[GRASS-SVN] r32656 - grass-addons/vector/v.parallel2
Sat Aug 9 17:15:04 EDT 2008
Author: rmatev
Date: 2008-08-09 17:15:04 -0400 (Sat, 09 Aug 2008)
New Revision: 32656
Added:
   grass-addons/vector/v.parallel2/e_intersect.c
   grass-addons/vector/v.parallel2/e_intersect.h
   grass-addons/vector/v.parallel2/dgraph.c
   grass-addons/vector/v.parallel2/main.c
   grass-addons/vector/v.parallel2/vlib_buffer.c
Everything working. Needs GMP to compile
Modified: grass-addons/vector/v.parallel2/dgraph.c
--- grass-addons/vector/v.parallel2/dgraph.c	2008-08-09 13:21:36 UTC (rev 32655)
+++ grass-addons/vector/v.parallel2/dgraph.c	2008-08-09 21:15:04 UTC (rev 32656)
@@ -2,11 +2,11 @@
 #include <math.h>
 #include <grass/Vect.h>
 #include <grass/gis.h>
+#include <gmp.h>
 #include "dgraph.h"
+#include "e_intersect.h"
 #define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
-#define FZERO(X, TOL) (fabs(X)<TOL)
-#define FEQUAL(X, Y, TOL) (fabs(X-Y)<TOL)
 #ifndef MIN
     #define MIN(X,Y) ((X<Y)?X:Y)
 #endif
@@ -15,268 +15,6 @@
 #endif
 #define PI M_PI
-/* tollerance aware version */
-/* TODO: fix all =='s left */
-int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
-    double *x1, double *y1, double *x2, double *y2, double tol)
-    double adx, ady, bdx, bdy;
-    double aa, bb;
-    double tola, tolb;
-    double d, d1, d2, ra, rb, t;
-    int    switched = 0;
-    /* TODO: Works for points ? */
-    G_debug(4, "segment_intersection_2d()");
-    G_debug(4, "    ax1  = %.18f, ay1  = %.18f", ax1, ay1);
-    G_debug(4, "    ax2  = %.18f, ay2  = %.18f", ax2, ay2);
-    G_debug(4, "    bx1  = %.18f, by1  = %.18f", bx1, by1);
-    G_debug(4, "    bx2  = %.18f, by2  = %.18f", bx2, by2);
-    /* Check identical lines */
-    if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) && FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
-        (FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) && FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
-        G_debug (2, " -> identical segments" );
-        *x1 = ax1; *y1 = ay1;
-        *x2 = ax2; *y2 = ay2;
-        return 5;
-    /*  'Sort' lines by x1, x2, y1, y2 */
-    if ( bx1 < ax1 )
-        switched = 1;
-    else if ( bx1 == ax1 ) {
-        if ( bx2 < ax2 ) switched = 1;
-        else if ( bx2 == ax2 ) {
-            if ( by1 < ay1 ) switched = 1;
-            else if ( by1 == ay1 ) {
-                if ( by2 < ay2 ) switched = 1; /* by2 != ay2 (would be identical */
-    if (switched) {
-        t = ax1; ax1 = bx1; bx1 = t; t = ay1; ay1 = by1; by1 = t;
-        t = ax2; ax2 = bx2; bx2 = t; t = ay2; ay2 = by2; by2 = t;
-    adx = ax2 - ax1;
-    ady = ay2 - ay1;
-    bdx = bx2 - bx1;
-    bdy = by2 - by1;
-    d  = (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2);
-    d1 = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
-    d2 = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
-    G_debug(2, "    d  = %.18f", d);
-    G_debug(2, "    d1 = %.18f", d1);
-    G_debug(2, "    d2 = %.18f", d2);
-    tola = tol/MAX(fabs(adx), fabs(ady));
-    tolb = tol/MAX(fabs(bdx), fabs(bdy));
-    G_debug(2, "    tol  = %.18f", tol);
-    G_debug(2, "    tola = %.18f", tola);
-    G_debug(2, "    tolb = %.18f", tolb);
-    if (!FZERO(d, tol)) {
-        ra = d1/d;
-        rb = d2/d;
-        G_debug(2, "    not parallel/collinear: ra = %.18f", ra);
-        G_debug(2, "                            rb = %.18f", rb);
-        if ((ra <= -tola) || (ra >= 1+tola) || (rb <= -tolb) || (rb >= 1+tolb)) {
-            G_debug(2, "        no intersection");
-            return 0;
-        ra = MIN(MAX(ra, 0), 1);
-        *x1 = ax1 + ra*(ax2 - ax1);
-        *y1 = ay1 + ra*(ay2 - ay1);
-        G_debug(2, "        intersection %.18f, %.18f", *x1, *y1);
-        return 1;
-    /* segments are parallel or collinear */
-    G_debug (3, " -> parallel/collinear" );
-    if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) { /* lines are parallel */
-        G_debug (2, "  -> parallel" );
-        return 0;
-    /* segments are colinear. check for overlap */
-/*    aa = adx*adx + ady*ady;
-    bb = bdx*bdx + bdy*bdy;
-    t = (ax1-bx1)*bdx + (ay1-by1)*bdy;*/
-    /* Collinear vertical */
-    /* original code assumed lines were not both vertical
-    *  so there is a special case if they are */
-    if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) && FEQUAL(ax1, bx1, tol)) {
-        G_debug(2, "  -> collinear vertical");
-        if (ay1 > ay2) { t=ay1; ay1=ay2; ay2=t;	} /* to be sure that ay1 < ay2 */
-        if (by1 > by2) { t=by1; by1=by2; by2=t; } /* to be sure that by1 < by2 */
-        if (ay1 > by2 || ay2 < by1) {
-            G_debug (2, "   -> no intersection");
-            return 0;
-        /* end points */
-        if (FEQUAL(ay1, by2, tol)) {
-            G_debug(2, "   -> connected by end points");
-            return 1; /* endpoints only */
-        if (FEQUAL(ay2, by1, tol)) {
-            *x1 = ax2; *y1 = ay2;
-            G_debug (2, "  -> connected by end points");
-        /* general overlap */
-        G_debug(3, "   -> vertical overlap");
-        /* a contains b */
-        if (ay1 <= by1 && ay2 >= by2) {
-            G_debug (2, "    -> a contains b" );
-           *x1 = bx1; *y1 = by1;
-            *x2 = bx2; *y2 = by2;
-            if (!switched)
-                return 3;
-            else
-                return 4;
-        /* b contains a */
-        if ( ay1 >= by1 && ay2 <= by2 ) {
-            G_debug (2, "    -> b contains a" );
-            if ( !switched )
-                return 4;
-            else
-                return 3;
-        /* general overlap, 2 intersection points */
-        G_debug (2, "    -> partial overlap" );
-        if ( by1 > ay1 && by1 < ay2 ) { /* b1 in a */
-            if ( !switched ) {
-            } else {
-                *x2 = bx1; *y2 = by1;
-            return 2;
-        if ( by2 > ay1 && by2 < ay2 ) { /* b2 in a */
-                *x1 = bx2; *y1 = by2;
-                *x2 = ax1; *y2 = ay1;
-            } else {
-            return 2;
-        /* should not be reached */
-        G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
-        G_warning("%.15g %.15g", ax1, ay1);
-        G_warning("%.15g %.15g", ax2, ay2);
-        G_warning("x");
-        G_warning("%.15g %.15g", bx1, by1);
-        G_warning("%.15g %.15g", bx2, by2);
-        return 0;
-    G_debug (2, "   -> collinear non vertical" );
-    /* Collinear non vertical */
-    if ( ( bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2 ) ||
-         ( bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2 ) ) {
-        G_debug (2, "   -> no intersection" );
-	return 0;
-    /* there is overlap or connected end points */
-    G_debug (2, "   -> overlap/connected end points" );
-    /* end points */
-    if ( (ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2) ) {
-	return 1;
-    if ( (ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2) ) {
-	return 1;
-    if (ax1 > ax2) { t=ax1; ax1=ax2; ax2=t; t=ay1; ay1=ay2; ay2=t; } /* to be sure that ax1 < ax2 */
-    if (bx1 > bx2) { t=bx1; bx1=bx2; bx2=t; t=by1; by1=by2; by2=t; } /* to be sure that bx1 < bx2 */
-    if ( ax1 <= bx1 && ax2 >= bx2 ) {
-        if ( !switched )
-       	    return 3;
-        else
-            return 4;
-    if ( ax1 >= bx1 && ax2 <= bx2 ) {
-        if ( !switched )
-            return 4;
-        else
-            return 3;
-    /* general overlap, 2 intersection points (lines are not vertical) */
-    if ( bx1 > ax1 && bx1 < ax2 ) { /* b1 is in a */
-	} else {
-	return 2;
-    if ( bx2 > ax1 && bx2 < ax2 ) { /* b2 is in a */
-	} else {
-	return 2;
-    G_warning(("segment_intersection_2d() ERROR (collinear non vertical segments)"));
-    G_warning("x");
-    return 0;
 struct intersection_point {
     double x;
     double y;
@@ -414,21 +152,43 @@
         return (aa->y < bb->y)?-1:((aa->y > bb->y)?1:0);
+/* O(Points->n_points) time */
+double get_epsilon(struct line_pnts *Points) {
+    int i, np;
+    double min, t;
+    double *x, *y;
+    np = Points->n_points;
+    x = Points->x;
+    y = Points->y;
+    min = MAX(fabs(x[1]-x[0]), fabs(y[1]-y[0]));
+    for (i = 1; i <= np-2; i++) {
+        t = MAX(fabs(x[i+1]-x[i]), fabs(y[i+1]-y[i]));
+        if ((t > 0) && (t < min)) {
+            min = t;
+    /* ??? is 0.001 ok ??? */
+    return min*0.000001;
 /* currently O(n*n); future implementation O(nlogn) */
 struct seg_intersections* find_all_intersections(struct line_pnts *Points) {
     int i, j, np;
     int group, t;
     int looped;
-    double EPSILON = 1e-10;
+    double EPSILON = 0.00000001;
     double *x, *y;
     double x1, y1, x2, y2;
-    int res;
+    int res, res2;
+    double x1_, y1_, x2_, y2_;
     struct seg_intersections *si;
     struct seg_intersection_list *il;
     struct intersection_point **sorted;
     G_debug(4, "find_all_intersections()");
-    G_debug(4, "    EPSILON=%.18f", EPSILON);
     x = Points->x;
@@ -436,14 +196,20 @@
     si = create_si_struct(np-1);
-    looped = FEQUAL(x[0], x[np-1], EPSILON) && FEQUAL(y[0], y[np-1], EPSILON);
+    looped = ((x[0] == x[np-1]) && (y[0] == y[np-1]));
     G_debug(4, "    looped=%d", looped);
     G_debug(4, "    finding intersections...");
     for (i = 0; i < np-1; i++) {
         for (j = i+1; j < np-1; j++) {
-            G_debug(3, "        checking %d-%d %d-%d", i, i+1, j, j+1);
-            res = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2, EPSILON);
+            G_debug(3, "        checking %d-%d %d-%d", i, i+1, j, j+1);
+            res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
+/*            res = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2, EPSILON);*/
+/*            res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
+            if (res != res2) {
+                G_debug(0, "res=%d res2=%d", res, res2);
             G_debug(3, "        intersection type = %d", res);
             if (res == 1) {
                 add_ipoint(Points, i, j, x1, y1, si);
@@ -492,8 +258,10 @@
         t = group;
         for (j = i-1; j >= 0; j--) {
             if (!FEQUAL(sorted[j]->x, sorted[i]->x, EPSILON))
+/*            if (!almost_equal(sorted[j]->x, sorted[i]->x, 16))*/
                 break;
             if (FEQUAL(sorted[j]->y, sorted[i]->y, EPSILON)) {
+/*            if (almost_equal(sorted[j]->y, sorted[i]->y, 16)) {*/
                 t = sorted[j]->group;
                 break;
@@ -508,7 +276,6 @@
     G_debug(4, "    postprocessing...done");
     /* output contents of si */
     for (i = 0; i < si->ilcount; i++) {
         G_debug(4, "%d-%d :", i, i+1);
         for (j = 0; j < si->il[i].count; j++) {
Added: grass-addons/vector/v.parallel2/e_intersect.c
--- grass-addons/vector/v.parallel2/e_intersect.c	                        (rev 0)
+++ grass-addons/vector/v.parallel2/e_intersect.c	2008-08-09 21:15:04 UTC (rev 32656)
@@ -0,0 +1,565 @@
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <gmp.h>
+#define SWAP(a,b) {t = a; a = b; b = t;}
+mpf_t p11, p12, p21, p22, t1, t2;
+mpf_t dd, dda, ddb, delta;
+int initialized = 0;
+void initialize_mpf_vars() {
+    mpf_set_default_prec(2048);
+    mpf_init(p11);
+    mpf_init(p12);
+    mpf_init(p21);
+    mpf_init(p22);
+    mpf_init(t1);
+    mpf_init(t2);
+    mpf_init(dd);
+    mpf_init(dda);
+    mpf_init(ddb);
+    mpf_init(delta);
+    initialized = 1;
+  Caclulates:
+  |a11-b11  a12-b12|
+  |a21-b21  a22-b22|
+void det22(mpf_t rop, double a11, double b11, double a12, double b12, double a21, double b21, double a22, double b22) {
+    mpf_set_d(t1, a11);
+    mpf_set_d(t2, b11);
+    mpf_sub(p11, t1, t2);
+    mpf_set_d(t1, a12);
+    mpf_set_d(t2, b12);
+    mpf_sub(p12, t1, t2);
+    mpf_set_d(t1, a21);
+    mpf_set_d(t2, b21);
+    mpf_sub(p21, t1, t2);
+    mpf_set_d(t1, a22);
+    mpf_set_d(t2, b22);
+    mpf_sub(p22, t1, t2);
+    mpf_mul(t1, p11, p22);
+    mpf_mul(t2, p12, p21);
+    mpf_sub(rop, t1, t2);
+    return;
+void swap(double *a, double *b) {
+    double t = *a;
+    *a = *b;
+    *b = t;
+    return;
+/* multi-precision version */
+int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+    double *x1, double *y1, double *x2, double *y2)
+    double t;
+    double max_ax, min_ax, max_ay, min_ay;
+    double max_bx, min_bx, max_by, min_by;
+    int sgn_d, sgn_da, sgn_db;
+    int vertical;
+    int f11, f12, f21, f22;
+    mp_exp_t exp;
+    char *s;
+    if (!initialized)
+        initialize_mpf_vars();
+    /* TODO: Works for points ? */
+    G_debug(3, "segment_intersection_2d_e()");
+    G_debug(4, "    ax1  = %.18f, ay1  = %.18f", ax1, ay1);
+    G_debug(4, "    ax2  = %.18f, ay2  = %.18f", ax2, ay2);
+    G_debug(4, "    bx1  = %.18f, by1  = %.18f", bx1, by1);
+    G_debug(4, "    bx2  = %.18f, by2  = %.18f", bx2, by2);
+    f11 = ((ax1 == bx1) && (ay1 == by1));
+    f12 = ((ax1 == bx2) && (ay1 == by2));
+    f21 = ((ax2 == bx1) && (ay2 == by1));
+    f22 = ((ax2 == bx2) && (ay2 == by2));
+    /* Check for identical segments */
+    if ((f11 && f22) || (f12 && f21)) {
+        G_debug (3, "    identical segments" );
+        *x1 = ax1; *y1 = ay1;
+        *x2 = ax2; *y2 = ay2;
+        return 5;
+    /* Check for identical endpoints */
+    if (f11 || f12) {
+        G_debug (3, "    connected by endpoints" );
+        return 1;
+    if (f21 || f22) {
+        *x1 = ax2; *y1 = ay2;
+        return 1;
+    if ((fmax(ax1, ax2) < fmin(bx1, bx2)) || (fmax(bx1, bx2) < fmin(ax1, ax2))) {
+        G_debug(3, "    no intersection (disjoint bounding boxes)");
+        return 0;
+    if ((fmax(ay1, ay2) < fmin(by1, by2)) || (fmax(by1, by2) < fmin(ay1, ay2))) {
+        return 0;
+    det22(dd,  ax2, ax1, bx1, bx2, ay2, ay1, by1, by2);
+    sgn_d = mpf_sgn(dd);
+    if (sgn_d != 0) {
+        G_debug(3, "    general position");
+        det22(dda, bx1, ax1, bx1, bx2, by1, ay1, by1, by2);
+        sgn_da = mpf_sgn(dda);
+        /*mpf_div(rra, dda, dd);
+        mpf_div(rrb, ddb, dd);
+        s = mpf_get_str(NULL, &exp, 10, 40, rra);
+        G_debug(4, "        ra = %sE%d", (s[0]==0)?"0":s, exp);
+        s = mpf_get_str(NULL, &exp, 10, 24, rrb);
+        G_debug(4, "        rb = %sE%d", (s[0]==0)?"0":s, exp);
+        if (sgn_d > 0) {
+            if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
+                G_debug(3, "        no intersection");
+                return 0;
+            det22(ddb, ax2, ax1, bx1, ax1, ay2, ay1, by1, ay1);
+            sgn_db = mpf_sgn(ddb);
+            if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
+                return 0;
+        else { /* if sgn_d < 0 */
+            if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
+                return 0;
+            if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
+                return 0;
+        G_debug(3, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));
+        G_debug(3, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));
+        mpf_set_d(delta, ax2 - ax1);
+        mpf_mul(t1, dda, delta);
+        mpf_div(t2, t1, dd);
+        *x1 = ax1 + mpf_get_d(t2);
+        mpf_set_d(delta, ay2 - ay1);
+        *y1 = ay1 + mpf_get_d(t2);
+        G_debug(3, "        intersection %.16g, %.16g", *x1, *y1);
+        return 1;
+    /* segments are parallel or collinear */
+    if (sgn_da != 0) {
+        /* segments are parallel */
+        G_debug(3, "    parallel segments");
+        return 0;
+    /* segments are colinear. check for overlap */
+    /* swap endpoints if needed */
+    /* if segments are vertical, we swap x-coords with y-coords */
+    vertical = 0;
+    if (ax1 > ax2) {
+        SWAP(ax1, ax2);
+        SWAP(ay1, ay2);
+    } else if (ax1 == ax2) {
+        vertical = 1;
+        if (ay1 > ay2)
+            SWAP(ay1, ay2);
+        SWAP(ax1, ay1);
+        SWAP(ax2, ay2);
+    if (bx1 > bx2) {
+        SWAP(bx1, bx2);
+        SWAP(by1, by2);
+    } else if (bx1 == bx2) {
+        if (by1 > by2)
+            SWAP(by1, by2);
+        SWAP(bx1, by1);
+        SWAP(bx2, by2);
+    G_debug(3, "    collinear segments");
+    if ((bx2 < ax1) || (bx1 > ax2)) {
+        return 0;
+    /* there is overlap or connected end points */
+    G_debug(3, "        overlap");
+    /* a contains b */
+    if ((ax1 < bx1) && (ax2 > bx2)) {
+        G_debug(3, "            a contains b");
+        if (!vertical) {
+            *x1 = bx1; *y1 = by1;
+            *x2 = bx2; *y2 = by2;
+        else {
+            *x1 = by1; *y1 = bx1;
+            *x2 = by2; *y2 = bx2;
+  	    return 3;
+    /* b contains a */
+    if ((ax1 > bx1) && (ax2 < bx2)) {
+        G_debug(3, "            b contains a");
+        if (!vertical) {
+        else {
+  	    return 4;
+    /* general overlap, 2 intersection points */
+    G_debug(3, "        partial overlap");
+    if ((bx1 > ax1) && (bx1 < ax2)) { /* b1 is in a */
+        if (!vertical) {
+        else {
+            *x2 = ay2; *y2 = ax2;
+  	    return 2;
+    if ((bx2 > ax1) && (bx2 < ax2)) { /* b2 is in a */
+        if (!vertical) {
+            *x1 = bx2; *y1 = by2;
+            *x2 = ax1; *y2 = ay1;
+        else {
+            *x1 = by2; *y1 = bx2;
+            *x2 = ay1; *y2 = ax1;
+  	    return 2;
+    /* should not be reached */
+    G_warning(("segment_intersection_2d() ERROR (should not be reached)"));
+    G_warning("%.16g %.16g", ax1, ay1);
+    G_warning("%.16g %.16g", ax2, ay2);
+    G_warning("x");
+    G_warning("%.16g %.16g", bx1, by1);
+    G_warning("%.16g %.16g", bx2, by2);
+    return 0;
+/* tollerance aware version */
+/* TODO: fix all ==s left */
+int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+    double *x1, double *y1, double *x2, double *y2, double tol)
+    double tola, tolb;
+    double d, d1, d2, ra, rb, t;
+    int    switched = 0;
+    G_debug(4, "segment_intersection_2d()");
+    /* Check identical lines */
+    if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) && FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
+        (FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) && FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
+        G_debug (2, " -> identical segments" );
+        return 5;
+    /*  'Sort' lines by x1, x2, y1, y2 */
+    if ( bx1 < ax1 )
+        switched = 1;
+    else if ( bx1 == ax1 ) {
+        if ( bx2 < ax2 ) switched = 1;
+        else if ( bx2 == ax2 ) {
+            if ( by1 < ay1 ) switched = 1;
+            else if ( by1 == ay1 ) {
+                if ( by2 < ay2 ) switched = 1; /* by2 != ay2 (would be identical */
+    if (switched) {
+        t = ax1; ax1 = bx1; bx1 = t; t = ay1; ay1 = by1; by1 = t;
+        t = ax2; ax2 = bx2; bx2 = t; t = ay2; ay2 = by2; by2 = t;
+    d  = (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2);
+    d1 = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
+    d2 = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
+    G_debug(2, "    d  = %.18f", d);
+    G_debug(2, "    d1 = %.18f", d1);
+    G_debug(2, "    d2 = %.18f", d2);
+    tola = tol/fmax(fabs(ax2-ax1), fabs(ay2-ay1));
+    tolb = tol/fmax(fabs(bx2-bx1), fabs(by2-by1));
+    G_debug(2, "    tol  = %.18f", tol);
+    G_debug(2, "    tola = %.18f", tola);
+    G_debug(2, "    tolb = %.18f", tolb);
+    if (!FZERO(d, tol)) {
+        ra = d1/d;
+        rb = d2/d;
+        G_debug(2, "    not parallel/collinear: ra = %.18f", ra);
+        G_debug(2, "                            rb = %.18f", rb);
+        if ((ra <= -tola) || (ra >= 1+tola) || (rb <= -tolb) || (rb >= 1+tolb)) {
+            G_debug(2, "        no intersection");
+            return 0;
+        ra = fmin(fmax(ra, 0), 1);
+        *x1 = ax1 + ra*(ax2 - ax1);
+        *y1 = ay1 + ra*(ay2 - ay1);
+        G_debug(2, "        intersection %.18f, %.18f", *x1, *y1);
+        return 1;
+    G_debug (3, " -> parallel/collinear" );
+    if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) { /* lines are parallel */
+        G_debug (2, "  -> parallel" );
+        return 0;
+/*    aa = adx*adx + ady*ady;
+    bb = bdx*bdx + bdy*bdy;
+    t = (ax1-bx1)*bdx + (ay1-by1)*bdy;*/
+    /* Collinear vertical */
+    /* original code assumed lines were not both vertical
+    *  so there is a special case if they are */
+    if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) && FEQUAL(ax1, bx1, tol)) {
+        G_debug(2, "  -> collinear vertical");
+        if (ay1 > ay2) { t=ay1; ay1=ay2; ay2=t;	} /* to be sure that ay1 < ay2 */
+        if (by1 > by2) { t=by1; by1=by2; by2=t; } /* to be sure that by1 < by2 */
+        if (ay1 > by2 || ay2 < by1) {
+            G_debug (2, "   -> no intersection");
+            return 0;
+        /* end points */
+        if (FEQUAL(ay1, by2, tol)) {
+            G_debug(2, "   -> connected by end points");
+            return 1; /* endpoints only */
+        if (FEQUAL(ay2, by1, tol)) {
+            G_debug (2, "  -> connected by end points");
+        /* general overlap */
+        G_debug(3, "   -> vertical overlap");
+        if (ay1 <= by1 && ay2 >= by2) {
+            G_debug (2, "    -> a contains b" );
+            if (!switched)
+                return 3;
+            else
+                return 4;
+        if ( ay1 >= by1 && ay2 <= by2 ) {
+            G_debug (2, "    -> b contains a" );
+            if ( !switched )
+                return 4;
+            else
+                return 3;
+        G_debug (2, "    -> partial overlap" );
+        if ( by1 > ay1 && by1 < ay2 ) { /* b1 in a */
+            if ( !switched ) {
+            } else {
+                *x2 = bx1; *y2 = by1;
+            return 2;
+        if ( by2 > ay1 && by2 < ay2 ) { /* b2 in a */
+            } else {
+            return 2;
+        G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
+        G_warning("%.15g %.15g", ax1, ay1);
+        G_warning("%.15g %.15g", ax2, ay2);
+        G_warning("x");
+        G_warning("%.15g %.15g", bx1, by1);
+        G_warning("%.15g %.15g", bx2, by2);
+        return 0;
+    G_debug (2, "   -> collinear non vertical" );
+    /* Collinear non vertical */
+    if ( ( bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2 ) ||
+         ( bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2 ) ) {
+        G_debug (2, "   -> no intersection" );
+	return 0;
+    G_debug (2, "   -> overlap/connected end points" );
+    /* end points */
+    if ( (ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2) ) {
+	return 1;
+    if ( (ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2) ) {
+	return 1;
+    if (ax1 > ax2) { t=ax1; ax1=ax2; ax2=t; t=ay1; ay1=ay2; ay2=t; } /* to be sure that ax1 < ax2 */
+    if (bx1 > bx2) { t=bx1; bx1=bx2; bx2=t; t=by1; by1=by2; by2=t; } /* to be sure that bx1 < bx2 */
+    if ( ax1 <= bx1 && ax2 >= bx2 ) {
+        if ( !switched )
+       	    return 3;
+        else
+            return 4;
+    if ( ax1 >= bx1 && ax2 <= bx2 ) {
+        if ( !switched )
+            return 4;
+        else
+            return 3;
+    /* general overlap, 2 intersection points (lines are not vertical) */
+    if ( bx1 > ax1 && bx1 < ax2 ) { /* b1 is in a */
+	} else {
+	return 2;
+    if ( bx2 > ax1 && bx2 < ax2 ) { /* b2 is in a */
+	} else {
+	return 2;
+    G_warning(("segment_intersection_2d() ERROR (collinear non vertical segments)"));
+    G_warning("x");
+    return 0;
+#define N 52 /* double's mantisa size in bits */
+/* a and b are different in at most <bits> significant digits */
+int almost_equal(double a, double b, int bits) {
+    int ea, eb, e;
+    if (a == b)
+        return 1;
+    if (a == 0 || b == 0) {
+        /* return (0 < -N+bits); */
+        return (bits > N);
+    frexp(a, &ea);
+    frexp(b, &eb);
+    if (ea != eb)
+        return (bits > N + abs(ea-eb));
+    frexp(a-b, &e);
+    return (e < ea-N+bits);
Added: grass-addons/vector/v.parallel2/e_intersect.h
--- grass-addons/vector/v.parallel2/e_intersect.h	                        (rev 0)
+++ grass-addons/vector/v.parallel2/e_intersect.h	2008-08-09 21:15:04 UTC (rev 32656)
@@ -0,0 +1,15 @@
+#ifndef E_INTERSECT_H
+#define E_INTERSECT_H
+#define FZERO(X, TOL) (fabs(X)<TOL)
+#define FEQUAL(X, Y, TOL) (fabs(X-Y)<TOL)
+    double *x1, double *y1, double *x2, double *y2);
+    double *x1, double *y1, double *x2, double *y2, double tol);
+int almost_equal(double a, double b, int bits);
+#endif
Modified: grass-addons/vector/v.parallel2/main.c
--- grass-addons/vector/v.parallel2/main.c	2008-08-09 13:21:36 UTC (rev 32655)
+++ grass-addons/vector/v.parallel2/main.c	2008-08-09 21:15:04 UTC (rev 32656)
@@ -56,7 +56,7 @@
     distb_opt->key = "minordistance";
     distb_opt->type =  TYPE_DOUBLE;
     distb_opt->required = NO;
-    dista_opt->options = "0-100000000";
+    distb_opt->options = "0-100000000";
     distb_opt->multiple = NO;
     distb_opt->description = _("Offset along minor axis in map units");
@@ -121,7 +121,7 @@
     else
         side = 0;
-    Vect_set_open_level (2);
+    Vect_set_open_level(2);
     Vect_open_old (&In, in_opt->answer, "");
     Vect_open_new (&Out, out_opt->answer, 0);
     Vect_copy_head_data (&In, &Out);
@@ -155,7 +155,7 @@
             else {
-                parallel_line_b(Points, da, db, dalpha, round_flag->answer, 1, tolerance, &oPoints, &iPoints, &inner_count);
+                Vect_line_buffer2(Points, da, db, dalpha, round_flag->answer, 1, tolerance, &oPoints, &iPoints, &inner_count);
                 Vect_write_line(&Out, ltype, oPoints, Cats);
                 for (j = 0; j < inner_count; j++) {
                     Vect_write_line(&Out, ltype, iPoints[j], Cats);
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	2008-08-09 13:21:36 UTC (rev 32655)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-08-09 21:15:04 UTC (rev 32656)
@@ -343,6 +343,7 @@
     for (i = 0; i <= np-2; i++)
+        G_debug(4, "point %d, segment %d-%d", i, i, i+1);
         /* save the old values */
         if (!round) {
             a0 = a1;
@@ -379,13 +380,17 @@
             norm_vector(0, 0, vx, vy, &tx, &ty);
             elliptic_tangent(side*tx, side*ty, da, db, dalpha, &tx, &ty);
             Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
+            G_debug(4, " append point (c) x=%.16f y=%.16f", x[i] + wx + tx, y[i] + wy + ty);
             Vect_append_point(nPoints, nx + tx, ny + ty, 0); /* nx == x[i] + vx, ny == y[i] + vy */
+            G_debug(4, " append point (c) x=%.16f y=%.16f", nx + tx, ny + ty);
         if ((!turns180) && (!round) && (!inner_corner)) {
             res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
-            if (res == 1)
+            if (res == 1) {
                 Vect_append_point(nPoints, rx, ry, 0);
+                G_debug(4, " append point (o) x=%.16f y=%.16f", rx, ry);
             else
                 G_fatal_error("unexpected result of line_intersection()");
@@ -408,15 +413,19 @@
             nsegments = (int)(delta_phi/angular_tol) + 1;
             angular_step = side*(delta_phi/nsegments);
+            phi1 += angular_step;
             for (j = 1; j <= nsegments-1; j++) {
                 elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx, &ty);
                 Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
+                G_debug(4, " append point (r) x=%.16f y=%.16f", x[i] + tx, y[i] + ty);
         Vect_append_point(nPoints, nx, ny, 0);
+        G_debug(4, " append point (s) x=%.16f y=%.16f", nx, ny);
         Vect_append_point(nPoints, mx, my, 0);
+        G_debug(4, " append point (s) x=%.16f y=%.16f", mx, my);
     /* close the output line */
@@ -465,7 +474,6 @@
     while (1) {
         Vect_append_point(nPoints, vert0->x, vert0->y, 0);
         G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0, v, eside, edge->v1, edge->v2);
-        G_debug(4, "ec: edge=%X, first=%X", edge, first);
         G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
         /* mark current edge as visited on the appropriate side */
@@ -502,17 +510,35 @@
         /* if line end is reached (no other edges at curr vertex) */
         if (opt_flag) {
-            if (stop_at_line_end)
+            if (stop_at_line_end) {
+                G_debug(3, "    end has been reached, will stop here");
                 break;
             else {
                 opt_j = 0; /* the only edge of vert is vert->edges[0] */
                 opt_side = -eside; /* go to the other side of the current edge */
+                G_debug(3, "    end has been reached, turning around");
+        /* break condition */
         if ((vert->edges[opt_j] == first) && (opt_side == side))
             break;
+        if (opt_side == 1) {
+            if (vert->edges[opt_j]->visited_right) {
+                G_warning("next edge was visited but it is not the first one !!! breaking loop");
+                G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v, (edge->v1 == v)?(edge->v2):(edge->v1), opt_side, vert->edges[opt_j]->v1, vert->edges[opt_j]->v2);
+                break;
+        else {
+            if (vert->edges[opt_j]->visited_left) {
+                break;
         edge = vert->edges[opt_j];
         eside = opt_side;
         v0 = v;
@@ -683,6 +709,29 @@
     return 0;
+/* returns 0 for ccw, non-zero for cw
+int get_polygon_orientation(const double *x, const double *y, int n) {
+    double x1,y1,x2,y2;
+    double area;
+    x2 = x[n-1];
+    y2 = y[n-1];
+    area = 0;
+    while (--n >= 0)
+        x1 = x2;
+        y1 = y2;
+        x2 = *x++;
+        y2 = *y++;
+        area += (y2+y1)*(x2-x1);
+    return signbit(area);
 /* internal */
 void add_line_to_array(struct line_pnts *Points, struct line_pnts ***arrPoints, int *count, int *allocated, int more) {
     if (*allocated == *count) {
@@ -694,29 +743,41 @@
     return;
-void parallel_line_b(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
-    struct planar_graph *pg, *pg2;
-    struct line_pnts *tPoints, *sPoints, *cPoints;
+void destroy_lines_array(struct line_pnts **arr, int count) {
+    int i;
+    for (i = 0; i < count; i++)
+        Vect_destroy_line_struct(arr[i]);
+    G_free(arr);
+/* area_outer and area_isles[i] must be closed non self-intersecting lines
+   side: 0 - auto, 1 - right, -1 left
+void buffer_lines(struct line_pnts *area_outer, struct line_pnts **area_isles, int isles_count, int side, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+    struct planar_graph *pg2;
+    struct line_pnts *sPoints, *cPoints;
     struct line_pnts **arrPoints;
     int i, count = 0;
     int res, winding;
+    int auto_side;
     int more = 8;
     int allocated = 0;
     double px, py;
-    G_debug(4, "parallel_line_b()");
+    G_debug(4, "buffer_lines()");
+    auto_side = (side == 0);
     /* initializations */
-    tPoints = Vect_new_line_struct();
     sPoints = Vect_new_line_struct();
     cPoints = Vect_new_line_struct();
     arrPoints = NULL;
-    pg = pg_create(Points);
     /* outer contour */
     *oPoints = Vect_new_line_struct();
-    extract_outer_contour(pg, 0, tPoints);
-    convolution_line(tPoints, da, db, dalpha, RIGHT_SIDE, round, caps, tol, sPoints);
+    if (auto_side)
+        side = get_polygon_orientation(area_outer->x, area_outer->y, area_outer->n_points-1)?LEFT_SIDE:RIGHT_SIDE;
+    convolution_line(area_outer, da, db, dalpha, side, round, caps, tol, sPoints);
     pg2 = pg_create(sPoints);
     extract_outer_contour(pg2, 0, *oPoints);
     res = extract_inner_contour(pg2, &winding, cPoints);
@@ -730,21 +791,22 @@
     pg_destroy_struct(pg2);
     /* inner contours */
-    res = extract_inner_contour(pg, &winding, tPoints);
-    while (res != 0) {
+    for (i = 0; i < isles_count; i++) {
+        if (auto_side)
+            side = get_polygon_orientation(area_isles[i]->x, area_isles[i]->y, area_isles[i]->n_points-1)?RIGHT_SIDE:LEFT_SIDE;
+        convolution_line(area_isles[i], da, db, dalpha, side, round, caps, tol, sPoints);
         extract_outer_contour(pg2, 0, cPoints);
         while (res != 0) {
             if (winding == -1) {
                 /* we need to check if the area is in the buffer.
-                   I simplfied convolution_line, so that it runs faster,
+                   I've simplfied convolution_line(), so that it runs faster,
                    however that leads to ocasional problems */
-                if (Vect_point_in_poly(cPoints->x[0], cPoints->y[0], tPoints)) {
+                if (Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_isles[i])) {
                     if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
                         G_fatal_error("Vect_get_point_in_poly() failed.");
-                    if (!point_in_buf(tPoints, px, py, da, db, dalpha)) {
+                    if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
                         add_line_to_array(cPoints, &arrPoints, &count, &allocated, more);
@@ -777,22 +839,160 @@
             Vect_copy_xyz_to_pnts(arrPoints[count], arrPoints2[i]->x, arrPoints2[i]->y, arrPoints2[i]->z, arrPoints2[i]->n_points);
             count++;
     arrPoints = G_realloc(arrPoints, count*sizeof(struct line_pnts *));
     *inner_count = count;
     *iPoints = arrPoints;
-    Vect_destroy_line_struct(tPoints);
     Vect_destroy_line_struct(sPoints);
     Vect_destroy_line_struct(cPoints);
+    return;
+  \fn void Vect_line_buffer(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+  \brief Creates buffer around the line Points.
+  \param InPoints input line
+  \param da distance along major axis
+  \param da distance along minor axis
+  \param dalpha angle between 0x and major axis
+  \param round make corners round
+  \param caps add caps at line ends
+  \param tol maximum distance between theoretical arc and output segments
+  \param oPoints output polygon outer border (ccw order)
+  \param inner_count number of holes
+  \param iPoints array of output polygon's holes (cw order)
+void Vect_line_buffer2(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+    struct planar_graph *pg;
+    struct line_pnts *tPoints, *outer;
+    struct line_pnts **isles;
+    int isles_count = 0;
+    int res, winding;
+    int more = 8;
+    int isles_allocated = 0;
+    G_debug(4, "Vect_line_buffer()");
+    /* initializations */
+    tPoints = Vect_new_line_struct();
+    isles = NULL;
+    pg = pg_create(Points);
+    /* outer contour */
+    outer = Vect_new_line_struct();
+    extract_outer_contour(pg, 0, outer);
+    /* inner contours */
+    res = extract_inner_contour(pg, &winding, tPoints);
+    while (res != 0) {
+        add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated, more);
+    buffer_lines(outer, isles, isles_count, RIGHT_SIDE, da, db, dalpha, round, caps, tol, oPoints, iPoints, inner_count);
+    Vect_destroy_line_struct(tPoints);
+    Vect_destroy_line_struct(outer);
+    destroy_lines_array(isles, isles_count);
     pg_destroy_struct(pg);
+    return;
+void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+    int i, res, winding, isle;
+    int more = 8;
+    double max = fmax(da, db);
+    G_debug(4, "Vect_area_buffer()");
+    isles_count = Vect_get_area_num_isles(Map, area);
+    isles_allocated = isles_count;
+    isles = G_malloc(isles_allocated*sizeof(struct line_pnts *));
+    Vect_get_area_points(Map, area, outer);
+    Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
+        isle = Vect_get_area_isle(Map, area, i);
+        Vect_get_isle_points(Map, isle, tPoints);
+        /* Check if the isle is big enough */
+        if (Vect_line_length(tPoints) < 2*PI*max)
+            continue;
+        Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0], tPoints->z[0]);
+    buffer_lines(outer, isles, isles_count, 0, da, db, dalpha, round, caps, tol, oPoints, iPoints, inner_count);
     return;
+  \fn void Vect_point_buffer(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts *nPoints) {
+  \brief Creates buffer around the point (px,py).
+  \param px input point x-coordinate
+  \param py input point y-coordinate
+  \param nPoints output polygon outer border (ccw order)
+void Vect_point_buffer2(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts *nPoints) {
+    double tx, ty;
+    double angular_tol, angular_step, phi1;
+    int j, nsegments;
+    Vect_reset_line(nPoints);
+    dalpha *= PI/180; /* convert dalpha from degrees to radians */
+    if (round || (!round)) {
+        angular_tol = angular_tolerance(tol, da, db);
+        nsegments = (int)(2*PI/angular_tol) + 1;
+        angular_step = 2*PI/nsegments;
+        phi1 = 0;
+        for (j = 0; j < nsegments; j++) {
+            elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx, &ty);
+            Vect_append_point(nPoints, px + tx, py + ty, 0);
+    else {
+    /* close the output line */
+    Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0], nPoints->z[0]);
   \fn void Vect_line_parallel2 ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
                        struct line_pnts *OutPoints )
@@ -815,112 +1015,3 @@
     return;
-  \fn void Vect_line_buffer ( struct line_pnts *InPoints, double distance, double tolerance,
-                              struct line_pnts *OutPoints )
-  \brief Create buffer around the line line.
-         Buffer is closed counter clockwise polygon.
-         Warning: output line may contain loops!
-  \param InPoints input line
-  \param distance
-  \param tolerance maximum distance between theoretical arc and polygon segments
-  \param OutPoints output line
-void
-Vect_line_buffer ( struct line_pnts *InPoints, double distance, double tolerance,
-    double dangle;
-    int    side, npoints;
-    static struct line_pnts *Points = NULL;
-    static struct line_pnts *PPoints = NULL;
-    distance = fabs (distance );
-    dangle = 2 * acos( 1-tolerance/fabs(distance) ); /* angle step */
-    if ( Points == NULL )
-        Points = Vect_new_line_struct();
-    if ( PPoints == NULL )
-        PPoints = Vect_new_line_struct();
-    /* Copy and prune input */
-    Vect_reset_line ( Points );
-    Vect_append_points ( Points, InPoints, GV_FORWARD );
-    Vect_line_prune ( Points );
-    Vect_reset_line ( OutPoints );
-    npoints = Points->n_points;
-    if ( npoints <= 0 ) {
-	return;
-    } else if ( npoints == 1 ) { /* make a circle */
-	double angle, x, y;
-	for ( angle = 0; angle < 2*PI; angle += dangle ) {
-	    x = Points->x[0] + distance * cos( angle );
-	    y = Points->y[0] + distance * sin( angle );
-	    Vect_append_point ( OutPoints, x, y, 0 );
-	/* Close polygon */
-	Vect_append_point ( OutPoints, OutPoints->x[0], OutPoints->y[0], 0 );
-    } else { /* 2 and more points */
-	for ( side = 0; side < 2; side++ ) {
-	    double angle, sangle;
-	    double lx1, ly1, lx2, ly2;
-	    double x, y, nx, ny, sx, sy, ex, ey;
-	    /* Parallel on one side */
-	    if ( side == 0 ) {
-		Vect_line_parallel ( Points, distance, tolerance, 0, PPoints );
-		Vect_append_points ( OutPoints, PPoints, GV_FORWARD );
-	    } else {
-		Vect_line_parallel ( Points, -distance, tolerance, 0, PPoints );
-		Vect_append_points ( OutPoints, PPoints, GV_BACKWARD );
-	    /* Arc at the end */
-	    /* 2 points at theend of original line */
-		lx1 = Points->x[npoints-2];
-		ly1 = Points->y[npoints-2];
-		lx2 = Points->x[npoints-1];
-		ly2 = Points->y[npoints-1];
-	    } else {
-		lx1 = Points->x[1];
-		ly1 = Points->y[1];
-		lx2 = Points->x[0];
-		ly2 = Points->y[0];
-	    /* normalized vector */
-	    norm_vector( lx1, ly1, lx2, ly2, &nx, &ny);
-	    /* starting point */
-	    sangle = atan2 ( -nx, ny ); /* starting angle */
-	    sx  = lx2 + ny * distance;
-	    sy  = ly2 - nx * distance;
-	    /* end point */
-	    ex  = lx2 - ny * distance;
-	    ey  = ly2 + nx * distance;
-	    Vect_append_point ( OutPoints, sx, sy, 0 );
-	    /* arc */
-	    for ( angle = dangle; angle < PI; angle += dangle ) {
-		x = lx2 + distance * cos( sangle + angle );
-		y = ly2 + distance * sin( sangle + angle );
-	    Vect_append_point ( OutPoints, ex, ey, 0 );
-    Vect_line_prune ( OutPoints );
