[GRASS-SVN] r32584 - in grass/trunk: display display/d.barscale display/d.colors display/d.colortable display/d.erase display/d.font display/d.geodesic display/d.graph display/d.grid display/d.his display/d.histogram display/d.info display/d.labels display/d.legend display/d.measure display/d.nviz display/d.path display/d.rast display/d.rast.arrow display/d.rast.num display/d.rgb display/d.rhumbline display/d.text.new display/d.thematic.area display/d.vect display/d.vect.chart display/d.what.rast display/d.what.vect display/d.zoom display/drivers general/g.mapset imagery include include/Make lib lib/cairodriver lib/display lib/driver lib/htmldriver lib/pngdriver lib/psdriver lib/raster raster/r.profile
Wed Aug 6 17:50:18 EDT 2008
Author: glynn
Date: 2008-08-06 17:50:17 -0400 (Wed, 06 Aug 2008)
New Revision: 32584
Added:
   grass/trunk/lib/cairodriver/description.html
   grass/trunk/lib/htmldriver/
   grass/trunk/lib/htmldriver/Driver.c
   grass/trunk/lib/htmldriver/Graph_Clse.c
   grass/trunk/lib/htmldriver/Graph_Set.c
   grass/trunk/lib/htmldriver/Makefile
   grass/trunk/lib/htmldriver/Polygn_abs.c
   grass/trunk/lib/htmldriver/README
   grass/trunk/lib/htmldriver/Text.c
   grass/trunk/lib/htmldriver/description.html
   grass/trunk/lib/htmldriver/htmlmap.h
   grass/trunk/lib/pngdriver/description.html
   grass/trunk/lib/psdriver/description.html
   grass/trunk/lib/raster/raster.c
Removed:
   grass/trunk/display/d.ask/
   grass/trunk/display/d.barscale/mouse.c
   grass/trunk/display/d.extend/
   grass/trunk/display/d.font.freetype/
   grass/trunk/display/d.frame/
   grass/trunk/display/d.geodesic/mouse.c
   grass/trunk/display/d.legend/box.c
   grass/trunk/display/d.menu/
   grass/trunk/display/d.mon/
   grass/trunk/display/d.rast.edit/
   grass/trunk/display/d.rhumbline/mouse.c
   grass/trunk/display/d.save/
   grass/trunk/display/drivers/HTMLMAP/
   grass/trunk/display/drivers/PNG/
   grass/trunk/display/drivers/PS/
   grass/trunk/display/drivers/cairo/
   grass/trunk/imagery/i.ask/
   grass/trunk/include/graphics.h
   grass/trunk/include/monitors.h
   grass/trunk/lib/display/get_win.c
   grass/trunk/lib/display/ident_win.c
   grass/trunk/lib/display/popup.c
   grass/trunk/lib/driver/Get_location.c
   grass/trunk/lib/driver/Panel.c
   grass/trunk/lib/driver/Work.c
   grass/trunk/lib/driver/command.c
   grass/trunk/lib/driver/connect_sock.c
   grass/trunk/lib/driver/main.c
   grass/trunk/lib/driver/pad.c
   grass/trunk/lib/driver/pad.h
   grass/trunk/lib/raster/com_get.c
   grass/trunk/lib/raster/com_io.c
   grass/trunk/lib/raster/com_pad.c
   grass/trunk/lib/raster/com_proto.c
   grass/trunk/lib/raster/common.c
   grass/trunk/lib/raster/io_sock.c
   grass/trunk/lib/raster/loc_get.c
   grass/trunk/lib/raster/loc_io.c
   grass/trunk/lib/raster/loc_pad.c
   grass/trunk/lib/raster/loc_proto.c
   grass/trunk/lib/raster/open.h
   grass/trunk/lib/raster/parse_mon.c
   grass/trunk/lib/raster/rem_get.c
   grass/trunk/lib/raster/rem_io.c
   grass/trunk/lib/raster/rem_pad.c
   grass/trunk/lib/raster/rem_proto.c
   grass/trunk/lib/raster/transport.h
   grass/trunk/display/Makefile
   grass/trunk/display/d.barscale/draw_scale.c
   grass/trunk/display/d.barscale/main.c
   grass/trunk/display/d.barscale/options.h
   grass/trunk/display/d.colors/main.c
   grass/trunk/display/d.colortable/main.c
   grass/trunk/display/d.erase/main.c
   grass/trunk/display/d.font/main.c
   grass/trunk/display/d.geodesic/main.c
   grass/trunk/display/d.graph/main.c
   grass/trunk/display/d.grid/main.c
   grass/trunk/display/d.his/main.c
   grass/trunk/display/d.histogram/main.c
   grass/trunk/display/d.info/main.c
   grass/trunk/display/d.labels/main.c
   grass/trunk/display/d.legend/main.c
   grass/trunk/display/d.measure/main.c
   grass/trunk/display/d.nviz/local.h
   grass/trunk/display/d.nviz/main.c
   grass/trunk/display/d.path/main.c
   grass/trunk/display/d.path/proto.h
   grass/trunk/display/d.path/select.c
   grass/trunk/display/d.rast.arrow/arrow.c
   grass/trunk/display/d.rast.num/number.c
   grass/trunk/display/d.rast/display.c
   grass/trunk/display/d.rast/local_proto.h
   grass/trunk/display/d.rast/main.c
   grass/trunk/display/d.rgb/main.c
   grass/trunk/display/d.rhumbline/main.c
   grass/trunk/display/d.text.new/main.c
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/display/d.vect.chart/main.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/display/d.what.rast/main.c
   grass/trunk/display/d.what.vect/main.c
   grass/trunk/display/d.what.vect/what.c
   grass/trunk/display/d.what.vect/what.h
   grass/trunk/display/d.zoom/main.c
   grass/trunk/general/g.mapset/main.c
   grass/trunk/imagery/Makefile
   grass/trunk/include/Make/Grass.make.in
   grass/trunk/include/display.h
   grass/trunk/include/raster.h
   grass/trunk/lib/Makefile
   grass/trunk/lib/cairodriver/Driver.c
   grass/trunk/lib/display/list.c
   grass/trunk/lib/display/setup.c
   grass/trunk/lib/display/window.c
   grass/trunk/lib/driver/Makefile
   grass/trunk/lib/driver/driver.h
   grass/trunk/lib/driver/driverlib.h
   grass/trunk/lib/driver/init.c
   grass/trunk/lib/pngdriver/Driver.c
   grass/trunk/lib/psdriver/Driver.c
   grass/trunk/lib/psdriver/Makefile
   grass/trunk/lib/raster/Makefile
   grass/trunk/raster/r.profile/local_proto.h
   grass/trunk/raster/r.profile/main.c
Breaking stuff part 2: the Tek4014 is obsolete
 Eliminate monitors, and all that depends upon them; direct rendering only
 No mouse, no panels, no pads
Modified: grass/trunk/display/Makefile
--- grass/trunk/display/Makefile	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -2,17 +2,10 @@
 MODULE_TOPDIR = ..
 SUBDIRS = \
-	drivers \
-	d.ask \
 	d.barscale \
 	d.colorlist \
-	d.colors \
 	d.colortable \
 	d.erase \
-	d.extend \
-	d.extract \
-	d.font \
-	d.frame \
 	d.geodesic \
 	d.graph \
 	d.grid \
@@ -22,28 +15,30 @@
 	d.labels \
 	d.legend \
 	d.linegraph \
-	d.measure \
-	d.menu \
-	d.mon \
 	d.nviz \
 	d.path \
-	d.profile \
 	d.rast \
 	d.rast.arrow \
 	d.rast.num \
 	d.rgb \
 	d.rhumbline \
-	d.save \
 	d.text.new \
 	d.title \
 	d.vect \
 	d.vect.chart \
 	d.thematic.area \
-	d.what.rast \
-	d.what.vect \
-	d.where \
-	d.zoom
+#	d.colors \
+#	d.extract \
+#	d.font \
+#	d.measure \
+#	d.profile \
+#	d.what.rast \
+#	d.what.vect \
+#	d.where \
+#	d.zoom \
+#	drivers
 include $(MODULE_TOPDIR)/include/Make/Dir.make
 default: parsubdirs
Modified: grass/trunk/display/d.barscale/draw_scale.c
--- grass/trunk/display/d.barscale/draw_scale.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.barscale/draw_scale.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -59,7 +59,7 @@
     "5000 miles", 8046720.000, 20000000., 5},}
-int draw_scale(char *save, int toptext)
+int draw_scale(int toptext)
     double meters;
     double line_len;
@@ -93,9 +93,6 @@
 	pr = x_pos + w + 2;	/* 1 pixel margin for both sides */
 	pb = y_pos + h + 2;	/* 1 pixel margin for both sides */
-	if (save)
-	    R_panel_save(save, pt, pb, pl, pr);
 	if (do_background) {
 	    D_raster_use_color(color1);
@@ -169,9 +166,6 @@
     if (pr > r)
 	pr = r;
-    if (save)
Modified: grass/trunk/display/d.barscale/main.c
--- grass/trunk/display/d.barscale/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.barscale/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -41,12 +41,11 @@
 int main(int argc, char **argv)
-    char window_name[64];
     struct Cell_head window;
     int t, b, l, r;
     struct GModule *module;
     struct Option *opt1, *opt2, *opt3;
-    struct Flag *mouse, *feet, *top, *linescale, *northarrow, *scalebar;
+    struct Flag *feet, *top, *linescale, *northarrow, *scalebar;
     struct Cell_head W;
     /* Initialize the GIS calls */
@@ -56,10 +55,6 @@
     module->keywords = _("display, cartography");
     module->description = _("Displays a barscale on the graphics monitor.");
-    mouse = G_define_flag();
-    mouse->key = 'm';
-    mouse->description = _("Use mouse to interactively place scale");
     feet = G_define_flag();
     feet->key = 'f';
     feet->description = _("Use feet/miles instead of meters");
@@ -139,13 +134,6 @@
     if (R_open_driver() != 0)
 	G_fatal_error(_("No graphics device selected"));
-    if (D_get_cur_wind(window_name))
-	G_fatal_error(_("No current window"));
-    if (D_set_cur_wind(window_name))
-	G_fatal_error(_("Current window not available"));
     /* Parse and select background color */
     color1 = D_parse_color(opt1->answer, 1);
     if (color1 == 0)
@@ -158,47 +146,20 @@
     /* Read in the map window associated with window */
     G_get_window(&window);
-    if (D_check_map_window(&window))
-	G_fatal_error(_("Setting map window"));
+    D_check_map_window(&window);
     if (G_set_window(&window) == -1)
 	G_fatal_error(_("Current window not settable"));
     /* Determine conversion factors */
-    if (D_get_screen_window(&t, &b, &l, &r))
-	G_fatal_error(_("Getting screen window"));
+    D_get_screen_window(&t, &b, &l, &r);
     if (D_do_conversions(&window, t, b, l, r))
 	G_fatal_error(_("Error in calculating conversions"));
-    if (!mouse->answer) {
-	/* Draw the scale */
-	draw_scale(NULL, top->answer);
+    /* Draw the scale */
+    draw_scale(top->answer);
-	/* Add this command to list */
-	D_add_to_list(G_recreate_command());
-    else if (mouse_query(top->answer)) {
-	char cmdbuf[255];
-	sprintf(cmdbuf, "%s at=%f,%f", argv[0], east, north);
-	sprintf(cmdbuf, "%s bcolor=%s", cmdbuf, opt1->answer);
-	sprintf(cmdbuf, "%s tcolor=%s", cmdbuf, opt2->answer);
-	if (top->answer)
-	    strcat(cmdbuf, " -t");
-	if (feet->answer)
-	    strcat(cmdbuf, " -f");
-	if (linescale->answer)
-	    strcat(cmdbuf, " -l");
-	if (northarrow->answer)
-	    strcat(cmdbuf, " -n");
-	if (scalebar->answer)
-	    strcat(cmdbuf, " -s");
-	D_add_to_list(cmdbuf);
     R_close_driver();
     exit(EXIT_SUCCESS);
Deleted: grass/trunk/display/d.barscale/mouse.c
--- grass/trunk/display/d.barscale/mouse.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.barscale/mouse.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,47 +0,0 @@
-#include <stdio.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include <grass/display.h>
-#include "options.h"
-int mouse_query(int toptext)
-    int t, b, l, r;
-    char *panel = G_tempfile();
-    int x_pos, y_pos, button;
-    fprintf(stderr, "Left:  choose location\n" "Middle: cancel\n");
-    R_get_location_with_pointer(&x_pos, &y_pos, &button);
-    if (button == 2)
-	return 0;
-    D_get_screen_window(&t, &b, &l, &r);
-    for (;;) {
-	east = (x_pos * 100.0) / (r - l);
-	north = (y_pos * 100.0) / (b - t);
-	draw_scale(panel, toptext);
-	fprintf(stderr,
-		"\n"
-		"Left: choose location\n"
-		"Middle: cancel\n" "Right: confirm location\n");
-	switch (button) {
-	case 1:
-	    R_panel_restore(panel);
-	    break;
-	case 2:
-	    return 0;
-	case 3:
-	    R_panel_delete(panel);
-	    return 1;
Modified: grass/trunk/display/d.barscale/options.h
--- grass/trunk/display/d.barscale/options.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.barscale/options.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -9,7 +9,4 @@
 extern int draw;
 /* draw_scale.c */
-int draw_scale(char *save, int toptext);
-/* mouse.c */
-int mouse_query(int toptext);
+int draw_scale(int toptext);
Modified: grass/trunk/display/d.colors/main.c
--- grass/trunk/display/d.colors/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.colors/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -37,15 +37,6 @@
     G_gisinit(argv[0]);
-    /* Try to get default raster name, don't fail so --interface-description works */
-    /* don't let R_open_driver() kill us */
-    R__open_quiet();
-    if (R_open_driver() == 0) {
-	if (D_get_cell_name(name) < 0)
-	    *name = 0;
-	R_close_driver();
     module = G_define_module();
     module->keywords = _("display");
Modified: grass/trunk/display/d.colortable/main.c
--- grass/trunk/display/d.colortable/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.colortable/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -35,7 +35,6 @@
     int cols;
     char buff[256];
     char *mapset;
     struct FPRange fp_range;
     struct Colors colors;
@@ -147,11 +146,6 @@
 	G_fatal_error("No graphics device selected");
-	G_fatal_error("No current frame");
-	G_fatal_error("Current frame not available");
     /* Figure out where to put boxes */
@@ -270,8 +264,6 @@
     R_close_driver();
     return 0;
Modified: grass/trunk/display/d.erase/main.c
--- grass/trunk/display/d.erase/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.erase/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -21,10 +21,8 @@
 int main(int argc, char *argv[])
     struct Option *color;
-    struct Flag *eraseframe, *dontaddtolist;
+    struct Flag *eraseframe;
-    char name[256], buf[128];
-    char *err;
     G_gisinit(argv[0]);
@@ -48,40 +46,19 @@
     eraseframe->key = 'f';
     eraseframe->description = _("Remove all frames and erase the screen");
-    dontaddtolist = G_define_flag();
-    dontaddtolist->key = 'x';
-    dontaddtolist->description =
-	_("Don't add to list of commands in monitor");
     if (argc > 1 && G_parser(argc, argv))
 	exit(1);
-    err = NULL;
-    if (D_get_cur_wind(name))
-	err = _("No current frame");
-    else if (D_set_cur_wind(name))
-	err = _("Current frame not available");
-    else {
-	/* D_setup(1);
-	   R_standard_color(D_translate_color(color->answer));
-	   D_erase_window(); */
-	D_erase(color->answer);
+    D_erase(color->answer);
-	if (eraseframe->answer) {
-	    D_full_screen();
-	if (!dontaddtolist->answer) {
-	    sprintf(buf, "d.erase color=%s", color->answer);
-	    D_add_to_list(buf);
+    if (eraseframe->answer) {
+	D_full_screen();
     R_close_driver();
-    if (err)
-	G_fatal_error(err);
     exit(0);
Modified: grass/trunk/display/d.font/main.c
--- grass/trunk/display/d.font/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.font/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -132,7 +132,6 @@
 	R_charset(opt3->answer);
     /* add this command to the list */
     R_close_driver();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.geodesic/main.c
--- grass/trunk/display/d.geodesic/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.geodesic/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -30,7 +30,6 @@
     int line_color;
     int text_color;
-    int use_mouse;
     double lon1, lat1, lon2, lat2;
     char msg[100];
     char *deftcolor;
@@ -53,7 +52,7 @@
     parm.coor->key = "coor";
     parm.coor->key_desc = "lon1,lat1,lon2,lat2";
     parm.coor->type = TYPE_STRING;
-    parm.coor->required = NO;
+    parm.coor->required = YES;
     parm.coor->description = "Starting and ending coordinates";
     parm.lcolor = G_define_option();
@@ -81,29 +80,25 @@
 	exit(1);
-    use_mouse = 1;
-    if (parm.coor->answer) {
-	if (parm.coor->answers[0] == NULL)
-	    G_fatal_error("No coordinates given");
+    if (parm.coor->answers[0] == NULL)
+	G_fatal_error("No coordinates given");
-	if (!G_scan_easting(parm.coor->answers[0], &lon1, G_projection())) {
-	    G_usage();
-	    G_fatal_error("%s - illegal longitude", parm.coor->answers[0]);
-	if (!G_scan_northing(parm.coor->answers[1], &lat1, G_projection())) {
-	    G_usage();
-	    G_fatal_error("%s - illegal longitude", parm.coor->answers[1]);
-	if (!G_scan_easting(parm.coor->answers[2], &lon2, G_projection())) {
-	    G_usage();
-	    G_fatal_error("%s - illegal longitude", parm.coor->answers[2]);
-	if (!G_scan_northing(parm.coor->answers[3], &lat2, G_projection())) {
-	    G_usage();
-	    G_fatal_error("%s - illegal longitude", parm.coor->answers[3]);
-	use_mouse = 0;
+    if (!G_scan_easting(parm.coor->answers[0], &lon1, G_projection())) {
+	G_usage();
+	G_fatal_error("%s - illegal longitude", parm.coor->answers[0]);
+    if (!G_scan_northing(parm.coor->answers[1], &lat1, G_projection())) {
+	G_usage();
+	G_fatal_error("%s - illegal longitude", parm.coor->answers[1]);
+    if (!G_scan_easting(parm.coor->answers[2], &lon2, G_projection())) {
+	G_usage();
+	G_fatal_error("%s - illegal longitude", parm.coor->answers[2]);
+    if (!G_scan_northing(parm.coor->answers[3], &lat2, G_projection())) {
+	G_usage();
+	G_fatal_error("%s - illegal longitude", parm.coor->answers[3]);
@@ -126,14 +121,8 @@
 	text_color = D_translate_color(parm.tcolor->answer);
     setup_plot();
-    if (use_mouse)
-	mouse(line_color, text_color);
-    else
-	plot(lon1, lat1, lon2, lat2, line_color, text_color);
+    plot(lon1, lat1, lon2, lat2, line_color, text_color);
-    if (!use_mouse)
     R_close_driver();
     exit(0);
Deleted: grass/trunk/display/d.geodesic/mouse.c
--- grass/trunk/display/d.geodesic/mouse.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.geodesic/mouse.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,47 +0,0 @@
-#include <stdio.h>
-#include "local_proto.h"
-void mouse(int line_color, int text_color)
-    int x1, y1, x2, y2;
-    double lat1, lon1, lat2, lon2;
-    int top, bottom, left, right;
-    int button;
-    right = (int)D_get_d_east();
-    left = (int)D_get_d_west();
-    top = (int)D_get_d_north();
-    bottom = (int)D_get_d_south();
-    x2 = x1 = (right + left) / 2;
-    y2 = y1 = (top + bottom) / 2;
-    fprintf(stderr, "\n");
-    fprintf(stderr, "Left:   begin\n");
-    fprintf(stderr, "Middle: draw\n");
-    fprintf(stderr, "Right:  quit\n");
-    while (1) {
-	R_standard_color(line_color);
-	R_get_location_with_line(x1, y1, &x2, &y2, &button);
-	if (button == 3)
-	    return;
-	if (x2 < left || x2 > right)
-	    continue;
-	if (y2 < top || y2 > bottom)
-	    continue;
-	if (button == 2) {
-	    lon1 = D_d_to_u_col((double)x1);
-	    lat1 = D_d_to_u_row((double)y1);
-	    lon2 = D_d_to_u_col((double)x2);
-	    lat2 = D_d_to_u_row((double)y2);
-	x1 = x2;
-	y1 = y2;
Modified: grass/trunk/display/d.graph/main.c
--- grass/trunk/display/d.graph/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.graph/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -41,7 +41,6 @@
     struct Option *opt1, *opt2;
     struct Flag *mapcoords;
@@ -115,15 +114,8 @@
     else
 	mapunits = FALSE;
     /* Finish graphics setup */
     R_set_window(t, b, l, r);
     D_setup(0);
@@ -136,9 +128,6 @@
     R_text_rotation(0.0);	/* reset */
     R_line_width(0);		/* reset */
-    if (opt1->answer)
     R_close_driver();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.grid/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -218,8 +218,6 @@
 	plot_border(size, east, north);
     R_close_driver();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.his/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -54,7 +54,6 @@
     struct Option *opt_h, *opt_i, *opt_s, *brighten;
     struct Flag *nulldraw;
     int t, b, l, r;
     double bright_mult;
@@ -116,14 +115,6 @@
-	G_fatal_error(_("No current graphics window"));
-	G_fatal_error(_("Current graphics window not available"));
-    D_set_cell_name("his result");
     /* Prepare the raster cell drawing functions */
     D_set_overlay_mode(nulldraw->answer ? 1 : 0);
@@ -267,7 +258,6 @@
     D_cell_draw_end();
     /* Close down connection to display driver */
     R_close_driver();
     /* Close the raster maps */
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.histogram/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -208,7 +208,6 @@
 	bar(&dist_stats, &pcolors);
     R_flush();
     R_close_driver();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.info/main.c
--- grass/trunk/display/d.info/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.info/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -24,7 +24,6 @@
     struct Flag *rflag, *dflag, *cflag, *fflag, *bflag, *gflag;
     int l, r, t, b;
-    char window_name[128];
     G_gisinit(argv[0]);
@@ -99,18 +98,11 @@
     if (bflag->answer) {
@@ -123,11 +115,6 @@
     if (gflag->answer) {
 	fprintf(stdout, "w=%f\n", window.west);
Modified: grass/trunk/display/d.labels/main.c
--- grass/trunk/display/d.labels/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.labels/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -27,7 +27,6 @@
     char *label_name;
     char *mapset;
     double minreg, maxreg, reg, dx, dy;
@@ -101,7 +100,6 @@
 	if (reg < minreg) {
 	    G_warning(_
 		      ("Region size is lower than minreg, nothing displayed."));
 	    R_close_driver();
 	    exit(0);
@@ -111,7 +109,6 @@
 	if (reg > maxreg) {
 	    G_warning(_
 		      ("Region size is greater than maxreg, nothing displayed."));
 	    R_close_driver();
 	    exit(0);
@@ -122,15 +119,8 @@
     if (infile == NULL)
 	G_fatal_error(_("Unable to open label file <%s>"), label_name);
@@ -143,8 +133,6 @@
     /* Go draw the raster map */
     do_labels(infile, !horiz_flag->answer);
     R_close_driver();
Deleted: grass/trunk/display/d.legend/box.c
--- grass/trunk/display/d.legend/box.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.legend/box.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,47 +0,0 @@
-int get_legend_box(int *x0, int *x1, int *y0, int *y1)
-    int screen_x, screen_y;
-    int button;
-    int cur_screen_x, cur_screen_y;
-    D_get_screen_window(&cur_screen_y, &screen_y, &cur_screen_x, &screen_x);
-    fprintf(stderr, "\n\n");
-    fprintf(stderr, "Buttons:\n");
-    fprintf(stderr, "Left:   Establish a corner\n");
-    fprintf(stderr, "Middle: Cancel\n");
-    fprintf(stderr, "Right:  Accept box for legend\n\n");
-    do {
-	R_get_location_with_box(cur_screen_x, cur_screen_y, &screen_x,
-				&screen_y, &button);
-	button &= 0xf;
-	switch (button) {
-	case 1:
-	    cur_screen_x = screen_x;
-	    cur_screen_y = screen_y;
-	    break;
-	case 2:
-	    return (0);
-	case 3:
-	    break;
-    } while (button != 3);
-    *x0 = cur_screen_x;
-    *x1 = screen_x;
-    *y0 = cur_screen_y;
-    *y1 = screen_y;
-    return (1);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.legend/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -40,7 +40,6 @@
     char *mapset;
     char buff[512];
     char *map_name;
     int black;
     int cats_num;
     int color;
@@ -52,7 +51,7 @@
     int lines, steps;
     int new_colr, fp;
     int t, b, l, r;
-    int hide_catnum, hide_catstr, hide_nodata, do_smooth, use_mouse;
+    int hide_catnum, hide_catstr, hide_nodata, do_smooth;
     char *cstr;
     int white;
     int x_box[5];
@@ -61,7 +60,7 @@
     struct Option *opt1, *opt2, *opt4, *opt5, *opt6, *opt7, *opt8, *opt9;
-    struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *mouse, *flipit;
+    struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *flipit;
     struct Range range;
     struct FPRange fprange;
     CELL min_ind, max_ind, null_cell;
@@ -156,10 +155,6 @@
     opt9->guisection = _("Advanced");
-    mouse->key = 'm';
-    mouse->description = _("Use mouse to size & place legend");
     hidestr = G_define_flag();
     hidestr->key = 'v';
     hidestr->description = _("Do not show category labels");
@@ -196,7 +191,6 @@
     hide_catnum = hidenum->answer;
     hide_nodata = hidenodata->answer;
     do_smooth = smooth->answer;
-    use_mouse = mouse->answer;
     flip = flipit->answer;
     color = 0;			/* if only to get rid of the compiler warning  */
@@ -274,12 +268,6 @@
     white = D_translate_color(DEFAULT_FG_COLOR);
     black = D_translate_color(DEFAULT_BG_COLOR);
@@ -287,39 +275,24 @@
-    if (use_mouse) {
-	if (!get_legend_box(&x0, &x1, &y0, &y1))
-	    exit(EXIT_SUCCESS);
-	G_debug(1, "mouse placement as percentage of display window "
-		"[bottom,top,left,right]:\n  \"at=%.1f,%.1f,%.1f,%.1f\"",
-		100. * (b - y1) / (b - t), 100. * (b - y0) / (b - t),
-		100. * x0 / (r - l), 100. * x1 / (r - l));
-	Y1 = 100. - (y1 - t) * 100. / (b - t);
-	Y0 = 100. - (y0 - t) * 100. / (b - t);
-	X0 = (x0 - l) * 100. / (r - l);
-	X1 = (x1 - l) * 100. / (r - l);
+    if (opt7->answer != NULL) {
+	sscanf(opt7->answers[0], "%lf", &Y1);
+	sscanf(opt7->answers[1], "%lf", &Y0);
+	sscanf(opt7->answers[2], "%lf", &X0);
+	sscanf(opt7->answers[3], "%lf", &X1);
-    else {
-	if (opt7->answer != NULL) {
-	    sscanf(opt7->answers[0], "%lf", &Y1);
-	    sscanf(opt7->answers[1], "%lf", &Y0);
-	    sscanf(opt7->answers[2], "%lf", &X0);
-	    sscanf(opt7->answers[3], "%lf", &X1);
-	else {			/* default */
-	    Y1 = 12;
-	    Y0 = 88;
-	    X0 = 3;
-	    X1 = 7;
-	x0 = l + (int)((r - l) * X0 / 100.);
-	x1 = l + (int)((r - l) * X1 / 100.);
-	y0 = t + (int)((b - t) * (100. - Y0) / 100.);	/* make lower left the origin */
-	y1 = t + (int)((b - t) * (100. - Y1) / 100.);
+    else {			/* default */
+	Y1 = 12;
+	Y0 = 88;
+	X0 = 3;
+	X1 = 7;
+    x0 = l + (int)((r - l) * X0 / 100.);
+    x1 = l + (int)((r - l) * X1 / 100.);
+    y0 = t + (int)((b - t) * (100. - Y0) / 100.);	/* make lower left the origin */
+    y1 = t + (int)((b - t) * (100. - Y1) / 100.);
     if (y0 > y1) {		/* allow for variety in order of corner */
 	flip = !flip;		/*   selection without broken output    */
 	xyTemp = y0;
@@ -496,7 +469,7 @@
 	/* center really tiny legends */
-	if (!use_mouse && opt7->answer == NULL) {	/* if defualt scaling */
+	if (opt7->answer == NULL) {	/* if defualt scaling */
 	    if (!do_smooth && (dots_per_line < 4))	/* if so small that there's no box */
 		if ((b - (dots_per_line * lines)) / (b * 1.0) > 0.15)	/* if there's more than a 15% blank at the bottom */
 		    y0 = ((b - t) - (dots_per_line * lines)) / 2;
@@ -687,7 +660,7 @@
 	    /* scale text to fit in window if position not manually set */
 	    /* usually not needed, except when frame is really narrow   */
-	    if (!use_mouse && opt7->answer == NULL) {	/* ie defualt scaling */
+	    if (opt7->answer == NULL) {	/* ie defualt scaling */
 		ScaleFactor = ((r - x1) / ((MaxLabelLen + 1) * txsiz * 0.81));	/* ?? txsiz*.81=actual text width. */
 		if (ScaleFactor < 1.0) {
 		    txsiz = (int)(txsiz * ScaleFactor);
@@ -775,7 +748,7 @@
 	txsiz = (int)((y1 - y0) / (2.0 * lines));
 	    ScaleFactor = ((true_r - true_l) / ((MaxLabelLen + 3) * txsiz * 0.81));	/* ?? txsiz*.81=actual text width. */
 		txsiz = (int)floor(txsiz * ScaleFactor);
@@ -917,17 +890,7 @@
 	    R_text(buff);
-    if (use_mouse) {
-	char buf[512];
-	mouse->answer = 0;
-	sprintf(buf, "%s at=%.1f,%.1f,%.1f,%.1f", G_recreate_command(),
-		Y1, Y0, X0, X1);
-    else
     R_close_driver();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.measure/main.c
--- grass/trunk/display/d.measure/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.measure/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -30,7 +30,6 @@
-    char frame[64];
     struct
@@ -86,12 +85,6 @@
-    if (D_get_cur_wind(frame))
-	G_fatal_error(_("No current frame"));
-    if (D_set_cur_wind(frame))
-	G_fatal_error(_("Current frame not available"));
     color1 = D_translate_color(parm.c1->answer);
     color2 = D_translate_color(parm.c2->answer);
     s_flag = parm.s->answer;
Modified: grass/trunk/display/d.nviz/local.h
--- grass/trunk/display/d.nviz/local.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.nviz/local.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,8 +1,3 @@
-static int move(int, int);
-static int cont(int, int);
-static int min_range[5], max_range[5];
-static int which_range;
-static int change_range;
 static double dist, e = 0, n = 0;
 static double DIST, HT;
 int do_profile(double, double, double, double, char *, int, int);
Modified: grass/trunk/display/d.nviz/main.c
--- grass/trunk/display/d.nviz/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.nviz/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -46,7 +46,7 @@
     char outfile[GNAME_MAX];
     int fd, projection;
     char buf[512], buf1[1024], buf2[1024];
-    int screen_x, screen_y, button;
+    int screen_x, screen_y;
     int i, k;
     int frame_start = 0;
     double e1, e2, n1, n2;
@@ -56,7 +56,7 @@
 	struct Option *opt1, *route, *name, *output, *dist, *ht, *frames,
 	    *start;
-	struct Flag *i, *f, *c, *k, *o, *e;
+	struct Flag *f, *c, *k, *o, *e;
     parm;
@@ -112,10 +112,6 @@
     parm.start->description = _("Start frame number (default=0)");
-    parm.i = G_define_flag();
-    parm.i->key = 'i';
-    parm.i->description = _("Interactively select route");
     parm.f = G_define_flag();
     parm.f->key = 'f';
     parm.f->description = _("Full render -- Save images");
@@ -142,7 +138,7 @@
 	exit(EXIT_FAILURE);
     /* check arguments */
-    if ((!parm.i->answer) && (!parm.route->answer))
+    if (!parm.route->answer)
 	G_fatal_error(_
 		      ("Either -i flag and/or route parameter must be used"));
@@ -241,99 +237,34 @@
 	fprintf(fp, "%s", buf1);
-    /* Get coords */
-    /* Select points interactively */
-    if (parm.i->answer) {
-	int count = 0;
+    /* Coords from Command Line */
+    for (i = 0; parm.route->answers[i]; i += 2) {
+	/* Test for number coordinate pairs */
+	k = i;
-	if (R_open_driver() != 0)
-	    G_fatal_error(_("No graphics device selected"));
-	D_setup(0);
+    if (k < 6) {
+	/* Only one coordinate pair supplied */
+	G_fatal_error(_("You must provide at least four points %d"), k);
-	G_setup_plot(D_get_d_north(),
-		     D_get_d_south(),
-		     D_get_d_west(), D_get_d_east(), move, cont);
-	dist = 0;
-	fprintf(stderr, "Use mouse to select Start Point\n");
-	R_get_location_with_pointer(&screen_x, &screen_y, &button);
-	e1 = D_d_to_u_col((double)screen_x);
-	n1 = D_d_to_u_row((double)screen_y);
-	fprintf(stderr, "\nUse mouse to select route \n");
-	fprintf(stderr, "Left:   Mark next point\n");
-	fprintf(stderr, "Middle: Mark next point\n");
-	fprintf(stderr, "Right:  Finish route and exit\n\n");
-	while (button != 3) {
-	    count++;
-	    R_get_location_with_line((int)(0.5 + D_u_to_d_col(e1)),
-				     (int)(0.5 + D_u_to_d_row(n1)), &screen_x,
-	    if (button == 1 || button == 2) {
-		e2 = D_d_to_u_col((double)screen_x);
-		n2 = D_d_to_u_row((double)screen_y);
-	    else {
-		if (e2 == -9999. || n2 == -9999.) {
-		    G_fatal_error(_("You must select more than one point"));
-		break;
-	    /* draw line from p1 to p2 */
-	    G_plot_line(e1, n1, e2, n2);
+    else {
+	for (i = 0; i <= k - 2; i += 2) {
+	    sscanf(parm.route->answers[i], "%lf", &e1);
+	    sscanf(parm.route->answers[i + 1], "%lf", &n1);
+	    sscanf(parm.route->answers[i + 2], "%lf", &e2);
+	    sscanf(parm.route->answers[i + 3], "%lf", &n2);
 	    /* Get profile info */
 	    do_profile(e1, e2, n1, n2, name, fd, data_type);
-	    n1 = n2;
-	    e1 = e2;
-	    R_stabilize();
+	    /* Get last coord */
+	    if (i == k - 2)
+		do_profile(e2, e2, n2, n2, name, fd, data_type);
-	if (count < 4) {
-	    G_fatal_error(_("You must select at least four points"));
-	R_close_driver();
-    else {
+	/* done with coordinates */
-	/* Coords from Command Line */
-	for (i = 0; parm.route->answers[i]; i += 2) {
-	    /* Test for number coordinate pairs */
-	    k = i;
-	if (k < 6) {
-	    /* Only one coordinate pair supplied */
-	    G_fatal_error(_("You must provide at least four points %d"), k);
-	else {
-	    for (i = 0; i <= k - 2; i += 2) {
-		sscanf(parm.route->answers[i], "%lf", &e1);
-		sscanf(parm.route->answers[i + 1], "%lf", &n1);
-		sscanf(parm.route->answers[i + 2], "%lf", &e2);
-		sscanf(parm.route->answers[i + 3], "%lf", &n2);
-		/* Get profile info */
-		do_profile(e1, e2, n1, n2, name, fd, data_type);
-		/* Get last coord */
-		if (i == k - 2)
-		    do_profile(e2, e2, n2, n2, name, fd, data_type);
-    }				/* done with coordinates */
     /* Output final part of script */
     /* generate key-frame script */
     if (key_frames) {
@@ -475,36 +406,6 @@
 }				/* done with do_profile */
-static int move(int x, int y)
-    D_move_abs(x, y);
-    return 0;
-static int cont(int x, int y)
-    if (D_cont_abs(x, y)) {	/* clipped */
-	change_range = 1;
-    else {			/* keep track of left,right x for lines drawn in window */
-	if (change_range) {
-	    which_range++;
-	    min_range[which_range] = max_range[which_range] = x;
-	    change_range = 0;
-	else {
-	    if (x < min_range[which_range])
-		min_range[which_range] = x;
-	    else if (x > max_range[which_range])
-		max_range[which_range] = x;
-    return 0;
  * read_rast
  * function to get raster value at set location
Modified: grass/trunk/display/d.path/main.c
--- grass/trunk/display/d.path/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.path/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -40,7 +40,6 @@
     int type, afield, nfield, geo;
     struct color_rgb color, hcolor, bgcolor;
     int r, g, b;
-    int use_mouse;
     double x1, y1, x2, y2;
@@ -62,7 +61,7 @@
     coor_opt->key = "coor";
     coor_opt->key_desc = "x1,y1,x2,y2";
     coor_opt->type = TYPE_STRING;
-    coor_opt->required = NO;
+    coor_opt->required = YES;
     coor_opt->description = _("Starting and ending coordinates");
     afield_opt = G_define_standard_option(G_OPT_V_FIELD);
@@ -137,24 +136,19 @@
     nfield = atoi(nfield_opt->answer);
-    use_mouse = TRUE;
-    if (coor_opt->answer) {
-	if (coor_opt->answers[0] == NULL)
-	    G_fatal_error(_("No coordinates given"));
+    if (coor_opt->answers[0] == NULL)
+	G_fatal_error(_("No coordinates given"));
-	if (!G_scan_easting(coor_opt->answers[0], &x1, G_projection()))
-	    G_fatal_error(_("%s - illegal x value"), coor_opt->answers[0]);
-	if (!G_scan_northing(coor_opt->answers[1], &y1, G_projection()))
-	    G_fatal_error(_("%s - illegal y value"), coor_opt->answers[1]);
-	if (!G_scan_easting(coor_opt->answers[2], &x2, G_projection()))
-	    G_fatal_error(_("%s - illegal x value"), coor_opt->answers[2]);
-	if (!G_scan_northing(coor_opt->answers[3], &y2, G_projection()))
-	    G_fatal_error(_("%s - illegal y value"), coor_opt->answers[3]);
+    if (!G_scan_easting(coor_opt->answers[0], &x1, G_projection()))
+	G_fatal_error(_("%s - illegal x value"), coor_opt->answers[0]);
+    if (!G_scan_northing(coor_opt->answers[1], &y1, G_projection()))
+	G_fatal_error(_("%s - illegal y value"), coor_opt->answers[1]);
+    if (!G_scan_easting(coor_opt->answers[2], &x2, G_projection()))
+	G_fatal_error(_("%s - illegal x value"), coor_opt->answers[2]);
+    if (!G_scan_northing(coor_opt->answers[3], &y2, G_projection()))
+	G_fatal_error(_("%s - illegal y value"), coor_opt->answers[3]);
-	use_mouse = FALSE;
@@ -204,10 +198,7 @@
     Vect_net_build_graph(&Map, type, afield, nfield, afcol->answer,
 			 abcol->answer, ncol->answer, geo, 0);
-    if (use_mouse)
-	path(&Map, &color, &hcolor, &bgcolor, bold_f->answer);
-    else
-	coor_path(&Map, &hcolor, bold_f->answer, x1, y1, x2, y2);
+    coor_path(&Map, &hcolor, bold_f->answer, x1, y1, x2, y2);
     R_close_driver();
Modified: grass/trunk/display/d.path/proto.h
--- grass/trunk/display/d.path/proto.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.path/proto.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,5 +1,2 @@
-int path(struct Map_info *, const struct color_rgb *,
-	 const struct color_rgb *, const struct color_rgb *, int);
 int coor_path(struct Map_info *, const struct color_rgb *, int,
 	      double, double, double, double);
Modified: grass/trunk/display/d.path/select.c
--- grass/trunk/display/d.path/select.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.path/select.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -12,161 +12,6 @@
 #define WDTH 5
-int display(struct Map_info *Map, struct line_pnts *,
-	    const struct color_rgb *, int, int, int);
-int path(struct Map_info *Map, const struct color_rgb *color,
-	 const struct color_rgb *hcolor, const struct color_rgb *bgcolor,
-	 int be_bold)
-    int button, ret;
-    double x, y, nx, ny, fx, fy, tx, ty, msize;
-    double x1, y1, x2, y2, maxdist;
-    struct line_pnts *Points;
-    int node;
-    int from_disp = 0, to_disp = 0, sp_disp = 0, from_node = 0, to_node = 0;
-    Points = Vect_new_line_struct();
-    msize = 10 * (D_d_to_u_col(2.0) - D_d_to_u_col(1.0));	/* do it better */
-    G_debug(1, "msize = %f\n", msize);
-    G_message(_("\nMouse Buttons:"));
-    fprintf(stderr, _("Left:   Select From\n"));
-    fprintf(stderr, _("Middle: Select To\n"));
-    fprintf(stderr, _("Right:  Quit\n\n"));
-    while (1) {
-	x = D_d_to_u_col((double)(screen_x));
-	y = D_d_to_u_row((double)(screen_y));
-	/* fprintf (stderr, "%f %f\n", x, y); */
-	x1 = D_d_to_u_col((double)(screen_x - WDTH));
-	y1 = D_d_to_u_row((double)(screen_y - WDTH));
-	x2 = D_d_to_u_col((double)(screen_x + WDTH));
-	y2 = D_d_to_u_row((double)(screen_y + WDTH));
-	x1 = fabs(x2 - x1);
-	y1 = fabs(y2 - y1);
-	if (x1 > y1)
-	    maxdist = x1;
-	else
-	    maxdist = y1;
-	G_debug(1, "Maximum distance in map units = %f\n", maxdist);
-	node = Vect_find_node(Map, x, y, 0.0, maxdist, 0);
-	if (node > 0) {
-	    Vect_get_node_coor(Map, node, &nx, &ny, NULL);
-	    fprintf(stderr, _("Node %d: %f %f\n"), node, nx, ny);
-	if (sp_disp) {		/* erase old */
-	    /* delete old highlight */
-	    display(Map, Points, color, from_node, to_node, be_bold);
-	    R_RGB_color(bgcolor->r, bgcolor->g, bgcolor->b);
-	    if (!from_node)
-		G_plot_line(Points->x[0], Points->y[0], Points->x[1],
-			    Points->y[1]);
-	    if (!to_node)
-		G_plot_line(Points->x[Points->n_points - 2],
-			    Points->y[Points->n_points - 2],
-			    Points->x[Points->n_points - 1],
-			    Points->y[Points->n_points - 1]);
-	switch (button) {
-	case 1:
-	    if (from_disp) {
-		G_plot_icon(fx, fy, G_ICON_BOX, 0.0, msize);
-	    if (node > 0) {
-		fx = nx;
-		fy = ny;
-		from_node = 1;
-	    else {
-		fx = x;
-		fy = y;
-		from_node = 0;
-	    R_RGB_color(hcolor->r, hcolor->g, hcolor->b);
-	    R_flush();
-	    from_disp = 1;
-	    break;
-	case 2:
-	    if (to_disp) {
-		G_plot_icon(tx, ty, G_ICON_CROSS, 0.0, msize);
-	    if (node > 0) {
-		tx = nx;
-		ty = ny;
-		to_node = 1;
-	    else {
-		tx = x;
-		ty = y;
-		to_node = 0;
-	    R_flush();
-	    to_disp = 1;
-	    break;
-	case 3:
-	    if (from_disp) {
-	    if (to_disp) {
-	    return 1;
-	    break;
-	if (from_disp && to_disp) {
-	    double fdist, tdist, cost;
-	    G_debug(2, "find path %f %f -> %f %f", fx, fy, tx, ty);
-	    ret =
-		Vect_net_shortest_path_coor(Map, fx, fy, 0.0, tx, ty, 0.0,
-					    5 * maxdist, 5 * maxdist, &cost,
-					    Points, NULL, NULL, NULL, &fdist,
-					    &tdist);
-	    if (ret == 0) {
-		fprintf(stdout, _("Destination unreachable\n"));
-		sp_disp = 0;
-	    else {
-		fprintf(stdout, _("Costs on the network = %f\n"), cost);
-		fprintf(stdout, _("  Distance to the network = %f, "
-				  "distance from the network = %f\n\n"),
-			fdist, tdist);
-		display(Map, Points, hcolor, 1, 1, be_bold);
-		sp_disp = 1;
-	R_flush();
-    return 0;
 int display(struct Map_info *Map, struct line_pnts *Points,
 	    const struct color_rgb *color, int first, int last, int be_bold)
Modified: grass/trunk/display/d.rast/display.c
--- grass/trunk/display/d.rast/display.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rast/display.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -12,7 +12,7 @@
 int display(char *name,
 	    char *mapset,
 	    int overlay,
-	    char *bg, RASTER_MAP_TYPE data_type, int invert, int nocmd)
+	    char *bg, RASTER_MAP_TYPE data_type, int invert)
     int r, g, b;
@@ -40,14 +40,6 @@
     /* release the colors now */
     G_free_colors(&colors);
-    /* record the raster map */
-    if (!nocmd) {
-	D_set_cell_name(G_fully_qualified_name(name, mapset));
-	D_add_to_cell_list(G_fully_qualified_name(name, mapset));
     return 0;
Modified: grass/trunk/display/d.rast/local_proto.h
--- grass/trunk/display/d.rast/local_proto.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rast/local_proto.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -3,7 +3,7 @@
 int get_rgb(char *, int *, int *, int *);
 /* display.c */
-int display(char *, char *, int, char *, RASTER_MAP_TYPE, int, int);
+int display(char *, char *, int, char *, RASTER_MAP_TYPE, int);
 int mask_raster_array(void *, int, int, RASTER_MAP_TYPE);
 /* main.c */
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rast/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -42,7 +42,6 @@
     struct Option *bg;
     struct Flag *flag_o;
     struct Flag *flag_i;
-    struct Flag *flag_x;
     G_gisinit(argv[0]);
@@ -93,11 +92,6 @@
     flag_i->key = 'i';
     flag_i->description = _("Invert catlist");
-    flag_x = G_define_flag();
-    flag_x->key = 'x';
-    flag_x->description =
-	_("Don't add to list of rasters and commands in monitor");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -132,11 +126,9 @@
     /* use DCELL even if the map is FCELL */
     if (fp)
-	display(name, mapset, overlay, bg->answer, DCELL_TYPE, invert,
-		flag_x->answer);
+	display(name, mapset, overlay, bg->answer, DCELL_TYPE, invert);
     else
-	display(name, mapset, overlay, bg->answer, CELL_TYPE, invert,
-		flag_x->answer);
+	display(name, mapset, overlay, bg->answer, CELL_TYPE, invert);
     R_close_driver();
Modified: grass/trunk/display/d.rast.arrow/arrow.c
--- grass/trunk/display/d.rast.arrow/arrow.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rast.arrow/arrow.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -64,7 +64,6 @@
 double D_ew, D_ns;
 char *mapset;
 char layer_name[128];
-int layer_set;
 int map_type, arrow_color, grid_color, x_color, unknown_color;
@@ -72,10 +71,8 @@
     extern double D_ew, D_ns;
     extern int D_x, D_y;
     int t, b, l, r;
-    char full_name[128];
     RASTER_MAP_TYPE raster_type, mag_raster_type = -1;
     int layer_fd;
     void *raster_row, *ptr;
@@ -115,7 +112,7 @@
     opt1 = G_define_option();
     opt1->key = "map";
     opt1->type = TYPE_STRING;
-    opt1->required = NO;
+    opt1->required = YES;
     opt1->multiple = NO;
     opt1->gisprompt = "old,cell,raster";
     opt1->description = _("Name of raster aspect map to be displayed");
@@ -189,16 +186,10 @@
 	exit(-1);
-    if (opt1->answer) {
-	G_strncpy(layer_name, opt1->answer, sizeof(layer_name) - 1);
-	if ((mapset = G_find_cell2(layer_name, "")) == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"), layer_name);
-	layer_set = 1;
-    else
-	layer_set = 0;
+    G_strncpy(layer_name, opt1->answer, sizeof(layer_name) - 1);
+    if ((mapset = G_find_cell2(layer_name, "")) == NULL)
+	G_fatal_error(_("Raster map <%s> not found"), layer_name);
     arrow_color = D_translate_color(opt3->answer);
     x_color = D_translate_color(opt5->answer);
     unknown_color = D_translate_color(opt6->answer);
@@ -245,17 +236,10 @@
@@ -362,19 +346,6 @@
-    /* if we didn't get a layer name from the arg options, then
-       get name of layer that is on the screen */
-    if (!layer_set) {
-	if (D_get_cell_name(full_name))
-	    G_fatal_error(_("No raster map exists in the current window"));
-	mapset = G_find_cell(full_name, "");
-	if (mapset == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"), full_name);
-	sscanf(full_name, "%s", layer_name);
     /* open the raster map */
     layer_fd = G_open_cell_old(layer_name, mapset);
     if (layer_fd < 0)
@@ -596,7 +567,7 @@
     G_close_cell(layer_fd);
     if (opt7->answer)
 	G_close_cell(mag_fd);
     R_close_driver();
     exit(0);
Modified: grass/trunk/display/d.rast.num/number.c
--- grass/trunk/display/d.rast.num/number.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rast.num/number.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -53,7 +53,6 @@
     DCELL *cell;
     char *mapset;
     double D_north, D_east;
     double D_south, D_west;
     double U_east, U_north;
@@ -87,7 +86,6 @@
 	  "displayed to the graphics monitor.");
     opt1 = G_define_standard_option(G_OPT_R_MAP);
     opt2 = G_define_option();
     opt2->key = "grid_color";
@@ -127,12 +125,7 @@
-    if (opt1->answer)
-	strcpy(full_name, opt1->answer);
-    else {
-	    G_fatal_error(_("No raster map exists in current window"));
+    strcpy(full_name, opt1->answer);
     if (strcmp("none", opt2->answer) == 0)
 	grid_color = -1;
@@ -158,18 +151,11 @@
     /* Setup driver and check important information */
@@ -303,7 +289,7 @@
     R_close_driver();
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rgb/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -45,7 +45,6 @@
     int t, b, l, r;
     int i;
@@ -61,10 +60,6 @@
     flag_o->key = 'o';
     flag_o->description = _("Overlay (non-null values only)");
-    flag_x->description = _("Don't add to list of commands in monitor");
     for (i = 0; i < 3; i++) {
 	char buff[80];
@@ -138,10 +133,6 @@
     G_percent(window.rows, window.rows, 5);
     D_cell_draw_end();
-    /* Close down connection to window driver */
-    if (!flag_x->answer)
     R_close_driver();
Modified: grass/trunk/display/d.rhumbline/main.c
--- grass/trunk/display/d.rhumbline/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rhumbline/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -31,7 +31,6 @@
     int line_color;
     int text_color = 0;
-    int use_mouse;
     struct
@@ -51,7 +50,7 @@
@@ -78,30 +77,26 @@
 	G_fatal_error("%s: database is not a %s database",
 		      argv[0], G__projection_name(PROJECTION_LL));
-    use_mouse = 1;
-	    G_usage();
-	    G_usage();
+	G_usage();
+	G_usage();
-	    G_usage();
-	    G_usage();
-	use_mouse = 0;
+	G_usage();
+	G_usage();
@@ -125,12 +120,7 @@
 #endif
     setup_plot();
-    if (use_mouse)
-    else {
     R_close_driver();
     exit(0);
Deleted: grass/trunk/display/d.rhumbline/mouse.c
--- grass/trunk/display/d.rhumbline/mouse.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.rhumbline/mouse.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,53 +0,0 @@
-#include <stdio.h>
-int mouse(int line_color, int text_color)
-    int button;
-    while (1) {
-#ifdef DEBUG
-	fprintf(stdout, "button=%d  x1,y1=%d,%d  x2,y2=%d,%d\n", button, x1,
-		y1, x2, y2);
-#endif
-	if (button == 3)
-	    return -1;
-	    continue;
-	    continue;
-	x1 = x2;
-	y1 = y2;
-    return 0;
Modified: grass/trunk/display/d.text.new/main.c
--- grass/trunk/display/d.text.new/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.text.new/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -72,7 +72,7 @@
 static void set_color(char *);
 static int get_coordinates(int *, int *, double *, double *,
-			   struct rectinfo, char **, char, char, char);
+			   struct rectinfo, char **, char, char);
 static void draw_text(char *, int *, int *, int, char *, double, char);
@@ -91,6 +91,7 @@
 	struct Option *font;
 	struct Option *path;
 	struct Option *charset;
+	struct Option *input;
     } opt;
     struct
@@ -99,7 +100,6 @@
 	struct Flag *b;
 	struct Flag *r;
 	struct Flag *s;
-	struct Flag *m;
 	struct Flag *c;
     } flag;
@@ -115,12 +115,10 @@
     char bold;
     /* window info */
-    char win_name[64];
     struct rectinfo win;
     /* command file */
     FILE *cmd_fp;
-    char *cmd_file;
     char buf[512];
@@ -138,8 +136,7 @@
-	_
-	("Draws text in the active display frame on the graphics monitor using the current font.");
+	_("Draws text in the active display frame on the graphics monitor using the current font.");
     opt.text = G_define_option();
     opt.text->key = "text";
@@ -225,9 +222,9 @@
     opt.charset->description =
 	_("Text encoding (only applicable to TrueType fonts)");
-    flag.m = G_define_flag();
-    flag.m->key = 'm';
-    flag.m->description = _("Use mouse to interactively place text");
+    opt.input = G_define_standard_option(G_OPT_F_INPUT);
+    opt.input->required = NO;
+    opt.input->description = _("Input file");
     flag.p = G_define_flag();
     flag.p->key = 'p';
@@ -260,8 +257,6 @@
     /* parse and check options and flags */
     if ((opt.line->answer && opt.at->answer) ||
-	(opt.line->answer && flag.m->answer) ||
-	(opt.at->answer && flag.m->answer) ||
 	(flag.p->answer && flag.g->answer))
 	G_fatal_error(_("Please choose only one placement method"));
@@ -296,12 +291,6 @@
     D_setup(0);
-    if (D_get_cur_wind(win_name))
-    if (D_set_cur_wind(win_name))
     /* figure out where to put text */
     D_get_screen_window(&win.t, &win.b, &win.l, &win.r);
     R_set_window(win.t, win.b, win.l, win.r);
@@ -321,9 +310,9 @@
     orig_x = orig_y = 0;
-    if (opt.at->answer || flag.m->answer) {
+    if (opt.at->answer) {
 	if (get_coordinates(&x, &y, &east, &north,
-			    win, opt.at->answers, flag.m->answer,
+			    win, opt.at->answers,
 			    flag.p->answer, flag.g->answer))
 	    G_fatal_error(_("Invalid coordinates"));
 	orig_x = x;
@@ -348,39 +337,7 @@
 	if (text[0])
 	    draw_text(text, &x2, &y2, size, align, rotation, bold);
-	if (opt.at->answer || opt.line->answer)
-	else {
-	    if (flag.m->answer) {
-		if (flag.p->answer)
-		    sprintf(buf, "%s -p at=%d,%d", argv[0], x, y);
-		else if (flag.g->answer)
-		    sprintf(buf, "%s -g at=%f,%f", argv[0], east, north);
-		else
-		    sprintf(buf, "%s at=%f,%f", argv[0],
-			    (double)(x * 100.0 / (double)(win.r - win.l)),
-			    (double)((win.b - y) * 100.0 / (double)(win.b -
-								    win.t)));
-		sprintf(buf, "%s text=\"%s\"", buf, opt.text->answer);
-		sprintf(buf, "%s size=%s", buf, opt.size->answer);
-		sprintf(buf, "%s color=%s", buf, opt.color->answer);
-		sprintf(buf, "%s align=%s", buf, opt.align->answer);
-		sprintf(buf, "%s rotation=%s", buf, opt.rotation->answer);
-		sprintf(buf, "%s linespacing=%s", buf,
-			opt.linespacing->answer);
-		if (flag.b->answer)
-		    strcat(buf, " -b");
-		if (flag.r->answer)
-		    strcat(buf, " -r");
-		if (flag.s->answer)
-		    strcat(buf, " -s");
-	    else
-		sprintf(buf, "%s line=1", G_recreate_command());
 	/* reset */
 	R_text_size(5, 5);
@@ -390,25 +347,26 @@
 	exit(EXIT_SUCCESS);
-    if (isatty(0))
-	fprintf(stdout,
-		_
-		("\nPlease enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"));
+    if (!opt.input->answer || strcmp(opt.input->answer, "-") == 0)
+	cmd_fp = stdin;
+    else {
+	cmd_fp = fopen(opt.input->answer, "r");
+	if (!cmd_fp)
+	    G_fatal_error(_("Unable to open input file <%s>"), opt.input->answer);
-    cmd_file = G_tempfile();
-    if ((cmd_fp = fopen(cmd_file, "w")) == NULL)
-	G_fatal_error(_("Unable to open temporary file <%s>"), cmd_file);
+    if (isatty(fileno(cmd_fp)))
+	fprintf(stderr,
+		_("\nPlease enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"));
     set_x = set_y = set_l = 0;
     first_text = 1;
     linefeed = 1;
     /* do the plotting */
-    while (fgets(buf, 512, stdin)) {
+    while (fgets(buf, sizeof(buf), cmd_fp)) {
 	int buf_len;
 	char *buf_ptr, *ptr;
-	fprintf(cmd_fp, "%s", buf);
 	buf_len = strlen(buf) - 1;
 	for (; buf[buf_len] == '\r' || buf[buf_len] == '\n'; buf_len--) ;
 	buf[buf_len + 1] = 0;
@@ -559,11 +517,9 @@
-    fclose(cmd_fp);
+    if (cmd_fp != stdin)
+	fclose(cmd_fp);
-    sprintf(buf, "%s < %s", G_recreate_command(), cmd_file);
     /* reset */
     R_text_size(5, 5);
@@ -599,25 +555,12 @@
 static int
 get_coordinates(int *x, int *y, double *east, double *north,
-		struct rectinfo win, char **at, char mouse, char pixel,
+		struct rectinfo win, char **at, char pixel,
 		char geocoor)
-    int i;
     double e, n;
-    if (mouse) {
-	fprintf(stderr, _("Click!\n"));
-	fprintf(stderr, _(" Left:    Place text here\n"));
-	fprintf(stderr, _(" Right:   Quit\n"));
-	R_get_location_with_pointer(x, y, &i);
-	i &= 0x0f;
-	if (i != 1)
-	    return 1;
-	e = D_d_to_u_col((double)*x);
-	n = D_d_to_u_row((double)*y);
-    else if (at) {
+    if (at) {
 	e = atof(at[0]);
 	n = atof(at[1]);
 	if (pixel) {
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.thematic.area/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -56,7 +56,7 @@
     struct Option *field_opt;
     struct Option *render_opt;
     struct Option *legend_file_opt;
-    struct Flag *legend_flag, *algoinfo_flag, *x_flag, *nodraw_flag;
+    struct Flag *legend_flag, *algoinfo_flag, *nodraw_flag;
     struct cat_list *Clist;
     int *cats, ncat, nrec, ctype;
@@ -185,12 +185,6 @@
     nodraw_flag->key = 'n';
     nodraw_flag->description = _("Do not draw map, only output the legend");
-    x_flag = G_define_flag();
-    x_flag->key = 'x';
-    x_flag->description =
-	_("Don't add to list of vectors and commands in monitor "
-	  "(it won't be drawn if the monitor is refreshed)");
     /* Check command line */
 	exit(EXIT_FAILURE);
@@ -467,13 +461,6 @@
 	}			/* end window check if */
-	if (!x_flag->answer) {
-	    D_set_dig_name(G_fully_qualified_name(map_name, mapset));
-	    D_add_to_dig_list(G_fully_qualified_name(map_name, mapset));
 	R_close_driver();
     }				/* end of nodraw_flag condition */
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.vect/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -103,7 +103,7 @@
     struct Option *width_opt, *wcolumn_opt, *wscale_opt;
     struct Flag *verbose_flag;	/* please remove before GRASS 7 released */
-    struct Flag *id_flag, *table_acolors_flag, *cats_acolors_flag, *x_flag,
+    struct Flag *id_flag, *table_acolors_flag, *cats_acolors_flag,
 	*zcol_flag;
     int *cats, ncat;
@@ -363,12 +363,6 @@
     id_flag->guisection = _("Query");
     id_flag->description = _("Use values from 'cats' option as feature id");
     zcol_flag = G_define_flag();
     zcol_flag->key = 'z';
     zcol_flag->description = _("Colorize polygons according to z height)");
@@ -413,9 +407,7 @@
 	minreg = atof(minreg_opt->answer);
 	if (reg < minreg) {
-	    G_message(_
-		      ("Region size is lower than minreg, nothing displayed."));
+	    G_message(_("Region size is lower than minreg, nothing displayed."));
 	    exit(EXIT_SUCCESS);
@@ -423,9 +415,7 @@
 	maxreg = atof(maxreg_opt->answer);
 	if (reg > maxreg) {
-	    G_message(_
-		      ("Region size is greater than maxreg, nothing displayed."));
+	    G_message(_("Region size is greater than maxreg, nothing displayed."));
 	    exit(EXIT_SUCCESS);
@@ -737,13 +727,6 @@
     R_close_driver();
     if (verbose)
Modified: grass/trunk/display/d.vect.chart/main.c
--- grass/trunk/display/d.vect.chart/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.vect.chart/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -279,12 +279,6 @@
 	       sizecol_opt->answer, size, scale,
 	       &ocolor, colors, y_center, max_reference);
-    if (ret == 0) {
-	D_set_dig_name(G_fully_qualified_name(map_opt->answer, mapset));
-	D_add_to_dig_list(G_fully_qualified_name(map_opt->answer, mapset));
     R_close_driver();
     Vect_close(&Map);
Modified: grass/trunk/display/d.what.rast/main.c
--- grass/trunk/display/d.what.rast/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.what.rast/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -30,7 +30,6 @@
-    char temp[128];
     int t, b, l, r;
     int i, j;
     int width, mwidth;
@@ -49,27 +48,13 @@
 	  "within the current geographic region.");
-    /* Don't fail initially if driver open fails, and don't let call kill
-     * us -- set quiet mode
-    R__open_quiet();
-	if (D_get_cell_list(&rast, &nrasts) < 0)
-	    rast = NULL;
-	else {
-	    rast = (char **)G_realloc(rast, (nrasts + 1) * sizeof(char *));
-	    rast[nrasts] = NULL;
-	R_close_driver();
+    rast = NULL;
     opt1->key = "map";
     opt1->multiple = YES;
-    if (rast)
-	opt1->answers = rast;
     opt1->description = _("Name of existing raster map(s)");
     opt1->key_desc = "name";
@@ -96,10 +81,7 @@
 	_
 	("Print out col/row for the entire map in grid resolution of the region");
-    if (!rast)
-	opt1->required = YES;
-    if ((argc > 1 || !rast) && G_parser(argc, argv))
+    if (argc > 1 && G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -109,17 +91,10 @@
-    if (D_get_cur_wind(temp))
-    if (D_set_cur_wind(temp))
-	G_fatal_error(_("Setting graphics window"));
 	G_fatal_error(_("Can't set current graphics window"));
Modified: grass/trunk/display/d.what.vect/main.c
--- grass/trunk/display/d.what.vect/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.what.vect/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -40,7 +40,7 @@
-    struct Flag *once, *terse, *txt, *topo_flag, *flash, *edit_flag;
+    struct Flag *once, *terse, *txt, *topo_flag, *edit_flag;
     struct Option *opt1;
     char *mapset, *openvect();
@@ -56,19 +56,8 @@
 	_("Allows the user to interactively query a vector map layer "
 	  "at user-selected locations within the current geographic region.");
-    /* Conditionalize R_open_driver() so "help" works, open quiet as well */
-    R__open_quiet();
-	if (D_get_dig_list(&vect, &nvects) < 0)
-	    vect = NULL;
-	else {
-	    vect = (char **)G_realloc(vect, (nvects + 1) * sizeof(char *));
-	    vect[nvects] = NULL;
+    vect = NULL;
-	R_close_driver();
     once = G_define_flag();
     once->key = '1';
     once->description = _("Identify just one location");
@@ -78,9 +67,7 @@
-    if (vect)
-	opt1->answers = vect;
     opt1->gisprompt = "old,vector,vector";
     opt1->description = _("Name of existing vector map");
@@ -97,18 +84,11 @@
     topo_flag->key = 'd';
     topo_flag->description = _("Print topological information (debugging)");
-    flash = G_define_flag();
-    flash->key = 'f';
-    flash->description = _("Enable flashing (slower)");
     edit_flag = G_define_flag();
     edit_flag->key = 'e';
     edit_flag->description = _("Open form in edit mode");
-    if (!vect)
-    if ((argc > 1 || !vect) && G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     if (opt1->answers && opt1->answers[0])
@@ -160,14 +140,13 @@
     D_setup(0);
-    what(once->answer, txt->answer, terse->answer, flash->answer,
+    what(once->answer, txt->answer, terse->answer,
 	 width, mwidth, topo_flag->answer, edit_flag->answer);
     for (i = 0; i < nvects; i++)
 	Vect_close(&Map[i]);
     R_close_driver();
-    R_pad_freelist(vect, nvects);
     G_message(_("Done."));
     exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.what.vect/what.c
--- grass/trunk/display/d.what.vect/what.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.what.vect/what.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -15,7 +15,7 @@
 #define WDTH 5
-int what(int once, int txt, int terse, int flash, int width, int mwidth,
+int what(int once, int txt, int terse, int width, int mwidth,
 	 int topo, int edit)
     int type, edit_mode;
@@ -32,7 +32,6 @@
     double maxdist;
     int getz = 0;
     struct field_info *Fi;
-    int flash_basecolr, flash_colr;
     plus_t line, area = 0, centroid;
     int i;
@@ -41,18 +40,12 @@
     char buf[1000], *str, title[500];
     dbString html;
     char *form;
-    char *panell;
     if (terse)
 	txt = 1;		/* force text for terse */
     G_get_set_window(&window);
-    if (flash)
-	G_setup_plot(D_get_d_north(), D_get_d_south(), D_get_d_west(),
-		     D_get_d_east(), D_move_abs, D_cont_abs);
     G_begin_polygon_area_calculations();
     nrows = window.rows;
     ncols = window.cols;
@@ -69,32 +62,15 @@
     else
 	notty = 0;
-    if (flash) {
-	panell = G_tempfile();
-	flash_basecolr = YELLOW;
     do {
-	if (flash)
-	    R_panel_save(panell, R_screen_top(), R_screen_bot(),
-			 R_screen_left(), R_screen_rite());
 	if (!terse)
-	    show_buttons(once, flash);
+	    show_buttons(once);
 	if (!once) {
 	    if (button == 3) {
-		if (flash)
-		    R_panel_delete(panell);
 		break;
 	    if (button == 2) {
-		if (flash) {
-		    flash_basecolr++;
-		    if (flash_basecolr >= G_num_standard_colors())
-			flash_basecolr = 1;
 		continue;
@@ -123,8 +99,6 @@
 	    maxdist = y1;
-	if (flash)
-	    flash_colr = flash_basecolr;
 	F_clear();
 	for (i = 0; i < nvects; i++) {
 	    Vect_reset_cats(Cats);
@@ -325,11 +299,6 @@
-		if (flash) {
-		    flash_line(&Map[i], line, Points, BLACK);
-		    flash_line(&Map[i], line, Points, flash_colr);
 	    if (area > 0) {
@@ -408,11 +377,6 @@
 		if (centroid > 0) {
 		    Vect_read_line(&Map[i], Points, Cats, centroid);
-		if (flash) {
-		    flash_area(&Map[i], area, Points, BLACK);
-		    flash_area(&Map[i], area, Points, flash_colr);
 	    if (Cats->n_cats > 0) {
@@ -490,19 +454,8 @@
 		G_debug(3, db_get_string(&html));
 		F_open(title, db_get_string(&html));
-	    if (flash) {
-		flash_colr++;
-		if (flash_colr >= G_num_standard_colors())
-		    flash_colr = 1;
-	if (flash) {
-	    R_panel_restore(panell);
     } while (!once);
     Vect_destroy_line_struct(Points);
@@ -510,7 +463,7 @@
 /* TODO */
-int show_buttons(int once, int flash)
+int show_buttons(int once)
     if (once) {
 	fprintf(stderr, _("\nClick mouse button on desired location\n\n"));
@@ -520,13 +473,8 @@
 	fprintf(stderr, _("Buttons\n"));
 	fprintf(stderr, _(" Left:  what's here\n"));
-	if (flash) {
-	    fprintf(stderr, _(" Middle: toggle flash color\n"));
-	    nlines = 5;
-	else
-	    nlines = 4;
 	fprintf(stderr, _(" Right: quit\n"));
+	nlines = 4;
     return 0;
Modified: grass/trunk/display/d.what.vect/what.h
--- grass/trunk/display/d.what.vect/what.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.what.vect/what.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -2,8 +2,8 @@
 char *openvect(char *);
 /* what.c */
-int what(int, int, int, int, int, int, int, int);
-int show_buttons(int, int);
+int what(int, int, int, int, int, int, int);
+int show_buttons(int);
 /*flash.c */
 void flash_area(struct Map_info *, plus_t, struct line_pnts *, int);
Modified: grass/trunk/display/d.zoom/main.c
--- grass/trunk/display/d.zoom/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/display/d.zoom/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -37,7 +37,7 @@
 #ifdef QUIET
     struct Flag *quiet;
 #endif
-    struct Flag *just, *full, *hand, *pan, *last;
+    struct Flag *full, *hand, *pan, *last;
     struct Option *rmap, *vmap, *zoom;
     double magnify;
@@ -59,32 +59,13 @@
 	_("Allows the user to change the current geographic "
 	  "region settings interactively, with a mouse.");
-    R__open_quiet();
-	    rast = NULL;
-	else {
+    rast = NULL;
+    vect = NULL;
-	    vect = NULL;
-	else {
-	R_close_driver();
     rmap = G_define_option();
     rmap->key = "rast";
     rmap->type = TYPE_STRING;
     rmap->multiple = YES;
-    if (rast)
-	rmap->answers = rast;
     rmap->required = NO;
     rmap->gisprompt = "old,cell,raster";
     rmap->description = _("Name of raster map");
@@ -93,8 +74,6 @@
     vmap->key = "vector";
     vmap->type = TYPE_STRING;
     vmap->multiple = YES;
-    if (vect)
-	vmap->answers = vect;
     vmap->required = NO;
     vmap->gisprompt = "old,dig,vector";
     vmap->description = _("Name of vector map");
@@ -125,20 +104,11 @@
     hand->key = 'h';
     hand->description = _("Handheld mode");
-    just = G_define_flag();
-    just->key = 'j';
-    just->description = _("Just redraw given maps using default colors");
     last = G_define_flag();
     last->key = 'r';
     last->description = _("Return to previous zoom");
-    if (!rast && !vect) {
-	rmap->required = YES;
-	just->answer = 1;
-    if ((argc > 1 || (!rast && !vect)) && G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     if ((full->answer + pan->answer + hand->answer) > 1)
@@ -153,49 +123,9 @@
 #endif
     cmd = NULL;
-    if (!just->answer) {
-	stat = R_pad_get_item("list", &list, &nlists);
-	R_close_driver();
-	if (stat || !nlists) {
-	    G_message(_("ERROR: can not get \"list\" items"));
-	    G_message(_("-j flag forced"));
-	    just->answer = 1;
-	else {
-	    cmd = (char *)G_malloc(strlen(list[0]) + 1);
-	    strcpy(cmd, list[0]);
-	    for (i = 1; i < nlists; i++) {
-		cmd =
-		    (char *)G_realloc(cmd, strlen(cmd) + strlen(list[i]) + 2);
-		strcat(cmd, "\n");
-		strcat(cmd, list[i]);
+    rast = rmap->answers;
+    vect = vmap->answers;
-    if (just->answer) {
-	if (rmap->answers && rmap->answers[0])
-	    rast = rmap->answers;
-	else {
-	    rast = NULL;
-	    nrasts = 0;
-	if (vmap->answers && vmap->answers[0])
-	    vect = vmap->answers;
-	else {
-	    vect = NULL;
-	    nvects = 0;
-    /* Make sure map is available */
-    if (rmap->required == YES && rmap->answers == NULL)
-	G_fatal_error(_("No map is displayed in GRASS monitor"));
     if (rast) {
@@ -229,9 +159,6 @@
-    if (vmap->required == YES && vmap->answers == NULL)
     if (vect) {
 	struct Map_info Map;
 	BOUND_BOX box;
@@ -343,12 +270,6 @@
     R_close_driver();
-    if (rast)
-	R_pad_freelist(rast, nrasts);
-    if (vect)
     G_message(_("Zooming complete."));
     exit(stat);
Modified: grass/trunk/general/g.mapset/main.c
--- grass/trunk/general/g.mapset/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/general/g.mapset/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -22,8 +22,6 @@
 #include <string.h>
 #include <unistd.h>
 #include <grass/glocale.h>
 #include <grass/spawn.h>
@@ -39,8 +37,7 @@
     char *mapset_old_path, *mapset_new_path;
     char *lock_prog;
     char path[GPATH_MAX];
-    char *shell, *monitor;
-    struct MON_CAP *cap;
+    char *shell;
     G_gisinit(argv[0]);
@@ -92,7 +89,6 @@
     mapset_old = G__getenv("MAPSET");
     G_asprintf(&mapset_old_path, "%s/%s/%s", gisdbase_old, location_old,
 	       mapset_old);
-    monitor = G__getenv("MONITOR");
     /* New values */
     if (gisdbase_opt->answer)
@@ -175,21 +171,6 @@
 		      ("%s is currently running GRASS in selected mapset or lock file cannot be checked"),
 		      G_whoami());
-    /* Erase monitors */
-    G_message(_("Erasing monitors..."));
-    while ((cap = R_parse_monitorcap(MON_NEXT, "")) != NULL) {
-	G__setenv("MONITOR", cap->name);
-	R__open_quiet();
-	    D_erase(DEFAULT_BG_COLOR);
-	    D_add_to_list("d.erase");
-	    R_close_driver();
-	    R_release_driver();
-    if (monitor)
-	G_setenv("MONITOR", monitor);
     /* Clean temporary directory */
     sprintf(path, "%s/etc/clean_temp", G_gisbase());
     G_message(_("Cleaning up temporary files..."));
Modified: grass/trunk/imagery/Makefile
--- grass/trunk/imagery/Makefile	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/imagery/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,7 +1,6 @@
 MODULE_TOPDIR = ..
 SUBDIRS = \
-	i.ask \
 	i.atcorr \
 	i.cluster \
 	i.find \
Modified: grass/trunk/include/Make/Grass.make.in
--- grass/trunk/include/Make/Grass.make.in	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/include/Make/Grass.make.in	2008-08-06 21:50:17 UTC (rev 32584)
@@ -102,6 +102,7 @@
 PNGDRIVER_LIBNAME     = grass_pngdriver
 PSDRIVER_LIBNAME      = grass_psdriver
 CAIRODRIVER_LIBNAME   = grass_cairodriver
+HTMLDRIVER_LIBNAME    = grass_htmldriver
 EDIT_LIBNAME          = grass_edit
 G3D_LIBNAME	      = grass_g3d
 GIS_LIBNAME	      = grass_gis
@@ -200,6 +201,7 @@
 PNGDRIVERLIB  = -l$(PNGDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB) $(PNGLIB)
 PSDRIVERLIB   = -l$(PSDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
 CAIRODRIVERLIB = -l$(CAIRODRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
+HTMLDRIVERLIB = -l$(HTMLDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
 EDITLIB       = -l$(EDIT_LIBNAME) $(GISLIB) $(VASKLIB)
 G3DLIB        = -l$(G3D_LIBNAME) $(GISLIB)
 GISLIB        = -l$(GIS_LIBNAME) $(DATETIMELIB) $(XDRLIB) $(SOCKLIB) $(INTLLIB)
@@ -299,6 +301,7 @@
 PNGDRIVERDEP= $(ARCH_LIBDIR)/$(LIB_PREFIX)$(PNGDRIVER_LIBNAME)$(LIB_SUFFIX)
 PSDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(PSDRIVER_LIBNAME)$(LIB_SUFFIX)
 CAIRODRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CAIRODRIVER_LIBNAME)$(LIB_SUFFIX)
+HTMLDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(HTMLDRIVER_LIBNAME)$(LIB_SUFFIX)
 DSPFDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DSPF_LIBNAME)$(LIB_SUFFIX)
 EDITDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(EDIT_LIBNAME)$(LIB_SUFFIX)
 G3DDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(G3D_LIBNAME)$(LIB_SUFFIX)
Modified: grass/trunk/include/display.h
--- grass/trunk/include/display.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/include/display.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -68,26 +68,10 @@
 void D_box(double, double, double, double);
 void D_line_width(double);
-/* get_win.c */
-int get_win_w_mouse(float *, float *, float *, float *);
-/* ident_win.c */
-int ident_win(char *);
 /* list.c */
-int D_set_cell_name(const char *);
-int D_get_cell_name(char *);
-int D_set_dig_name(const char *);
-int D_get_dig_name(char *);
-int D_add_to_cell_list(const char *);
-int D_get_cell_list(char ***, int *);
-int D_add_to_dig_list(const char *);
-int D_get_dig_list(char ***, int *);
-int D_add_to_list(const char *);
-int D_get_list(char ***, int *);
-int D_clear_window(void);
-int D_set_erase_color(const char *);
-int D_get_erase_color(char *);
+void D_clear_window(void);
+void D_set_erase_color(const char *);
+void D_get_erase_color(char *);
 /* popup.c */
 int D_popup(int, int, int, int, int, int, char *[]);
@@ -130,15 +114,12 @@
 int D_color_number_to_RGB(int, int *, int *, int *);
 /* window.c */
-int D_new_window(char *, int, int, int, int);
-int D_new_window_percent(char *, float, float, float, float);
-int D_set_cur_wind(const char *);
-int D_get_cur_wind(char *);
-int D_show_window(int);
+void D_new_window(char *, int, int, int, int);
+void D_new_window_percent(char *, float, float, float, float);
+void D_show_window(int);
 int D_get_screen_window(int *, int *, int *, int *);
-int D_check_map_window(struct Cell_head *);
-int D_reset_screen_window(int, int, int, int);
-int D_timestamp(void);
+void D_check_map_window(struct Cell_head *);
+void D_reset_screen_window(int, int, int, int);
 void D_remove_window(void);
 void D_erase_window(void);
 void D_erase(const char *);
Deleted: grass/trunk/include/graphics.h
--- grass/trunk/include/graphics.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/include/graphics.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,94 +0,0 @@
- * command esc character
- * set to have most bits (but not all) set to 1
-#define COMMAND_ESC 127
- * BEGIN sync count
- * This is number of zero bytes to be returned by
- * driver in response to a BEGIN request
-#define BEGIN_SYNC_COUNT 32
- * command tokens
- * note: none should be zero, or equal to COMMAND_ESC
-#define GET_NUM_COLORS              1
-#define CONT_ABS                    4
-#define CONT_REL                    5
-#define RGB_COLOR                   6
-#define ERASE                       7
-#define GET_LOCATION_WITH_BOX       8
-#define GET_LOCATION_WITH_LINE      9
-#define GET_LOCATION_WITH_POINTER   10
-#define GRAPH_CLOSE                 11
-#define MOVE_ABS                    13
-#define MOVE_REL                    14
-#define POLYGON_ABS                 15
-#define POLYGON_REL                 16
-#define POLYLINE_ABS                17
-#define POLYLINE_REL                18
-#define POLYDOTS_ABS                19
-#define POLYDOTS_REL                20
-#define SCREEN_LEFT                 25
-#define SCREEN_RITE                 26
-#define SCREEN_BOT                  27
-#define SCREEN_TOP                  28
-#define TEXT                        29
-#define TEXT_SIZE                   30
-#define TEXT_ROTATION               39
-#define SET_WINDOW                  40
-#define GET_TEXT_BOX                42
-#define FONT                        44
-#define RESPOND                     45
-#define BEGIN                       46
-#define STANDARD_COLOR              47
-#define BOX_ABS                     48
-#define BOX_REL                     49
-#define PANEL_SAVE                  53
-#define PANEL_RESTORE               54
-#define PANEL_DELETE                55
-#define PAD_CREATE                  61
-#define PAD_CURRENT                 62
-#define PAD_DELETE                  63
-#define PAD_INVENT                  64
-#define PAD_LIST                    65
-#define PAD_SELECT                  66
-#define PAD_APPEND_ITEM             71
-#define PAD_DELETE_ITEM             72
-#define PAD_GET_ITEM                73
-#define PAD_LIST_ITEMS              74
-#define PAD_SET_ITEM                75
-/* fonts */
-#define FONT_INFO                   76
-#define FONT_LIST                   77
-#define CHARSET                     78
-/* line attributes */
-#define LINE_WIDTH                  79
-/* bitmap */
-#define BITMAP                      80
-/* scaled raster */
-#define BEGIN_SCALED_RASTER         84
-#define SCALED_RASTER               85
-#define END_SCALED_RASTER           86
-/* return codes for pad routines */
-#define OK 0
-#define NO_MEMORY 1
-#define NO_PAD 2
-#define NO_CUR_PAD 3
-#define NO_ITEM 4
-#define DUPLICATE 5
-#define ILLEGAL 6
Deleted: grass/trunk/include/monitors.h
--- grass/trunk/include/monitors.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/include/monitors.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,20 +0,0 @@
-#ifndef _GRASS_MONITORS_H
-#define _GRASS_MONITORS_H
-struct MON_CAP
-    char *name;			/* name of monitor */
-    char *path;			/* full path name to execute monitor */
-    char *comment;		/* like this */
-    char *link;			/* were monitor interfaces to gis */
-    char *tty;			/* where monitor must be run from */
-    char *where;		/* version of above for user */
-#define MON_NEXT 1
-#define MON_NAME 2
-#define MON_PATH 3
-#define MON_LINK 4
-#define MON_CLOSE 5
-#endif
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/include/raster.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,63 +1,12 @@
 #ifndef _GRASS_RASTER_H
 #define _GRASS_RASTER_H
-#include <grass/monitors.h>
-/* common.c */
 void R_flush(void);
-void R_pad_perror(const char *, int);
-void R_pad_freelist(char **, int);
-/* get.c */
-void R_get_location_with_box(int, int, int *, int *, int *);
-void R_get_location_with_line(int, int, int *, int *, int *);
-void R_get_location_with_pointer(int *, int *, int *);
-/* io.c */
-int _send_ident(int);
-int _send_char(const unsigned char *);
-int _send_char_array(int, const unsigned char *);
-int _send_int_array(int, const int *);
-int _send_float_array(int, const float *);
-int _send_int(const int *);
-int _send_float(const float *);
-int _send_text(const char *);
-int _get_char(char *);
-int _get_int(int *);
-int _get_float(float *);
-int _get_text(char *);
-char *_get_text_2(void);
+int R_open_driver(void);
 void R__open_quiet(void);
-int sync_driver(char *name);
-void _hold_signals(int);
 void R_stabilize(void);
-void R_kill_driver(void);
 void R_close_driver(void);
-void R_release_driver(void);
-/* io_fifo.c / io_sock.c */
-int unlock_driver(int);
-int R_open_driver(void);
-/* pad.c */
-int R_pad_create(const char *);
-int R_pad_current(char *);
-int R_pad_delete(void);
-int R_pad_invent(char *);
-int R_pad_list(char ***, int *);
-int R_pad_select(const char *);
-int R_pad_append_item(const char *, const char *, int);
-int R_pad_delete_item(const char *);
-int R_pad_get_item(const char *, char ***, int *);
-int R_pad_list_items(char ***, int *);
-int R_pad_set_item(const char *, const char *);
-/* parse_mon.c */
-struct MON_CAP *R_parse_monitorcap(int, char *);
-/* protocol.c */
 int R_screen_left(void);
 int R_screen_rite(void);
 int R_screen_bot(void);
@@ -94,10 +43,6 @@
 void R_font_list(char ***, int *);
 void R_font_info(char ***, int *);
-void R_panel_save(const char *, int, int, int, int);
-void R_panel_restore(const char *);
-void R_panel_delete(const char *);
 void R_begin_scaled_raster(int, int[2][2], int[2][2]);
 int R_scaled_raster(int, int,
 		    const unsigned char *,
Modified: grass/trunk/lib/Makefile
--- grass/trunk/lib/Makefile	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -9,6 +9,7 @@
 	driver \
 	pngdriver \
 	psdriver \
+	htmldriver \
 	raster \
 	bitmap \
 	btree \
Modified: grass/trunk/lib/cairodriver/Driver.c
--- grass/trunk/lib/cairodriver/Driver.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/cairodriver/Driver.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -32,15 +32,9 @@
     drv.Client_Open = NULL;
     drv.Client_Close = Cairo_Client_Close;
     drv.Erase = Cairo_Erase;
-    drv.Get_with_box = NULL;
-    drv.Get_with_line = NULL;
-    drv.Get_with_pointer = NULL;
     drv.Graph_set = Cairo_Graph_set;
     drv.Graph_close = Cairo_Graph_close;
     drv.Line_width = Cairo_Line_width;
-    drv.Panel_save = NULL;
-    drv.Panel_restore = NULL;
-    drv.Panel_delete = NULL;
     drv.Polydots_abs = NULL;
     drv.Polydots_rel = NULL;
     drv.Polyline_abs = Cairo_Polyline_abs;
@@ -52,8 +46,6 @@
     drv.Scaled_raster = Cairo_scaled_raster;
     drv.End_scaled_raster = Cairo_end_scaled_raster;
     drv.Respond = Cairo_Respond;
-    drv.Work_stream = NULL;
-    drv.Do_work = NULL;
     drv.lookup_color = Cairo_lookup_color;
     drv.color = Cairo_color;
     drv.draw_line = Cairo_draw_line;
Added: grass/trunk/lib/cairodriver/description.html
--- grass/trunk/lib/cairodriver/description.html	                        (rev 0)
+++ grass/trunk/lib/cairodriver/description.html	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,174 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<HTML>
+<HEAD>
+ <TITLE>Cairo driver</TITLE>
+ <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
+ <link rel="stylesheet" href="grassdocs.css" type="text/css">
+</HEAD>
+<BODY bgColor=white>
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<H2>NAME</H2>
+<EM><B>Cairo driver</B></EM> - driver for bitmap or vector output using
+the Cairo graphics library.
+<BR>
+<EM>(drivers)</EM>
+<H2>DESCRIPTION</H2>
+The Cairo driver generates PNG, BMP, PPM, PS, PDF or SVG images from GRASS
+display commands, using the
+<A HREF="http://www.cairographics.org/">Cairo graphics library</A>.
+The image format is selected from the extension of the output file.
+<P>
+It is started as 'pseudo' monitor (output to an image file) and when
+stopped, all output from previously used display commands are written to
+the output file.
+<H2>USAGE</H2>
+<H3>Environment variables</H3>
+Several environment variables affect the operation of the Cairo driver:
+<UL>
+  <LI><B>GRASS_WIDTH=xxx</B><BR>
+     the width of the image.
+  </LI><BR>
+  <LI><B>GRASS_HEIGHT=yyy</B><BR>
+    the height of the image.
+  </LI><BR>
+  <LI><B>GRASS_CAIROFILE=filename</B><BR>
+     the name and format of the resulting image file, default is
+     <tt>map.png</tt>.<BR>
+     The image format is determined from the file extension.<BR>
+     Supported bitmap formats:
+     <UL>
+       <LI><B>.png</B> - Portable Network Graphics (PNG)</LI>
+       <LI><B>.bmp</B> - Windows Bitmap (BMP)</LI>
+       <LI><B>.ppm</B> - Portable Pixmap (PPM)</LI>
+     </UL>
+     Supported vector formats:
+     <UL>
+       <LI><B>.pdf</B> - Portable Document Format (PDF)</LI>
+       <LI><B>.ps</B> - PostScript (PS)</LI>
+       <LI><B>.svg</B> - Scalable Vector Graphics (SVG)</LI>
+     </UL>
+     (Note: Some formats may not be available, depending on your platform and
+     the Cairo library that GRASS was built with.)
+  </LI><BR>
+  <LI><B>GRASS_BACKGROUNDCOLOR=RRGGBB</B><BR>
+     specifies the background color to use in RGB
+    notation (hex values). Default is <b>FFFFFF</b> (white).
+  </LI><BR>
+  <LI><B>GRASS_TRANSPARENT=[TRUE|FALSE]</B><BR>
+    sets transparent background on (TRUE) or off (FALSE, default).
+  </LI><BR>
+  <LI><B>GRASS_AUTO_WRITE=[TRUE|FALSE]</B><BR>
+    if set to <tt>TRUE</tt>, the image file will be written after each
+    operation (i.e. whenever a client disconnects), rather than
+    only being written out when the driver terminates.<BR>
+    (Note: This only applies to bitmap formats - vector formats
+    are always written directly to file).
+  </LI><BR>
+  <LI><B>GRASS_CAIRO_READ</B><BR>
+     if <tt>TRUE</tt>, the Cairo driver will initialize the image from
+    the contents of GRASS_CAIROFILE.<BR>
+    (Note: This is only supported for bitmap formats)
+  </LI><BR>
+  <LI><B>GRASS_CAIRO_MAPPED</B><BR>
+    if <tt>TRUE</tt>, the Cairo driver will map GRASS_CAIROFILE as its framebuffer,
+    rather than using memory. This only works with BMP files.
+  </LI>
+</UL>
+<H3>Examples</H3>
+Example using the driver directly (bash-syntax):
+<div class="code"><PRE>
+export GRASS_WIDTH=800
+export GRASS_HEIGHT=800
+d.mon start=cairo
+d.rast map=elevation.10m
+d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
+d.vect map=roads width=2
+d.mon stop=cairo
+</PRE></div>
+Example using <em><a href="d.out.file.html">d.out.file</a></em>:
+d.mon x0
+d.out.file -c sf_cairo format=png size=800,800
+</PRE></div>
+<P>
+A more complicated example using <em><a href="d.out.file.html">d.out.file</a></em>:
+r.shaded.relief map=elevation.dem
+r.watershed elev=elevation.dem basin=watershed.basin thresh=10000
+d.mon x1
+d.shadedmap rel=elevation.dem.shade drape=watershed.basin bright=30
+d.vect streams color=aqua fcolor=aqua type=area,line
+d.vect roads where="label ~ 'light-duty road'" color=grey
+d.vect roads where="label ~ 'unimproved'" color=orange
+d.vect roads where="label ~ 'secondary highway'" color=100:100:100 width=2
+d.vect roads where="label ~ 'primary highway'" color=50:50:50 width=2
+d.vect railroads col=red width=2
+d.vect roads where="label = 'interstate'" color=black width=3
+d.vect archsites icon=basic/star size=25 fcolor=yellow
+d.font Andale_Mono
+echo "Spearfish, SD" | d.text color=black at=28,53 -b
+d.out.file -c sf_cairo2 format=png
+</PRE></div>
+<H2>NOTES</H2>
+The driver is still in development. Enable it by specifying
+<CODE>--with-cairo</CODE> when configuring GRASS. This
+requires a reasonably recent version of the Cairo libraries
+and a working pkg-config.
+<P>
+Antialiasing is enabled by default for bitmap formats. There is
+currently no way of disabling this.
+<P>
+Cairo supports true vector format output whenever possible. However,
+if the selected format doesn't support a necessary feature, Cairo may
+fall back on rendering a bitmap representation of the image wrapped in
+the selected vector format.
+<P>
+Cairo driver output via <em><A HREF="d.out.file.html">d.out.file</A></em>
+is supported via the -c flag.</P>
+<h2>SEE ALSO</h2>
+<EM>
+<A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
+<A HREF="pngdriver.html">PNG driver</A>,
+<A HREF="psdriver.html">PostScript driver</A>,
+<A href="xdriver.html">XDRIVER</A>
+<BR>
+<A HREF="d.frame.html">d.frame</A>,
+<A href="d.mon.html">d.mon</A>,
+<A href="d.rast.html">d.rast</A>,
+<A href="d.vect.html">d.vect</A>
+<A href="d.out.file.html">d.out.file</A>
+</EM>
+<H2>AUTHOR</H2>
+Lars Ahlzen &lt;<I>lars (at) ahlzen.com</I>&gt;<BR>
+and the GRASS Development Team.
Deleted: grass/trunk/lib/display/get_win.c
--- grass/trunk/lib/display/get_win.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/display/get_win.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,49 +0,0 @@
-#include <stdio.h>
-#include <grass/raster.h>
-int get_win_w_mouse(float *top, float *bottom, float *left, float *right)
-    int button;
-    int st, sb, sl, sr;
-    int t, b, l, r;
-    st = R_screen_top();
-    sb = R_screen_bot();
-    sl = R_screen_left();
-    sr = R_screen_rite();
-    fprintf(stderr, "\nButtons:\n");
-    fprintf(stderr, "Right:  Accept window\n");
-    l = sl;
-    b = sb;
-    r = l + 10;
-    t = b - 10;
-    do {
-	R_get_location_with_box(l, b, &r, &t, &button);
-	if (button == 1) {
-	    l = r;
-	    b = t;
-    if (l > r) {
-	button = l;
-	l = r;
-	r = button;
-    if (t > b) {
-	button = t;
-	t = b;
-	b = button;
-    *bottom = 100. - 100. * (b - st) / (sb - st);
-    *top = 100. - 100. * (t - st) / (sb - st);
-    *left = 100. * (l - sl) / (sr - sl);
-    *right = 100. * (r - sl) / (sr - sl);
-    return 0;
Deleted: grass/trunk/lib/display/ident_win.c
--- grass/trunk/lib/display/ident_win.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/display/ident_win.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,66 +0,0 @@
-#include <string.h>
-#include <grass/display.h>
-int ident_win(char *cur_pad)
-    char **list;
-    char **pads;
-    int count;
-    int closest;
-    int npads;
-    int p;
-    int stat;
-    int x, y, t, b, l, r;
-    int button;
-    int gotone;
-    /* Get list of pads (windows) */
-    R_pad_list(&pads, &npads);
-    button = 1;
-    x = (R_screen_rite() + R_screen_left()) / 2;
-    y = (R_screen_top() + R_screen_bot()) / 2;
-    while (button == 1) {
-	closest = 9999999;
-	gotone = 0;
-	R_get_location_with_pointer(&x, &y, &button);
-	for (p = 0; p < npads; p++) {
-	    if (!strlen(pads[p]))
-		continue;
-	    stat = R_pad_select(pads[p]);
-	    if (stat) {
-		R_pad_perror("ERROR", stat);
-		continue;
-	    /* Check each window's "d_win" */
-	    stat = R_pad_get_item("d_win", &list, &count);
-	    if (stat) {
-		continue;
-	    sscanf(list[0], "%d %d %d %d", &t, &b, &l, &r);
-	    R_pad_freelist(list, count);
-	    /* If chosen point is outside pad window, continue */
-	    if (x < l || x > r || y < t || y > b)
-		continue;
-	    /* If right edge closer than closest, the save pad name */
-	    if ((r - x) >= 0 && (r - x) < closest) {
-		closest = r - x;
-		gotone = 1;
-		strcpy(cur_pad, pads[p]);
-	if (gotone)
-	    D_set_cur_wind(cur_pad);
-    return (button);
Modified: grass/trunk/lib/display/list.c
--- grass/trunk/lib/display/list.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/display/list.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,51 +1,5 @@
 /*  Routines to manage the graphics window contents list
- * D_clear_window()
- *     Removes all information about current window
- * D_add_to_list(string)
- *     Adds string to growing list of screen contents.
- *     "string" is, by convention, a command string.
- * D_get_list(list,count)
- *     returns the list of the commands for the maps currently displayed
- * D_set_cell_name(name)
- *     sets the name of the cell file currently displayed
- * D_get_cell_name(name)
- *     returns the name of the cell file currently displayed
- * D_set_dig_name(name)
- *     sets the name of the dig file currently displayed
- * D_get_dig_name(name)
- *     returns the name of the dig file currently displayed
- * D_set_site_name(name)
- *     sets the name of the site_lists file currently displayed
- * D_get_site_name(name)
- *     returns the name of the site_lists file currently displayed
- * D_add_to_cell_list(name)
- *     adds the name of the cell file currently displayed to cell_list
- * D_get_cell_list(list,count)
- *     returns the list of the cell_list currently displayed
- * D_add_to_dig_list(name)
- *     adds the name of the dig file currently displayed to dig_list
- * D_get_dig_list(list,count)
- *     returns the list of the dig_list currently displayed
- * D_add_to_site_list(name)
- *     adds the name of the site_lists file currently displayed to site_list
- * D_get_site_list(list,count)
- *     returns the list of the site_list currently displayed
  * D_set_erase_color(color)
  *     sets the color name of the current erase color for the window
@@ -61,156 +15,6 @@
- * \brief add raster map name to display list
- * Stores the raster\remarks{As with the change from <i>window</i> to
- * <i>frame</i>, GRASS 4.0 changed word usage from <i>cell</i> to
- * <i>raster.</i> For compatibility with existing code, the routines have not
- * changed their names.} map <b>name</b> in the information associated with
- * the current frame.
- *  \param name
- *  \return int
-int D_set_cell_name(const char *name)
-    R_pad_delete_item("cell");
-    return (R_pad_set_item("cell", name));
- * \brief retrieve raster map name
- * Returns the <b>name</b> of the raster map associated with the current frame.
- *  \param name
- *  \return int
-int D_get_cell_name(char *name)
-    int stat;
-    char **list;
-    int count;
-    if ((stat = R_pad_get_item("cell", &list, &count)))
-	return (-1);
-    strcpy(name, list[0]);
-    return (0);
- * \brief add vector map name to display list
- * Stores the vector map <b>name</b> in the information associated with
- *  \param name
- *  \return int
-int D_set_dig_name(const char *name)
-    R_pad_delete_item("dig");
-    return (R_pad_set_item("dig", name));
- * \brief retrieve vector map name
- * Returns the <b>name</b> of the vector map associated with the current frame.
- *  \param name
- *  \return int
-int D_get_dig_name(char *name)
-    int stat;
-    char **list;
-    int count;
-    if ((stat = R_pad_get_item("dig", &list, &count)))
-	return (-1);
-    return (0);
-int D_add_to_cell_list(const char *name)
-    return (R_pad_append_item("cell_list", name, 1));
-int D_get_cell_list(char ***list, int *count)
-    int stat;
-    if ((stat = R_pad_get_item("cell_list", list, count)))
-	return (-1);
-    return (0);
-int D_add_to_dig_list(const char *name)
-    return (R_pad_append_item("dig_list", name, 1));
-int D_get_dig_list(char ***list, int *count)
-    int stat;
-    if ((stat = R_pad_get_item("dig_list", list, count)))
-	return (-1);
-    return (0);
- * \brief add command to frame display list
- * Adds <b>string</b> to list of screen contents. By convention,
- * <b>string</b> is a command string which could be used to recreate a part of
- * the graphics contents. This should be done for all screen graphics except for
- * the display of raster maps. The <i>D_set_cell_name</i> routine,the
- * <i>D_set_dig_name</i> routine and the <i>D_set_site_name</i> routine
- * are used for this special case.
- *  \param string
- *  \return int
-int D_add_to_list(const char *string)
-    return (R_pad_append_item("list", string, 0));
-int D_get_list(char ***list, int *count)
-    int stat;
-    if ((stat = R_pad_get_item("list", list, count)))
-	return (-1);
-    return (0);
  * \brief clears information about current frame
  * Removes all information about the current frame. This includes the map region and the
@@ -220,49 +24,25 @@
  *  \return int
- * \brief clear frame display lists
- * Removes all display information lists associated with the current frame.
- *  \param ~
- *  \return int
-    R_pad_delete_item("list");
-    R_pad_delete_item("site");
-    R_pad_delete_item("cell_list");
-    R_pad_delete_item("dig_list");
-    R_pad_delete_item("site_list");
-    R_pad_delete_item("m_win");
-    R_pad_delete_item("erase");
-    return 0;
-int D_set_erase_color(const char *colorname)
+static char *erase_color;
+void D_set_erase_color(const char *colorname)
+    if (erase_color)
+	G_free(erase_color);
-    return (R_pad_set_item("erase", colorname));
+    erase_color = G_store(colorname);
-int D_get_erase_color(char *colorname)
+void D_get_erase_color(char *colorname)
-    int stat;
-    char **list;
-    int count;
+    if (!erase_color)
+	erase_color = G_store(DEFAULT_BG_COLOR);
-    if ((stat = R_pad_get_item("erase", &list, &count)))
-	return (-1);
-    strcpy(colorname, list[0]);
-    return (0);
+    strcpy(colorname, erase_color);
Deleted: grass/trunk/lib/display/popup.c
--- grass/trunk/lib/display/popup.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/display/popup.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,210 +0,0 @@
- * D_popup(back_colr, text_colr, div_colr, top, left, percent_per_line, options)
- *    int back_colr ;           color of window
- *    int text_color ;          color of text and border
- *    int div_color ;           color of item divider lines
- *    int left, top ;           pixle coordinates of top-left corner
- *                              (Coordinate system is 0,0 lower left,
- *                              100,100 upper right)
- *    int percent_per_line ;    percent of entire window per line of text
- *    char *options[] ;         array of text showing options.
- *                              The first entry is a title, not an option
- * The bottom-right coordinates are calculated based on the top-left coors.,
- * the percent_per_line, the number of options, and the longest option text
- * length.  If necessary, the window is moved to make sure it is inside
- * the screen.
- * - Current screen contents are stashed away in the area.
- * - Area is blanked with the background color and fringed with the
- *    text color.
- * - Options are drawn using the current font.
- * - User uses the mouse to choose the desired option.
- * - Area is restored with the original contents.
- * - Number of this option is returned to the calling program.
-#include <stdlib.h>
-#include <grass/gis.h>
-#define Y_BORDER	5
-#define X_BORDER	5
- * \brief pop-up menu
- * This routine provides a pop-up type menu
- * on the graphics screen. The <b>bcolor</b> specifies the background color.
- * The <b>tcolor</b> is the text color. The <b>dcolor</b> specifies the color
- * of the line used to divide the menu items. The <b>top</b> and <b>left</b>
- * specify the placement of the top left corner of the menu on the screen. 0,0 is
- * at the bottom left of the screen, and 100,100 is at the top right. The
- * <b>size</b> of the text is given as a percentage of the vertical size of the
- * screen.  The <b>options</b> array is a NULL terminated array of character
- * strings.  The first is a menu title and the rest are the menu options (i.e.,
- * options[0] is the menu title, and options[1], options[2], etc., are the menu
- * options). The last option must be the NULL pointer.
- * The coordinates of the bottom right of the menu are calculated based on the
- * <b>top left</b> coordinates, the <b>size</b>, the number of
- * <b>options</b>, and the longest option text length. If necessary, the menu
- * coordinates are adjusted to make sure the menu is on the screen.
- * <i>D_popup(~)</i> does the following:
- * <ol>
- <li> Current screen contents under the menu are saved.
- </li>
- <li> Area is blanked with the background color and fringed with the text color.
- </li>
- <li> Menu options are drawn using the current font.
- </li>
- <li> User uses the mouse to choose the desired option.
- </li>
- <li> Menu is erased and screen is restored with the original contents.
- </li>
- <li> Number of the selected option is returned to the calling module.
- </li></ol>
- *  \param bcolor
- *  \param tcolor
- *  \param dcolor
- *  \param top
- *  \param left
- *  \param size
- *  \param options[]
- *  \return int
-int D_popup(int back_colr, int text_colr, int div_colr,
-	    int top, int left, int percent_per_line, char *options[])
-    int t, l, b, r;
-    int opt;
-    int x, y;
-    int button;
-    int text_size;
-    int text_raise;
-    int n_options;
-    int max_len;
-    int len;
-    char *panel;
-    int dots_per_line, dots_per_char, height, width;
-    /* Figure the number of options and the max length of options */
-    max_len = 0;
-    for (n_options = 0; options[n_options] != NULL; n_options++) {
-	len = strlen(options[n_options]);
-	if (max_len < len)
-	    max_len = len;
-    /* Figure the dots per line and dots_per_char */
-    height = R_screen_bot() - R_screen_top();
-    width = R_screen_rite() - R_screen_left();
-    dots_per_line = height * percent_per_line / 100;
-    dots_per_char = width / (max_len + 2);
-    /* we want the box to fit into window horizontally */
-    t = R_screen_bot() - (R_screen_bot() - R_screen_top()) * top / 100;
-    l = R_screen_left() + (R_screen_rite() - R_screen_left()) * left / 100;
-    /* Figure the bottom and right of the window */
-    text_size = (int)(.8 * (float)dots_per_line);
-    if (text_size > dots_per_char)
-	text_size = dots_per_char;
-    text_raise = (dots_per_line - text_size + 1) / 2;
-    if (text_raise == 0)
-	text_raise = 1;
-    b = Y_BORDER + t + dots_per_line * n_options;
-    r = 2 * X_BORDER + l + text_size * max_len;
-    /* Adjust, if necessary, to make sure window is all on screen */
-    if (t < R_screen_top()) {
-	b = b + (R_screen_top() - t);
-	t = R_screen_top();
-    if (b > R_screen_bot()) {
-	t = t - (b - R_screen_bot());
-	b = R_screen_bot();
-	G_fatal_error("popup window too big vertically\n");
-    if (l < R_screen_left()) {
-	r = r + (R_screen_left() - l);
-	l = R_screen_left();
-    if (r > R_screen_rite()) {
-	l = l - (r - R_screen_rite());
-	r = R_screen_rite();
-	/* actually, this should never happen */
-	fprintf(stderr, "ERROR:\n");
-	fprintf(stderr, "popup window too big horizontally\n");
-	fprintf(stderr, "to fit into the graphics window.\n");
-	fprintf(stderr, "Widen the graphics window.");
-	fprintf(stderr, "\nExiting...\n");
-	exit(1);
-    /* Make sure text is not drawn outside of window */
-    R_set_window(t, b, l, r);
-    /* Save the panel in some name */
-    panel = G_tempfile();
-    R_panel_save(panel, t, b, l, r);
-    /* Clear the panel */
-    R_standard_color(back_colr);
-    R_box_abs(l, t, r, b);
-    /* Draw border */
-    R_standard_color(text_colr);
-    R_move_abs(l + 1, t + 1);
-    R_cont_abs(r - 1, t + 1);
-    R_cont_abs(r - 1, b - 1);
-    R_cont_abs(l + 1, b - 1);
-    R_cont_abs(l + 1, t + 1);
-    /* Prepare for text */
-    R_text_size(text_size, text_size);
-    /* list the options */
-    for (opt = 1; opt <= n_options; opt++) {
-	if (opt != n_options) {
-	    R_standard_color(div_colr);
-	    R_move_abs(l + 2, t + Y_BORDER + opt * dots_per_line);
-	    R_cont_rel(r - l - 4, 0);
-	R_move_abs(l + X_BORDER,
-		   t + Y_BORDER + opt * dots_per_line - text_raise);
-	R_text(options[opt - 1]);
-    R_flush();
-    x = (l + r) / 2;
-    y = (t + b) / 2;
-    while (1) {
-	int n;
-	if (x > r
-	    || x < l || y < t + Y_BORDER + dots_per_line || y > b - Y_BORDER)
-	    continue;
-	n = y - t - Y_BORDER;
-	if (n % dots_per_line == 0)
-	    continue;
-	R_panel_restore(panel);
-	R_panel_delete(panel);
-	return (n / dots_per_line);
Modified: grass/trunk/lib/display/setup.c
--- grass/trunk/lib/display/setup.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/display/setup.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -59,22 +59,15 @@
 int D_setup(int clear)
     struct Cell_head region;
-    char name[128];
     int t, b, l, r;
-    if (D_get_cur_wind(name)) {
-	strcpy(name, "full_screen");
-	D_new_window(name, t, b, l, r);
+    t = R_screen_top();
+    b = R_screen_bot();
+    l = R_screen_left();
+    r = R_screen_rite();
+    D_new_window("full_screen", t, b, l, r);
-    if (D_set_cur_wind(name))
-	G_fatal_error("Current graphics frame not available");
-    if (D_get_screen_window(&t, &b, &l, &r))
-	G_fatal_error("Getting graphics coordinates");
+    D_get_screen_window(&t, &b, &l, &r);
     /* clear the frame, if requested to do so */
     if (clear) {
@@ -85,8 +78,7 @@
     /* Set the map region associated with graphics frame */
     G_get_set_window(&region);
-    if (D_check_map_window(&region))
-	G_fatal_error("Setting graphics coordinates");
+    D_check_map_window(&region);
     if (G_set_window(&region) < 0)
 	G_fatal_error("Invalid graphics coordinates");
Modified: grass/trunk/lib/display/window.c
--- grass/trunk/lib/display/window.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/display/window.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -7,14 +7,6 @@
  * D_reset_screen_window(t, b, l, r)
  *   resets the edges of the current window
- * D_set_cur_wind(name)
- *   saves "name" in cur_w field in "no-name" pad
- *   outlines previous current window in GRAY
- *   outlines "name" in DEFAULT_FG_COLOR
- * D_get_cur_wind(name)
- *   gets the current name stored in cur_w field in "no_name" pad
  * D_show_window(color)
  *   outlines current window in color (from ../colors.h)
@@ -40,8 +32,50 @@
+static struct {
+    int t, b, l, r;
+} screen_window;
+static int screen_window_set;
+static struct Cell_head map_window;
+static int map_window_set;
+static void D_set_window(int t, int b, int l, int r)
+    screen_window.t = t;
+    screen_window.b = b;
+    screen_window.l = l;
+    screen_window.r = r;
+    screen_window_set = 1;
+ * \brief retrieve current frame coordinates
+ * Returns current frame's
+ * coordinates in the pointers <b>top, bottom, left</b>, and <b>right.</b>
+ *  \param top
+ *  \param bottom
+ *  \param left
+ *  \param right
+ *  \return int
+int D_get_screen_window(int *t, int *b, int *l, int *r)
+    if (!screen_window_set)
+	return -1;
+    *t = screen_window.t;
+    *b = screen_window.b;
+    *l = screen_window.l;
+    *r = screen_window.r;
+    return 0;
  * \brief create new graphics frame
  * Creates a new frame <b>name</b> with
@@ -57,45 +91,13 @@
  *  \return int
-int D_new_window(char *name, int t, int b, int l, int r)
+void D_new_window(char *name, int t, int b, int l, int r)
-    int stat;
-    char buff[256];
-    /* If no name was sent, get a unique name for the window */
-    if (!*name)
-	R_pad_invent(name);
-    /* Create the work pad */
-    if ((stat = R_pad_create(name))) {
-	R_pad_perror(name, stat);
-	return (-1);
-    /* Select work pad for use */
-    if ((stat = R_pad_select(name)))
-	goto pad_error;
-    /* Timestamp current pad */
-    D_timestamp();
-    sprintf(buff, "%d %d %d %d", t, b, l, r);
-    if ((stat = R_pad_set_item("d_win", buff)))
-	goto pad_error;
+    screen_window_set = 0;
+    map_window_set = 0;
     /* Display outline of new window */
     D_show_window(GRAY);
-    return (0);
-  pad_error:
-    R_pad_delete();
-    sprintf(buff, "window <%s>, item <%s>", name, "d_win");
-    R_pad_perror(buff, stat);
-    return (-1);
+    D_set_window(t, b, l, r);
@@ -115,7 +117,7 @@
  *  \return int
-int D_new_window_percent(char *name, float b, float t, float l, float r)
+void D_new_window_percent(char *name, float b, float t, float l, float r)
     int scr_t = R_screen_top();
     int scr_b = R_screen_bot();
@@ -136,113 +138,11 @@
     if (win_r > scr_r)
 	win_r = scr_r;
-    return D_new_window(name, win_t, win_b, win_l, win_r);
+    D_new_window(name, win_t, win_b, win_l, win_r);
- * \brief set current graphics frame
- * Selects the frame <b>name</b> to be the current frame. The previous current frame
- * (if there was one) is outlined in grey. The selected current frame is outlined
- * in white.
- *  \param name
- *  \return int
-int D_set_cur_wind(const char *name)
-    char pad_cur[64];
-    int stat;
-    int not_same_window;
-    int t, b, l, r;
-    /* Abort if window name is null */
-    if (!strlen(name))
-	return (-1);
-    /* Abort if window name is not available */
-	return (stat);
-    /* Get name of current window pad */
-    D_get_cur_wind(pad_cur);
-    /* Establish whether it is the same as the currently selected pad */
-    if (strlen(pad_cur)) {
-	not_same_window = strcmp(name, pad_cur);
-	if (not_same_window) {
-	    R_pad_select(pad_cur);
-	    D_show_window(GRAY);
-    else {
-	not_same_window = 1;
-	/* Delete the current window name in no-name pad */
-	R_pad_select("");
-	if ((stat = R_pad_delete_item("cur_w")))
-	    return (stat);
-	/* Update the current window name in no-name pad */
-	if ((stat = R_pad_set_item("cur_w", name)))
-	    return (stat);
-	/* Select new window pad */
-	    return (stat);
-	/* Outline new window in highlight color */
-	D_show_window(D_translate_color(DEFAULT_FG_COLOR));
-	/* Tell driver of current window */
-	D_get_screen_window(&t, &b, &l, &r);
-    else {
-	    return (stat);
-    return (0);
- * \brief identify current graphics frame
- * Captures the name of the current frame in string <b>name.</b>
- *  \param name
- *  \return int
-int D_get_cur_wind(char *name)
-    int count;
-    int stat;
-    char **list;
-    if ((stat = R_pad_select("")))
-	return (stat);
-    if ((stat = R_pad_get_item("cur_w", &list, &count))) {
-	strcpy(name, "");
-	return (stat);
-    R_pad_select(name);
-    return (0);
  * \brief outlines current frame
  * Outlines
@@ -255,15 +155,13 @@
  *  \return int
-int D_show_window(int color)
+void D_show_window(int color)
     int t, b, l, r;
-    int stat;
-    if ((stat = D_get_screen_window(&t, &b, &l, &r)))
-	return (stat);
-    R_set_window(t - 1, b + 1, l - 1, r + 1);
+    D_set_window(t - 1, b + 1, l - 1, r + 1);
     R_standard_color(color);
     R_move_abs(l - 1, b);
@@ -273,43 +171,11 @@
     R_cont_abs(l - 1, b);
     R_flush();
-    return (0);
- * \brief retrieve current frame coordinates
- * Returns current frame's
- * coordinates in the pointers <b>top, bottom, left</b>, and <b>right.</b>
- *  \param top
- *  \param bottom
- *  \param left
- *  \param right
- *  \return int
-int D_get_screen_window(int *t, int *b, int *l, int *r)
-    int stat;
-    int count;
-    char **list;
-    if ((stat = R_pad_get_item("d_win", &list, &count)))
-	return (stat);
-    sscanf(list[0], "%d %d %d %d", t, b, l, r);
-    return (0);
  * \brief assign/retrieve current map region
  * Graphics frames can have GRASS map regions associated with
@@ -323,51 +189,15 @@
  *  \return int
-int D_check_map_window(struct Cell_head *wind)
+void D_check_map_window(struct Cell_head *wind)
-    char buff[256];
-    char ebuf[64], nbuf[64], sbuf[64], wbuf[64];
-    int num;
-    int count;
-    char **list;
-    char *err;
-    if (0 != R_pad_get_item("m_win", &list, &count)) {
-	G_format_easting(wind->east, ebuf, wind->proj);
-	G_format_easting(wind->west, wbuf, wind->proj);
-	G_format_northing(wind->north, nbuf, wind->proj);
-	G_format_northing(wind->south, sbuf, wind->proj);
-	sprintf(buff, "%d %d %s %s %s %s %d %d",
-		wind->proj, wind->zone,
-		ebuf, wbuf, nbuf, sbuf, wind->rows, wind->cols);
-	if (R_pad_set_item("m_win", buff))
-	    return (-1);
-	return (0);
+    if (map_window_set)
+	*wind = map_window;
+    else
+	map_window = *wind;
+	map_window_set = 1;
-    else {
-	num = sscanf(list[0], "%d %d %s %s %s %s %d %d",
-		     &wind->proj, &wind->zone,
-		     ebuf, wbuf, nbuf, sbuf, &wind->rows, &wind->cols);
-	if (num != 8)
-	    return -2;
-	if (!G_scan_easting(ebuf, &wind->east, wind->proj))
-	    return -2;
-	if (!G_scan_easting(wbuf, &wind->west, wind->proj))
-	    return -2;
-	if (!G_scan_northing(nbuf, &wind->north, wind->proj))
-	    return -2;
-	if (!G_scan_northing(sbuf, &wind->south, wind->proj))
-	    return -2;
-	if ((err = G_adjust_Cell_head(wind, 1, 1)))
-	    return -2;
-	return 0;
@@ -384,68 +214,16 @@
  *  \return int
-int D_reset_screen_window(int t, int b, int l, int r)
+void D_reset_screen_window(int t, int b, int l, int r)
-    int stat;
-    char buff[256];
     D_show_window(D_translate_color(DEFAULT_BG_COLOR));
-    R_pad_delete_item("d_win");
-	return (stat);
-    return (0);
- * \brief give current time to frame
- * Timestamp the current
- * frame. This is used primarily to identify which frames are on top of other,
- * specified frames.
- *  \param ~
- *  \return int
-    char buff[128];
-    int stat;
-    int count;
-    char **list;
-    char cur_pad[64];
-    int cur_time;
-    R_pad_current(cur_pad);
-    R_pad_select("");
-    if ((stat = R_pad_get_item("time", &list, &count))) {
-	R_pad_set_item("time", "1");
-	R_pad_select(cur_pad);
-	return (1);
-    sscanf(list[0], "%d", &cur_time);
-    sprintf(buff, "%d", cur_time + 1);
-    R_pad_set_item("time", buff);
-    R_pad_delete_item("time");
-    return (R_pad_set_item("time", buff));
  * \brief remove a frame
  * Removes any trace of the
@@ -456,9 +234,8 @@
-    R_pad_delete();
-    R_pad_select("");
-    R_pad_delete_item("cur_w");
@@ -500,20 +277,8 @@
 void D_remove_windows(void)
-    char **pads;
-    int npads;
-    int i;
-    R_pad_select("");
-    for (i = 0; i < npads; i++) {
-	R_pad_select(pads[i]);
-	R_pad_delete();
 void D_full_screen(void)
@@ -521,9 +286,8 @@
     D_remove_windows();
     D_new_window_percent("full_screen", 0.0, 100.0, 0.0, 100.0);
-    if (D_set_cur_wind("full_screen") == 0)
-	D_timestamp();
     R_standard_color(D_translate_color(DEFAULT_BG_COLOR));
     R_erase();
Deleted: grass/trunk/lib/driver/Get_location.c
--- grass/trunk/lib/driver/Get_location.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/Get_location.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,41 +0,0 @@
-#include "driver.h"
-#include "driverlib.h"
-int COM_Get_location_with_pointer(int *wx, int *wy, int *button)
-    int ret = 0;
-    if (driver->Get_with_pointer) {
-	ret = (*driver->Get_with_pointer) (wx, wy, button);
-	if (*button >= 1 && *button <= 3)
-	    *button = mouse_button[*button - 1];
-    return ret;
-int COM_Get_location_with_line(int cx, int cy, int *wx, int *wy, int *button)
-    int ret = 0;
-    if (driver->Get_with_line) {
-	ret = (*driver->Get_with_line) (cx, cy, wx, wy, button);
-    return ret;
-int COM_Get_location_with_box(int cx, int cy, int *wx, int *wy, int *button)
-    int ret = 0;
-    if (driver->Get_with_box) {
-	ret = (*driver->Get_with_box) (cx, cy, wx, wy, button);
-    return ret;
Modified: grass/trunk/lib/driver/Makefile
--- grass/trunk/lib/driver/Makefile	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -6,46 +6,6 @@
 EXTRA_LIBS=$(GISLIB) $(FTLIB) $(ICONVLIB)
 LIB_NAME = $(DRIVER_LIBNAME)
-LIB_OBJS =\
-	Bitmap.o\
-	Box.o\
-	Client.o\
-	Color.o\
-	Cont.o\
-	Draw.o\
-	Erase.o\
-	Font.o\
-	Get_location.o\
-	Get_t_box.o\
-	Graph.o\
-	Line_width.o\
-	Move.o\
-	Panel.o\
-	Polydots.o\
-	Polyline.o\
-	Polygon.o\
-	Raster.o\
-	Respond.o\
-	Returns.o\
-	Set_window.o\
-	Text.o\
-	Text_size.o\
-	Work.o\
-	font2.o\
-	font_freetype.o\
-	init.o\
-	pad.o\
-	parse_ftcap.o\
-	text2.o\
-	text3.o
-ifneq ($(HAVE_SOCKET),)
-  LIB_OBJS += \
-	main.o\
-	command.o\
-	connect_sock.o
-endif
 include $(MODULE_TOPDIR)/include/Make/Lib.make
 default: lib
Deleted: grass/trunk/lib/driver/Panel.c
--- grass/trunk/lib/driver/Panel.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/Panel.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,21 +0,0 @@
-void COM_Panel_save(const char *name, int top, int bottom, int left,
-		    int right)
-    if (driver->Panel_save)
-	(*driver->Panel_save) (name, top, bottom, left, right);
-void COM_Panel_restore(const char *name)
-    if (driver->Panel_restore)
-	(*driver->Panel_restore) (name);
-void COM_Panel_delete(const char *name)
-    if (driver->Panel_delete)
-	(*driver->Panel_delete) (name);
Deleted: grass/trunk/lib/driver/Work.c
--- grass/trunk/lib/driver/Work.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/Work.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,19 +0,0 @@
-int COM_Has_work(void)
-    return driver->Do_work ? 1 : 0;
-int COM_Work_stream(void)
-    return driver->Work_stream ? (*driver->Work_stream) ()
-	: -1;
-void COM_Do_work(int opened)
-    if (driver->Do_work)
-	(*driver->Do_work) (opened);
Deleted: grass/trunk/lib/driver/command.c
--- grass/trunk/lib/driver/command.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/command.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,639 +0,0 @@
- * MODULE:       driver
- * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com> (original contributor)
- *               Jachym Cepicky <jachym les-ejk.cz>
- * PURPOSE:
- * COPYRIGHT:    (C) 2006-2007 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-#include <stdio.h>
-#include <signal.h>
-#include <setjmp.h>
-#include <unistd.h>
-#include <errno.h>
-#include <sys/time.h>
-#include <sys/types.h>
-#include <grass/graphics.h>
-#include "pad.h"
-#include <grass/glocale.h>
-#define REC(a,b)    if ((ateof=rec((a),(b)))) break
-#define RECTEXT(x,s)  if ((ateof=rectext(&x,&s))) break
-#define SEND(a,b)   _send((a),(b))
-#define SENDTEXT(x)  sendtext((x))
-static int rec(void *, int);
-static int rectext(char **, int *);
-static int _send(const void *, int);
-static int sendtext(const char *);
-static int RESULT(int);
-static int _wfd;
-static int _rfd;
-static char inbuf[4096];
-static int n_read;
-static int atbuf;
-static char current_command;
-static int ateof;
-static PAD *curpad;		/* current selected pad */
-static unsigned char *blua;
-static unsigned char *grna;
-static unsigned char *reda;
-static unsigned char *nula;
-static int blu_alloc;
-static int grn_alloc;
-static int red_alloc;
-static int nul_alloc;
-static int *xarray;
-static int *yarray;
-static int n_xarray;
-static int n_yarray;
-static char lc;
-static void *xalloc(void *buf, int *cur, int new, int len)
-    if (*cur < new) {
-	buf = G_realloc(buf, (size_t) new * len);
-	*cur = new;
-    return buf;
-void command_init(int rfd, int wfd)
-    _rfd = rfd;
-    _wfd = wfd;
-    atbuf = n_read = 0;
-    current_command = 0;
-    ateof = 0;
-int LIB_command_get_input(void)
-    return _rfd;
-static void send_fonts(void (*func) (char ***, int *))
-    char **fonts;
-    int num_fonts;
-    int i;
-    (*func) (&fonts, &num_fonts);
-    SEND(&num_fonts, sizeof num_fonts);
-    for (i = 0; i < num_fonts; i++)
-	SENDTEXT(fonts[i]);
-    free_font_list(fonts, num_fonts);
-int process_command(int c)
-    static char *name;
-    static int name_size;
-    static char *text;
-    static int text_size;
-    int t, b, l, r, ret;
-    int x, y;
-    unsigned char red, grn, blu;
-    int number;
-    int index;
-    int button;
-    float wx;
-    ITEM *item;
-    LIST *list;
-    PAD *pad;
-    unsigned char ch;
-    int src[2][2], dst[2][2];
-    switch (c) {
-    case BEGIN:
-	ch = 0;
-	for (index = -10; index < BEGIN_SYNC_COUNT; index++)
-	    SEND(&ch, 1);
-	ch = COMMAND_ESC;
-	SEND(&ch, 1);
-	break;
-    case RESPOND:
-	COM_Respond();
-	SEND(&ch, 1);
-	break;
-    case GET_NUM_COLORS:
-	COM_Number_of_colors(&index);
-	SEND(&index, sizeof index);
-	break;
-    case STANDARD_COLOR:
-	REC(&index, sizeof index);
-	COM_Standard_color(index);
-	break;
-    case RGB_COLOR:
-	REC(&red, sizeof red);
-	REC(&grn, sizeof grn);
-	REC(&blu, sizeof blu);
-	COM_Color_RGB(red, grn, blu);
-	break;
-    case LINE_WIDTH:
-	REC(&number, sizeof number);
-	COM_Line_width(number);
-	break;
-    case CONT_ABS:
-	REC(&x, sizeof x);
-	REC(&y, sizeof y);
-	COM_Cont_abs(x, y);
-	break;
-    case CONT_REL:
-	COM_Cont_rel(x, y);
-	break;
-    case BOX_ABS:
-	REC(&l, sizeof l);
-	REC(&t, sizeof t);
-	REC(&r, sizeof r);
-	REC(&b, sizeof b);
-	COM_Box_abs(l, t, r, b);
-	break;
-    case BOX_REL:
-	COM_Box_rel(l, t);
-	break;
-    case ERASE:
-	COM_Erase();
-	break;
-    case GET_LOCATION_WITH_BOX:
-	COM_Get_location_with_box(t, b, &x, &y, &button);
-	SEND(&x, sizeof x);
-	SEND(&y, sizeof y);
-	SEND(&button, sizeof button);
-	break;
-    case GET_LOCATION_WITH_LINE:
-	COM_Get_location_with_line(t, b, &x, &y, &button);
-	break;
-    case GET_LOCATION_WITH_POINTER:
-	REC(&button, sizeof button);
-	COM_Get_location_with_pointer(&x, &y, &button);
-	break;
-    case GRAPH_CLOSE:
-	COM_Graph_close();
-	exit(0);
-    case MOVE_ABS:
-	COM_Move_abs(x, y);
-	break;
-    case MOVE_REL:
-	COM_Move_rel(x, y);
-	break;
-    case BITMAP:
-	blua =
-	    (unsigned char *)xalloc(blua, &blu_alloc, x * y, sizeof(*blua));
-	REC(blua, x * y * sizeof(char));
-	COM_Bitmap(x, y, index, blua);
-	break;
-    case BEGIN_SCALED_RASTER:
-	REC(&index, sizeof(int));
-	REC(&src[0][0], 4 * sizeof(int));
-	REC(&dst[0][0], 4 * sizeof(int));
-	COM_begin_scaled_raster(index, src, dst);
-	break;
-    case SCALED_RASTER:
-	reda = (unsigned char *)xalloc(reda, &red_alloc, x, sizeof(*reda));
-	grna = (unsigned char *)xalloc(grna, &grn_alloc, x, sizeof(*grna));
-	blua = (unsigned char *)xalloc(blua, &blu_alloc, x, sizeof(*blua));
-	nula = (unsigned char *)xalloc(nula, &nul_alloc, x, sizeof(*nula));
-	REC(reda, x * sizeof(char));
-	REC(grna, x * sizeof(char));
-	REC(blua, x * sizeof(char));
-	REC(nula, x * sizeof(char));
-	ret = COM_scaled_raster(x, y, reda, grna, blua, t ? nula : NULL);
-	SEND(&ret, sizeof ret);
-	break;
-    case END_SCALED_RASTER:
-	COM_end_scaled_raster();
-	break;
-    case POLYGON_ABS:
-	xarray = (int *)xalloc(xarray, &n_xarray, number, sizeof(*xarray));
-	yarray = (int *)xalloc(yarray, &n_yarray, number, sizeof(*yarray));
-	REC(xarray, number * sizeof(xarray[0]));
-	REC(yarray, number * sizeof(yarray[0]));
-	COM_Polygon_abs(xarray, yarray, number);
-	break;
-    case POLYGON_REL:
-	COM_Polygon_rel(xarray, yarray, number);
-	break;
-    case POLYLINE_ABS:
-	COM_Polyline_abs(xarray, yarray, number);
-	break;
-    case POLYLINE_REL:
-	COM_Polyline_rel(xarray, yarray, number);
-	break;
-    case POLYDOTS_ABS:
-	COM_Polydots_abs(xarray, yarray, number);
-	break;
-    case POLYDOTS_REL:
-	COM_Polydots_rel(xarray, yarray, number);
-	break;
-    case SCREEN_LEFT:
-	COM_Screen_left(&index);
-	break;
-    case SCREEN_RITE:
-	COM_Screen_rite(&index);
-	break;
-    case SCREEN_BOT:
-	COM_Screen_bot(&index);
-	break;
-    case SCREEN_TOP:
-	COM_Screen_top(&index);
-	break;
-    case SET_WINDOW:
-	COM_Set_window(t, b, l, r);
-	break;
-    case GET_TEXT_BOX:
-	RECTEXT(text, text_size);
-	COM_Get_text_box(text, &t, &b, &l, &r);
-	SEND(&t, sizeof t);
-	SEND(&b, sizeof b);
-	SEND(&l, sizeof l);
-	SEND(&r, sizeof r);
-	break;
-    case FONT:
-	COM_Font_get(text);
-	break;
-    case CHARSET:
-	COM_Font_init_charset(text);
-	break;
-    case FONT_LIST:
-	send_fonts(COM_Font_list);
-	break;
-    case FONT_INFO:
-	send_fonts(COM_Font_info);
-	break;
-    case TEXT:
-	COM_Text(text);
-	break;
-    case TEXT_SIZE:
-	COM_Text_size(x, y);
-	break;
-    case TEXT_ROTATION:
-	REC(&wx, sizeof wx);
-	COM_Text_rotation(wx);
-	break;
-    case PANEL_SAVE:
-	COM_Panel_save(text, t, b, l, r);
-	break;
-    case PANEL_RESTORE:
-	COM_Panel_restore(text);
-	break;
-    case PANEL_DELETE:
-	COM_Panel_delete(text);
-	break;
-    case PAD_CREATE:
-	if (*text == 0)		/* this is scratch pad */
-	    RESULT(OK);
-	else if (find_pad(text) != NULL)
-	    RESULT(DUPLICATE);	/* duplicate pad */
-	else if (create_pad(text))
-	    RESULT(OK);
-	else
-	    RESULT(NO_MEMORY);
-	break;
-    case PAD_CURRENT:
-	if (curpad == NULL) {
-	    RESULT(NO_CUR_PAD);
-	    SENDTEXT("");
-	else {
-	    RESULT(OK);
-	    SENDTEXT(curpad->name);
-	break;
-    case PAD_DELETE:
-	else if (*curpad->name == 0)
-	    RESULT(ILLEGAL);
-	else {
-	    delete_pad(curpad);
-	    curpad = NULL;
-	    RESULT(OK);
-	break;
-    case PAD_INVENT:
-	invent_pad(text);
-	SENDTEXT(text);
-	break;
-    case PAD_LIST:
-	for (pad = pad_list(); pad != NULL; pad = pad->next)
-	    if (*pad->name)
-		SENDTEXT(pad->name);
-	SENDTEXT("");
-	break;
-    case PAD_SELECT:
-	RECTEXT(text, text_size);	/* pad name */
-	curpad = find_pad(text);
-	    RESULT(NO_PAD);
-	else
-	    RESULT(OK);
-	break;
-    case PAD_GET_ITEM:
-	RECTEXT(text, text_size);	/* item name */
-	    break;
-	item = find_item(curpad, text);
-	if (item == NULL) {
-	    RESULT(NO_ITEM);
-	    break;
-	RESULT(OK);
-	for (list = item->list; list != NULL; list = list->next)
-	    if (*list->value)
-		SENDTEXT(list->value);
-	SENDTEXT("");
-	break;
-    case PAD_SET_ITEM:
-	RECTEXT(name, name_size);	/* item name */
-	RECTEXT(text, text_size);	/* item value */
-	    break;
-	delete_item(curpad, name);
-	if (append_item(curpad, name, text, 0))
-	    RESULT(OK);
-	else
-	break;
-    case PAD_APPEND_ITEM:
-	REC(&index, sizeof index);	/* replace flag */
-	    break;
-	if (append_item(curpad, name, text, index))
-	    RESULT(OK);
-	else
-	break;
-    case PAD_DELETE_ITEM:
-	    break;
-	delete_item(curpad, text);
-	RESULT(OK);
-	break;
-    case PAD_LIST_ITEMS:
-	    break;
-	RESULT(OK);
-	for (item = curpad->items; item != NULL; item = item->next)
-	    if (*item->name)
-		SENDTEXT(item->name);
-	SENDTEXT("");
-	break;
-    default:
-	G_warning(_("Unknown command: %d last: %d"), c, lc);
-	break;
-    lc = c;
-    return ateof;
-static int read1(char *c)
-    if (atbuf == n_read) {
-	atbuf = 0;
-	n_read = read(_rfd, inbuf, sizeof inbuf);
-	if (n_read < 0)
-	    perror("Monitor: read1: Error reading input");
-	if (n_read <= 0)
-	    return 1;		/* EOF */
-    *c = inbuf[atbuf++];
-    return 0;
-int get_command(char *c)
-    /* is there a command char pending? */
-    if ((*c = current_command)) {
-	return 0;
-     * look for 1 (or more) COMMAND_ESC chars
-     * followed by a non-zero comamnd token char
-    while (read1(c) == 0) {	/* while !EOF */
-	if (*c != COMMAND_ESC)
-	    continue;
-	while (*c == COMMAND_ESC)
-	    if (read1(c) != 0) {
-		G_warning(_("Monitor: get_command: Premature EOF"));
-	if (*c)
-	    return 0;		/* got the command token */
-static int get1(char *c)
-	return 0;		/* OK */
-    if (*c) {
-	current_command = *c;
-	return -1;		/* Got command within data */
-    *c = COMMAND_ESC;		/* sequence COMMAND_ESC,0 becomes data COMMAND_ESC */
-static int rec(void *buf, int n)
-    char *cbuf = buf;
-    int stat;
-    while (n-- > 0) {
-	if ((stat = get1(cbuf++)) != 0)
-	    return stat;	/* EOF or COMMAND_ESC */
-    return 0;
-static int rectext(char **buff_p, int *size_p)
-    char *buff = *buff_p;
-    int size = *size_p;
-    int i, stat;
-    for (i = 0;; i++) {
-	char c;
-	stat = get1(&c);
-	if (stat != 0)
-	if (i >= size) {
-	    *size_p = size = size ? size * 2 : 1000;
-	    *buff_p = buff = G_realloc(buff, size);
-	buff[i] = c;
-	if (!c)
-	    return 0;
-static int _send(const void *buf, int n)
-    int r = write(_wfd, buf, n);
-    if (r < 0) {
-	perror("Monitor: _send: write");
-	return 1;
-    if (r < n) {
-	G_warning("Monitor: _send: write returned short count: %d of %d",
-		  r, n);
-	return 1;
-    return 0;
-static int sendtext(const char *s)
-    SEND(s, strlen(s) + 1);
-    return 0;
-static int RESULT(int n)
-    unsigned char c;
-    c = n;
-    SEND(&c, 1);
-    return 0;
Deleted: grass/trunk/lib/driver/connect_sock.c
--- grass/trunk/lib/driver/connect_sock.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/connect_sock.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,93 +0,0 @@
-#include <grass/config.h>
-#ifdef HAVE_SOCKET
-#include <stdio.h>
-#include <errno.h>
-int prepare_connection_sock(const char *me)
-    const char *connpath;
-    int fd;
-    connpath = G_sock_get_fname(me);
-    if (!connpath)
-	G_fatal_error("Couldn't get socket path");
-    /* Now we must check and see whether or not someone */
-    /* (possibly another invocation of ourself) is using our socket.    */
-    if (G_sock_exists(connpath)) {
-	if ((fd = G_sock_connect(connpath)) >= 0) {
-	    close(fd);
-	    G_warning("Graphics driver [%s] is already running", me);
-	    G_fatal_error("Unable to start monitor <%s>", me);
-	if (unlink(connpath) < 0) {
-	    G_warning("Failed to remove stale socket file: %s", connpath);
-    /* We are free to run now.  No one is using our socket.                   */
-    if ((fd = G_sock_bind(connpath)) < 0) {
-	G_fatal_error("Can't bind to socket: error \"%s\"\n",
-		      strerror(errno));
-    /* Now set up listen */
-    if (G_sock_listen(fd, 1) != 0) {
-	G_fatal_error("G_sock_listen: error \"%s\"\n", strerror(errno));
-    return fd;
-int get_connection_sock(int listenfd, int *rfd, int *wfd, int other_fd)
-    int fd;
-#ifndef __MINGW32__
-    if (other_fd >= 0) {
-	fd_set waitset;
-	FD_ZERO(&waitset);
-	FD_SET(listenfd, &waitset);
-	FD_SET(other_fd, &waitset);
-	if (select(FD_SETSIZE, &waitset, NULL, NULL, NULL) < 0) {
-	    perror("get_connection_sock: select");
-	    exit(EXIT_FAILURE);
-	if (!FD_ISSET(listenfd, &waitset))
-	    return -1;
-#endif
-    /* G_sock_accept will block until a connection is requested */
-    fd = G_sock_accept(listenfd);
-    if (fd >= 0) {
-	*rfd = fd;
-	*wfd = dup(fd);
-	return 0;
-    if (errno == EINTR)
-	return -1;
-    G_warning("G_sock_accept: error \"%s\"", strerror(errno));
-#endif /* HAVE_SOCKET */
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/driver.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -29,15 +29,9 @@
     void (*Client_Open) (void);
     void (*Client_Close) (void);
     void (*Erase) (void);
-    int (*Get_with_box) (int, int, int *, int *, int *);
-    int (*Get_with_line) (int, int, int *, int *, int *);
-    int (*Get_with_pointer) (int *, int *, int *);
     int (*Graph_set) (int, char **);
     void (*Graph_close) (void);
     void (*Line_width) (int);
-    void (*Panel_save) (const char *, int, int, int, int);
-    void (*Panel_restore) (const char *);
-    void (*Panel_delete) (const char *);
     void (*Polydots_abs) (const int *, const int *, int);
     void (*Polydots_rel) (const int *, const int *, int);
     void (*Polyline_abs) (const int *, const int *, int);
@@ -52,8 +46,6 @@
 			  const unsigned char *, const unsigned char *);
     void (*End_scaled_raster) (void);
     void (*Respond) (void);
-    int (*Work_stream) (void);
-    void (*Do_work) (int);
     int (*lookup_color) (int, int, int);
     void (*color) (int);
@@ -65,15 +57,9 @@
 /* Library Functions */
-/* command.c */
-extern int LIB_command_get_input(void);
 /* init.c */
 extern int LIB_init(const struct driver *drv, int argc, char **argv);
-/* main.c */
-extern int LIB_main(int argc, char **argv);
 /* Commands */
 /* Bitmap.c */
@@ -104,11 +90,6 @@
 extern void COM_Font_list(char ***, int *);
 extern void COM_Font_info(char ***, int *);
-/* Get_location.c */
-extern int COM_Get_location_with_box(int, int, int *, int *, int *);
-extern int COM_Get_location_with_line(int, int, int *, int *, int *);
-extern int COM_Get_location_with_pointer(int *, int *, int *);
 /* Get_t_box.c */
 extern void COM_Get_text_box(const char *, int *, int *, int *, int *);
@@ -123,11 +104,6 @@
 extern void COM_Move_abs(int, int);
 extern void COM_Move_rel(int, int);
-/* Panel.c */
-extern void COM_Panel_save(const char *, int, int, int, int);
-extern void COM_Panel_restore(const char *);
-extern void COM_Panel_delete(const char *);
 /* Polydots.c */
 extern void COM_Polydots_abs(const int *, const int *, int);
 extern void COM_Polydots_rel(const int *, const int *, int);
@@ -167,11 +143,6 @@
 extern void COM_Text_size(int, int);
 extern void COM_Text_rotation(double);
-/* Work.c */
-extern int COM_Has_work(void);
-extern int COM_Work_stream(void);
-extern void COM_Do_work(int);
 /* Driver Operations */
 /* Color.c */
Modified: grass/trunk/lib/driver/driverlib.h
--- grass/trunk/lib/driver/driverlib.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/driverlib.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -34,15 +34,6 @@
 const char *font_get_charset(void);
 int font_get_index(void);
-/* connect_sock.c */
-int get_connection_sock(int, int *, int *, int);
-int prepare_connection_sock(const char *);
-/* command.c */
-void command_init(int, int);
-int get_command(char *);
-int process_command(int);
 /* parse_ftcap.c */
 extern int font_exists(const char *name);
 extern struct GFONT_CAP *parse_freetypecap(void);
Modified: grass/trunk/lib/driver/init.c
--- grass/trunk/lib/driver/init.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/init.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -21,7 +21,6 @@
 #include <grass/freetypecap.h>
 #include "driver.h"
-#include "pad.h"
 const struct driver *driver;
@@ -41,8 +40,6 @@
 double text_size_y;
 double text_rotation;
-int mouse_button[3] = { 1, 2, 3 };
     const char *p;
@@ -60,25 +57,8 @@
     screen_top = 0;
     screen_bottom = (p && atoi(p)) ? atoi(p) : DEF_HEIGHT;
-    /* read mouse button setting */
-    if ((p = getenv("GRASS_MOUSE_BUTTON"))) {
-	int i;
-	for (i = 0; i < 3 && p[i]; i++) {
-	    if (p[i] < '1' || p[i] > '3')
-		break;
-	if (i == 3 && p[0] != p[1] && p[1] != p[2] && p[0] != p[2]) {
-	    for (i = 0; i < 3; i++)
-		mouse_button[i] = p[i] - '0';
     if (COM_Graph_set(argc, argv) < 0)
 	exit(1);
-    /* initialize the pads */
-    create_pad("");		/* scratch pad */
     return 0;
Deleted: grass/trunk/lib/driver/main.c
--- grass/trunk/lib/driver/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,157 +0,0 @@
- * MODULE:       driver
- * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com>(original contributor)
- * PURPOSE:      graphics monitor driver
- *               for details.
-#include <stdio.h>
-#include "pad.h"
-static jmp_buf save;
-static RETSIGTYPE handle_sigpipe(int sig)
-    longjmp(save, 1);
-static RETSIGTYPE handle_sigterm(int sig)
-int LIB_main(int argc, char **argv)
-    char *me;
-    int _wfd;
-    int _rfd;
-    int eof;
-    char c;
-    pid_t pid;
-    int foreground;
-    int listenfd;
-    struct sigaction sigact;
-#endif
-    /* The calling syntax is as follows:
-       monitor_name [-] ["input_fifo output_fifo"]
-       The "-", if present, causes the monitor to run in foreground.
-       Otherwise, once it has been determined that the monitor is not
-       already running, we will fork and the parent will exit, so that
-       the monitor is left running in background.
-    if (argc < 2) {
-	G_warning("Usage:  %s <name> [-]", argv[0]);
-	return 1;
-    /* whoami */
-    me = argv[1];
-    foreground = (argc >= 3 && argv[2][0] == '-');
-#ifdef SIGPIPE
-    sigact.sa_handler = handle_sigpipe;
-    sigemptyset(&sigact.sa_mask);
-    sigact.sa_flags = 0;
-    sigaction(SIGPIPE, &sigact, NULL);
-#endif
-    sigact.sa_handler = handle_sigterm;
-    sigaction(SIGTERM, &sigact, NULL);
-#endif
-    listenfd = prepare_connection_sock(me);
-    G_message(_("Graphics driver [%s] started"), me);
-    if (!foreground) {
-	pid = fork();
-	if (pid) {
-	    if (pid > 0) {	/* parent exits */
-		exit(0);
-	    else {		/* weren't able to fork */
-		G_fatal_error("Error - Could not fork to start [%s]", me);
-	else {
-	    /* change process groups to be shielded from keyboard signals */
-#ifdef SETPGRP_VOID
-	    setpgrp();
-#else
-	    setpgrp(0, getpid());
-#endif
-    }				/* monitor runs */
-#endif
-    while (1) {			/* re-open upon EOF */
-	for (;;) {
-	    if (get_connection_sock(listenfd, &_rfd, &_wfd, COM_Work_stream())
-		>= 0)
-		break;
-	    COM_Do_work(0);
-	command_init(_rfd, _wfd);
-	COM_Client_Open();
-	eof = 0;
-	while (eof <= 0) {
-	    COM_Do_work(1);
-	    if (setjmp(save)) {
-		G_warning("Monitor <%s>: Caught SIGPIPE", me);
-		break;
-	    if (get_command(&c) != 0)
-		break;
-	    if (process_command(c)) {
-		G_warning("Monitor <%s>: Premature EOF", me);
-		break;
-	/* read encountered EOF. close socket now */
-	close(_wfd);
-	close(_rfd);
-	_rfd = _wfd = -1;	/* Set to invalid file descriptor number */
-	COM_Client_Close();
-    return 0;
Deleted: grass/trunk/lib/driver/pad.c
--- grass/trunk/lib/driver/pad.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/pad.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,226 +0,0 @@
-/* required for NULL */
-#include <stdio.h>
-#include "pad.h"
-static PAD *padlist;
-static int free_item(ITEM * item)
-    LIST *list, *next;
-    if (item->name != NULL)
-	G_free(item->name);
-    for (list = item->list; list != NULL; list = next) {
-	next = list->next;
-	if (list->value)
-	    G_free(list->value);
-	G_free(list);
-    G_free(item);
-    return 0;
-static ITEM *new_item(PAD * pad, const char *name)
-    ITEM *item;
-    item = (ITEM *) G_malloc((size_t) sizeof(ITEM));
-    if (item == NULL)
-	return (ITEM *) NULL;
-    item->name = G_store(name);
-    if (item->name == NULL) {
-	G_free(item);
-    item->list = NULL;
-    item->next = pad->items;
-    if (item->next != NULL)
-	item->next->prev = item;
-    item->prev = NULL;
-    pad->items = item;
-    return item;
-static int remove_value(ITEM * item, const char *value)
-    LIST **p = &item->list;
-    LIST *l = *p;
-    for (l = *p; l; l = *p) {
-	if (value && l->value && !strcmp(value, l->value)) {
-	    *p = l->next;
-	    if (l->value)
-		G_free(l->value);
-	    G_free(l);
-	else
-	    p = &l->next;
-    return 0;
-int append_item(PAD * pad, const char *name, const char *value, int replace)
-    ITEM *item;
-    LIST *cur, *prev;
-    LIST *list;
-    if (pad == NULL)
-	return 0;
-    /* allocate a list struct and put value into it */
-    list = (LIST *) G_malloc((size_t) sizeof(LIST));
-    if (list == NULL)
-	return 0;
-    list->next = NULL;
-    list->value = G_store(value);
-    if (list->value == NULL) {
-	G_free(list);
-	return 0;
-    /* find the named item for the current pad */
-    item = find_item(pad, name);
-    if (item == NULL)
-	item = new_item(pad, name);
-    if (item == NULL)
-	return 0;
-    /* remove any existing occurences of the value */
-    if (replace)
-	remove_value(item, value);
-    /* add the LIST at the end of the item LIST */
-    prev = NULL;
-    for (cur = item->list; cur != NULL; cur = cur->next)
-	prev = cur;
-    if (prev == NULL)
-	item->list = list;
-    else
-	prev->next = list;
-    return 1;
-int delete_item(PAD * pad, const char *name)
-    ITEM *item;
-    if (item == NULL)
-	return 0;
-    if (item->prev == NULL)
-	pad->items = item->next;
-    else
-	item->prev->next = item->next;
-	item->next->prev = item->prev;
-    /* free the item */
-    free_item(item);
-    return 1;
-ITEM *find_item(PAD * pad, const char *name)
-    ITEM *item;
-    if (pad != NULL)
-	for (item = pad->items; item != NULL; item = item->next)
-	    if (strcmp(name, item->name) == 0)
-		return item;
-PAD *pad_list(void)
-    return padlist;
-static int delink_pad(PAD * pad)
-    if (pad == NULL)
-	return 1;
-    if (pad->prev == NULL)
-	padlist = pad->next;
-    else
-	pad->prev->next = pad->next;
-    if (pad->next != NULL)
-	pad->next->prev = pad->prev;
-    return 0;
-int create_pad(const char *name)
-    PAD *pad;
-    pad = (PAD *) G_malloc((size_t) sizeof(PAD));
-    if (pad == NULL)
-	return 0;
-    pad->name = G_store(name);
-    if (pad->name == NULL) {
-	G_free(pad);
-	return 0;
-    pad->items = NULL;
-    pad->next = padlist;
-	pad->next->prev = pad;
-    pad->prev = NULL;
-    padlist = pad;
-    return 1;
-int delete_pad(PAD * pad)
-    ITEM *item, *next;
-    if (pad == NULL)
-	return 0;
-    delink_pad(pad);
-    /* free the items */
-    for (item = pad->items; item != NULL; item = next) {
-	next = item->next;
-	free_item(item);
-    G_free(pad);
-    return 1;
-PAD *find_pad(const char *name)
-    PAD *pad;
-    for (pad = padlist; pad != NULL; pad = pad->next)
-	if (strcmp(name, pad->name) == 0)
-	    return pad;
-    return (PAD *) NULL;
-int invent_pad(char *name)
-    static int i = 0;
-    do
-	sprintf(name, "%d", ++i);
-    while (find_pad(name) != NULL);
-    return 0;
Deleted: grass/trunk/lib/driver/pad.h
--- grass/trunk/lib/driver/pad.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/driver/pad.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,34 +0,0 @@
-#ifndef _PAD_H_
-#define _PAD_H_
-typedef struct _list
-    char *value;
-    struct _list *next;
-} LIST;
-typedef struct _item_
-    char *name;
-    LIST *list;
-    struct _item_ *next, *prev;
-} ITEM;
-typedef struct _pad_
-    char *name;
-    ITEM *items;
-    struct _pad_ *next, *prev;
-} PAD;
-PAD *pad_list(void);
-PAD *find_pad(const char *);
-int delete_pad(PAD *);
-int create_pad(const char *);
-int append_item(PAD *, const char *, const char *, int);
-int invent_pad(char *);
-int delete_item(PAD *, const char *);
-ITEM *find_item(PAD *, const char *);
-#endif /* _PAD_H_ */
Property changes on: grass/trunk/lib/htmldriver
___________________________________________________________________
   + *.tmp.html
*OBJ*
Added: grass/trunk/lib/htmldriver/Driver.c
--- grass/trunk/lib/htmldriver/Driver.c	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Driver.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,57 @@
+ * MODULE:       HTMLMAP
+ * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com> (original contributor)
+ * PURPOSE:      driver to allow HTML image maps
+ * COPYRIGHT:    (C) 2007-2007 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include "driver.h"
+#include "htmlmap.h"
+const struct driver *HTML_Driver(void)
+    static struct driver drv;
+    static int initialized;
+    if (initialized)
+	return &drv;
+    drv.Box_abs = NULL;
+    drv.Box_rel = NULL;
+    drv.Client_Open = NULL;
+    drv.Client_Close = NULL;
+    drv.Erase = NULL;
+    drv.Graph_set = HTML_Graph_set;
+    drv.Graph_close = HTML_Graph_close;
+    drv.Line_width = NULL;
+    drv.Polydots_abs = NULL;
+    drv.Polydots_rel = NULL;
+    drv.Polyline_abs = NULL;
+    drv.Polyline_rel = NULL;
+    drv.Polygon_abs = HTML_Polygon_abs;
+    drv.Polygon_rel = NULL;
+    drv.Set_window = NULL;
+    drv.Begin_scaled_raster = NULL;
+    drv.Scaled_raster = NULL;
+    drv.End_scaled_raster = NULL;
+    drv.Respond = NULL;
+    drv.lookup_color = NULL;
+    drv.color = NULL;
+    drv.draw_line = NULL;
+    drv.draw_point = NULL;
+    drv.draw_bitmap = NULL;
+    drv.draw_text = HTML_Text;
+    initialized = 1;
+    return &drv;
Added: grass/trunk/lib/htmldriver/Graph_Clse.c
--- grass/trunk/lib/htmldriver/Graph_Clse.c	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Graph_Clse.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,166 @@
+ * Close down the graphics processing.  This gets called only at driver
+ * termination time.
+#include <grass/gis.h>
+#include "driverlib.h"
+/* sreen dimensions defined in Graph_Set.c */
+extern int screen_top;
+extern int screen_left;
+extern int screen_right;
+extern int screen_bottom;
+/* point in polygon test by Randolph Franklin */
+/* http://www.ecse.rpi.edu/Homepages/wrf/     */
+/* adapted for integer coordinates            */
+static int pnpoly(int npol, int *xp, int *yp, int x, int y)
+    int i, j, c = 0;
+    for (i = 0, j = npol - 1; i < npol; j = i++) {
+	if ((((yp[i] <= y) && (y < yp[j])) ||
+	     ((yp[j] <= y) && (y < yp[i]))) &&
+	    (x < (xp[j] - xp[i]) * (y - yp[i]) / (yp[j] - yp[i]) + xp[i]))
+	    c = !c;
+    return c;
+void HTML_Graph_close(void)
+    struct MapPoly *poly, *test_poly;
+    int i;
+    int inside;
+     * exmaine the list of polygons, if a polygon wholly exists inside of
+     * another polygon, then remove it.
+    for (poly = head; poly != NULL; poly = poly->next_poly) {
+	for (test_poly = head; test_poly != NULL;
+	     test_poly = test_poly->next_poly) {
+	    if (poly == test_poly) {
+		continue;	/* don't check ourselves */
+	    inside = 1;
+	    for (i = 0; i < poly->num_pts && inside; i++) {
+		inside = pnpoly(test_poly->num_pts,
+				test_poly->x_pts, test_poly->y_pts,
+				poly->x_pts[i], poly->y_pts[i]);
+	    if (inside) {
+		poly->num_pts = 0;	/* mark polygon as having no points */
+		break;
+     * write any beginning prologue appropriate for the map type
+    switch (html_type) {
+    case APACHE:
+	fprintf(output, "#base _base_\n#default _default_\n");
+	break;
+    case RAW:
+	break;
+    case CLIENT:
+	fprintf(output, "<MAP NAME=\"map\">\n");
+	break;
+     * write the polygons in a specific format
+	if (poly->num_pts >= 3) {
+	    case APACHE:
+		fprintf(output, "poly %s", poly->url);
+		for (i = 0; i < poly->num_pts; i++) {
+		    fprintf(output, " %d,%d", poly->x_pts[i], poly->y_pts[i]);
+		fprintf(output, " %d,%d", poly->x_pts[0], poly->y_pts[0]);
+		fprintf(output, "\n");
+		break;
+	    case RAW:
+		fprintf(output, "%s", poly->url);
+		    fprintf(output, " %d %d", poly->x_pts[i], poly->y_pts[i]);
+		fprintf(output, " %d %d", poly->x_pts[0], poly->y_pts[0]);
+		break;
+	    case CLIENT:
+		fprintf(output,
+			"<AREA SHAPE=\"POLY\"\n HREF=\"%s\"\n  ALT=\"%s\"\n  COORDS=\"",
+			poly->url, poly->url);
+		    if (i > 0)
+			fprintf(output, ", ");
+		     * don't add newlines, which confuses the weak-minded
+		     * i.e., ms internet exploder :-(
+		     * was: if (i % 8 == 0 && i != 0) fprintf(output,"\n  ");
+		    fprintf(output, "%d,%d", poly->x_pts[i], poly->y_pts[i]);
+		fprintf(output, ", %d,%d", poly->x_pts[0], poly->y_pts[0]);
+		fprintf(output, "\">\n");
+		break;
+    /* final stuff, if needed */
+    case APACHE:
+	break;
+    case RAW:
+	break;
+    case CLIENT:
+	fprintf(output,
+		"<AREA SHAPE=\"RECT\" NOHREF COORDS=\"%d,%d %d,%d\">\n",
+		screen_left, screen_top, screen_right, screen_bottom);
+	fprintf(output, "</MAP>\n");
+	break;
+     * close file
+    fclose(output);
Added: grass/trunk/lib/htmldriver/Graph_Set.c
--- grass/trunk/lib/htmldriver/Graph_Set.c	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Graph_Set.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,146 @@
+ * Start up graphics processing.  Anything that needs to be assigned, set up,
+ * started-up, or otherwise initialized happens here.  This is called only at
+ * the startup of the graphics driver.
+ * The external variables define the pixle limits of the graphics surface.  The
+ * coordinate system used by the applications programs has the (0,0) origin
+ * in the upper left-hand corner.  Hence,
+ *    screen_left < screen_right
+ *    screen_top  < screen_bottom
+#include <string.h>
+#include <stdlib.h>
+char *last_text;
+int last_text_len;
+char *file_name;
+int html_type;
+FILE *output;
+struct MapPoly *head;
+struct MapPoly **tail;
+int BBOX_MINIMUM;
+int MAX_POINTS;
+int MINIMUM_DIST;
+int HTML_Graph_set(int argc, char **argv)
+    char *p;
+    G_gisinit("HTMLMAP driver");
+    NCOLORS = 256;
+     * set the minimum bounding box dimensions
+    if (NULL != (p = getenv("GRASS_HTMLMINBBOX"))) {
+	BBOX_MINIMUM = atoi(p);
+	if (BBOX_MINIMUM <= 0) {
+	    BBOX_MINIMUM = DEF_MINBBOX;
+    else {
+     * set the maximum number of points
+    if (NULL != (p = getenv("GRASS_HTMLMAXPOINTS"))) {
+	MAX_POINTS = atoi(p);
+	if (MAX_POINTS <= 0) {
+	    MAX_POINTS = DEF_MAXPTS;
+    else {
+     * set the minimum difference to keep a point
+    if (NULL != (p = getenv("GRASS_HTMLMINDIST"))) {
+	MINIMUM_DIST = atoi(p);
+	if (MINIMUM_DIST <= 0) {
+	    MINIMUM_DIST = DEF_MINDIST;
+    else {
+     * open the output file
+    if (NULL != (p = getenv("GRASS_HTMLFILE"))) {
+	if (strlen(p) == 0) {
+	    p = FILE_NAME;
+    else {
+	p = FILE_NAME;
+    file_name = p;
+    output = fopen(file_name, "w");
+    if (output == NULL) {
+	G_fatal_error("HTMLMAP: couldn't open output file %s", file_name);
+	exit(EXIT_FAILURE);
+    G_message("HTMLMAP: collecting to file: %s\n width = %d, height = %d, ",
+	      file_name, screen_right, screen_bottom);
+     * check type of map wanted
+    if (NULL == (p = getenv("GRASS_HTMLTYPE"))) {
+	p = "CLIENT";
+    if (strcmp(p, "APACHE") == 0) {
+	html_type = APACHE;
+	fprintf(stdout, "type = APACHE\n");
+    else if (strcmp(p, "RAW") == 0) {
+	html_type = RAW;
+	fprintf(stdout, "type = RAW\n");
+    else {
+	html_type = CLIENT;
+	fprintf(stdout, "type = CLIENT\n");
+     * initialize text memory and list pointers
+    last_text = (char *)G_malloc(INITIAL_TEXT + 1);
+    last_text[0] = '\0';
+    last_text_len = INITIAL_TEXT;
+    head = NULL;
+    tail = &head;
+    return 0;
Added: grass/trunk/lib/htmldriver/Makefile
--- grass/trunk/lib/htmldriver/Makefile	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Platform.make
+PACKAGE ="libhtmldriver"
+DEFS=-DPACKAGE=\"$(PACKAGE)\"
+EXTRA_CFLAGS=-I../driver $(PICFLAGS) $(DEFS)
+EXTRA_LIBS=$(DRIVERLIB) $(GISLIB)
+LIB_NAME = $(HTMLDRIVER_LIBNAME)
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+default: lib
Added: grass/trunk/lib/htmldriver/Polygn_abs.c
--- grass/trunk/lib/htmldriver/Polygn_abs.c	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Polygn_abs.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,211 @@
+#include <math.h>
+#define RAD_DEG 57.29578
+/* max points & bbox minimum dimension defined in Graph_Set.c */
+extern int MAX_POINTS;
+extern int BBOX_MINIMUM;
+extern int MINIMUM_DIST;
+static void delete_point(int *x, int *y, int count)
+    int i;
+    for (i = 0; i < count; i++) {
+	x[i] = x[i + 1];
+	y[i] = y[i + 1];
+static double find_azimuth(double x1, double y1, double x2, double y2)
+    double xx, yy;
+    xx = x1 - x2;
+    yy = y1 - y2;
+    if (x1 == x2) {
+	return (y2 > y1) ? 90.0 : 270.0;
+    else {
+	if (y2 < y1) {
+	    if (x2 > x1) {
+		return 360.0 + (RAD_DEG * atan(yy / xx));
+	    else {
+		return 180.0 + (RAD_DEG * atan(yy / xx));
+	else {
+	    if (x2 > x1) {
+		return (RAD_DEG * atan(yy / xx));
+	    else {
+void HTML_Polygon_abs(const int *px, const int *py, int n)
+    struct MapPoly *new;
+    int i;
+    int delta_x, delta_y;
+    int min_x, max_x, min_y, max_y;
+    double min_azimuth = 1.0;
+    double azimuth1, azimuth2, diff1, diff2;
+    int *x = G_malloc(n * sizeof(int));
+    int *y = G_malloc(n * sizeof(int));
+    memcpy(x, px, n * sizeof(int));
+    memcpy(y, py, n * sizeof(int));
+     * remove points that have adjacent duplicates or have differences of
+     * less the the minimum allowed.  remove end points that are same as
+     * the begin point (ending point = starting point is added
+     * during Graph_Clse)
+    i = 0;
+    while (i < (n - 1)) {
+	delta_x = x[i] - x[i + 1];
+	if (delta_x < 0)
+	    delta_x = -delta_x;
+	delta_y = y[i] - y[i + 1];
+	if (delta_y < 0)
+	    delta_y = -delta_y;
+	if ((x[i] == x[i + 1] && y[i] == y[i + 1]) ||
+	    (delta_x <= MINIMUM_DIST && delta_y <= MINIMUM_DIST)) {
+	    delete_point(&x[i + 1], &y[i + 1], n - i - 1);
+	    --n;
+	else {
+	    ++i;
+    /* perform same checks for last point & first point */
+    while (1) {
+	delta_x = x[0] - x[n - 1];
+	if (delta_x < 0)
+	delta_y = y[0] - y[n - 1];
+	if (delta_y < 0)
+	if ((x[0] == x[n - 1] && y[0] == y[n - 1]) ||
+	    --n;
+	else {
+	    break;
+     * if a polygon has either x or y extents less than the bounding box
+     * minimum, ignore it
+    min_x = max_x = x[0];
+    min_y = max_y = y[0];
+    for (i = 0; i < n; i++) {
+	if (x[i] < min_x)
+	    min_x = x[i];
+	if (x[i] > max_x)
+	    max_x = x[i];
+	if (y[i] < min_y)
+	    min_y = y[i];
+	if (y[i] > max_y)
+	    max_y = y[i];
+    delta_x = max_x - min_x;
+    delta_y = max_y - min_y;
+    if (delta_x < BBOX_MINIMUM || delta_y < BBOX_MINIMUM) {
+	n = 0;
+     * remove points in excess of MAX_POINTS vertices
+    while (n > MAX_POINTS) {
+	for (i = 0; i < (n - 2); i++) {
+	     * see if middle point can be removed, by checking if the
+	     * relative bearing to the middle is less than our current tolerance
+	    azimuth1 = find_azimuth((double)x[i], (double)y[i],
+				    (double)x[i + 1], (double)y[i + 1]);
+	    azimuth2 = find_azimuth((double)x[i], (double)y[i],
+				    (double)x[i + 2], (double)y[i + 2]);
+	    diff1 = fmod(fabs((azimuth2 + 360.0) - azimuth1), 360.0);
+	    diff2 = fmod(fabs((azimuth1 + 360.0) - azimuth2), 360.0);
+	    if (diff1 <= min_azimuth || diff2 <= min_azimuth) {
+		--n;
+		++i;
+		/* either stop deleting points because we're less than 100,
+		   or keep deleting points with the same difference as this
+		   one (which might make a smaller polygon yet).
+		   if (n <= 100) {
+		   break;
+	/* increase minimum azimuth difference for next round */
+	min_azimuth += 1.0;
+     * copy remaining points into a new MapPoly
+    if (n >= 3) {
+	new = (struct MapPoly *)G_malloc(sizeof(struct MapPoly));
+	/* grab the last text string written as url */
+	new->url = G_store(last_text);
+	/* hook up new MapPoly into list */
+	new->next_poly = NULL;
+	*tail = new;
+	tail = &(new->next_poly);
+	new->num_pts = n;
+	new->x_pts = x;
+	new->y_pts = y;
+    else {
+	G_free(x);
+	G_free(y);
Added: grass/trunk/lib/htmldriver/README
--- grass/trunk/lib/htmldriver/README	                        (rev 0)
+++ grass/trunk/lib/htmldriver/README	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,172 @@
+                                  HTMLMAP driver
+                                  Tom Poindexter
+                                 tpoindex at nyx.net
+  This display driver is to allow the generation of HTML image maps for
+area vector data.  HTML image maps are used in conjunction with images
+to provide unique URL targets for different portions of an image.  The HTMLMAP
+driver can create both client-side image maps embedded into HTML files, or
+server-side image maps used by web server software.
+  Note that commands that require the MOUSE will NOT work correctly (or
+at all!)
+  Polygons can at most have 100 vertices (this limit imposed by HTML image map
+formats.)  The driver will attempt to trim polygons that have more that 100
+vertices (also see GRASS_HTMLMAXPOINTS, below.)  Also, any polygon that is
+entirely bounded by another polygon will be discarded.
+  Text written to the driver before polygons are used as the HREF tag for
+all subsequent polygons written.  It is intended that all polygons
+that exists in a vector file will have the same HREF tag.
+  The only GRASS display commands that should be used with this driver are:
+	d.text	 - pass href information for resulting image maps.
+	d.vect.area	 - draw polygons from a vector file.
+    0. Set environment variables:
+       GRASS_WIDTH=xxx   #if you want another size than the default 640
+       export GRASS_WIDTH
+       GRASS_HEIGHT=xxx  #if you want another size than the default 480
+       Additionally, HTMLMAP driver recognizes:
+       export GRASS_HTMLTYPE
+       GRASS_HTMLTYPE=xxx
+            specifies the type of Html map to create:
+	    CLIENT  - Netscape client-side image map (default).  (NAME="map")
+	    APACHE  - Apache/NCSA server-side image map
+	    RAW     - Raw url and polygon vertices ("url x1 y1 x2 y2 .....")
+                      suitable for conversion to CERN server format, or
+                      any other format with user supplied conversion program.
+       export GRASS_HTMLFILE
+       GRASS_HTMLFILE=xxxxxx
+	    specifies the resulting file to store the html image map,
+	    default is 'htmlmap'.  Files without absolute path names are
+            written in the current directory where the driver was started.
+            Any existing file is overwritten without warning.
+	export GRASS_HTMLMINDIST
+	GRASS_HTMLMINDIST=xx
+	    specifies the minimum distance (in pixels) that a point must
+	    change from the previous one to keep in the list of vertices
+            for a polygon.  The default is '2', which means that a point's
+	    x or y difference from the previous point must change by a number
+	    of pixels greate than this value.  This parameters helps
+	    to eliminate points closely spaced points.
+	export GRASS_HTMLMINBBOX
+	GRASS_HTMLMINBBOX=xx
+	    specifies the minimum bounding box dimenions (both width and
+	    height) in order to store a polygon.  The default is '2', which
+	    means any polygon having bounding box width or height extent
+	    of less than 2 pixels will not be output as a clickable area.
+            This parameter helps to eliminate clickable areas that are one
+	    pixel in height or width, typically a single point or line.
+	export GRASS_HTMLMAXPOINTS
+	GRASS_HTMLMAXPOINTS=xx
+	    specifies the maxiumum number of vertices that a polygon can
+	    have.  The default is 99.  Some browser can only handle
+	    image map polygons of less that 100 vertices.
+    1. Start it up.
+         # set the environment variables (above) if desired, or use defaults
+         d.mon start=HTMLMAP
+         d.mon select=HTMLMAP
+    2. Display text strings (href's) and area polygons:
+         echo "http://www.no-such-place.net/area51/" | d.text
+	 d.vect.area map=area51
+         echo "http://www.roswell-nm.net/little/green/men.html" | d.text
+	 d.vect.area map=roswell
+    3. When done displaying stuff to HTMLMAP driver, use
+         d.mon stop=HTMLMAP
+       This will write the image map file file. A new file called 'htmlmap'
+       (or whatever you specified with GRASS_HTMLFILE) will be created
+       in your current directory.
+    4. In practice, you'll want to create gif/jpg/png images that correspond
+       with your newly created image map:
+         # using previous GRASS_WIDTH & GRASS_HEIGHT
+         d.mon start=CELL
+         d.mon select=CELL
+         d.rast map=terrain
+         d.vect.area map=area51  fillcolor=white  linecolor=blue
+         d.vect.area map=roswell fillcolor=yellow linecolor=blue
+         d.vect map=states  color=green
+         d.vect map=roads   color=blue
+         d.mon stop=CELL
+         # make the region the same as the newly created cell for ppm export
+         g.pushregion.sh  # or g.region save=saved.reg
+         g.region raster=D_cell
+         r.out.ppm -q input=D_cell output=alien.ppm
+         # use the netpbm utilities to create a gif (quantize if needed)
+         # assemble some html with the image and the image map
+         echo '<html><body><img src="alien.gif" usemap="#map">' >alien.html
+         cat htmlmap                                           >>alien.html
+         echo '</body></html>'                                 >>alien.html
+         # don't forget to reset your region
+         g.popregion.sh   # or g.region region=saved.reg
+	 # take a look and test it out
+	 netscape file:`pwd`/alien.html &
+  Building the HTMLMAP driver:
+    Change to the HTMLMAP directory, and make it:
+	cd src/display/devices/HTMLMAP
+	gmake5
+    If all goes well, the HTMLMAP driver will be compiled and moved into
+    your device driver directory ($GISBASE/driver) and "etc/monitorcap"
+    will be modified.
+  Other:
+    Don't forget to add the HTMLMAP driver in your monitorcap file!
+    Your monitorcap file exists as $GISBASE/etc/monitorcap.
+        HTMLMAP:driver/HTMLMAP:Create HTML Image Map: \
+             /usr/local/grass43/dev/fifo.9a /usr/local/grass43/dev/fifo.9b \
+             ::any terminal
+    Note: This job will be done by the Gmakefile.
+    HTMLMAP was adapted from the CELL driver in GRASS 4.3.  Point-in-
+    polygon-test code was lifted from Randolph Franklin's web page, see
+	http://www.ecse.rpi.edu/Homepages/wrf/
+	http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html
+    If you create an HTML file with two or more images & image maps, you
+    will need to edit the map names.  The HTMLMAP driver creates its map
+    with the name 'map'.  A small sed script can easily change the map name:
+	sed -e 's/NAME="map"/NAME="foomap"/' <htmlmap >foomap.html
+http://www.nyx.net/~tpoindex/grass-stuff/
Added: grass/trunk/lib/htmldriver/Text.c
--- grass/trunk/lib/htmldriver/Text.c	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Text.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,30 @@
+/* Text.c - save text string into last_text buffer */
+void HTML_Text(const char *text)
+    int len = strlen(text);
+    const char *s;
+    char *d;
+    if (len > last_text_len) {
+	G_free(last_text);
+	last_text = (char *)G_malloc(len + 1);
+	last_text_len = len;
+    /* copy string to last_text area, make sure we don't copy \n */
+    for (d = last_text, s = text; *s != '\0'; s++) {
+	if (*s != '\n') {
+	    *d = *s;
+	    d++;
+    *d = '\0';
Added: grass/trunk/lib/htmldriver/description.html
--- grass/trunk/lib/htmldriver/description.html	                        (rev 0)
+++ grass/trunk/lib/htmldriver/description.html	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,190 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<HTML>
+<HEAD>
+ <TITLE>HTMLMAP driver</TITLE>
+ <META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
+ <link rel="stylesheet" href="grassdocs.css" type="text/css">
+</HEAD>
+<BODY bgColor=white>
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<H2>NAME</H2>
+<EM><B>HTMLMAP driver</B></EM> - driver to create HTML image maps.
+<BR><EM>(drivers)</EM>
+<H2>DESCRIPTION</H2>
+The HTMLMAP driver allows the generation of HTML image maps
+for area vector data. HTML image maps are used in conjunction with images to
+provide unique URL targets for different portions of an image. The HTMLMAP
+<P>
+Note that GRASS display commands that require the MOUSE will not work
+correctly (or at all!)
+<P>
+Polygons can at most have 100 vertices (this limit imposed by HTML image map
+formats, see <B>GRASS_HTMLMAXPOINTS</B> below.) The driver will attempt to
+trim polygons that have more that 100
+vertices by removing vertices with the least amount of angle to the next
+vertice. Also, any polygon that is entirely bounded by another polygon will be
+discarded.
+<P>
+Text written to the driver before polygons are used as the HREF tag for all
+subsequent polygons written. All polygons that exist in a vector map will have
+the same HREF tag.
+<P>
+The only GRASS display commands that should be used with this driver are:
+<UL>
+  <LI><a href="d.text.html">d.text</A>
+  - pass href information for resulting image maps.</LI>
+  <LI><a href="d.vect.html">d.vect</A>
+  - draw polygons from a vector map.</LI>
+</UL>
+<H2>USAGE</H2>
+<H3>Environment variables</H3>Several environment variables effect the operation
+of HTMLMAP.
+<UL>
+  <LI><B>GRASS_WIDTH=xxx</B><BR>the width of the image map (default is
+    640).
+  </LI><BR>
+  <LI><B>GRASS_HEIGHT=yyy</B><BR>the height of the image map (default is
+    480).
+  </LI><BR>
+  <LI><B>GRASS_HTMLTYPE=type</B><BR>the type of image mape to create (default is
+    CLIENT):
+    <UL>
+      <DD><TT><B>CLIENT</B></TT> &nbsp;&nbsp; Netscape/IE client-side image map.
+	(NAME="map")<BR>
+      <DD><TT><B>APACHE</B></TT> &nbsp;&nbsp; Apache/NCSA server-side image
+	map.<BR>
+      <DD><TT><B>RAW</B></TT> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Raw url
+	and polygon vertices ( <I>url&nbsp; x1&nbsp; y1&nbsp; x2&nbsp; y2&nbsp;
+	  ..... </I>), suitable for conversion to CERN server format, or any other
+	format with user supplied conversion program.</DD>
+    </UL>
+  </LI><BR>
+  <LI><B>GRASS_HTMLFILE=filename</B><BR>
+    the html image map, default is <tt>htmlmap</tt>. Files without absolute path
+    names are written in the current directory where the driver was started.
+    <BR>
+    <em>Any existing file of the same name is overwritten without
+      warning.</em>
+  </LI><BR>
+  <LI><B>GRASS_HTMLMINDIST=n</B><BR>specifies the minimum distance in pixels
+  that a point must change from the previous point to keep in the list of
+  vertices for a polygon.  The default is <tt>2</tt>, which means that a
+  point's x and y difference from the previous point must change by a number
+  of pixels greater than this value.  This parameter helps to eliminate
+  closely spaced points.
+  </LI><BR>
+  <LI><B>GRASS_HTMLMINBBOX=n</B><BR>specifies the minimum bounding box
+  dimensions to record a polygon as a clickable area.
+  The default is <tt>2</tt>, which means that a polygon with a bounding box
+  of less than this value is not included. This parameter helps to eliminate
+  polygons than are a point or line.
+  </LI><BR>
+  <LI><B>GRASS_HTMLMAXPOINTS=n</B><BR>specifies the maximum number of
+  vertices included in a polygon's clickable area.
+  The default is <tt>99</tt>.  Some browsers can only accomodate polygons of
+  100 vertices or less.  The HTMLMAP driver automatically ensures that a
+  polygon is closed by making the last point the same as the first
+  point.</LI><BR>
+</UL>
+<H3>Typical usage</H3>
+<UL>
+  <LI>Start up the driver
+<DIV class="code"><PRE>
+d.mon start=HTMLMAP
+</PRE></DIV>
+  </LI>
+  <LI>Display text strings (HREF's) and polygons
+echo "http://www.no-such-place.net/area51/" | d.text
+d.vect map=area51
+echo "http://www.roswell-nm.net/little/green/men.html" | d.text
+d.vect map=roswell
+</PRE></div>
+  <LI>Stop the driver when all polygon have been displayed. This will cause a file
+    named 'htmlmap' to be created in your current directory.
+d.mon stop=HTMLMAP
+</PRE></DIV>
+  <LI>You will also want to create an image for your image map. Use the PNG
+    driver and other utilities to create .gif or .jpg files.
+    <i>The following example is somewhat out of date and refers to options
+      available in GRASS 5.</i>
+# using previous GRASS_WIDTH &amp; GRASS_HEIGHT
+d.mon start=PNG
+d.mon select=PNG
+d.rast map=terrain
+d.vect map=area51  fillcolor=white  linecolor=blue
+d.vect map=roswell fillcolor=yellow linecolor=blue
+d.vect map=states  color=green
+d.vect map=roads   color=black
+d.mon stop=PNG
+<!-- ????  FIXME -->
+# make the region the same as the newly created cell for ppm export
+g.region save=saved.reg
+g.region raster=D_cell
+r.out.ppm -q input=D_cell output=alien.ppm
+# use the netpbm utilities to create a gif (quantize if needed)
+# assemble some html with the image and the image map
+echo '&lt;html&gt;&lt;body&gt;&lt;img src="alien.gif" usemap="#map"&gt;' &gt;alien.html
+cat htmlmap                                           &gt;&gt;alien.html
+echo '&lt;/body&gt;&lt;/html&gt;'                                 &gt;&gt;alien.html
+# don't forget to reset your region
+g.region region=saved.reg
+# take a look and test it out
+netscape file:`pwd`/alien.html &amp;
+</PRE></DIV>
+  </LI>
+</UL>
+<H2>NOTES</H2>
+HTMLMAP was adapted from the CELL driver in GRASS 4.3.
+Point-in-polygon test code was lifted from Randolph Franklin's web page, see
+<UL>
+  <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/">http://www.ecse.rpi.edu/Homepages/wrf/</A></LI>
+  <LI><a href="http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html">http://www.ecse.rpi.edu/Homepages/wrf/research/geom/pnpoly.html</A></LI>
+</UL>
+<P>
+If you create an HTML file with two or more images and image maps, you will
+need to edit the map names. The HTMLMAP driver creates its map with the name
+<tt>map</tt>. A small sed script can easily change the map name:
+<PRE>
+  sed -e 's/NAME="map"/NAME="foomap"/' &lt; htmlmap &gt; foomap.html
+</PRE>
+<H2>SEE ALSO</H2>
+<EM>
+  <a href="displaydrivers.html">Display drivers</a>
+  <br>
+  <a href="pngdriver.html">PNG driver</A>,
+  <a href="psdriver.html">PostScript driver</A>,
+  <a href="xdriver.html">XDRIVER</A>
+  <BR>
+  <A href="d.mon.html">d.mon</A>,
+  <a href="d.text.html">d.text</A>,
+  <a href="d.vect.html">d.vect</A>
+</EM>
+<p>
+<i>Last changed: $Date: 2008-03-23 14:34:53 +0000 (Sun, 23 Mar 2008) $</i>
Added: grass/trunk/lib/htmldriver/htmlmap.h
--- grass/trunk/lib/htmldriver/htmlmap.h	                        (rev 0)
+++ grass/trunk/lib/htmldriver/htmlmap.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,48 @@
+#include <stdio.h>
+#define DEF_MINBBOX  2
+#define DEF_MINDIST  2
+#define DEF_MAXPTS  99
+#define FILE_NAME  "htmlmap"
+#define INITIAL_TEXT 1000
+#define APACHE 0		/* write output in apache/ncsa server image map format */
+#define NCSA   0		/* write output in apache/ncsa server image map format */
+#define CLIENT 1		/* write output in netscape client side image map format */
+#define RAW    2		/* write output in raw format */
+extern char *last_text;
+extern int last_text_len;
+extern char *file_name;
+extern int html_type;
+extern FILE *output;
+struct MapPoly
+    char *url;
+    int num_pts;
+    int *x_pts;
+    int *y_pts;
+    struct MapPoly *next_poly;
+extern struct MapPoly *head;
+extern struct MapPoly **tail;
+/* Driver.c */
+extern const struct driver *HTML_Driver(void);
+/* Graph_Clse.c */
+extern void HTML_Graph_close(void);
+/* Graph_Set.c */
+extern int HTML_Graph_set(int, char **);
+/* Polygn_abs.c */
+extern void HTML_Polygon_abs(const int *, const int *, int);
+/* Text.c */
+extern void HTML_Text(const char *);
Modified: grass/trunk/lib/pngdriver/Driver.c
--- grass/trunk/lib/pngdriver/Driver.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/pngdriver/Driver.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -32,15 +32,9 @@
     drv.Client_Close = PNG_Client_Close;
     drv.Erase = PNG_Erase;
-    drv.Get_with_box = NULL;
-    drv.Get_with_line = NULL;
-    drv.Get_with_pointer = NULL;
     drv.Graph_set = PNG_Graph_set;
     drv.Graph_close = PNG_Graph_close;
     drv.Line_width = PNG_Line_width;
-    drv.Panel_save = NULL;
-    drv.Panel_restore = NULL;
-    drv.Panel_delete = NULL;
@@ -52,8 +46,6 @@
     drv.Scaled_raster = PNG_scaled_raster;
     drv.Respond = PNG_Respond;
-    drv.Work_stream = NULL;
-    drv.Do_work = NULL;
     drv.lookup_color = PNG_lookup_color;
     drv.color = PNG_color;
     drv.draw_line = PNG_draw_line;
Added: grass/trunk/lib/pngdriver/description.html
--- grass/trunk/lib/pngdriver/description.html	                        (rev 0)
+++ grass/trunk/lib/pngdriver/description.html	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,125 @@
+<HTML>
+<HEAD>
+ <TITLE>PNG driver</TITLE>
+</HEAD>
+<H2>NAME</H2>
+<EM><B> PNG driver</B></EM> - driver to create PNG and PPM images.
+The PNG driver generates PNG and PPM images from GRASS display commands.
+Per default PNG files are written with this driver. It is started as 'pseudo' monitor
+(image file instead) and when stopped, all output from previously used
+display commands are written to the PNG image file.
+<H2>USAGE</H2>
+Several environment variables effect the operation
+of the PNG driver.
+<UL>
+     the width of the image map (default is 640).</LI><BR>
+    the height of the image map (default is 480).</LI><BR>
+  <LI><B>GRASS_PNGFILE=filename</B><BR>
+     the filename to put the resulting image in, default is <tt>map.png</tt>.
+     If you set GRASS_PNGFILE to a filename which ends in ".ppm", a PPM
+     file will be created.<br><br>
+  <LI><B>GRASS_BACKGROUNDCOLOR=RRGGBB</B><BR>
+     specifies the background color to use in RGB
+     notation (hex values). Default is <b>000000</b> (black).<br><br>
+  <LI><B>GRASS_TRANSPARENT=[TRUE|FALSE]</B><BR>
+    sets transparent background on (TRUE) or off (FALSE, default).</LI><BR>
+  <LI><B>GRASS_TRUECOLOR=[TRUE|FALSE]</B><BR>
+    sets true-color support</LI><BR>
+  <LI><B>GRASS_PNG_COMPRESSION=[0|1|9]</B><BR>
+    compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)</LI><BR>
+  <LI><B>GRASS_PNG_AUTO_WRITE=[TRUE|FALSE]</B><BR>
+     if set to <tt>TRUE</tt>, the image file will be written after each
+     operation (i.e. whenever a client disconnects), rather than
+     only being written out when the driver terminates.</LI><BR>
+  <LI><B>GRASS_PNG_READ</B><BR>
+     if <tt>TRUE</tt>, the PNG driver will initialize the image from
+     the contents of GRASS_PNGFILE.</LI><BR>
+  <LI><B>GRASS_PNG_MAPPED</B><BR>
+     if <tt>TRUE</tt>, the PNG driver will map GRASS_PNGFILE as its framebuffer,
+     rather than using memory. This only works with BMP files.</LI><BR>
+  <LI><B>GRASS_RENDER_IMMEDIATE=[TRUE|FALSE]</B><BR>
+     tells the raster library to use its built-in PNG driver rather
+     than connecting to an external monitor process using sockets. If
+     <tt>TRUE</tt>, there is no need to run <tt>d.mon start=PNG</tt>.
+</UL>
+<H3>Example</H3>
+<OL>
+  <LI>Define driver settings (here: bash shell syntax)
+export GRASS_RENDER_IMMEDIATE=TRUE
+export GRASS_TRUECOLOR=TRUE
+</PRE></DIV>
+  </LI>
+d.mon start=PNG
+</PRE></DIV>
+  </LI>
+  <LI>Display raster map and vector polygons
+d.rast <i>somerastermap</i>
+d.vect <i>somevectormap</i> color=red
+</PRE></DIV>
+  </LI>
+  <LI> Stop the driver subsequently. This will write a
+    file named <tt>map.png</tt> to be created in your current directory:
+d.mon stop=PNG
+</PRE></DIV>
+  </LI>
+</OL>
+<H2>NOTES</H2>
+The PNG driver uses the libpng (see the <a href="http://www.libpng.org/pub/png/">libpng</a>
+home page) and zlib (see the
+<a href="http://www.zlib.net">zlib</a> home page), all which needs to
+be installed for the PNG driver to work (it's worth it).
+<p>
+The resolution of the <i>PNG</i> raster map is defined by the map
+extents. Use <em>g.region -p</em> to get the number of rows and cols and
+use the environment variables to set the PNG size. If you would like a
+larger image, multiply both rows and cols by the same whole number to
+preserve the aspect ratio.
+<p>
+Further PNG file processing (e.g. quantization to 1 bit for monochrome images)
+can be done with 'pnmquant' of the <a href="http://netpbm.sourceforge.net/">netpbm</a> tools.
+<h2>SEE ALSO</h2>
+<EM>
+  <br>
+  <A HREF="htmlmapdriver.html">HTMLMAP driver</A>,
+  <A HREF="psdriver.html">PostScript driver</A>,
+  <A href="xdriver.html">XDRIVER</A>
+  <BR>
+  <A HREF="d.frame.html">d.frame</A>,
+  <A href="d.rast.html">d.rast</A>,
+  <A href="d.vect.html">d.vect</A>
+</EM>
+<H2>AUTHOR</H2>
+Original version: Per Henrik Johansen &lt;<I>phj (at) norgit.no</I>&gt; <I><a href="http://www.norgit.no">NORGIT AS</a></I>
+<BR>
+Rewritten by: Glynn Clements, 2003
+<p>
Modified: grass/trunk/lib/psdriver/Driver.c
--- grass/trunk/lib/psdriver/Driver.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/psdriver/Driver.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -32,15 +32,9 @@
     drv.Client_Close = PS_Client_Close;
     drv.Erase = PS_Erase;
     drv.Graph_set = PS_Graph_set;
     drv.Graph_close = PS_Graph_close;
     drv.Line_width = PS_Line_width;
     drv.Polyline_abs = PS_Polyline_abs;
@@ -52,8 +46,6 @@
     drv.Scaled_raster = PS_scaled_raster;
     drv.End_scaled_raster = PS_end_scaled_raster;
     drv.Respond = PS_Respond;
     drv.lookup_color = PS_lookup_color;
     drv.color = PS_color;
     drv.draw_line = PS_draw_line;
Modified: grass/trunk/lib/psdriver/Makefile
--- grass/trunk/lib/psdriver/Makefile	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/psdriver/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -9,25 +9,6 @@
 LIB_NAME = $(PSDRIVER_LIBNAME)
-LIB_OBJS =	\
-	Box.o			\
-	Client.o		\
-	Color.o			\
-	Color_table.o		\
-	Draw_bitmap.o		\
-	Draw_line.o		\
-	Draw_point.o		\
-	Driver.o		\
-	Erase.o			\
-	Graph_close.o		\
-	Graph_set.o		\
-	Line_width.o		\
-	Polygon.o		\
-	Polyline.o		\
-	Raster.o		\
-	Respond.o		\
-	Set_window.o
 default: lib $(ETC)/psdriver.ps
Added: grass/trunk/lib/psdriver/description.html
--- grass/trunk/lib/psdriver/description.html	                        (rev 0)
+++ grass/trunk/lib/psdriver/description.html	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,109 @@
+<HTML>
+<HEAD>
+ <TITLE>PS driver</TITLE>
+</HEAD>
+<H2>NAME</H2>
+<EM><B> PS driver</B></EM> - driver to create PostScript files.
+The PS driver generates a PostScript file from GRASS display commands.
+The driver is started as 'pseudo' monitor (PS file instead) and when
+stopped, all output from previously used display commands are written
+to the PostScript file.
+<H2>USAGE</H2>
+of the PS driver:
+<UL>
+  <LI><B>GRASS_PSFILE</B><BR>
+    name of output file. If it ends with ".eps" an EPS file
+    will be created.</LI><BR>
+  <LI><B>GRASS_PAPER</B><BR>
+    sets the screen dimensions and margins to
+    fit a standard paper size, see also GRASS_WIDTH, GRASS_HEIGHT.</LI><BR>
+  <LI><B>GRASS_WIDTH</B><BR>
+    defines the width of the screen, see also GRASS_HEIGHT</LI><BR>
+  <LI><B>GRASS_HEIGHT</B><BR>
+    defines the height of the screen, see also GRASS_WIDTH</LI><BR>
+  <LI><B>GRASS_TRUECOLOR</B><BR>
+    if <tt>TRUE</tt>, the PS driver generates color output, otherwise
+    monochrome.</LI><BR>
+  <LI><B>GRASS_LANDSCAPE</B><BR>
+    if <tt>TRUE</tt>, the screen is rotated 90 degrees
+    counter-clockwise so that a "landscape" screen fits better on
+    "portrait" paper.</LI><BR>
+  <LI><B>GRASS_PS_HEADER</B><BR>
+    if <tt>FALSE</tt>, the output is appended to any existing file,
+    and no prolog or setup sections are generated.</LI><BR>
+  <LI><B>GRASS_PS_TRAILER</B><BR>
+    if <tt>FALSE</tt>, no trailer section is generated.</LI>
+</UL>
+<H3>Example</H3>
+<OL>
+d.mon start=PS
+</PRE></DIV>
+  </LI>
+d.vect map=<i>somevectormap</i> color=red
+</PRE></DIV>
+  </LI>
+    file named <tt>map.ps</tt> to be created in your current directory:
+d.mon stop=PS
+</PRE></DIV>
+  </LI>
+</OL>
+<H2>NOTES</H2>
+The resolution of the <i>PS</i> raster map is defined by the map
+use the environment variables to set the PS size. If you would like a
+<P>
+GRASS_TRUECOLOR requires either PostScript level 2 or level 1 plus the
+colorimage and setrgbcolor operators (this is the case for colour printers
+which pre-date level 2 PostScript).
+<p>
+Only masked images (<tt>d.rast -o</tt>, <tt>d.rgb -o</tt>, <tt>d.his
+-n</tt>) require PostScript level 3.
+<h2>SEE ALSO</h2>
+<EM>
+  <br>
+  <A HREF="pngdriver.html">PNG driver</A>,
+  <BR>
+  <A href="d.out.file.html">d.out.file</A>,
+</EM>
+<H2>AUTHOR</H2>
+Glynn Clements, 2007
+<p>
Modified: grass/trunk/lib/raster/Makefile
--- grass/trunk/lib/raster/Makefile	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/Makefile	2008-08-06 21:50:17 UTC (rev 32584)
@@ -4,7 +4,7 @@
 EXTRA_CFLAGS=$(GETHOSTNAME) $(FTINC) -I../driver $(PICFLAGS) $(DEFS)
-EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(PNGDRIVERLIB) $(PSDRIVERLIB)
+EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(PNGDRIVERLIB) $(PSDRIVERLIB) $(HTMLDRIVERLIB)
 LIB_NAME = $(RASTER_LIBNAME)
Deleted: grass/trunk/lib/raster/com_get.c
--- grass/trunk/lib/raster/com_get.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/com_get.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,20 +0,0 @@
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include "transport.h"
-void R_get_location_with_box(int cx, int cy, int *wx, int *wy, int *button)
-    trans->get_location_with_box(cx, cy, wx, wy, button);
-void R_get_location_with_line(int cx, int cy, int *wx, int *wy, int *button)
-    trans->get_location_with_line(cx, cy, wx, wy, button);
-void R_get_location_with_pointer(int *wx, int *wy, int *button)
-    trans->get_location_with_pointer(wx, wy, button);
Deleted: grass/trunk/lib/raster/com_io.c
--- grass/trunk/lib/raster/com_io.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/com_io.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,211 +0,0 @@
-#include <errno.h>
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include "driver.h"
-struct transport loc_trans = {
-    LOC_open_driver,
-    LOC__open_quiet,
-    LOC_stabilize,
-    LOC_kill_driver,
-    LOC_close_driver,
-    LOC_release_driver,
-    LOC_screen_left,
-    LOC_screen_rite,
-    LOC_screen_bot,
-    LOC_screen_top,
-    LOC_get_num_colors,
-    LOC_standard_color,
-    LOC_RGB_color,
-    LOC_line_width,
-    LOC_erase,
-    LOC_move_abs,
-    LOC_move_rel,
-    LOC_cont_abs,
-    LOC_cont_rel,
-    LOC_polydots_abs,
-    LOC_polydots_rel,
-    LOC_polyline_abs,
-    LOC_polyline_rel,
-    LOC_polygon_abs,
-    LOC_polygon_rel,
-    LOC_box_abs,
-    LOC_box_rel,
-    LOC_text_size,
-    LOC_text_rotation,
-    LOC_set_window,
-    LOC_text,
-    LOC_get_text_box,
-    LOC_font,
-    LOC_charset,
-    LOC_font_list,
-    LOC_font_info,
-    LOC_panel_save,
-    LOC_panel_restore,
-    LOC_panel_delete,
-    LOC_begin_scaled_raster,
-    LOC_scaled_raster,
-    LOC_end_scaled_raster,
-    LOC_bitmap,
-    LOC_get_location_with_box,
-    LOC_get_location_with_line,
-    LOC_get_location_with_pointer,
-    LOC_pad_create,
-    LOC_pad_current,
-    LOC_pad_delete,
-    LOC_pad_invent,
-    LOC_pad_list,
-    LOC_pad_select,
-    LOC_pad_append_item,
-    LOC_pad_delete_item,
-    LOC_pad_get_item,
-    LOC_pad_list_items,
-    LOC_pad_set_item
-#ifdef HAVE_SOCKET
-struct transport rem_trans = {
-    REM_open_driver,
-    REM__open_quiet,
-    REM_stabilize,
-    REM_kill_driver,
-    REM_close_driver,
-    REM_release_driver,
-    REM_screen_left,
-    REM_screen_rite,
-    REM_screen_bot,
-    REM_screen_top,
-    REM_get_num_colors,
-    REM_standard_color,
-    REM_RGB_color,
-    REM_line_width,
-    REM_erase,
-    REM_move_abs,
-    REM_move_rel,
-    REM_cont_abs,
-    REM_cont_rel,
-    REM_polydots_abs,
-    REM_polydots_rel,
-    REM_polyline_abs,
-    REM_polyline_rel,
-    REM_polygon_abs,
-    REM_polygon_rel,
-    REM_box_abs,
-    REM_box_rel,
-    REM_text_size,
-    REM_text_rotation,
-    REM_set_window,
-    REM_text,
-    REM_get_text_box,
-    REM_font,
-    REM_charset,
-    REM_font_list,
-    REM_font_info,
-    REM_panel_save,
-    REM_panel_restore,
-    REM_panel_delete,
-    REM_begin_scaled_raster,
-    REM_scaled_raster,
-    REM_end_scaled_raster,
-    REM_bitmap,
-    REM_get_location_with_box,
-    REM_get_location_with_line,
-    REM_get_location_with_pointer,
-    REM_pad_create,
-    REM_pad_current,
-    REM_pad_delete,
-    REM_pad_invent,
-    REM_pad_list,
-    REM_pad_select,
-    REM_pad_append_item,
-    REM_pad_delete_item,
-    REM_pad_get_item,
-    REM_pad_list_items,
-    REM_pad_set_item
-#endif
-const struct transport *trans;
-static const struct transport *get_trans(void)
-#ifndef HAVE_SOCKET
-    return &loc_trans;
-#else
-    const char *p = getenv("GRASS_RENDER_IMMEDIATE");
-    if (!p)
-	return &rem_trans;
-    if (G_strcasecmp(p, "TRUE") == 0)
-    if (G_strcasecmp(p, "FALSE") == 0)
-    if (G_strcasecmp(p, "PNG") == 0)
-    if (G_strcasecmp(p, "PS") == 0)
-    G_warning("Unrecognised GRASS_RENDER_IMMEDIATE setting: %s", p);
-#endif
-static void init_transport(void)
-    if (trans)
-	return;
-    trans = get_trans();
-int R_open_driver(void)
-    init_transport();
-    return trans->open_driver();
-void R__open_quiet(void)
-    init_transport();
-    trans->open_quiet();
-void R_stabilize(void)
-    trans->stabilize();
-void R_kill_driver(void)
-    trans->kill_driver();
-void R_close_driver(void)
-    trans->close_driver();
-void R_release_driver(void)
-    trans->release_driver();
Deleted: grass/trunk/lib/raster/com_pad.c
--- grass/trunk/lib/raster/com_pad.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/com_pad.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,72 +0,0 @@
-#include <stdio.h>
-#include <grass/graphics.h>
-/* PAD FUNCTIONS
-   The monitor has a very simple database management capability
-   which supports the windowing.  There are scratch pads
-   to be written on. Each scratch pad can contain items,  and
-   each  item can have a list of values.  These are NOT to be
-   used by the programmer.  They are used indirectly  through
-   the displaylib library calls.
-int R_pad_create(const char *pad)
-    return trans->pad_create(pad);
-int R_pad_current(char *name)
-    return trans->pad_current(name);
-int R_pad_delete(void)
-    return trans->pad_delete();
-int R_pad_invent(char *pad)
-    return trans->pad_invent(pad);
-int R_pad_list(char ***list, int *count)
-    return trans->pad_list(list, count);
-int R_pad_select(const char *pad)
-    return trans->pad_select(pad);
-int R_pad_append_item(const char *item, const char *value, int replace)
-    return trans->pad_append_item(item, value, replace);
-int R_pad_delete_item(const char *name)
-    return trans->pad_delete_item(name);
-int R_pad_get_item(const char *name, char ***list, int *count)
-    return trans->pad_get_item(name, list, count);
-int R_pad_list_items(char ***list, int *count)
-    return trans->pad_list_items(list, count);
-int R_pad_set_item(const char *name, const char *value)
-    return trans->pad_set_item(name, value);
Deleted: grass/trunk/lib/raster/com_proto.c
--- grass/trunk/lib/raster/com_proto.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/com_proto.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,535 +0,0 @@
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <fcntl.h>
-#include <unistd.h>
- * \brief screen left edge
- * Returns the coordinate of the left edge of the screen.
- *  \param void
- *  \return int
-int R_screen_left(void)
-    return trans->screen_left();
- * \brief screen right edge
- * Returns the coordinate of the right edge of the screen.
- *  \param void
- *  \return int
-int R_screen_rite(void)
-    return trans->screen_rite();
- * \brief bottom of screen
- * Returns the coordinate of the bottom of the screen.
- *  \param void
- *  \return int
-int R_screen_bot(void)
-    return trans->screen_bot();
- * \brief top of screen
- * Returns the coordinate of the top of the screen.
- *  \param void
- *  \return int
-int R_screen_top(void)
-    return trans->screen_top();
-void R_get_num_colors(int *n)
-    trans->get_num_colors(n);
- * \brief select standard color
- * Selects the
- * standard <b>color</b> to be used in subsequent draw commands.  The
- * <b>color</b> value is best retrieved using <i>D_translate_color.</i>
- * See Display_Graphics_Library.
- *  \param index
- *  \return int
-void R_standard_color(int index)
-    trans->standard_color(index);
- * \brief select color
- * When in
- * float mode (see <i>R_color_table_float</i>), this call selects the color
- * most closely matched to the <b>red, grn</b>, and <b>blue</b> intensities
- * requested. These values must be in the range of 0-255.
- *  \param red
- *  \param grn
- *  \param blue
- *  \return int
-void R_RGB_color(unsigned char red, unsigned char grn, unsigned char blu)
-    trans->RGB_color(red, grn, blu);
- * \brief change the width of line
- * Changes the <b>width</b> of line to be used in subsequent draw commands.
- *  \param width
- *  \return int
-void R_line_width(int width)
-    trans->line_width(width);
- * \brief erase screen
- * Erases the entire screen to black.
- *  \param void
- *  \return int
-void R_erase(void)
-    trans->erase();
- * \brief move current location
- * Move the current location to the absolute screen coordinate <b>x,y.</b>
- * Nothing is drawn on the screen.
- *  \param x
- *  \param y
- *  \return int
-void R_move_abs(int x, int y)
-    trans->move_abs(x, y);
- * Shift the current screen location by the values in <b>dx</b> and <b>dy</b>:
- \code
- Newx = Oldx + dx;
- Newy = Oldy + dy;
- \endcode
- *  \param x dx
- *  \param y dy
- *  \return int
-void R_move_rel(int x, int y)
-    trans->move_rel(x, y);
- * \brief draw line
- * Draw a line using the current color, selected via <i>R_color</i>, from the
- * current location to the location specified by <b>x,y.</b> The current location
- * is updated to <b>x,y.</b>
- *  \param x
- *  \param y
- *  \return int
-void R_cont_abs(int x, int y)
-    trans->cont_abs(x, y);
- * current color, selected via <i>R_color</i>, from the current location to
- * the relative location specified by <b>x</b> and <b>y.</b> The current
- * location is updated:
- \code
- Newx = Oldx + x;
- Newy = Oldy + y;
- \endcode
- *  \param x
- *  \param y
- *  \return int
-void R_cont_rel(int x, int y)
-    trans->cont_rel(x, y);
- * \brief draw a series of dots
- * Pixels at the <b>num</b> absolute positions in the <b>x</b> and
- * <b>y</b> arrays are turned to the current color. The current location is
- * left updated to the position of the last dot.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void R_polydots_abs(const int *xarray, const int *yarray, int number)
-    trans->polydots_abs(xarray, yarray, number);
- * Pixels at the <b>number</b> relative positions in the <b>x</b> and
- * <b>y</b> arrays are turned to the current color. The first position is
- * relative to the starting current location; the succeeding positions are then
- * relative to the previous position. The current location is updated to the
- * position of the last dot.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void R_polydots_rel(const int *xarray, const int *yarray, int number)
-    trans->polydots_rel(xarray, yarray, number);
- * \brief draw an open polygon
- * The <b>number</b> absolute positions in the <b>x</b> and <b>y</b>
- * arrays are used to generate a multisegment line (often curved). This line is
- * drawn with the current color. The current location is left updated to the
- * position of the last point.
- * <b>Note.</b> It is not assumed that the line is closed, i.e., no line is
- * drawn from the last point to the first point.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void R_polyline_abs(const int *xarray, const int *yarray, int number)
-    trans->polyline_abs(xarray, yarray, number);
- * The <b>number</b> relative positions in the <b>x</b> and <b>y</b>
- * arrays are used to generate a multisegment line (often curved). The first
- * position is relative to the starting current location; the succeeding
- * positions are then relative to the previous position. The current location is
- * updated to the position of the last point. This line is drawn with the current
- * color.
- * <b>Note.</b> No line is drawn between the last point and the first point.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void R_polyline_rel(const int *xarray, const int *yarray, int number)
-    trans->polyline_rel(xarray, yarray, number);
- * \brief draw a closed polygon
- * The <b>number</b> absolute positions in the <b>x</b> and <b>y</b> arrays
- * outline a closed polygon which is filled with the current color. The current
- * location is undefined afterwards.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void R_polygon_abs(const int *xarray, const int *yarray, int number)
-    trans->polygon_abs(xarray, yarray, number);
- * arrays outline a closed polygon which is filled with the current color. The
- * first position is relative to the starting current location; the succeeding
- * undefined afterwards.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void R_polygon_rel(const int *xarray, const int *yarray, int number)
-    trans->polygon_rel(xarray, yarray, number);
- * \brief fill a box
- * A box is drawn in the current color using the coordinates <b>x1,y1</b> and
- * <b>x2,y2</b> as opposite corners of the box. The current location is undefined
- * afterwards
- *  \param x1
- *  \param y1
- *  \param x2
- *  \param y2
- *  \return int
-void R_box_abs(int x1, int y1, int x2, int y2)
-    trans->box_abs(x1, y1, x2, y2);
- * A box is drawn in the current color using the current location as one corner
- * and the current location plus <b>x</b> and <b>y</b> as the opposite corner
- * of the box. The current location is undefined afterwards.
- *  \param x
- *  \param y
- *  \return int
-void R_box_rel(int x, int y)
-    trans->box_rel(x, y);
- * \brief set text size
- * Sets text pixel width and height to <b>width</b> and <b>height.</b>
- *  \param width
- *  \param height
- *  \return int
-void R_text_size(int width, int height)
-    trans->text_size(width, height);
-void R_text_rotation(float rotation)
-    trans->text_rotation(rotation);
- * \brief set text clipping frame
- * Subsequent calls to <i>R_text</i> will have text strings
- * clipped to the screen frame defined by <b>top, bottom, left, right.</b>
- *  \param t top
- *  \param b bottom
- *  \param l left
- *  \param r right
- *  \return int
-void R_set_window(int t, int b, int l, int r)
-    trans->set_window(t, b, l, r);
- * \brief write text
- * Writes <b>text</b> in the current color and font, at the current text
- * width and height, starting at the current screen location.
- *  \param sometext
- *  \return int
-void R_text(const char *text)
-    trans->text(text);
- * \brief get text extents
- * The extent of the area enclosing the <b>text</b>
- * is returned in the integer pointers <b>top, bottom, left</b>, and
- * <b>right.</b> No text is actually drawn. This is useful for capturing the
- * text extent so that the text location can be prepared with proper background
- * or border.
- *  \param sometext
- *  \param t top
- *  \param b bottom
- *  \param l left
- *  \param r right
- *  \return int
-void R_get_text_box(const char *text, int *t, int *b, int *l, int *r)
-    trans->get_text_box(text, t, b, l, r);
- * \brief choose font
- * Set current font to <b>font name</b>. Available fonts are:
- <table>
- <tr><td><b>Font Name</b></td><td><b>Description</b></td></tr>
- <tr><td>cyrilc </td><td> cyrillic</td></tr>
- <tr><td>gothgbt </td><td> Gothic Great Britain triplex</td></tr>
- <tr><td>gothgrt </td><td>  Gothic German triplex</td></tr>
- <tr><td>gothitt </td><td>  Gothic Italian triplex</td></tr>
- <tr><td>greekc </td><td> Greek complex</td></tr>
- <tr><td>greekcs </td><td> Greek complex script</td></tr>
- <tr><td>greekp </td><td> Greek plain</td></tr>
- <tr><td>greeks </td><td> Greek simplex</td></tr>
- <tr><td>italicc </td><td>  Italian complex</td></tr>
- <tr><td>italiccs </td><td> Italian complex small</td></tr>
- <tr><td>italict </td><td> Italian triplex</td></tr>
- <tr><td>romanc </td><td> Roman complex</td></tr>
- <tr><td>romancs </td><td> Roman complex small</td></tr>
- <tr><td>romand </td><td> Roman duplex</td></tr>
- <tr><td>romanp </td><td> Roman plain</td></tr>
- <tr><td>romans </td><td> Roman simplex</td></tr>
- <tr><td>romant </td><td> Roman triplex</td></tr>
- <tr><td>scriptc </td><td> Script complex</td></tr>
- <tr><td>scripts </td><td> Script simplex</td></tr>
- </table>
- *  \param name
- *  \return int
-void R_font(const char *name)
-    trans->font(name);
-void R_charset(const char *name)
-    trans->charset(name);
-void R_font_list(char ***list, int *count)
-    trans->font_list(list, count);
-void R_font_info(char ***list, int *count)
-    trans->font_info(list, count);
-void R_panel_save(const char *name, int t, int b, int l, int r)
-    trans->panel_save(name, t, b, l, r);
-void R_panel_restore(const char *name)
-    trans->panel_restore(name);
-void R_panel_delete(const char *name)
-    trans->panel_delete(name);
-void R_begin_scaled_raster(int mask, int src[2][2], int dst[2][2])
-    trans->begin_scaled_raster(mask, src, dst);
-int R_scaled_raster(int n, int row,
-		    const unsigned char *red, const unsigned char *grn,
-		    const unsigned char *blu, const unsigned char *nul)
-    return trans->scaled_raster(n, row, red, grn, blu, nul);
-void R_end_scaled_raster(void)
-    trans->end_scaled_raster();
-void R_bitmap(int ncols, int nrows, int threshold, const unsigned char *buf)
-    trans->bitmap(ncols, nrows, threshold, buf);
Deleted: grass/trunk/lib/raster/common.c
--- grass/trunk/lib/raster/common.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/common.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,67 +0,0 @@
- * \brief flush graphics
- * Send all pending graphics commands to the graphics driver.
- * This is done automatically when graphics input requests are made.
- * Generally this is only needed for interactive graphics.
- *  \param void
- *  \return int
-void R_flush(void)
-    R_stabilize();
-void R_pad_perror(const char *msg, int code)
-    const char *err;
-    switch (code) {
-    case OK:
-	err = "";
-	break;
-    case NO_CUR_PAD:
-	err = "no current pad";
-	break;
-    case NO_PAD:
-	err = "pad not found";
-	break;
-    case NO_MEMORY:
-	err = "out of memory";
-	break;
-    case NO_ITEM:
-	err = "item not found";
-	break;
-    case ILLEGAL:
-	err = "illegal request";
-	break;
-    case DUPLICATE:
-	err = "duplicate name";
-	break;
-    default:
-	err = "unknown error";
-	break;
-    fprintf(stderr, "%s%s%s\n", msg, *msg ? " : " : "", err);
-void R_pad_freelist(char **list, int count)
-    int i;
-    if (count <= 0)
-	return;
-    for (i = 0; i < count; i++)
-	G_free(list[i]);
-    G_free(list);
Deleted: grass/trunk/lib/raster/io_sock.c
--- grass/trunk/lib/raster/io_sock.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/io_sock.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,128 +0,0 @@
-#include <grass/config.h>
-#ifdef HAVE_SOCKET
-#include <stdio.h>
-#include <signal.h>
-#include <errno.h>
-#ifdef __MINGW32__
-#include <winsock2.h>
-#define ECONNREFUSED WSAECONNREFUSED
-#define EADDRINUSE   WSAEADDRINUSE
-#define ENOTSOCK     WSAENOTSOCK
-#define ETIMEDOUT    WSAETIMEDOUT
-#endif
-#include <grass/glocale.h>
-#include "open.h"
-extern int _rfd, _wfd;
-extern int _quiet;
-extern int sync_driver(char *);
-static char *sockpath;
- * \brief initialize graphics
- * Initializes connection to
- * current graphics driver. Refer to GRASS User's Manual entries on the
- * <i>d.mon</i> command. If connection cannot be made, the application module
- * sends a message to the user stating that a driver has not been selected or
- * could not be opened. Note that only one application module can be connected to
- * a graphics driver at once.
- * After all graphics have been completed, the driver should be closed.
- *  \param void
- *  \return int
-int REM_open_driver(void)
-    int verbose;
-    char *name;
-    verbose = !_quiet;
-    _quiet = 0;
-    name = getenv("MONITOR_OVERRIDE");
-    if (!name)
-	name = G__getenv("MONITOR");
-    if (!name) {
-	if (verbose) {
-	    G_warning(_("No graphics monitor has been selected for output."));
-	    G_warning(_
-		      ("Please run \"d.mon\" to select a graphics monitor."));
-	return (NO_MON);
-    /* Get the full path to the unix socket */
-    if ((sockpath = G_sock_get_fname(name)) == NULL) {
-	if (verbose)
-	    G_warning(_("Failed to get socket name for monitor <%s>."), name);
-	return (NO_MON);
-    /* See if the socket exists, if it doesn't no point in trying to
-     * connect to it.
-    if (!G_sock_exists(sockpath)) {
-	if (verbose)
-	    G_warning(_("No socket to connect to for monitor <%s>."), name);
-	return (NO_MON);
-    /** We try to make a connection now **/
-    _wfd = G_sock_connect(sockpath);
-    if (_wfd > 0) {		/* success */
-	_rfd = dup(_wfd);
-	sync_driver(name);
-	return (OK);
-    switch (errno) {
-    case ECONNREFUSED:
-    case EADDRINUSE:
-	if (verbose) {
-	    G_warning(_
-		      ("Socket is already in use or not accepting connections."));
-	    G_warning(_("Use d.mon to select a monitor"));
-	return (NO_RUN);
-    case EBADF:
-    case ENOTSOCK:
-	if (verbose) {
-	    G_warning(_("Trying to connect to something not a socket."));
-	    G_warning(_("Probably program error."));
-	return (NO_RUN);
-    case ETIMEDOUT:
-	if (verbose) {
-	    G_warning(_("Connect attempt timed out."));
-	    G_warning(_("Probably an error with the server."));
-	return (NO_RUN);
-    default:
-	break;
-    if (verbose)
-	G_warning(_("Connection failed."));
-    /* We couldn't connect... */
-    return (NO_RUN);
-#endif /* HAVE_SOCKET */
Deleted: grass/trunk/lib/raster/loc_get.c
--- grass/trunk/lib/raster/loc_get.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/loc_get.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,18 +0,0 @@
-void LOC_get_location_with_box(int cx, int cy, int *wx, int *wy, int *button)
-void LOC_get_location_with_line(int cx, int cy, int *wx, int *wy, int *button)
-void LOC_get_location_with_pointer(int *wx, int *wy, int *button)
Deleted: grass/trunk/lib/raster/loc_io.c
--- grass/trunk/lib/raster/loc_io.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/loc_io.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,96 +0,0 @@
-#include <errno.h>
-#include <stdio.h>
-#include "open.h"
-#include "pad.h"
-extern const struct driver *PNG_Driver(void);
-extern const struct driver *PS_Driver(void);
-static void LOC_init(void)
-    const char *name = "full_screen";
-    const char *fenc = getenv("GRASS_ENCODING");
-    const char *font = getenv("GRASS_FONT");
-    int t = R_screen_top();
-    int b = R_screen_bot();
-    int l = R_screen_left();
-    int r = R_screen_rite();
-    char buff[256];
-    R_font(font ? font : "romans");
-    if (fenc)
-	R_charset(fenc);
-    R_pad_select("");
-    R_pad_set_item("time", "1");
-    R_pad_set_item("cur_w", name);
-    R_pad_create(name);
-    R_pad_select(name);
-    sprintf(buff, "%d %d %d %d", t, b, l, r);
-    R_pad_set_item("d_win", buff);
-    R_set_window(t, b, l, r);
-int LOC_open_driver(void)
-    const struct driver *drv = (p && G_strcasecmp(p, "PS") == 0)
-	? PS_Driver()
-	: PNG_Driver();
-    LIB_init(drv, 0, NULL);
-    LOC_init();
-    COM_Client_Open();
-    return OK;
-int LOC__open_quiet(void)
-    return 0;
-void LOC_stabilize(void)
-    COM_Respond();
-void LOC_kill_driver(void)
-    COM_Graph_close();
-void LOC_close_driver(void)
-    LOC_stabilize();
-    COM_Client_Close();
-    LOC_kill_driver();
-void LOC_release_driver(void)
-    LOC_stabilize();
Deleted: grass/trunk/lib/raster/loc_pad.c
--- grass/trunk/lib/raster/loc_pad.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/loc_pad.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,178 +0,0 @@
-#include <stdio.h>
-#include "pad.h"
-/* PAD FUNCTIONS
-   The monitor has a very simple database management capabil­
-   ity  which supports the windowing.  There are scratch pads
-static PAD *curpad;		/* current selected pad */
-int LOC_pad_create(const char *pad)
-    if (*pad == 0)		/* this is scratch pad */
-	return OK;
-    else if (find_pad(pad) != NULL)
-	return DUPLICATE;	/* duplicate pad */
-    else if (create_pad(pad))
-	return OK;
-    else
-	return NO_MEMORY;
-int LOC_pad_current(char *name)
-    if (curpad == NULL) {
-	*name = '\0';
-	return NO_CUR_PAD;
-    else {
-	strcpy(name, curpad->name);
-	return OK;
-int LOC_pad_delete(void)
-    else if (*curpad->name == 0)
-	return ILLEGAL;
-    else {
-	delete_pad(curpad);
-	curpad = NULL;
-	return OK;
-int LOC_pad_invent(char *pad)
-    invent_pad(pad);
-    return 0;
-int LOC_pad_list(char ***list, int *count)
-    PAD *p;
-    char **l;
-    int n;
-    for (p = pad_list(), n = 0; p; p = p->next)
-	if (*p->name)
-	    n++;
-    *count = n;
-    *list = l = G_malloc(n * sizeof(char *));
-    for (p = pad_list(); p; p = p->next)
-	if (*p->name)
-	    *l++ = G_store(p->name);
-    return 0;
-int LOC_pad_select(const char *pad)
-    curpad = find_pad(pad);
-	return NO_PAD;
-    return OK;
-int LOC_pad_append_item(const char *item, const char *value, int replace)
-    if (append_item(curpad, item, value, replace))
-	return OK;
-    return NO_MEMORY;
-int LOC_pad_delete_item(const char *name)
-    delete_item(curpad, name);
-    return OK;
-int LOC_pad_get_item(const char *name, char ***list, int *count)
-    ITEM *item;
-    LIST *p;
-    char **l;
-    int n;
-    item = find_item(curpad, name);
-    if (item == NULL)
-	return NO_ITEM;
-    for (p = item->list, n = 0; p; p = p->next)
-	if (*p->value)
-	    n++;
-    *count = n;
-	if (*p->value)
-	    *l++ = G_store(p->value);
-    return OK;
-int LOC_pad_list_items(char ***list, int *count)
-    ITEM *p;
-    char **l;
-    int n;
-    for (p = curpad->items, n = 0; p; p = p->next)
-	if (*p->name)
-	    n++;
-    *count = n;
-	if (*p->name)
-    return OK;
-int LOC_pad_set_item(const char *name, const char *value)
-    if (append_item(curpad, name, value, 0))
-	return OK;
-    return NO_MEMORY;
Deleted: grass/trunk/lib/raster/loc_proto.c
--- grass/trunk/lib/raster/loc_proto.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/loc_proto.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,558 +0,0 @@
-#include <stdio.h>
-#include <fcntl.h>
- *  \param void
- *  \return int
-int LOC_screen_left(void)
-    int l;
-    COM_Screen_left(&l);
-    return l;
- *  \param void
- *  \return int
-int LOC_screen_rite(void)
-    int r;
-    COM_Screen_rite(&r);
-    return r;
- *  \param void
- *  \return int
-int LOC_screen_bot(void)
-    int b;
-    COM_Screen_bot(&b);
-    return b;
- *  \param void
- *  \return int
-int LOC_screen_top(void)
-    int t;
-    COM_Screen_top(&t);
-    return t;
-void LOC_get_num_colors(int *n)
-    COM_Number_of_colors(n);
- * Selects the
- *  \param index
- *  \return int
-void LOC_standard_color(int index)
-    COM_Standard_color(index);
- * When in
- *  \param red
- *  \param grn
- *  \param blue
- *  \return int
-void LOC_RGB_color(unsigned char red, unsigned char grn, unsigned char blu)
-    COM_Color_RGB(red, grn, blu);
- *  \param width
- *  \return int
-void LOC_line_width(int width)
-    COM_Line_width(width);
- *  \param void
- *  \return int
-void LOC_erase(void)
-    COM_Erase();
- *  \param x
- *  \param y
- *  \return int
-void LOC_move_abs(int x, int y)
-    COM_Move_abs(x, y);
- \code
- Newx = Oldx + dx;
- Newy = Oldy + dy;
- \endcode
- *  \param x dx
- *  \param y dy
- *  \return int
-void LOC_move_rel(int x, int y)
-    COM_Move_rel(x, y);
- *  \param x
- *  \param y
- *  \return int
-void LOC_cont_abs(int x, int y)
-    COM_Cont_abs(x, y);
- \code
- Newx = Oldx + x;
- Newy = Oldy + y;
- \endcode
- *  \param x
- *  \param y
- *  \return int
-void LOC_cont_rel(int x, int y)
-    COM_Cont_rel(x, y);
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void LOC_polydots_abs(const int *xarray, const int *yarray, int number)
-    COM_Polydots_abs(xarray, yarray, number);
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void LOC_polydots_rel(const int *xarray, const int *yarray, int number)
-    COM_Polydots_rel(xarray, yarray, number);
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void LOC_polyline_abs(const int *xarray, const int *yarray, int number)
-    COM_Polyline_abs(xarray, yarray, number);
- * color.
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void LOC_polyline_rel(const int *xarray, const int *yarray, int number)
-    COM_Polyline_rel(xarray, yarray, number);
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void LOC_polygon_abs(const int *xarray, const int *yarray, int number)
-    COM_Polygon_abs(xarray, yarray, number);
- *  \param xarray x
- *  \param yarray y
- *  \param number
- *  \return int
-void LOC_polygon_rel(const int *xarray, const int *yarray, int number)
-    COM_Polygon_rel(xarray, yarray, number);
- * afterwards
- *  \param x1
- *  \param y1
- *  \param x2
- *  \param y2
- *  \return int
-void LOC_box_abs(int x1, int y1, int x2, int y2)
-    COM_Box_abs(x1, y1, x2, y2);
- *  \param x
- *  \param y
- *  \return int
-void LOC_box_rel(int x, int y)
-    COM_Box_rel(x, y);
- *  \param width
- *  \param height
- *  \return int
-void LOC_text_size(int width, int height)
-    COM_Text_size(width, height);
-void LOC_text_rotation(float rotation)
-    COM_Text_rotation(rotation);
- *  \param t top
- *  \param b bottom
- *  \param l left
- *  \param r right
- *  \return int
-void LOC_set_window(int t, int b, int l, int r)
-    COM_Set_window(t, b, l, r);
- *  \param sometext
- *  \return int
-void LOC_text(const char *text)
-    COM_Text(text);
- * or border.
- *  \param sometext
- *  \param t top
- *  \param b bottom
- *  \param l left
- *  \param r right
- *  \return int
-void LOC_get_text_box(const char *text, int *t, int *b, int *l, int *r)
-    COM_Get_text_box(text, t, b, l, r);
- <table>
- </table>
- *  \param name
- *  \return int
-void LOC_font(const char *name)
-    COM_Font_get(name);
-void LOC_charset(const char *name)
-    COM_Font_init_charset(name);
-void LOC_font_list(char ***list, int *count)
-    COM_Font_list(list, count);
-void LOC_font_info(char ***list, int *count)
-    COM_Font_info(list, count);
-void LOC_panel_save(const char *name, int t, int b, int l, int r)
-    close(creat(name, 0666));
-    COM_Panel_save(name, t, b, l, r);
-    R_stabilize();
-void LOC_panel_restore(const char *name)
-    COM_Panel_restore(name);
-    R_stabilize();
-void LOC_panel_delete(const char *name)
-    COM_Panel_delete(name);
-    R_stabilize();
-    remove(name);
-void LOC_begin_scaled_raster(int mask, int src[2][2], int dst[2][2])
-    COM_begin_scaled_raster(mask, src, dst);
-int LOC_scaled_raster(int n, int row,
-    return COM_scaled_raster(n, row, red, grn, blu, nul);
-void LOC_end_scaled_raster(void)
-    COM_end_scaled_raster();
-void LOC_bitmap(int ncols, int nrows, int threshold, const unsigned char *buf)
-    COM_Bitmap(ncols, nrows, threshold, buf);
Deleted: grass/trunk/lib/raster/open.h
--- grass/trunk/lib/raster/open.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/open.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,15 +0,0 @@
-/* quiet mode returns:   0 - open OK */
-/*                      -1 - driver locked */
-/*                      -2 - driver not running */
-/*                      -3 - can't open fifos */
-/*                      -4 - no such monitor */
-/*                      -5 - GIS_LOCK undefined in shell environment */
-/*                      -6 - couldn't read, write or create lock file */
-#define OK       0
-#define LOCKED  -1
-#define NO_RUN  -2
-#define NO_OPEN -3
-#define NO_MON  -4
-#define NO_KEY  -5
-#define LOCK_FAILED -6
Deleted: grass/trunk/lib/raster/parse_mon.c
--- grass/trunk/lib/raster/parse_mon.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/parse_mon.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,166 +0,0 @@
-/* parse_mon - parse monitorcap entry */
-#include <stdio.h>
-#include <grass/monitors.h>
-static FILE *monitors = NULL;
-static struct MON_CAP cap;
-static char *substr(char *, char *);
-static int read_line(FILE *, char *, int);
-struct MON_CAP *R_parse_monitorcap(int field, char *key)
-    int rewound;
-    char line[1024];
-    char *p;
-    char file[500];
-    char *gisbase;
-    gisbase = G_gisbase();
-    rewound = 0;
-    if (!(field == MON_NEXT || field == MON_NAME ||
-	  field == MON_PATH || field == MON_LINK || field == MON_CLOSE))
-	return (NULL);
-    if (monitors == NULL) {
-	sprintf(file, "%s/etc/monitorcap", gisbase);
-	if ((monitors = fopen(file, "r")) == NULL)
-	    G_fatal_error("Unable to open %s", file);
-    else {
-	if (field == MON_CLOSE) {
-	    fclose(monitors);
-	    monitors = NULL;
-	    return (NULL);
-    while (-1) {
-	if (read_line(monitors, line, sizeof line)) {
-	    if (field == MON_NEXT)
-		return (NULL);
-	    rewind(monitors);
-	    if (read_line(monitors, line, sizeof line) || rewound)
-		return (NULL);
-	    rewound = -1;
-	cap.path = cap.comment = cap.link = cap.tty = cap.where = NULL;
-	if ((cap.name = G_malloc(strlen(line) + 1)) == NULL)
-	    return (NULL);
-	strcpy(cap.name, line);
-	if ((p = substr(":", cap.name)) != NULL) {
-	    *p++ = '\0';
-	    cap.path = p;
-	    if ((p = substr(":", p)) != NULL) {
-		*p++ = '\0';
-		cap.comment = p;
-		    *p++ = '\0';
-		    cap.link = p;
-			*p++ = '\0';
-			cap.tty = p;
-			    *p++ = 0;
-			    cap.where = p;
-			    if ((p = substr("\n", p)) != NULL)
-				*p = '\0';
-	if (cap.path == NULL || cap.link == NULL || cap.where == NULL ||
-	    cap.tty == NULL || cap.comment == NULL)
-	    G_free(cap.name);
-	else {
-	    sprintf(line, "%s/%s", gisbase, cap.path);
-	    cap.path = G_store(line);
-	    if (field == MON_NEXT ||
-		(field == MON_NAME && !strcmp(key, cap.name))
-		|| (field == MON_PATH && !strcmp(key, cap.path))
-		|| (field == MON_LINK && !strcmp(key, cap.link)))
-		return (&cap);
-	    else
-		G_free(cap.name);
-/* read_line - read a line, possibly continued with a "\" into a buffer */
-static int read_line(FILE * file,	/* file from which to read */
-		     char *line,	/* buffer in which to put it */
-		     int size)
-{				/* size of buffer */
-    int length, full_line, eof, done;
-    char c, last_c;
-    *line = '\0';
-    for (length = full_line = eof = 0; !full_line && !eof;) {	/*   one entire line at a time */
-	while (1) {
-	    eof = (fgets(line + length, size - length - 1, file) == NULL);
-	    if (eof)
-		break;
-	    if (*(line + length) != '#')
-		break;
-	length = strlen(line) - 1;
-	if (*(line + length) == '\n') {
-	    if (*(line + length - 1) == '\\')
-		--length;
-	    else
-		full_line = -1;
-	else {
-	    if (length != -1) {
-		fprintf(stderr, "error:  input line too long\n");
-		full_line = -1;
-		last_c = c = ' ';
-		for (done = 0; !done;) {
-		    if ((c = getc(file)) != EOF) {
-			if (c == '\n' && last_c != '\\')
-			    done = -1;
-			else
-			    last_c = c;
-		    else
-			eof = done = -1;
-    return (eof);
-/* substr - find substring in a string.  returns pointer to start of */
-/* substring or NULL if not found */
-static char *substr(char *string, char *buffer)
-    int start, i, found;
-    char c;
-    start = i = found = 0;
-    while ((c = *(buffer + start + i)) != '\0' && !found) {
-	if (c == *(string + i)) {
-	    if (*(string + ++i) == '\0')
-		found = -1;
-	else {
-	    start++;
-	    i = 0;
-    if (found)
-	return (buffer + start);
-    else
-	return (NULL);
Added: grass/trunk/lib/raster/raster.c
--- grass/trunk/lib/raster/raster.c	                        (rev 0)
+++ grass/trunk/lib/raster/raster.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -0,0 +1,573 @@
+#include <grass/config.h>
+#include <errno.h>
+#include <signal.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+#include "driver.h"
+extern const struct driver *PNG_Driver(void);
+extern const struct driver *PS_Driver(void);
+static void init(void)
+    const char *fenc = getenv("GRASS_ENCODING");
+    const char *font = getenv("GRASS_FONT");
+    int t = R_screen_top();
+    int b = R_screen_bot();
+    int l = R_screen_left();
+    int r = R_screen_rite();
+    R_font(font ? font : "romans");
+    if (fenc)
+	R_charset(fenc);
+    R_set_window(t, b, l, r);
+int R_open_driver(void)
+    const char *p = getenv("GRASS_RENDER_IMMEDIATE");
+    const struct driver *drv =
+	(p && G_strcasecmp(p, "PS") == 0) ? PS_Driver() :
+	(p && G_strcasecmp(p, "HTML") == 0) ? HTML_Driver() :
+	PNG_Driver();
+    LIB_init(drv, 0, NULL);
+    init();
+    COM_Client_Open();
+    return 0;
+void R__open_quiet(void)
+void R_stabilize(void)
+    COM_Respond();
+void R_close_driver(void)
+    R_stabilize();
+    COM_Client_Close();
+void R_flush(void)
+    R_stabilize();
+ * \brief screen left edge
+ * Returns the coordinate of the left edge of the screen.
+ *  \param void
+ *  \return int
+int R_screen_left(void)
+    int l;
+    COM_Screen_left(&l);
+    return l;
+ * \brief screen right edge
+ * Returns the coordinate of the right edge of the screen.
+ *  \param void
+ *  \return int
+int R_screen_rite(void)
+    int r;
+    COM_Screen_rite(&r);
+    return r;
+ * \brief bottom of screen
+ * Returns the coordinate of the bottom of the screen.
+ *  \param void
+ *  \return int
+int R_screen_bot(void)
+    int b;
+    COM_Screen_bot(&b);
+    return b;
+ * \brief top of screen
+ * Returns the coordinate of the top of the screen.
+ *  \param void
+ *  \return int
+int R_screen_top(void)
+    int t;
+    COM_Screen_top(&t);
+    return t;
+void R_get_num_colors(int *n)
+    COM_Number_of_colors(n);
+ * \brief select standard color
+ * Selects the
+ * standard <b>color</b> to be used in subsequent draw commands.  The
+ * <b>color</b> value is best retrieved using <i>D_translate_color.</i>
+ * See Display_Graphics_Library.
+ *  \param index
+ *  \return int
+void R_standard_color(int index)
+    COM_Standard_color(index);
+ * \brief select color
+ * When in
+ * float mode (see <i>R_color_table_float</i>), this call selects the color
+ * most closely matched to the <b>red, grn</b>, and <b>blue</b> intensities
+ * requested. These values must be in the range of 0-255.
+ *  \param red
+ *  \param grn
+ *  \param blue
+ *  \return int
+void R_RGB_color(unsigned char red, unsigned char grn, unsigned char blu)
+    COM_Color_RGB(red, grn, blu);
+ * \brief change the width of line
+ * Changes the <b>width</b> of line to be used in subsequent draw commands.
+ *  \param width
+ *  \return int
+void R_line_width(int width)
+    COM_Line_width(width);
+ * \brief erase screen
+ * Erases the entire screen to black.
+ *  \param void
+ *  \return int
+void R_erase(void)
+    COM_Erase();
+ * \brief move current location
+ * Move the current location to the absolute screen coordinate <b>x,y.</b>
+ * Nothing is drawn on the screen.
+ *  \param x
+ *  \param y
+ *  \return int
+void R_move_abs(int x, int y)
+    COM_Move_abs(x, y);
+ * Shift the current screen location by the values in <b>dx</b> and <b>dy</b>:
+ \code
+ Newx = Oldx + dx;
+ Newy = Oldy + dy;
+ \endcode
+ *  \param x dx
+ *  \param y dy
+ *  \return int
+void R_move_rel(int x, int y)
+    COM_Move_rel(x, y);
+ * \brief draw line
+ * Draw a line using the current color, selected via <i>R_color</i>, from the
+ * current location to the location specified by <b>x,y.</b> The current location
+ * is updated to <b>x,y.</b>
+ *  \param x
+ *  \param y
+ *  \return int
+void R_cont_abs(int x, int y)
+    COM_Cont_abs(x, y);
+ * current color, selected via <i>R_color</i>, from the current location to
+ * the relative location specified by <b>x</b> and <b>y.</b> The current
+ * location is updated:
+ \code
+ Newx = Oldx + x;
+ Newy = Oldy + y;
+ \endcode
+ *  \param x
+ *  \param y
+ *  \return int
+void R_cont_rel(int x, int y)
+    COM_Cont_rel(x, y);
+ * \brief draw a series of dots
+ * Pixels at the <b>num</b> absolute positions in the <b>x</b> and
+ * <b>y</b> arrays are turned to the current color. The current location is
+ * left updated to the position of the last dot.
+ *  \param xarray x
+ *  \param yarray y
+ *  \param number
+ *  \return int
+void R_polydots_abs(const int *xarray, const int *yarray, int number)
+    COM_Polydots_abs(xarray, yarray, number);
+ * Pixels at the <b>number</b> relative positions in the <b>x</b> and
+ * <b>y</b> arrays are turned to the current color. The first position is
+ * relative to the starting current location; the succeeding positions are then
+ * relative to the previous position. The current location is updated to the
+ * position of the last dot.
+ *  \param xarray x
+ *  \param yarray y
+ *  \param number
+ *  \return int
+void R_polydots_rel(const int *xarray, const int *yarray, int number)
+    COM_Polydots_rel(xarray, yarray, number);
+ * \brief draw an open polygon
+ * The <b>number</b> absolute positions in the <b>x</b> and <b>y</b>
+ * arrays are used to generate a multisegment line (often curved). This line is
+ * drawn with the current color. The current location is left updated to the
+ * position of the last point.
+ * <b>Note.</b> It is not assumed that the line is closed, i.e., no line is
+ * drawn from the last point to the first point.
+ *  \param xarray x
+ *  \param yarray y
+ *  \param number
+ *  \return int
+void R_polyline_abs(const int *xarray, const int *yarray, int number)
+    COM_Polyline_abs(xarray, yarray, number);
+ * The <b>number</b> relative positions in the <b>x</b> and <b>y</b>
+ * arrays are used to generate a multisegment line (often curved). The first
+ * position is relative to the starting current location; the succeeding
+ * positions are then relative to the previous position. The current location is
+ * updated to the position of the last point. This line is drawn with the current
+ * color.
+ * <b>Note.</b> No line is drawn between the last point and the first point.
+ *  \param xarray x
+ *  \param yarray y
+ *  \param number
+ *  \return int
+void R_polyline_rel(const int *xarray, const int *yarray, int number)
+    COM_Polyline_rel(xarray, yarray, number);
+ * \brief draw a closed polygon
+ * The <b>number</b> absolute positions in the <b>x</b> and <b>y</b> arrays
+ * outline a closed polygon which is filled with the current color. The current
+ * location is undefined afterwards.
+ *  \param xarray x
+ *  \param yarray y
+ *  \param number
+ *  \return int
+void R_polygon_abs(const int *xarray, const int *yarray, int number)
+    COM_Polygon_abs(xarray, yarray, number);
+ * arrays outline a closed polygon which is filled with the current color. The
+ * first position is relative to the starting current location; the succeeding
+ * undefined afterwards.
+ *  \param xarray x
+ *  \param yarray y
+ *  \param number
+ *  \return int
+void R_polygon_rel(const int *xarray, const int *yarray, int number)
+    COM_Polygon_rel(xarray, yarray, number);
+ * \brief fill a box
+ * A box is drawn in the current color using the coordinates <b>x1,y1</b> and
+ * <b>x2,y2</b> as opposite corners of the box. The current location is undefined
+ * afterwards
+ *  \param x1
+ *  \param y1
+ *  \param x2
+ *  \param y2
+ *  \return int
+void R_box_abs(int x1, int y1, int x2, int y2)
+    COM_Box_abs(x1, y1, x2, y2);
+ * A box is drawn in the current color using the current location as one corner
+ * and the current location plus <b>x</b> and <b>y</b> as the opposite corner
+ * of the box. The current location is undefined afterwards.
+ *  \param x
+ *  \param y
+ *  \return int
+void R_box_rel(int x, int y)
+    COM_Box_rel(x, y);
+ * \brief set text size
+ * Sets text pixel width and height to <b>width</b> and <b>height.</b>
+ *  \param width
+ *  \param height
+ *  \return int
+void R_text_size(int width, int height)
+    COM_Text_size(width, height);
+void R_text_rotation(float rotation)
+    COM_Text_rotation(rotation);
+ * \brief set text clipping frame
+ * Subsequent calls to <i>R_text</i> will have text strings
+ * clipped to the screen frame defined by <b>top, bottom, left, right.</b>
+ *  \param t top
+ *  \param b bottom
+ *  \param l left
+ *  \param r right
+ *  \return int
+void R_set_window(int t, int b, int l, int r)
+    COM_Set_window(t, b, l, r);
+ * \brief write text
+ * Writes <b>text</b> in the current color and font, at the current text
+ * width and height, starting at the current screen location.
+ *  \param sometext
+ *  \return int
+void R_text(const char *text)
+    COM_Text(text);
+ * \brief get text extents
+ * The extent of the area enclosing the <b>text</b>
+ * is returned in the integer pointers <b>top, bottom, left</b>, and
+ * <b>right.</b> No text is actually drawn. This is useful for capturing the
+ * text extent so that the text location can be prepared with proper background
+ * or border.
+ *  \param sometext
+ *  \param t top
+ *  \param b bottom
+ *  \param l left
+ *  \param r right
+ *  \return int
+void R_get_text_box(const char *text, int *t, int *b, int *l, int *r)
+    COM_Get_text_box(text, t, b, l, r);
+ * \brief choose font
+ * Set current font to <b>font name</b>.
+ *  \param name
+ *  \return int
+void R_font(const char *name)
+    COM_Font_get(name);
+void R_charset(const char *name)
+    COM_Font_init_charset(name);
+void R_font_list(char ***list, int *count)
+    COM_Font_list(list, count);
+void R_font_info(char ***list, int *count)
+    COM_Font_info(list, count);
+void R_begin_scaled_raster(int mask, int src[2][2], int dst[2][2])
+    COM_begin_scaled_raster(mask, src, dst);
+int R_scaled_raster(int n, int row,
+		      const unsigned char *red, const unsigned char *grn,
+		      const unsigned char *blu, const unsigned char *nul)
+    return COM_scaled_raster(n, row, red, grn, blu, nul);
+void R_end_scaled_raster(void)
+    COM_end_scaled_raster();
+void R_bitmap(int ncols, int nrows, int threshold, const unsigned char *buf)
+    COM_Bitmap(ncols, nrows, threshold, buf);
Deleted: grass/trunk/lib/raster/rem_get.c
--- grass/trunk/lib/raster/rem_get.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/rem_get.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,98 +0,0 @@
-#ifdef HAVE_SOCKET
- * \brief get mouse location using a box
- * Identical to <i>R_get_location_with_line</i> except a rubber-band box is
- * used instead of a rubber-band line.
- * <b>button</b> is set to: 1 - left, 2 - middle, 3 - right
- *  \param cx
- *  \param cy
- *  \param wx
- *  \param wy
- *  \param button
- *  \return ~
-void REM_get_location_with_box(int cx, int cy, int *wx, int *wy, int *button)
-    _send_ident(GET_LOCATION_WITH_BOX);
-    _send_int(&cx);
-    _send_int(&cy);
-    _send_int(wx);
-    _send_int(wy);
-    _get_int(wx);
-    _get_int(wy);
-    _get_int(button);
- * \brief get mouse location using a line
- * Similar to <i>R_get_location_with_pointer</i> except the pointer is
- * replaced by a line which has one end fixed at the coordinate identified
- * by the <b>x,y</b> values. The other end of the line is initialized at the
- * coordinate identified by the <b>nx,ny</b> pointers. This end then tracks
- * the mouse until a button is pressed. The mouse button (1 for left, 2 for
- * middle, and 3 for right) is returned in the <b>button</b> pointer.
- *  \param cx
- *  \param cy
- *  \param wx
- *  \param wy
- *  \param button
- *  \return ~
-void REM_get_location_with_line(int cx, int cy, int *wx, int *wy, int *button)
-    _send_ident(GET_LOCATION_WITH_LINE);
-    _send_int(&cx);
-    _send_int(&cy);
-    _send_int(wx);
-    _send_int(wy);
-    _get_int(wx);
-    _get_int(wy);
-    _get_int(button);
- * \brief get mouse location using pointer
- * A cursor is put on the screen at the location specified by the coordinate
- * found at the <b>wx,wy</b> pointers. This cursor tracks the mouse (or
- * other pointing device) until one of three mouse buttons are pressed. Upon
- * pressing, the cursor is removed from the screen, the current mouse
- * coordinates are returned by the <b>wx</b> and <b>wy</b> pointers, and the
- * mouse button (1 for left, 2 for middle, and 3 for right) is returned in
- * the <b>button</b> pointer.
- *  \param wx
- *  \param wy
- *  \param button
- *  \return ~
-void REM_get_location_with_pointer(int *wx, int *wy, int *button)
-    *button = 0;		/* ?, how button = -1 is used (see driver) */
-    _send_ident(GET_LOCATION_WITH_POINTER);
-    _send_int(wx);
-    _send_int(wy);
-    _send_int(button);
-    _get_int(wx);
-    _get_int(wy);
-    _get_int(button);
Deleted: grass/trunk/lib/raster/rem_io.c
--- grass/trunk/lib/raster/rem_io.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/rem_io.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,335 +0,0 @@
-#ifdef HAVE_SOCKET
-#include <stdio.h>
-#include <errno.h>
-#include "open.h"
-#define BUFFERSIZ   2048
-int _rfd, _wfd;
-int _quiet;
-extern int unlock_driver(int);
-int sync_driver(char *);
-static unsigned char outbuf[BUFFERSIZ];
-static int cursiz;
-static volatile int no_mon;
-static RETSIGTYPE dead(int);
-static int _get(char *buf, int n)
-    int x;
-    while (n > 0) {
-	x = read(_rfd, buf, n);
-	if (x <= 0) {
-	    fprintf(stderr, _("ERROR %s from graphics driver.\n"),
-		    x ? "reading" : "eof");
-	    exit(1);
-	n -= x;
-	buf += x;
-    return 0;
-static int flushout(void)
-    if (cursiz) {
-	write(_wfd, outbuf, (size_t) cursiz);
-	cursiz = 0;
-    return 0;
-int _send_ident(int anint)
-    unsigned char achar;
-    achar = anint;
-    if ((cursiz + 2) >= BUFFERSIZ)
-	flushout();
-    outbuf[cursiz++] = COMMAND_ESC;
-    outbuf[cursiz++] = achar;
-    return 0;
-int _send_char(const unsigned char *achar)
-	flushout();
-    outbuf[cursiz++] = *achar;
-    if (*achar == COMMAND_ESC)
-	outbuf[cursiz++] = 0;
-    return 0;
-int _send_char_array(int num, const unsigned char *achar)
-    while (num-- > 0)
-	_send_char(achar++);
-    return 0;
-int _send_int_array(int num, const int *anint)
-    return _send_char_array(num * sizeof(int), (const unsigned char *)anint);
-int _send_float_array(int num, const float *afloat)
-    return _send_char_array(num * sizeof(float),
-			    (const unsigned char *)afloat);
-int _send_int(const int *anint)
-    return _send_char_array(sizeof(int), (const unsigned char *)anint);
-int _send_float(const float *afloat)
-    return _send_char_array(sizeof(float), (const unsigned char *)afloat);
-int _send_text(const char *text)
-    return _send_char_array(1 + strlen(text), (const unsigned char *)text);
-int _get_char(char *achar)
-    flushout();
-    _get(achar, 1);
-    return 0;
-int _get_int(int *anint)
-    flushout();
-    _get((char *)anint, sizeof(int));
-    return 0;
-int _get_float(float *afloat)
-    flushout();
-    _get((char *)afloat, sizeof(float));
-    return 0;
-int _get_text(char *buf)
-    char *b;
-    b = buf;
-    do
-	_get_char(b);
-    while (*b++ != 0);
-    return 0;
-char *_get_text_2(void)
-    static char *buf;
-    static int len;
-    int i;
-    for (i = 0;; i++) {
-	if (i >= len) {
-	    len += 1000;
-	    buf = G_realloc(buf, len);
-	    if (!buf) {
-		fprintf(stderr, _("Unable to allocate memory\n"));
-		exit(1);
-	_get_char(&buf[i]);
-	if (!buf[i])
-	    break;
-    return buf;
-int REM__open_quiet(void)
-    _quiet = 1;
-    return 0;
-int sync_driver(char *name)
-#ifndef __MINGW32__
-    RETSIGTYPE(*sigalarm) (int);
-#endif
-    int try;
-    int count;
-    unsigned char c;
-    _send_ident(BEGIN);
-    flushout();
-     * look for at least BEGIN_SYNC_COUNT zero bytes
-     * then look for COMMAND_ESC
-     * try twice. first timeout is warning, second is fatal
-    count = 0;
-    sigalarm = signal(SIGALRM, dead);
-#endif
-    for (try = 0; try < 2; try++) {
-	no_mon = 0;
-	alarm(try ? 10 : 5);
-#endif
-	while (no_mon == 0) {
-	    if (read(_rfd, &c, (size_t) 1) != 1) {
-		if (no_mon)
-		    break;	/* from while */
-		fprintf(stderr, _("ERROR - eof from graphics monitor.\n"));
-		exit(-1);
-	    if (c == 0)
-		count++;
-	    else if (c == COMMAND_ESC && count >= BEGIN_SYNC_COUNT)
-		break;
-	    else
-		count = 0;	/* start over */
-	alarm(0);
-	signal(SIGALRM, sigalarm);
-#endif
-	if (no_mon == 0)
-	    return 1;		/* ok! */
-	if (try)
-	    break;
-	fprintf(stderr,
-		_("Warning - no response from graphics monitor <%s>.\n"),
-		name);
-	fprintf(stderr, _("Check to see if the mouse is still active.\n"));
-	signal(SIGALRM, dead);
-#endif
-    fprintf(stderr, _("ERROR - no response from graphics monitor <%s>.\n"),
-	    name);
-    exit(-1);
-static RETSIGTYPE dead(int sig)
-    no_mon = 1;
-void _hold_signals(int hold)
-    static RETSIGTYPE(*sigint) (int);
-#ifdef SIGQUIT
-    static RETSIGTYPE(*sigquit) (int);
-#endif
-    if (hold) {
-	sigint = signal(SIGINT, SIG_IGN);
-#ifdef SIGQUIT
-	sigquit = signal(SIGQUIT, SIG_IGN);
-#endif
-    else {
-	signal(SIGINT, sigint);
-#ifdef SIGQUIT
-	signal(SIGQUIT, sigquit);
-#endif
- * \brief synchronize graphics
- * Send all pending graphics commands to the graphics driver and cause
- * all pending graphics to be drawn (provided the driver is written to
- * comply). This function is called automatically when the graphics driver
- * closes (<i>R_close_driver()</i>). Otherwise it only needs to be used
- * within a module for flushing interactive graphics.
- *  \param void
- *  \return int
-void REM_stabilize(void)
-    char c;
-    flushout();
-    _send_ident(RESPOND);
-    _get_char(&c);
-void REM_kill_driver(void)
-    char dummy;
-    _send_ident(GRAPH_CLOSE);
-    flushout();
-    read(_rfd, &dummy, 1);
-    R_release_driver();
- * \brief terminate graphics
- * This routine breaks the connection with the graphics driver opened by R_open_driver().
- *  \param void
- *  \return int
-void REM_close_driver(void)
-    R_stabilize();
-    close(_rfd);
-    close(_wfd);
-    _wfd = _rfd = -1;
-void REM_release_driver(void)
-    close(_rfd);
-    close(_wfd);
-    _wfd = _rfd = -1;
Deleted: grass/trunk/lib/raster/rem_pad.c
--- grass/trunk/lib/raster/rem_pad.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/rem_pad.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,215 +0,0 @@
-#ifdef HAVE_SOCKET
-#include <stdio.h>
-/* PAD FUNCTIONS
-static void _get_list(char ***list, int *count)
-    char **a;
-    int n;
-    char *buf;
-    *list = NULL;
-    *count = 0;
-    buf = _get_text_2();
-    for (n = 0; *buf; n++) {
-	if (n == 0)
-	    a = G_malloc(sizeof(char *));
-	else
-	    a = G_realloc(a, (n + 1) * sizeof(char *));
-	a[n] = G_strdup(buf);
-    *list = a;
-    *count = n;
-int REM_pad_create(const char *pad)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_CREATE);
-    _send_text(pad);
-    _get_char(&result);
-    _hold_signals(0);
-    return result;
-int REM_pad_current(char *name)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_CURRENT);
-    _get_text(name);
-    _hold_signals(0);
-    return result;
-int REM_pad_delete(void)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_DELETE);
-    _hold_signals(0);
-    return result;
-int REM_pad_invent(char *pad)
-    _hold_signals(1);
-    _send_ident(PAD_INVENT);
-    _get_text(pad);
-    _hold_signals(0);
-    return 0;
-int REM_pad_list(char ***list, int *count)
-    _hold_signals(1);
-    _send_ident(PAD_LIST);
-    _get_list(list, count);
-    _hold_signals(0);
-    return 0;
-int REM_pad_select(const char *pad)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_SELECT);
-    _send_text(pad);
-    _hold_signals(0);
-    return result;
-int REM_pad_append_item(const char *item, const char *value, int replace)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_APPEND_ITEM);
-    _send_text(item);
-    _send_text(value);
-    _send_int(&replace);
-    _hold_signals(0);
-    return result;
-int REM_pad_delete_item(const char *name)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_DELETE_ITEM);
-    _send_text(name);
-    _hold_signals(0);
-    return result;
-int REM_pad_get_item(const char *item, char ***list, int *count)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_GET_ITEM);
-    _send_text(item);
-    if (result == OK)
-    _hold_signals(0);
-    return result;
-int REM_pad_list_items(char ***list, int *count)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_LIST_ITEMS);
-    if (result == OK)
-    _hold_signals(0);
-    return result;
-int REM_pad_set_item(const char *item, const char *value)
-    char result;
-    _hold_signals(1);
-    _send_ident(PAD_SET_ITEM);
-    _send_text(item);
-    _hold_signals(0);
-    return result;
Deleted: grass/trunk/lib/raster/rem_proto.c
--- grass/trunk/lib/raster/rem_proto.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/rem_proto.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,639 +0,0 @@
-#ifdef HAVE_SOCKET
-#include <stdio.h>
-#include <fcntl.h>
- *  \param void
- *  \return int
-int REM_screen_left(void)
-    int l;
-    _send_ident(SCREEN_LEFT);
-    _get_int(&l);
-    return l;
- *  \param void
- *  \return int
-int REM_screen_rite(void)
-    int r;
-    _send_ident(SCREEN_RITE);
-    _get_int(&r);
-    return r;
- *  \param void
- *  \return int
-int REM_screen_bot(void)
-    int b;
-    _send_ident(SCREEN_BOT);
-    _get_int(&b);
-    return b;
- *  \param void
- *  \return int
-int REM_screen_top(void)
-    int t;
-    _send_ident(SCREEN_TOP);
-    _get_int(&t);
-    return t;
-void REM_get_num_colors(int *n)
-    _send_ident(GET_NUM_COLORS);
-    _get_int(n);
- * Selects the
- *  \param index
-void REM_standard_color(int index)
-    _send_ident(STANDARD_COLOR);
-    _send_int(&index);
- * When in
- *  \param red
- *  \param grn
- *  \param blue
-void REM_RGB_color(unsigned char red, unsigned char grn, unsigned char blu)
-    _send_ident(RGB_COLOR);
-    _send_char(&red);
-    _send_char(&grn);
-    _send_char(&blu);
- *  \param width
-void REM_line_width(int width)
-    _send_ident(LINE_WIDTH);
-    _send_int(&width);
- *  \param void
-void REM_erase(void)
-    _send_ident(ERASE);
- *  \param x
- *  \param y
-void REM_move_abs(int x, int y)
-    _send_ident(MOVE_ABS);
-    _send_int(&x);
-    _send_int(&y);
- \code
- Newx = Oldx + dx;
- Newy = Oldy + dy;
- \endcode
- *  \param x dx
- *  \param y dy
-void REM_move_rel(int x, int y)
-    _send_ident(MOVE_REL);
-    _send_int(&x);
-    _send_int(&y);
- *  \param x
- *  \param y
-void REM_cont_abs(int x, int y)
-    _send_ident(CONT_ABS);
-    _send_int(&x);
-    _send_int(&y);
- \code
- Newx = Oldx + x;
- Newy = Oldy + y;
- \endcode
- *  \param x
- *  \param y
-void REM_cont_rel(int x, int y)
-    _send_ident(CONT_REL);
-    _send_int(&x);
-    _send_int(&y);
- *  \param xarray x
- *  \param yarray y
- *  \param number
-void REM_polydots_abs(const int *xarray, const int *yarray, int number)
-    _send_ident(POLYDOTS_ABS);
-    _send_int(&number);
-    _send_int_array(number, xarray);
-    _send_int_array(number, yarray);
- *  \param xarray x
- *  \param yarray y
- *  \param number
-void REM_polydots_rel(const int *xarray, const int *yarray, int number)
-    _send_ident(POLYDOTS_REL);
- *  \param xarray x
- *  \param yarray y
- *  \param number
-void REM_polyline_abs(const int *xarray, const int *yarray, int number)
-    _send_ident(POLYLINE_ABS);
- * color.
- *  \param xarray x
- *  \param yarray y
- *  \param number
-void REM_polyline_rel(const int *xarray, const int *yarray, int number)
-    _send_ident(POLYLINE_REL);
- *  \param xarray x
- *  \param yarray y
- *  \param number
-void REM_polygon_abs(const int *xarray, const int *yarray, int number)
-    _send_ident(POLYGON_ABS);
- *  \param xarray x
- *  \param yarray y
- *  \param number
-void REM_polygon_rel(const int *xarray, const int *yarray, int number)
-    _send_ident(POLYGON_REL);
- * afterwards
- *  \param x1
- *  \param y1
- *  \param x2
- *  \param y2
-void REM_box_abs(int x1, int y1, int x2, int y2)
-    _send_ident(BOX_ABS);
-    _send_int(&x1);
-    _send_int(&y1);
-    _send_int(&x2);
-    _send_int(&y2);
- *  \param x
- *  \param y
-void REM_box_rel(int x, int y)
-    _send_ident(BOX_REL);
-    _send_int(&x);
-    _send_int(&y);
- *  \param width
- *  \param height
-void REM_text_size(int width, int height)
-    _send_ident(TEXT_SIZE);
-    _send_int(&height);
-void REM_text_rotation(float rotation)
-    _send_ident(TEXT_ROTATION);
-    _send_float(&rotation);
- *  \param t top
- *  \param b bottom
- *  \param l left
- *  \param r right
-void REM_set_window(int t, int b, int l, int r)
-    _send_ident(SET_WINDOW);
-    _send_int(&t);
-    _send_int(&b);
-    _send_int(&l);
-    _send_int(&r);
- *  \param sometext
-void REM_text(const char *sometext)
-    _send_ident(TEXT);
-    _send_text(sometext);
- * or border.
- *  \param sometext
- *  \param t top
- *  \param b bottom
- *  \param l left
- *  \param r right
-void REM_get_text_box(const char *sometext, int *t, int *b, int *l, int *r)
-    _send_ident(GET_TEXT_BOX);
-    _get_int(t);
-    _get_int(b);
-    _get_int(l);
-    _get_int(r);
- <table>
- </table>
- *  \param name
-void REM_font(const char *name)
-    _send_ident(FONT);
-    _send_text(name);
-void REM_charset(const char *name)
-    _send_ident(CHARSET);
-    _send_text(name);
-static void font_list(char ***list, int *count, int op)
-    char **fonts;
-    int num_fonts;
-    int i;
-    _send_ident(op);
-    _get_int(&num_fonts);
-    fonts = G_malloc(num_fonts * sizeof(char *));
-    for (i = 0; i < num_fonts; i++)
-	fonts[i] = G_store(_get_text_2());
-    *list = fonts;
-    *count = num_fonts;
-void REM_font_list(char ***list, int *count)
-    font_list(list, count, FONT_LIST);
-void REM_font_info(char ***list, int *count)
-    font_list(list, count, FONT_INFO);
-void REM_panel_save(const char *name, int t, int b, int l, int r)
-    _send_ident(PANEL_SAVE);
-    _send_text(name);
-    _send_int(&t);
-    _send_int(&b);
-    _send_int(&l);
-    _send_int(&r);
-    R_stabilize();
-void REM_panel_restore(const char *name)
-    _send_ident(PANEL_RESTORE);
-    _send_text(name);
-    R_stabilize();
-void REM_panel_delete(const char *name)
-    _send_ident(PANEL_DELETE);
-    _send_text(name);
-    R_stabilize();
-    unlink(name);
-void REM_begin_scaled_raster(int mask, int src[2][2], int dst[2][2])
-    _send_ident(BEGIN_SCALED_RASTER);
-    _send_int(&mask);
-    _send_int_array(4, &src[0][0]);
-    _send_int_array(4, &dst[0][0]);
-int REM_scaled_raster(int n, int row,
-    int z = !!nul;
-    int t;
-    _send_ident(SCALED_RASTER);
-    _send_int(&n);
-    _send_int(&row);
-    _send_char_array(n, red);
-    _send_char_array(n, grn);
-    _send_char_array(n, blu);
-    _send_char_array(n, nul ? nul : red);
-    _send_int(&z);
-    _get_int(&t);
-    return t;
-void REM_end_scaled_raster(void)
-    _send_ident(END_SCALED_RASTER);
-void REM_bitmap(int ncols, int nrows, int threshold, const unsigned char *buf)
-    _send_ident(BITMAP);
-    _send_int(&ncols);
-    _send_int(&nrows);
-    _send_int(&threshold);
-    _send_char_array(ncols * nrows, buf);
Deleted: grass/trunk/lib/raster/transport.h
--- grass/trunk/lib/raster/transport.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/lib/raster/transport.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -1,215 +0,0 @@
-#ifndef _TRANSPORT_H
-#define _TRANSPORT_H
-extern void LOC_get_location_with_box(int cx, int cy, int *wx, int *wy,
-				      int *button);
-extern void LOC_get_location_with_line(int cx, int cy, int *wx, int *wy,
-				       int *button);
-extern void LOC_get_location_with_pointer(int *wx, int *wy, int *button);
-extern int LOC_open_driver(void);
-extern int LOC__open_quiet(void);
-extern void LOC_stabilize(void);
-extern void LOC_kill_driver(void);
-extern void LOC_close_driver(void);
-extern void LOC_release_driver(void);
-extern int LOC_pad_create(const char *pad);
-extern int LOC_pad_current(char *name);
-extern int LOC_pad_delete(void);
-extern int LOC_pad_invent(char *pad);
-extern int LOC_pad_list(char ***list, int *count);
-extern int LOC_pad_select(const char *pad);
-extern int LOC_pad_append_item(const char *item, const char *value,
-			       int replace);
-extern int LOC_pad_delete_item(const char *name);
-extern int LOC_pad_get_item(const char *name, char ***list, int *count);
-extern int LOC_pad_list_items(char ***list, int *count);
-extern int LOC_pad_set_item(const char *name, const char *value);
-extern int LOC_screen_left(void);
-extern int LOC_screen_rite(void);
-extern int LOC_screen_bot(void);
-extern int LOC_screen_top(void);
-extern void LOC_get_num_colors(int *n);
-extern void LOC_standard_color(int index);
-extern void LOC_RGB_color(unsigned char red, unsigned char grn,
-			  unsigned char blu);
-extern void LOC_line_width(int width);
-extern void LOC_erase(void);
-extern void LOC_move_abs(int x, int y);
-extern void LOC_move_rel(int x, int y);
-extern void LOC_cont_abs(int x, int y);
-extern void LOC_cont_rel(int x, int y);
-extern void LOC_polydots_abs(const int *xarray, const int *yarray,
-			     int number);
-extern void LOC_polydots_rel(const int *xarray, const int *yarray,
-			     int number);
-extern void LOC_polyline_abs(const int *xarray, const int *yarray,
-			     int number);
-extern void LOC_polyline_rel(const int *xarray, const int *yarray,
-			     int number);
-extern void LOC_polygon_abs(const int *xarray, const int *yarray, int number);
-extern void LOC_polygon_rel(const int *xarray, const int *yarray, int number);
-extern void LOC_box_abs(int x1, int y1, int x2, int y2);
-extern void LOC_box_rel(int x, int y);
-extern void LOC_text_size(int width, int height);
-extern void LOC_text_rotation(float rotation);
-extern void LOC_set_window(int t, int b, int l, int r);
-extern void LOC_text(const char *text);
-extern void LOC_get_text_box(const char *text, int *t, int *b, int *l,
-			     int *r);
-extern void LOC_font(const char *name);
-extern void LOC_charset(const char *name);
-extern void LOC_font_list(char ***list, int *count);
-extern void LOC_font_info(char ***list, int *count);
-extern void LOC_panel_save(const char *name, int t, int b, int l, int r);
-extern void LOC_panel_restore(const char *name);
-extern void LOC_panel_delete(const char *name);
-extern void LOC_begin_scaled_raster(int mask, int src[2][2], int dst[2][2]);
-extern int LOC_scaled_raster(int n, int row, const unsigned char *red,
-			     const unsigned char *grn,
-			     const unsigned char *nul);
-extern void LOC_end_scaled_raster(void);
-extern void LOC_bitmap(int ncols, int nrows, int threshold,
-		       const unsigned char *buf);
-extern void REM_get_location_with_box(int cx, int cy, int *wx, int *wy,
-				      int *button);
-extern void REM_get_location_with_line(int cx, int cy, int *wx, int *wy,
-				       int *button);
-extern void REM_get_location_with_pointer(int *wx, int *wy, int *button);
-extern int REM_open_driver(void);
-extern int REM__open_quiet(void);
-extern void REM_stabilize(void);
-extern void REM_kill_driver(void);
-extern void REM_close_driver(void);
-extern void REM_release_driver(void);
-extern int REM_pad_create(const char *pad);
-extern int REM_pad_current(char *name);
-extern int REM_pad_delete(void);
-extern int REM_pad_invent(char *pad);
-extern int REM_pad_list(char ***list, int *count);
-extern int REM_pad_select(const char *pad);
-extern int REM_pad_append_item(const char *item, const char *value,
-			       int replace);
-extern int REM_pad_delete_item(const char *name);
-extern int REM_pad_get_item(const char *name, char ***list, int *count);
-extern int REM_pad_list_items(char ***list, int *count);
-extern int REM_pad_set_item(const char *name, const char *value);
-extern int REM_screen_left(void);
-extern int REM_screen_rite(void);
-extern int REM_screen_bot(void);
-extern int REM_screen_top(void);
-extern void REM_get_num_colors(int *n);
-extern void REM_standard_color(int index);
-extern void REM_RGB_color(unsigned char red, unsigned char grn,
-extern void REM_line_width(int width);
-extern void REM_erase(void);
-extern void REM_move_abs(int x, int y);
-extern void REM_move_rel(int x, int y);
-extern void REM_cont_abs(int x, int y);
-extern void REM_cont_rel(int x, int y);
-extern void REM_polydots_abs(const int *xarray, const int *yarray,
-			     int number);
-extern void REM_polydots_rel(const int *xarray, const int *yarray,
-			     int number);
-extern void REM_polyline_abs(const int *xarray, const int *yarray,
-			     int number);
-extern void REM_polyline_rel(const int *xarray, const int *yarray,
-			     int number);
-extern void REM_polygon_abs(const int *xarray, const int *yarray, int number);
-extern void REM_polygon_rel(const int *xarray, const int *yarray, int number);
-extern void REM_box_abs(int x1, int y1, int x2, int y2);
-extern void REM_box_rel(int x, int y);
-extern void REM_text_size(int width, int height);
-extern void REM_text_rotation(float rotation);
-extern void REM_set_window(int t, int b, int l, int r);
-extern void REM_text(const char *text);
-extern void REM_get_text_box(const char *text, int *t, int *b, int *l,
-			     int *r);
-extern void REM_font(const char *name);
-extern void REM_charset(const char *name);
-extern void REM_font_list(char ***list, int *count);
-extern void REM_font_info(char ***list, int *count);
-extern void REM_panel_save(const char *name, int t, int b, int l, int r);
-extern void REM_panel_restore(const char *name);
-extern void REM_panel_delete(const char *name);
-extern void REM_begin_scaled_raster(int mask, int src[2][2], int dst[2][2]);
-extern int REM_scaled_raster(int n, int row, const unsigned char *red,
-extern void REM_end_scaled_raster(void);
-extern void REM_bitmap(int ncols, int nrows, int threshold,
-struct transport
-    int (*open_driver) (void);
-    int (*open_quiet) (void);
-    void (*stabilize) (void);
-    void (*kill_driver) (void);
-    void (*close_driver) (void);
-    void (*release_driver) (void);
-    int (*screen_left) (void);
-    int (*screen_rite) (void);
-    int (*screen_bot) (void);
-    int (*screen_top) (void);
-    void (*get_num_colors) (int *);
-    void (*standard_color) (int);
-    void (*RGB_color) (unsigned char, unsigned char, unsigned char);
-    void (*line_width) (int);
-    void (*erase) (void);
-    void (*move_abs) (int, int);
-    void (*move_rel) (int, int);
-    void (*cont_abs) (int, int);
-    void (*cont_rel) (int, int);
-    void (*polydots_abs) (const int *, const int *, int);
-    void (*polydots_rel) (const int *, const int *, int);
-    void (*polyline_abs) (const int *, const int *, int);
-    void (*polyline_rel) (const int *, const int *, int);
-    void (*polygon_abs) (const int *, const int *, int);
-    void (*polygon_rel) (const int *, const int *, int);
-    void (*box_abs) (int, int, int, int);
-    void (*box_rel) (int, int);
-    void (*text_size) (int, int);
-    void (*text_rotation) (float);
-    void (*set_window) (int, int, int, int);
-    void (*text) (const char *);
-    void (*get_text_box) (const char *, int *, int *, int *, int *);
-    void (*font) (const char *);
-    void (*charset) (const char *);
-    void (*font_list) (char ***, int *);
-    void (*font_info) (char ***, int *);
-    void (*panel_save) (const char *, int, int, int, int);
-    void (*panel_restore) (const char *);
-    void (*panel_delete) (const char *);
-    void (*begin_scaled_raster) (int, int[2][2], int[2][2]);
-    int (*scaled_raster) (int, int, const unsigned char *,
-			  const unsigned char *, const unsigned char *,
-			  const unsigned char *);
-    void (*end_scaled_raster) (void);
-    void (*bitmap) (int, int, int, const unsigned char *);
-    void (*get_location_with_box) (int, int, int *, int *, int *);
-    void (*get_location_with_line) (int, int, int *, int *, int *);
-    void (*get_location_with_pointer) (int *, int *, int *);
-    int (*pad_create) (const char *);
-    int (*pad_current) (char *);
-    int (*pad_delete) (void);
-    int (*pad_invent) (char *);
-    int (*pad_list) (char ***, int *);
-    int (*pad_select) (const char *);
-    int (*pad_append_item) (const char *, const char *, int);
-    int (*pad_delete_item) (const char *);
-    int (*pad_get_item) (const char *, char ***, int *);
-    int (*pad_list_items) (char ***, int *);
-    int (*pad_set_item) (const char *, const char *);
-extern const struct transport *trans;
-#endif /* _TRANSPORT_H */
Modified: grass/trunk/raster/r.profile/local_proto.h
--- grass/trunk/raster/r.profile/local_proto.h	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/raster/r.profile/local_proto.h	2008-08-06 21:50:17 UTC (rev 32584)
@@ -3,8 +3,6 @@
 #include <string.h>
 #include <math.h>
-#include <grass/display.h>
-#include <grass/raster.h>
 /* main.c */
@@ -18,10 +16,5 @@
 /* input.c */
 int input(char *, char *, char *, char *, char *);
-#ifdef MAIN
-int clr;
-struct Colors colors;
-#else
 extern int clr;
 extern struct Colors colors;
-#endif
Modified: grass/trunk/raster/r.profile/main.c
--- grass/trunk/raster/r.profile/main.c	2008-08-06 21:37:41 UTC (rev 32583)
+++ grass/trunk/raster/r.profile/main.c	2008-08-06 21:50:17 UTC (rev 32584)
@@ -11,15 +11,12 @@
-#define MAIN
 #include "local_proto.h"
+int clr;
+struct Colors colors;
 static double dist, e, n;
-static int min_range[5], max_range[5];
-static int which_range;
-static int change_range;
-static int move(int, int);
-static int cont(int, int);
 int main(int argc, char *argv[])
@@ -27,7 +24,6 @@
     char *name, *outfile, *mapset;
     int fd, projection;
     FILE *fp;
-    int screen_x, screen_y, button;
     double res;
     char *null_string;
     char ebuf[256], nbuf[256], label[512], formatbuff[256];
@@ -41,7 +37,7 @@
     struct
 	struct Option *opt1, *profile, *res, *output, *null_str;
-	struct Flag *i, *g, *c;
+	struct Flag *g, *c;
     parm;
     struct GModule *module;
@@ -88,10 +84,6 @@
     parm.null_str->answer = "*";
     parm.null_str->description = _("Character to represent no data cell");
-    parm.i = G_define_flag();
-    parm.i->key = 'i';
-    parm.i->description = _("Interactively select End-Points");
     parm.g = G_define_flag();
     parm.g->key = 'g';
     parm.g->description =
@@ -126,8 +118,6 @@
 	/* Do average of EW and NS res */
 	res = (window.ew_res + window.ns_res) / 2;
-    screen_x = ((int)D_get_d_west() + (int)D_get_d_east()) / 2;
-    screen_y = ((int)D_get_d_north() + (int)D_get_d_south()) / 2;
     G_message(_("Using resolution [%g]"), res);
@@ -162,18 +152,6 @@
     data_type = G_get_raster_map_type(fd);
     /* Done with file */
-    /* Get coords */
-    if (parm.i->answer) {
-	R_open_driver();
-	D_setup(0);
-	G_setup_plot(D_get_d_north(),
-		     D_get_d_south(),
-		     D_get_d_west(), D_get_d_east(), move, cont);
-	R_standard_color(D_translate_color(DEFAULT_FG_COLOR));
     /* Show message giving output format */
     G_message(_("Output Format:"));
     if (coords == 1)
@@ -186,7 +164,7 @@
     G_message(formatbuff);
     /* Get Profile Start Coords */
-    if (!parm.profile->answer && !parm.i->answer) {
+    if (!parm.profile->answer) {
 	/* Assume input from stdin */
 	for (n = 1; input(b1, ebuf, b2, nbuf, label); n++) {
 	    G_debug(4, "stdin line %d: ebuf=[%s]  nbuf=[%s]", n, ebuf, nbuf);
@@ -202,50 +180,6 @@
 	    havefirst = TRUE;
-    else if (parm.i->answer) {
-	/* Select points interactively */
-	dist = 0;
-	fprintf(stderr, "\n\n");
-	fprintf(stderr, _("Use mouse to select Start Point\n"));
-	R_get_location_with_pointer(&screen_x, &screen_y, &button);
-	e1 = D_d_to_u_col((double)screen_x);
-	n1 = D_d_to_u_row((double)screen_y);
-	fprintf(stderr, _("\nUse mouse to draw profile line\n"));
-	fprintf(stderr, _("Buttons:\n"));
-	fprintf(stderr, _("Left:   Mark next point\n"));
-	fprintf(stderr, _("Middle: Mark next point\n"));
-	fprintf(stderr, _("Right:  Finish profile and exit\n\n"));
-	while (button != 3) {
-	    R_get_location_with_line((int)(0.5 + D_u_to_d_col(e1)),
-				     (int)(0.5 + D_u_to_d_row(n1)), &screen_x,
-				     &screen_y, &button);
-	    if (button == 1 || button == 2) {
-		e2 = D_d_to_u_col((double)screen_x);
-		n2 = D_d_to_u_row((double)screen_y);
-	    else {
-		break;
-	    /* draw line from p1 to p2 */
-	    G_plot_line(e1, n1, e2, n2);
-	    /* Get profile info */
-	    do_profile(e1, e2, n1, n2, name, coords, res, fd, data_type, fp,
-		       null_string);
-	    n1 = n2;
-	    e1 = e2;
-	    R_stabilize();
-	R_close_driver();
     else {
 	/* Coords from Command Line */
 	for (i = 0; parm.profile->answers[i]; i += 2) {
@@ -402,32 +336,3 @@
     return 0;
 }				/* done with do_profile */
-static int move(int x, int y)
-    D_move_abs(x, y);
-    return 0;
-static int cont(int x, int y)
-    if (D_cont_abs(x, y)) {	/* clipped */
-	change_range = 1;
-    else {			/* keep track of left,right x for lines drawn in window */
-	if (change_range) {
-	    which_range++;
-	    min_range[which_range] = max_range[which_range] = x;
-	    change_range = 0;
-	else {
-	    if (x < min_range[which_range])
-		min_range[which_range] = x;
-	    else if (x > max_range[which_range])
-		max_range[which_range] = x;
-    return 0;
