[GRASS-SVN] r32633 - grass/trunk/lib/gis
Fri Aug 8 00:35:13 EDT 2008
Author: glynn
Date: 2008-08-08 00:35:12 -0400 (Fri, 08 Aug 2008)
New Revision: 32633
   grass/trunk/lib/gis/color_read.c
   grass/trunk/lib/gis/open.c
   grass/trunk/lib/gis/open_misc.c
Fix handling of qualified map names
Modified: grass/trunk/lib/gis/color_read.c
--- grass/trunk/lib/gis/color_read.c	2008-08-08 00:48:58 UTC (rev 32632)
+++ grass/trunk/lib/gis/color_read.c	2008-08-08 04:35:12 UTC (rev 32633)
@@ -64,7 +64,7 @@
     int fp;
     char buf[GNAME_MAX];
     char *err;
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    char xname[GNAME_MAX];
     struct Range range;
     struct FPRange drange;
     CELL min, max;
@@ -72,12 +72,11 @@
     fp = G_raster_map_is_fp(name, mapset);
     G_init_colors(colors);
-    if (G__name_is_fully_qualified(name, xname, xmapset)) {
-	if (strcmp(xmapset, mapset) != 0)
-	    return -1;
-	name = xname;
+    strcpy(xname, name);
+    mapset = G_find_cell(xname, mapset);
+    name = xname;
     if (fp)
 	G_mark_colors_as_fp(colors);
@@ -114,9 +113,8 @@
 	return 1;
-    sprintf(buf, _("color support for [%s] in mapset [%s] %s"), name, mapset,
-	    err);
-    G_warning(buf);
+    G_warning(_("color support for [%s] in mapset [%s] %s"), name, mapset,
+	      err);
     return -1;
Modified: grass/trunk/lib/gis/open.c
--- grass/trunk/lib/gis/open.c	2008-08-08 00:48:58 UTC (rev 32632)
+++ grass/trunk/lib/gis/open.c	2008-08-08 04:35:12 UTC (rev 32633)
@@ -15,11 +15,7 @@
 #include <grass/config.h>
 #include <string.h>
-#ifdef HAVE_UNISTD_H
 #include <unistd.h>
-#endif
-#include <unistd.h>
 #include <fcntl.h>
 #include <grass/gis.h>
@@ -54,7 +50,7 @@
 		   const char *name, const char *mapset, int mode)
     char path[GPATH_MAX];
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX], *dummy;
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
     G__check_gisinit();
@@ -62,25 +58,31 @@
     /* READ */
     if (mode == 0) {
-	    if (strcmp(xmapset, mapset) != 0) {
+	    if (*mapset && strcmp(xmapset, mapset) != 0) {
 		G_warning(_("G__open(read): mapset <%s> doesn't match xmapset <%s>"),
 			  mapset, xmapset);
 		return -1;
 	    name = xname;
+	    mapset = xmapset;
-	if ((dummy = G_find_file2(element, name, mapset)) == NULL)
+	else if (!*mapset)
+	    mapset = G_find_file2(element, name, mapset);
+	if (!mapset)
 	    return -1;
 	G__file_name(path, element, name, mapset);
 	return open(path, 0);
     /* WRITE */
     if (mode == 1 || mode == 2) {
+	mapset = G_mapset();
-	    if (strcmp(xmapset, G_mapset()) != 0) {
+	    if (strcmp(xmapset, mapset) != 0) {
 		G_warning(_("G__open(write): xmapset <%s> != G_mapset() <%s>"),
-			  xmapset, G_mapset());
+			  xmapset, mapset);
 		return -1;
 	    name = xname;
@@ -89,7 +91,8 @@
 	if (G_legal_filename(name) == -1)
 	    return -1;
-	G__file_name(path, element, name, G_mapset());
+	G__file_name(path, element, name, mapset);
 	if (mode == 1 || access(path, 0) != 0) {
 	    G__make_mapset_element(element);
 	    close(open(path, O_WRONLY | O_CREAT | O_TRUNC, 0666));
Modified: grass/trunk/lib/gis/open_misc.c
--- grass/trunk/lib/gis/open_misc.c	2008-08-08 00:48:58 UTC (rev 32632)
+++ grass/trunk/lib/gis/open_misc.c	2008-08-08 04:35:12 UTC (rev 32633)
@@ -22,20 +22,18 @@
 #include <string.h>
 #include <unistd.h>
-#endif
+#include <fcntl.h>
-#include <fcntl.h>
+#include <grass/glocale.h>
 static int G__open_misc(const char *dir,
 			const char *element,
     G__check_gisinit();
@@ -43,15 +41,18 @@
     /* READ */
     if (mode == 0) {
-		fprintf(stderr,
-			"G__open(r): mapset (%s) doesn't match xmapset (%s)\n",
-			mapset, xmapset);
+ 		G_warning(_("G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"),
+ 			  mapset, xmapset);
 		return -1;
 	    name = xname;
+	    mapset = xmapset;
-	if ((dummy = G_find_file2_misc(dir, element, name, mapset)) == NULL)
+    	    mapset = G_find_file2_misc(dir, element, name, mapset);
+	if (!mapset)
 	    return -1;
 	G__file_name_misc(path, dir, element, name, mapset);
@@ -60,11 +61,11 @@
     /* WRITE */
-		fprintf(stderr,
-			"G__open(w): xmapset (%s) != G_mapset() (%s)\n",
+ 		G_warning(_("G__open_misc(write): xmapset <%s> != G_mapset() <%s>"),
+			  xmapset, mapset);
 		return -1;
 	    name = xname;
@@ -73,7 +74,7 @@
 	    return -1;
-	G__file_name_misc(path, dir, element, name, G_mapset());
+	G__file_name_misc(path, dir, element, name, mapset);
 	    G__make_mapset_element_misc(dir, name);
 	    close(creat(path, 0666));
