[GRASS-SVN] r32664 - grass/trunk/gui/wxpython/gui_modules
Sun Aug 10 08:44:14 EDT 2008
Author: martinl
Date: 2008-08-10 08:44:13 -0400 (Sun, 10 Aug 2008)
New Revision: 32664
   grass/trunk/gui/wxpython/gui_modules/utils.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: check all mapsets in search patch when given layer name is not qualified
	(merge from devbr6, r32663)
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py	2008-08-10 10:39:01 UTC (rev 32663)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py	2008-08-10 12:44:13 UTC (rev 32664)
@@ -17,6 +17,8 @@
 import os
 import sys
+import grass
 import globalvar
 import gcmd
 import grassenv
@@ -57,12 +59,16 @@
     except:
         return None
-def GetLayerNameFromCmd(dcmd, fullyQualified=False, param=None):
+def GetLayerNameFromCmd(dcmd, fullyQualified=False, param=None,
+                        layerType=None):
     """Get map name from GRASS command
     @param dcmd GRASS command (given as list)
     @param fullyQualified change map name to be fully qualified
     @param force parameter otherwise 'input'/'map'
+    @param update change map name in command
+    @param layerType check also layer type ('raster', 'vector', '3d-raster', ...)
     @return map name
     @return '' if no map name found in command
@@ -94,10 +100,23 @@
         if idx < len(dcmd):
             mapname = dcmd[idx].split('=')[1]
             if fullyQualified and '@' not in mapname:
-                dcmd[idx] = dcmd[idx].split('=')[0] + '=' + \
-                    mapname +  '@' + grassenv.GetGRASSVariable('MAPSET')
-                mapname = dcmd[idx].split('=')[1]
+                if layerType in ('raster', 'vector', '3d-raster'):
+                    try:
+                        if layerType == 'raster':
+                            findType = 'cell'
+                        else:
+                            findType = layerType
+                        result = grass.find_file(mapname, element=findType)
+                    except AttributeError, e: # not found
+                        return ''
+                    if result:
+                        mapname = result['fullname']
+                    else:
+                        mapname += '@' + grassenv.GetGRASSVariable('MAPSET')
+                else:
+                dcmd[idx] = dcmd[idx].split('=')[0] + '=' + mapname
     return mapname
 def GetValidLayerName(name):
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-10 10:39:01 UTC (rev 32663)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-10 12:44:13 UTC (rev 32664)
@@ -1131,8 +1131,18 @@
         # set layer text to map name
         if dcmd:
-            opacity = int(self.GetPyData(layer)[0]['maplayer'].GetOpacity(float=True) * 100)
-            mapname = utils.GetLayerNameFromCmd(dcmd, fullyQualified=True)
+            mapLayer = self.GetPyData(layer)[0]['maplayer']
+            opacity = int(mapLayer.GetOpacity(float=True) * 100)
+            mapname = utils.GetLayerNameFromCmd(dcmd, layerType=mapLayer.type,
+                                                fullyQualified=True)
+            if not mapname:
+                wx.MessageBox(parent=self,
+                              message=_("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd),
+                              caption=_("Error"),
+                              style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                return
             self.SetItemText(layer, mapname + ' (opacity: ' + str(opacity) + '%)')
         # update layer data
@@ -1142,12 +1152,9 @@
             self.GetPyData(layer)[0]['cmd'] = dcmd
         self.GetPyData(layer)[0]['propwin'] = propwin
-        # check layer as active
-        # self.CheckItem(layer, checked=True)
         # change parameters for item in layers list in render.Map
         self.ChangeLayer(layer)
         if self.mapdisplay.toolbars['nviz'] and dcmd:
             # update nviz session
