[GRASS-SVN] r32645 - in grass/branches/develbranch_6/gui/wxpython: gui_modules vdigit
Fri Aug 8 10:23:30 EDT 2008
Author: martinl
Date: 2008-08-08 10:23:30 -0400 (Fri, 08 Aug 2008)
New Revision: 32645
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
wxGUI/vdigit: optionally select only features inside of selection bounding box (by default are selected all features overlapping bounding box)
* settings dialog layout cosmetics
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-08-08 13:25:09 UTC (rev 32644)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-08-08 14:23:30 UTC (rev 32645)
@@ -291,6 +291,9 @@
                 'checkForDupl' : {
                     'enabled' : False
+                'selectInside' : {
+                    'enabled' : False
                 # exit
                 'saveOnExit' : {
                     'enabled' : False
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-08-08 13:25:09 UTC (rev 32644)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-08-08 14:23:30 UTC (rev 32645)
@@ -1375,7 +1375,7 @@
         nselected = self.__display.SelectLinesByBox(x1, y1, -1.0 * wxvdigit.PORT_DOUBLE_MAX,
                                                     x2, y2, wxvdigit.PORT_DOUBLE_MAX,
-                                                    type)
+                                                    type, UserSettings.Get(group='vdigit', key='selectInside', subkey='enabled'))
         Debug.msg(4, "CDisplayDriver.SelectLinesByBox(): selected=%d" % \
                       nselected)
@@ -1718,10 +1718,9 @@
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Snapping"))
         sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        flexSizer1 = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
-        flexSizer1.AddGrowableCol(0)
-        flexSizer2 = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
-        flexSizer2.AddGrowableCol(0)
+        flexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+        flexSizer.AddGrowableCol(0)
         # snapping
         text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Snapping threshold"))
         self.snappingValue = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(75, -1),
@@ -1732,18 +1731,9 @@
                                       choices=["screen pixels", "map units"])
         self.snappingUnit.SetStringSelection(UserSettings.Get(group='vdigit', key="snapping", subkey='units'))
         self.snappingUnit.Bind(wx.EVT_CHOICE, self.OnChangeSnappingUnits)
-        flexSizer1.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer1.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        flexSizer1.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
-        # background map
-        text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Background vector map"))
-        self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=(200,-1),
-                                           type="vector", exceptOf=[self.parent.digit.map])
-        self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
-        self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
-        flexSizer2.Add(text, proportion=1, flag=wx.ALIGN_CENTER_VERTICAL)
-        flexSizer2.Add(self.backgroundMap, proportion=1, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
-        #flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        flexSizer.Add(text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(self.snappingValue, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
+        flexSizer.Add(self.snappingUnit, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
         vertexSizer = wx.BoxSizer(wx.VERTICAL)
         self.snapVertex = wx.CheckBox(parent=panel, id=wx.ID_ANY,
@@ -1758,12 +1748,33 @@
         vertexSizer.Add(item=self.snappingInfo, proportion=0,
                         flag=wx.ALL | wx.EXPAND, border=1)
-        sizer.Add(item=flexSizer1, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
-        sizer.Add(item=flexSizer2, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
-        sizer.Add(item=vertexSizer, proportion=1, flag=wx.BOTTOM | wx.LEFT | wx.EXPAND, border=1)
+        sizer.Add(item=flexSizer, proportion=1, flag=wx.EXPAND)
+        sizer.Add(item=vertexSizer, proportion=1, flag=wx.EXPAND)
         border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+        # background vector map
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Background vector map"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        boxSizer = wx.BoxSizer(wx.VERTICAL)
+        self.backgroundMap = gselect.Select(parent=panel, id=wx.ID_ANY, size=globalvar.DIALOG_GSELECT_SIZE,
+                                           type="vector", exceptOf=[self.parent.digit.map])
+        self.backgroundMap.SetValue(UserSettings.Get(group='vdigit', key="backgroundMap", subkey='value'))
+        self.backgroundMap.Bind(wx.EVT_TEXT, self.OnChangeBackgroundMap)
+        boxSizer.Add(item=self.backgroundMap, proportion=0,
+                     flag=wx.EXPAND | wx.ALL, border=5)
+        boxSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                        label=_("This vector map is used for snapping and copying features.")),
+                     proportion=0,
+        sizer.Add(item=boxSizer, proportion=1, flag=wx.TOP | wx.LEFT | wx.EXPAND, border=1)
+        border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
         # select box
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Select vector features"))
@@ -1794,12 +1805,19 @@
         flexSizer.Add(units, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
                       border=10)
+        self.selectIn = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                    label=_("Select only features inside of selection bounding box"))
+        self.selectIn.SetValue(UserSettings.Get(group='vdigit', key="selectInside", subkey='enabled'))
+        self.selectIn.SetToolTipString(_("By default are selected all features overlapping selection bounding box "))
         self.checkForDupl = wx.CheckBox(parent=panel, id=wx.ID_ANY,
                                         label=_("Check for duplicates"))
         self.checkForDupl.SetValue(UserSettings.Get(group='vdigit', key="checkForDupl", subkey='enabled'))
-        flexSizer.Add(item=self.checkForDupl, proportion=0, flag=wx.EXPAND)
         sizer.Add(item=flexSizer, proportion=0, flag=wx.EXPAND)
+        sizer.Add(item=self.selectIn, proportion=0, flag=wx.EXPAND | wx.ALL, border=1)
+        sizer.Add(item=self.checkForDupl, proportion=0, flag=wx.EXPAND | wx.ALL, border=1)
         border.Add(item=sizer, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
@@ -2200,6 +2218,8 @@
                          value=int(self.selectThreshValue.GetValue()))
         UserSettings.Set(group='vdigit', key="checkForDupl", subkey='enabled',
                          value=self.checkForDupl.IsChecked())
+        UserSettings.Set(group='vdigit', key="selectInside", subkey='enabled',
+                         value=self.selectIn.IsChecked())
         # on-exit
         UserSettings.Set(group='vdigit', key="saveOnExit", subkey='enabled',
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2008-08-08 13:25:09 UTC (rev 32644)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2008-08-08 14:23:30 UTC (rev 32645)
@@ -930,13 +930,15 @@
    \param[in] x1,y1,z1,x2,y2,z3 bounding box definition
    \param[in] type feature type
+   \param[in] onlyInside if true select only features inside
+   of bounding box (not overlapping)
    \return number of selected features
    \return -1 on error
 int DisplayDriver::SelectLinesByBox(double x1, double y1, double z1,
 				    double x2, double y2, double z2,
-				    int type)
+				    int type, bool onlyInside)
     if (!mapInfo)
 	return -1;
@@ -964,6 +966,21 @@
     for (int i = 0; i < list->n_values; i++) {
 	line = list->value[i];
+	if (onlyInside) {
+	    bool inside;
+	    inside = true;
+	    Vect_read_line(mapInfo, points, cats, line);
+	    for (int p = 0; p < points->n_points; p++) {
+		if (!Vect_point_in_poly(points->x[p], points->y[p],
+					bbox)) {
+		    inside = false;
+		    break;
+	    if (!inside)
+		continue; /* skip lines just overlapping bbox */
 	if (!IsSelected(line)) {
 	    Vect_list_append(selected, line);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h	2008-08-08 13:25:09 UTC (rev 32644)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h	2008-08-08 14:23:30 UTC (rev 32645)
@@ -171,7 +171,8 @@
     int DrawMap(bool);
     /* select */
-    int SelectLinesByBox(double, double, double, double, double, double, int);
+    int SelectLinesByBox(double, double, double, double,
+			 double, double, int, bool);
     std::vector<double> SelectLineByPoint(double, double, double,
 					  double, int, int);
