[GRASS-SVN] r32535 - grass/trunk/gui/wxpython/gui_modules
Tue Aug 5 02:34:51 EDT 2008
Author: cmbarton
Date: 2008-08-05 02:34:51 -0400 (Tue, 05 Aug 2008)
New Revision: 32535
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
Modified drag and drop so that dragging above tree moves layer to top of tree and dragging below tree moves layer to bottom of tree.
Fixed bug in settings edit popup menu due to code left over from spin control opacity setting.
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-05 05:18:56 UTC (rev 32534)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-05 06:34:51 UTC (rev 32535)
@@ -85,11 +85,11 @@
         self.layer_selected = None # ID of currently selected layer
         self.saveitem = {}         # dictionary to preserve layer attributes for drag and drop
         self.first = True          # indicates if a layer is just added or not
-        self.drag = False          # flag to indicate a drag event is in process
+        self.flag = ''             # flag for drag and drop hittest
         self.disp_idx = kargs['idx']
         self.gismgr = kargs['gismgr']
         self.notebook = kargs['notebook']   # GIS Manager notebook for layer tree
-        self.treepg = parent      # notebook page holding layer tree
+        self.treepg = parent        # notebook page holding layer tree
         self.auimgr = kargs['auimgr']       # aui manager
         # init associated map display
@@ -183,6 +183,8 @@
         self.Bind(CT.EVT_TREE_ITEM_CHECKED,     self.OnLayerChecked)
         self.Bind(wx.EVT_TREE_DELETE_ITEM,      self.OnDeleteLayer)
         self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
+        #self.Bind(wx.EVT_TREE_BEGIN_DRAG,       self.OnDrag)
+        self.Bind(wx.EVT_TREE_END_DRAG,         self.OnEndDrag)
         #self.Bind(wx.EVT_TREE_END_LABEL_EDIT,   self.OnChangeLayerName)
         self.Bind(wx.EVT_KEY_UP,                self.OnKeyUp)
         # self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
@@ -242,11 +244,6 @@
                 ltype != "command": # properties
             self.popupMenu.AppendSeparator()
             self.popupMenu.Append(self.popupID8, text=_("Change opacity level"))
-            if self.FindWindowById(self.GetPyData(self.layer_selected)[0]['ctrl']).GetName() == 'spinCtrl':
-                checked = True
-            else:
-                checked = False
-            self.popupMenu.Check(self.popupID8, checked)
             self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=self.popupID8)
             self.popupMenu.Append(self.popupID3, text=_("Properties"))
             self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
@@ -829,7 +826,7 @@
         item    = event.GetItem()
         checked = item.IsChecked()
-        if self.drag == False and self.first == False:
+        if self.first == False:
             # change active parameter for item in layers list in render.Map
             if self.GetPyData(item)[0]['type'] == 'group':
                 child, cookie = self.GetFirstChild(item)
@@ -958,13 +955,21 @@
         self.layer_selected = event.GetItem()
         if self.GetPyData(self.layer_selected)[0]['type'] == 'group':
             self.SetItemImage(self.layer_selected, self.folder_open)
+    def OnEndDrag(self, event):
+        self.StopDragging()
+        dropTarget = event.GetItem()
+        self.flag = self.HitTest(event.GetPoint())[1]
+        if self.IsValidDropTarget(dropTarget):
+            self.UnselectAll()
+            if dropTarget != None:
+                self.SelectItem(dropTarget)
+            self.OnDrop(dropTarget, self._dragItem)
+        elif dropTarget == None:
     def OnDrop(self, dropTarget, dragItem):
         # save everthing associated with item to drag
-        dropIndex = self.GetIndexOfItem(dropTarget)
-        dragIndex = self.GetIndexOfItem(dragItem)
-        #Insert copy of layer in new position and delete original at old position
         try:
             old = dragItem  # make sure this member exists
         except:
@@ -973,7 +978,7 @@
         Debug.msg (4, "LayerTree.OnDrop(): layer=%s" % \
                    (self.GetItemText(dragItem)))
-        # recreate data layer
+        # recreate data layer, insert copy of layer in new position, and delete original at old position
         newItem  = self.RecreateItem (dragItem, dropTarget)
         # if recreated layer is a group, also recreate its children
@@ -1045,7 +1050,8 @@
             windval = None
             data    = None
-        if dropTarget != None:
+        # decide where to put recreated item
+        if dropTarget != None and dropTarget != self.GetRootItem():
             if parent:
                 # new item is a group
                 afteritem = parent
@@ -1066,10 +1072,16 @@
                                        text=text, ct_type=1, wnd=newctrl, \
                                        image=image, data=data)
         else:
-            # if dragItem not dropped on a layer or group, prepend it to the layer tree
-            newItem = self.PrependItem(self.root, text=text, \
-                                  ct_type=1, wnd=newctrl, image=image, \
-                                  data=data)
+            # if dragItem not dropped on a layer or group, append or prepend it to the layer tree
+            if self.flag & wx.TREE_HITTEST_ABOVE:
+                newItem = self.PrependItem(self.root, text=text, \
+                                      ct_type=1, wnd=newctrl, image=image, \
+                                      data=data)
+            elif (self.flag &  wx.TREE_HITTEST_BELOW) or (self.flag & wx.TREE_HITTEST_NOWHERE) \
+                     or (self.flag & wx.TREE_HITTEST_TOLEFT) or (self.flag & wx.TREE_HITTEST_TORIGHT):
+                newItem = self.AppendItem(self.root, text=text, \
+                                      data=data)
         #update new layer
         self.SetPyData(newItem, self.GetPyData(dragItem))
