[GRASS-SVN] r32628 - grass/trunk/raster/r.support
Thu Aug 7 18:02:38 EDT 2008
Author: glynn
Date: 2008-08-07 18:02:38 -0400 (Thu, 07 Aug 2008)
New Revision: 32628
   grass/trunk/raster/r.support/front.c
Add options to save/load history
Modified: grass/trunk/raster/r.support/front.c
--- grass/trunk/raster/r.support/front.c	2008-08-07 21:27:37 UTC (rev 32627)
+++ grass/trunk/raster/r.support/front.c	2008-08-07 22:02:38 UTC (rev 32628)
@@ -40,6 +40,7 @@
     struct Option *raster, *title_opt, *history_opt;
     struct Option *datasrc1_opt, *datasrc2_opt, *datadesc_opt;
     struct Option *map_opt, *units_opt, *vdatum_opt;
+    struct Option *load_opt, *save_opt;
     struct Flag *stats_flag, *null_flag, *del_flag;
     int cellhd_ok;		/* Is cell header OK? */
     int is_reclass;		/* Is raster reclass? */
@@ -113,6 +114,16 @@
     map_opt->gisprompt = "old,cell,raster";
     map_opt->description = _("Raster map from which to copy category table");
+    load_opt = G_define_standard_option(G_OPT_F_INPUT);
+    load_opt->key = "loadhistory";
+    load_opt->required = NO;
+    load_opt->description = _("Text file from which to load history");
+    save_opt = G_define_standard_option(G_OPT_F_OUTPUT);
+    save_opt->key = "savehistory";
+    save_opt->required = NO;
+    save_opt->description = _("Text file in which to save history");
     stats_flag = G_define_flag();
     stats_flag->key = 's';
     stats_flag->description = _("Update statistics (histogram, range)");
@@ -147,6 +158,46 @@
 	G_put_cell_title(raster->answer, title);
+    if (save_opt->answer) {
+	FILE *fp = fopen(save_opt->answer, "w");
+	int i;
+	if (!fp)
+	    G_fatal_error(_("Unable to open output file <%s>"), save_opt->answer);
+	G_read_history(raster->answer, mapset, &hist);
+	for (i = 0; i < hist.edlinecnt; i++)
+	    fprintf(fp, "%s\n", hist.edhist[i]);
+	fclose(fp);
+    if (load_opt->answer) {
+	FILE *fp = fopen(load_opt->answer, "r");
+	int i;
+	if (!fp)
+	    G_fatal_error(_("Unable to open input file <%s>"), load_opt->answer);
+	for (i = 0; ; i++) {
+	    if (i >= MAXEDLINES) {
+		G_warning(_("Not enough room in history file"));
+		break;
+	    if (!G_getl2(hist.edhist[i], RECORD_LEN - 2, fp))
+		break;
+	fclose(fp);
+	hist.edlinecnt = i;
+	G_write_history(raster->answer, &hist);
     if (history_opt->answer) {
