[GRASS-SVN] r32578 - in grass/trunk: lib/gis raster/r.mapcalc
Wed Aug 6 13:48:43 EDT 2008
Author: glynn
Date: 2008-08-06 13:48:43 -0400 (Wed, 06 Aug 2008)
New Revision: 32578
   grass/trunk/lib/gis/parser.c
   grass/trunk/raster/r.mapcalc/evaluate.c
   grass/trunk/raster/r.mapcalc/globals.h
   grass/trunk/raster/r.mapcalc/main.c
   grass/trunk/raster/r.mapcalc/map.c
   grass/trunk/raster/r.mapcalc/map3.c
   grass/trunk/raster/r.mapcalc/mapcalc.h
Make r.mapcalc use G_parser()
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/lib/gis/parser.c	2008-08-06 17:48:43 UTC (rev 32578)
@@ -959,6 +959,9 @@
     char element[KEYLENGTH];
     char desc[KEYLENGTH];
+    if (module_info.overwrite)
+	return 1;
     /* figure out if any of the options use a "new" gisprompt */
     /* This is to see if we should spit out the --o flag      */
     if (n_opts) {
@@ -2498,6 +2501,8 @@
     char *overstr;
     int over;
+    module_info.overwrite = 0;
     if (!n_opts)
 	return (0);
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/raster/r.mapcalc/evaluate.c	2008-08-06 17:48:43 UTC (rev 32578)
@@ -269,6 +269,20 @@
     for (l = ee; l; l = l->next) {
 	expression *e = l->exp;
 	const char *var;
+	if (e->type != expr_type_binding)
+	    G_fatal_error("internal error: execute: invalid type: %d",
+			  e->type);
+	var = e->data.bind.var;
+	if (!overwrite && check_output_map(var))
+	    G_fatal_error(_("output map <%s> exists"), var);
+    for (l = ee; l; l = l->next) {
+	expression *e = l->exp;
+	const char *var;
 	expression *val;
Modified: grass/trunk/raster/r.mapcalc/globals.h
--- grass/trunk/raster/r.mapcalc/globals.h	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/raster/r.mapcalc/globals.h	2008-08-06 17:48:43 UTC (rev 32578)
@@ -5,6 +5,7 @@
 extern volatile int floating_point_exception;
 extern volatile int floating_point_exception_occurred;
 extern int overflow_occurred;
+extern int overwrite;
 extern int current_depth, current_row;
 extern int depths, rows, columns;
Modified: grass/trunk/raster/r.mapcalc/main.c
--- grass/trunk/raster/r.mapcalc/main.c	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/raster/r.mapcalc/main.c	2008-08-06 17:48:43 UTC (rev 32578)
@@ -26,25 +26,13 @@
+int overwrite;
-static const char help_text[] =
-    "r.mapcalc - Raster map layer data calculator\n"
-    "\n"
-    "usage: r.mapcalc '<map>=<expression>'\n"
-    "\n"
-    "r.mapcalc performs arithmetic on raster map layers.\n"
-    "\n"
-    "New raster map layers can be created which are arithmetic expressions\n"
-    "involving existing raster map layers, integer or floating point constants,\n"
-    "and functions.\n" "\n" "For more information use 'g.manual r.mapcalc'\n";
 static expr_list *result;
@@ -90,50 +78,74 @@
-static const char *join(int argc, char **argv)
+static expr_list *parse_file(const char *filename)
-    int size = 0;
-    char *buf;
-    int i;
+    expr_list *res;
+    FILE *fp;
-    for (i = 0; i < argc; i++)
-	size += strlen(argv[i]) + 1;
+    if (strcmp(filename, "-") == 0)
+	return parse_stream(stdin);
-    buf = G_malloc(size);
-    *buf = '\0';
-    for (i = 0; i < argc; i++) {
-	if (i)
-	    strcat(buf, " ");
-	strcat(buf, argv[i]);
+    fp = fopen(filename, "r");
+    if (!fp)
+	G_fatal_error(_("unable to open input file <%s>"), filename);
-    return buf;
+    res = parse_stream(fp);
+    fclose(fp);
+    return res;
 int main(int argc, char **argv)
+    struct GModule *module;
+    struct Option *expr, *file;
     int all_ok;
-    int overwrite;
     G_gisinit(argv[0]);
-    if (argc > 1 && (strcmp(argv[1], "help") == 0 ||
-		     strcmp(argv[1], "--help") == 0)) {
-	fputs(help_text, stderr);
-	return EXIT_SUCCESS;
+    module = G_define_module();
+    module->keywords = _("raster");
+    module->description = _("Raster map calculator.");
+    module->overwrite = 1;
+    expr = G_define_option();
+    expr->key = "expression";
+    expr->type = TYPE_STRING;
+    expr->required = NO;
+    expr->description = _("Expression to evaluate");
+    file = G_define_standard_option(G_OPT_F_INPUT);
+    file->required = NO;
+    file->description = _("File containing expression to evaluate");
+    if (argc == 1)
+	char **p = G_malloc(3 * sizeof(char *));
+	p[0] = argv[0];
+	p[1] = G_store("input=-");
+	p[2] = NULL;
+	argv = p;
+	argc = 2;
-    result = (argc >= 2)
-	? parse_string(join(argc - 1, argv + 1))
-	: parse_stream(stdin);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-    if (!result)
-	return EXIT_FAILURE;
+    overwrite = module->overwrite;
-    overwrite = G_check_overwrite(argc, argv);
+    if (expr->answer)
+	result = parse_string(expr->answer);
+    else if (file->answer)
+	result = parse_file(file->answer);
+    else
+	result = parse_stream(stdin);
+    if (!result)
+	G_fatal_error(_("parse error"));
     pre_exec();
     execute(result);
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/raster/r.mapcalc/map.c	2008-08-06 17:48:43 UTC (rev 32578)
@@ -498,6 +498,11 @@
+int check_output_map(const char *name)
+    return !!G_find_cell2(name, G_mapset());
 int open_output_map(const char *name, int res_type)
     int fd;
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/raster/r.mapcalc/map3.c	2008-08-06 17:48:43 UTC (rev 32578)
@@ -566,6 +566,11 @@
+    return !!G_find_grid3(name, G_mapset());
     void *handle;
Modified: grass/trunk/raster/r.mapcalc/mapcalc.h
--- grass/trunk/raster/r.mapcalc/mapcalc.h	2008-08-06 17:06:40 UTC (rev 32577)
+++ grass/trunk/raster/r.mapcalc/mapcalc.h	2008-08-06 17:48:43 UTC (rev 32578)
@@ -49,6 +49,7 @@
 			void *buf, int res_type);
 extern void close_maps(void);
+extern int check_output_map(const char *name);
 extern int open_output_map(const char *name, int res_type);
 extern void put_map_row(int fd, void *buf, int res_type);
 extern void close_output_map(int fd);
