[GRASS-SVN] r32673 - in grass/branches/develbranch_6: display/d.vect gui/wxpython/gui_modules include lib/gis
Mon Aug 11 04:47:24 EDT 2008
Author: martinl
Date: 2008-08-11 04:47:24 -0400 (Mon, 11 Aug 2008)
New Revision: 32673
   grass/branches/develbranch_6/display/d.vect/main.c
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
   grass/branches/develbranch_6/include/gis.h
   grass/branches/develbranch_6/lib/gis/parser.c
gislib: new GISPROMPT_DBCOLUMN, used in wxGUI menuform module
standardize column parameter in d.vect
Modified: grass/branches/develbranch_6/display/d.vect/main.c
--- grass/branches/develbranch_6/display/d.vect/main.c	2008-08-11 00:06:32 UTC (rev 32672)
+++ grass/branches/develbranch_6/display/d.vect/main.c	2008-08-11 08:47:24 UTC (rev 32673)
@@ -171,14 +171,10 @@
     fcolor_opt->guisection = _("Colors");
     fcolor_opt->gisprompt = GISPROMPT_COLOR;
-    rgbcol_opt = G_define_option();
+    rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
     rgbcol_opt->key = "rgb_column";
-    rgbcol_opt->type = TYPE_STRING;
-    rgbcol_opt->required = NO;
-    rgbcol_opt->multiple = NO;
     rgbcol_opt->guisection = _("Colors");
-    rgbcol_opt->description =
-	_("Name of color definition column (for use with -a flag)");
+    rgbcol_opt->description = _("Name of color definition column (for use with -a flag)");
     rgbcol_opt->answer = "GRASSRGB";
     zcol_opt = G_define_option();
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-08-11 00:06:32 UTC (rev 32672)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-08-11 08:47:24 UTC (rev 32673)
@@ -1125,7 +1125,8 @@
                 which_sizer.Add(item=txt, proportion=0,
                                 flag=wx.ADJUST_MINSIZE | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
                 # element selection tree combobox (maps, icons, regions, etc.)
-                if p.get('prompt','') != 'color' and p.get('element', '') != 'file':
+                if p.get('prompt','') not in ('color', 'dbcolumn') and \
+                       p.get('element', '') != 'file':
                     if p.get('multiple','no') == 'yes':
                         multiple = True
                     else:
@@ -1146,6 +1147,18 @@
                     # we target the textctl here
                     p['wxId'] = selection.GetChildren()[0].GetId()
                     selection.Bind(wx.EVT_TEXT, self.OnSetValue)
+                # dbcolumn entry
+                elif p.get('prompt','') == 'dbcolumn':
+                    columns = wx.ComboBox(parent=which_panel, id=wx.ID_ANY,
+                                          size=globalvar.DIALOG_COMBOBOX_SIZE,
+                                          style=wx.CB_SIMPLE | wx.CB_READONLY,
+                                          choices=[])
+                    p['wxId'] = columns.GetId()
+                    p['wxGetValue'] = columns.GetStringSelection
+                    columns.Bind(wx.EVT_ENTER_WINDOW, self.OnDbColumn)
+                    columns.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+                    this_sizer.Add(item=columns, proportion=0,
+                                   flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
                 # color entry
                 elif p.get('prompt','') == 'color':
                     # Heuristic way of finding whether transparent is allowed
@@ -1349,10 +1362,50 @@
         me = wx.FindWindowById( myId )
         for porf in self.task.params + self.task.flags:
             if 'wxId' in porf and type( porf[ 'wxId' ] ) == type( 1 ) and porf['wxId'] == myId:
-                porf[ 'value' ] = me.GetValue()
+                if porf.has_key('wxGetValue') and porf['wxGetValue']:
+                    porf['value'] = porf['wxGetValue']()
+                else:
+                    porf['value'] = me.GetValue()
         self.OnUpdateValues()
+        event.Skip()
+    def OnDbColumn(self, event):
+        """Get list of table columns"""
+        choices = []
+        mapName = utils.GetLayerNameFromCmd(self.task.getCmd(ignoreErrors=True))
+        if mapName !=  _('<required>'):
+            layer = 1
+            for p in self.task.params:
+                if p.get('name', '') == 'layer':
+                    value = p.get('value', '1')
+                    if value:
+                        layer = int(value)
+                    break
+            cmd = ['v.info',
+                   'map=%s' % mapName,
+                   'layer=%d' % layer,
+                   '-c', '--q']
+            try:
+                for line in gcmd.Command(cmd).ReadStdOutput():
+                    type, name = line.split('|')
+                    choices.append(name.strip())
+            except gcmd.CmdError:
+                pass
+        win = self.FindWindowById(event.GetId())
+        win.SetItems(choices)
+        if len(choices) < 1:
+            win.SetValue('')
+        event.Skip()
     def createCmd( self, ignoreErrors = False ):
         Produce a command line string (list) or feeding into GRASS.
Modified: grass/branches/develbranch_6/include/gis.h
--- grass/branches/develbranch_6/include/gis.h	2008-08-11 00:06:32 UTC (rev 32672)
+++ grass/branches/develbranch_6/include/gis.h	2008-08-11 08:47:24 UTC (rev 32673)
@@ -99,6 +99,7 @@
 #define YES           1
 #define NO            0
 #define GISPROMPT_COLOR "color,grass,color"
+#define GISPROMPT_DBCOLUMN "dbcolumn,grass,dbcolumn"
 /* File/directory name lengths */
 #define GNAME_MAX 256
Modified: grass/branches/develbranch_6/lib/gis/parser.c
--- grass/branches/develbranch_6/lib/gis/parser.c	2008-08-11 00:06:32 UTC (rev 32672)
+++ grass/branches/develbranch_6/lib/gis/parser.c	2008-08-11 08:47:24 UTC (rev 32673)
@@ -325,8 +325,7 @@
 	Opt->type = TYPE_STRING;
 	Opt->key_desc = "sql_query";
 	Opt->required = NO;
-	Opt->label =
-	    _("WHERE conditions of SQL statement without 'where' keyword");
+	Opt->label = _("WHERE conditions of SQL statement without 'where' keyword");
 	Opt->description = _("Example: income < 1000 and inhab >= 10000");
 	break;
     case G_OPT_TABLE:
@@ -360,6 +359,7 @@
 	Opt->required = NO;
 	Opt->multiple = NO;
 	Opt->description = _("Name of attribute column");
+	Opt->gisprompt = GISPROMPT_DBCOLUMN;
 	break;
     case G_OPT_COLUMNS:
 	Opt->key = "columns";
@@ -368,6 +368,7 @@
 	Opt->required = NO;
 	Opt->multiple = YES;
 	Opt->description = _("Name of attribute column(s)");
 	break;
 	/* imagery group */
