(amis->stream_len()) {
+ //create buff[0] as a level1 buffer
+ MEMORY_LOG("em_pqueue::empty_buff_0: create new em_buffer\n");
+ buff[0] = new em_buffer<T,Key>(1, bufsize, buf_arity);
+ buff[0]->insert(amis);
+ crt_buf = 1;
+#endif
+//free space
+em_pqueue<T,Key>::~em_pqueue() {
+ //delete in memory pqueue
+ if (pq) delete pq;
+ //delete in memory buffer
+ if (buff_0) delete buff_0;
+ //delete ext memory buffers
+ for (unsigned short i=0; i< crt_buf; i++) {
+ if (buff[i]) delete buff[i];
+ delete [] buff;
+//return maximum capacity of i-th external buffer
+long em_pqueue<T,Key>::maxlen(unsigned short i) {
+ if (i >= max_nbuf) {
+ printf("em_pqueue::max_len: level=%d exceeds capacity=%d\n",
+ i, max_nbuf);
+ return 0;
+ if (i < crt_buf) {
+ return buff[i]->get_buf_maxlen();
+ //try allocating buffer
+ em_buffer<T,Key> * tmp = new em_buffer<T,Key>(i+1, bufsize, buf_arity);
+ if (!tmp) {
+ cout << "em_pqueue::max_len: cannot allocate\n";
+ return 0;
+ long len = tmp->get_buf_maxlen();
+ delete tmp;
+ return len;
+//return maximum capacity of em_pqueue
+long em_pqueue<T,Key>::maxlen() {
+ long len = 0;
+ for (unsigned short i=0; i< max_nbuf; i++) {
+ len += maxlen(i);
+ return len + buff_0->get_buf_maxlen();
+//return the total nb of elements in the structure
+unsigned long em_pqueue<T,Key>::size() {
+ //sum up the lenghts(nb of elements) of the external buffers
+ unsigned long elen = 0;
+ for (unsigned short i=0; i < crt_buf; i++) {
+ elen += buff[i]->get_buf_len();
+ return elen + pq->size() + buff_0->get_buf_len();
+bool em_pqueue<T,Key>::is_empty() {
+ //return (size() == 0);
+ //more efficient?
+ return ((pq->size() == 0) && (buff_0->get_buf_len() == 0) &&
+ (size() == 0));
+//called when pq must be filled from external buffers
+bool em_pqueue<T,Key>::fillpq() {
+#ifndef NDEBUG
+ int k=0;
+ for (unsigned short i=0; i<crt_buf; i++) {
+ k |= buff[i]->get_buf_len();
+ if(!k) {
+ cerr << "fillpq called with empty external buff!" << endl;
+ assert(k);
+#endif
+#ifdef EMPQ_PQ_FILL_PRINT
+ cout << "filling pq\n"; cout .flush();
+#endif
+ XXX cerr << "filling pq" << endl;
+ MY_LOG_DEBUG_ID("fillpq");
+ AMI_err ae;
+ char str[200];
+ sprintf(str, "em_pqueue::fillpq: allocate array of %hd AMI_STREAMs\n",
+ crt_buf);
+ MEMORY_LOG(str);
+ //merge pqsize smallest elements from each buffer into a new stream
+ ExtendedMergeStream** outstreams;
+ //gcc-3.4 doesn't allows (TYPE*)[SIZE] declarations
+ //use TYPE*[SIZE]
+ outstreams = new ExtendedMergeStream*[crt_buf];
+ MY_LOG_DEBUG_ID(crt_buf);
+ outstreams[i] = new ExtendedMergeStream();
+ assert(buff[i]->get_buf_len());
+ ae = merge_buffer(buff[i], outstreams[i], pqsize);
+ assert(outstreams[i]->stream_len());
+ //print_stream(outstreams[i]); cout.flush();
+ if (crt_buf == 1) {
+ //just one level; make common case faster :)
+ merge_bufs2pq(outstreams[0]);
+ delete outstreams[0];
+ delete [] outstreams;
+ } else {
+ //merge the outstreams to get the global mins and delete them afterwards
+ ExtendedMergeStream *minstream = new ExtendedMergeStream();
+ //cout << "merging streams\n";
+ ae = merge_streams(outstreams, crt_buf, minstream, pqsize);
+ delete outstreams[i];
+ //copy the minstream in the internal pqueue while merging with buff_0;
+ //the smallest <pqsize> elements between minstream and buff_0 will be
+ //inserted in internal pqueue;
+ //also, the elements from minstram which are inserted in pqueue must be
+ //marked as deleted in the source streams;
+ merge_bufs2pq(minstream);
+ delete minstream;
+ //cout << "after merge_bufs2pq: \n" << *this << "\n";
+ XXX assert(pq->size());
+ XXX cerr << "fillpq done" << endl;
+ return true;
+bool
+em_pqueue<T,Key>::min(T& elt){
+ bool ok;
+ MY_LOG_DEBUG_ID("em_pqueue::min");
+ //try first the internal pqueue
+ if (!pq->empty()) {
+ ok = pq->min(elt);
+ assert(ok);
+ return ok;
+ MY_LOG_DEBUG_ID("extract_min: reset pq");
+ pq->reset();
+ //if external buffers are empty
+ if (crt_buf == 0) {
+ //if internal buffer is empty too, then nothing to extract
+ if (buff_0->is_empty()) {
+ //cerr << "min called on empty empq" << endl;
+ return false;
+ } else {
+#ifdef EMPQ_PRINT_FILLPQ_FROM_BUFF0
+ cout << "filling pq from B0\n"; cout.flush();
+#endif
+ //ext. buffs empty; fill int pqueue from buff_0
+ long n = pq->fill(buff_0->get_array(), buff_0->get_buf_len());
+ buff_0->reset(pqsize, n);
+ assert(ok);
+ return true;
+ } else {
+ //external buffers are not empty;
+ XXX print_size();
+ fillpq();
+ XXX cerr << "fillpq done; about to take min" << endl;
+ XXX cerr << "after taking min" << endl;
+ assert(ok);
+ return ok;
+ } //end of else (if ext buffers are not empty)
+ assert(0); //not reached
+static void print_ExtendedMergeStream(ExtendedMergeStream &str) {
+ ExtendedEltMergeType<T,Key> *x;
+ str.seek(0);
+ while (str.read_item(&x) == AMI_ERROR_NO_ERROR) {
+ cout << *x << ", ";
+ cout << "\n";
+//delete the element with minimum priority in the structure;
+//return false if pq is empty
+bool em_pqueue<T,Key>::extract_min(T& elt) {
+ bool ok;
+ MY_LOG_DEBUG_ID("\n\nEM_PQUEUE::EXTRACT_MIN");
+ //cout << "extract from internal pq\n";
+ MY_LOG_DEBUG_ID("extract from internal pq");
+ ok = pq->extract_min(elt);
+ assert(ok);
+ return ok;
+ //if internal pqueue is empty, fill it up
+ MY_LOG_DEBUG_ID("internal pq empty: filling it up from external buffers");
+ pq->reset();
+ return false;
+ } else {
+#endif
+ MY_LOG_DEBUG_ID("filling pq from buff_0");
+ assert(ok);
+ return true;
+ } else {
+ MY_LOG_DEBUG_ID("filling pq from buffers");
+#ifdef EMPQ_PRINT_SIZE
+ long x = size(), y;
+ y = x*sizeof(T) >> 20;
+ cout << "pqsize:[" << active_streams() << " streams: ";
+ cout << " total " << x << "(" << y << "MB)]" << endl;
+ cout.flush();
+#endif
+ fillpq();
+ MY_LOG_DEBUG_ID("pq filled");
+ XXX cerr << "about to get the min" << endl;
+ assert(pq);
+ if (!ok) {
+ cout << "failing assertion: pq->extract_min == true\n";
+ this->print();
+ assert(ok);
+ return ok;
