[GRASS-SVN] r32623 - grass/trunk/lib/db/dbmi_client
Thu Aug 7 14:53:46 EDT 2008
Author: neteler
Date: 2008-08-07 14:53:46 -0400 (Thu, 07 Aug 2008)
New Revision: 32623
   grass/trunk/lib/db/dbmi_client/c_add_col.c
   grass/trunk/lib/db/dbmi_client/c_bindupdate.c
   grass/trunk/lib/db/dbmi_client/c_close_cur.c
   grass/trunk/lib/db/dbmi_client/c_closedb.c
   grass/trunk/lib/db/dbmi_client/c_create_idx.c
   grass/trunk/lib/db/dbmi_client/c_create_tab.c
   grass/trunk/lib/db/dbmi_client/c_createdb.c
   grass/trunk/lib/db/dbmi_client/c_delete.c
   grass/trunk/lib/db/dbmi_client/c_deletedb.c
   grass/trunk/lib/db/dbmi_client/c_desc_table.c
   grass/trunk/lib/db/dbmi_client/c_drop_col.c
   grass/trunk/lib/db/dbmi_client/c_drop_index.c
   grass/trunk/lib/db/dbmi_client/c_drop_tab.c
   grass/trunk/lib/db/dbmi_client/c_execute.c
   grass/trunk/lib/db/dbmi_client/c_fetch.c
   grass/trunk/lib/db/dbmi_client/c_finddb.c
   grass/trunk/lib/db/dbmi_client/c_insert.c
   grass/trunk/lib/db/dbmi_client/c_list_drivers.c
   grass/trunk/lib/db/dbmi_client/c_list_idx.c
   grass/trunk/lib/db/dbmi_client/c_list_tabs.c
   grass/trunk/lib/db/dbmi_client/c_listdb.c
   grass/trunk/lib/db/dbmi_client/c_opendb.c
   grass/trunk/lib/db/dbmi_client/c_openinsert.c
   grass/trunk/lib/db/dbmi_client/c_openselect.c
   grass/trunk/lib/db/dbmi_client/c_openupdate.c
   grass/trunk/lib/db/dbmi_client/c_priv.c
   grass/trunk/lib/db/dbmi_client/c_rows.c
   grass/trunk/lib/db/dbmi_client/c_update.c
   grass/trunk/lib/db/dbmi_client/c_version.c
   grass/trunk/lib/db/dbmi_client/column.c
   grass/trunk/lib/db/dbmi_client/copy_tab.c
   grass/trunk/lib/db/dbmi_client/db.c
   grass/trunk/lib/db/dbmi_client/delete_tab.c
   grass/trunk/lib/db/dbmi_client/printtab.c
   grass/trunk/lib/db/dbmi_client/select.c
   grass/trunk/lib/db/dbmi_client/shutdown.c
   grass/trunk/lib/db/dbmi_client/start.c
   grass/trunk/lib/db/dbmi_client/table.c
added original author
Modified: grass/trunk/lib/db/dbmi_client/c_add_col.c
--- grass/trunk/lib/db/dbmi_client/c_add_col.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_add_col.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * License (>=v2). Read the file COPYING that comes with GRASS
  * for details.
- * \author Radim Blazek
+ * \author Joel Jones (CERL/UIUC), Radim Blazek
 #include <grass/dbmi.h>
Modified: grass/trunk/lib/db/dbmi_client/c_bindupdate.c
--- grass/trunk/lib/db/dbmi_client/c_bindupdate.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_bindupdate.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_close_cur.c
--- grass/trunk/lib/db/dbmi_client/c_close_cur.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_close_cur.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
Modified: grass/trunk/lib/db/dbmi_client/c_closedb.c
--- grass/trunk/lib/db/dbmi_client/c_closedb.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_closedb.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_create_idx.c
--- grass/trunk/lib/db/dbmi_client/c_create_idx.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_create_idx.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <string.h>
Modified: grass/trunk/lib/db/dbmi_client/c_create_tab.c
--- grass/trunk/lib/db/dbmi_client/c_create_tab.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_create_tab.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_createdb.c
--- grass/trunk/lib/db/dbmi_client/c_createdb.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_createdb.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_delete.c
--- grass/trunk/lib/db/dbmi_client/c_delete.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_delete.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_deletedb.c
--- grass/trunk/lib/db/dbmi_client/c_deletedb.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_deletedb.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_desc_table.c
--- grass/trunk/lib/db/dbmi_client/c_desc_table.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_desc_table.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_drop_col.c
--- grass/trunk/lib/db/dbmi_client/c_drop_col.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_drop_col.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_drop_index.c
--- grass/trunk/lib/db/dbmi_client/c_drop_index.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_drop_index.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_drop_tab.c
--- grass/trunk/lib/db/dbmi_client/c_drop_tab.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_drop_tab.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_execute.c
--- grass/trunk/lib/db/dbmi_client/c_execute.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_execute.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_fetch.c
--- grass/trunk/lib/db/dbmi_client/c_fetch.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_fetch.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_finddb.c
--- grass/trunk/lib/db/dbmi_client/c_finddb.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_finddb.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
Modified: grass/trunk/lib/db/dbmi_client/c_insert.c
--- grass/trunk/lib/db/dbmi_client/c_insert.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_insert.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_list_drivers.c
--- grass/trunk/lib/db/dbmi_client/c_list_drivers.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_list_drivers.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_list_idx.c
--- grass/trunk/lib/db/dbmi_client/c_list_idx.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_list_idx.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_list_tabs.c
--- grass/trunk/lib/db/dbmi_client/c_list_tabs.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_list_tabs.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
Modified: grass/trunk/lib/db/dbmi_client/c_listdb.c
--- grass/trunk/lib/db/dbmi_client/c_listdb.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_listdb.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_opendb.c
--- grass/trunk/lib/db/dbmi_client/c_opendb.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_opendb.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_openinsert.c
--- grass/trunk/lib/db/dbmi_client/c_openinsert.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_openinsert.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_openselect.c
--- grass/trunk/lib/db/dbmi_client/c_openselect.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_openselect.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_openupdate.c
--- grass/trunk/lib/db/dbmi_client/c_openupdate.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_openupdate.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_priv.c
--- grass/trunk/lib/db/dbmi_client/c_priv.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_priv.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_rows.c
--- grass/trunk/lib/db/dbmi_client/c_rows.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_rows.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_update.c
--- grass/trunk/lib/db/dbmi_client/c_update.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_update.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/c_version.c
--- grass/trunk/lib/db/dbmi_client/c_version.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/c_version.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/column.c
--- grass/trunk/lib/db/dbmi_client/column.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/column.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
  * \author Update by Glynn Clement <glynn gclements.plus.com>
  * and Martin Landa <landa.martin gmail.com>
Modified: grass/trunk/lib/db/dbmi_client/copy_tab.c
--- grass/trunk/lib/db/dbmi_client/copy_tab.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/copy_tab.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
Modified: grass/trunk/lib/db/dbmi_client/db.c
--- grass/trunk/lib/db/dbmi_client/db.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/db.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/delete_tab.c
--- grass/trunk/lib/db/dbmi_client/delete_tab.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/delete_tab.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
Modified: grass/trunk/lib/db/dbmi_client/printtab.c
--- grass/trunk/lib/db/dbmi_client/printtab.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/printtab.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <string.h>
Modified: grass/trunk/lib/db/dbmi_client/select.c
--- grass/trunk/lib/db/dbmi_client/select.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/select.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
Modified: grass/trunk/lib/db/dbmi_client/shutdown.c
--- grass/trunk/lib/db/dbmi_client/shutdown.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/shutdown.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
Modified: grass/trunk/lib/db/dbmi_client/start.c
--- grass/trunk/lib/db/dbmi_client/start.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/start.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <string.h>
Modified: grass/trunk/lib/db/dbmi_client/table.c
--- grass/trunk/lib/db/dbmi_client/table.c	2008-08-07 18:08:36 UTC (rev 32622)
+++ grass/trunk/lib/db/dbmi_client/table.c	2008-08-07 18:53:46 UTC (rev 32623)
@@ -9,7 +9,7 @@
  * for details.
 #include <stdlib.h>
