[GRASS-SVN] r32678 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Mon Aug 11 06:12:40 EDT 2008
Author: martinl
Date: 2008-08-11 06:12:39 -0400 (Mon, 11 Aug 2008)
New Revision: 32678
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI: don't crash when gis element is selected repeatedly
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2008-08-11 09:45:28 UTC (rev 32677)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2008-08-11 10:12:39 UTC (rev 32678)
@@ -99,7 +99,7 @@
     def GetStringValue(self):
         str = ""
         for value in self.value:
-            str += self.seltree.GetItemText(value) + ","
+            str += value + ","
         str = str.rstrip(',')
         return str
@@ -110,9 +110,13 @@
         self.GetElementList(self.type, self.mapsets, self.exceptOf)
         if len(self.value) > 0:
-            self.seltree.EnsureVisible(self.value[0])
-            self.seltree.SelectItem(self.value[0])
+            root = self.seltree.GetRootItem()
+            if not root:
+                return
+            item = self.FindItem(root, self.value[0])
+            self.seltree.EnsureVisible(item)
+            self.seltree.SelectItem(item)
     def SetStringValue(self, value):
         # this assumes that item strings are unique...
@@ -242,7 +246,7 @@
             if self.seltree.ItemHasChildren(item):
                 item = self.FindItem(item, text)
             item, cookie = self.seltree.GetNextChild(parentItem, cookie)
-        return wx.TreeItemId();
+        return wx.TreeItemId()
     def AddItem(self, value, parent=None):
@@ -273,9 +277,10 @@
                 self.value = [] # cannot select mapset item
             else:
                 if self.multiple is True:
-                    self.value.append(item)
+                    # text item should be unique
+                    self.value.append(self.seltree.GetItemText(item))
                 else:
-                    self.value = [item, ]
+                    self.value = [self.seltree.GetItemText(item), ]
             self.Dismiss()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-08-11 09:45:28 UTC (rev 32677)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-08-11 10:12:39 UTC (rev 32678)
@@ -655,39 +655,60 @@
         point = wx.GetMousePosition()
         toolMenu = wx.Menu()
         # Add items to the menu
-        copy = wx.MenuItem(toolMenu, wx.ID_ANY, _('Copy features from (background) vector map'))
+        copy = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Copy features from (background) vector map'),
+                           kind=wx.ITEM_CHECK)
+        if self.action == "copyLine":
+            print copy.GetId()
+            toolMenu.Check(1, True)
         toolMenu.AppendItem(copy)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
-        flip = wx.MenuItem(toolMenu, wx.ID_ANY, _('Flip selected lines/boundaries'))
+        flip = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Flip selected lines/boundaries'),
         toolMenu.AppendItem(flip)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
-        merge = wx.MenuItem(toolMenu, wx.ID_ANY, _('Merge selected lines/boundaries'))
+        merge = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Merge selected lines/boundaries'),
         toolMenu.AppendItem(merge)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
-        breakL = wx.MenuItem(toolMenu, wx.ID_ANY, _('Break selected lines/boundaries at intersection'))
+        breakL = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                             text=_('Break selected lines/boundaries at intersection'),
         toolMenu.AppendItem(breakL)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
-        snap = wx.MenuItem(toolMenu, wx.ID_ANY, _('Snap selected lines/boundaries (only to nodes)'))
+        snap = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                           text=_('Snap selected lines/boundaries (only to nodes)'),
         toolMenu.AppendItem(snap)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
-        connect = wx.MenuItem(toolMenu, wx.ID_ANY, _('Connect selected lines/boundaries'))
+        connect = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                              text=_('Connect selected lines/boundaries'),
         toolMenu.AppendItem(connect)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
-        query = wx.MenuItem(toolMenu, wx.ID_ANY, _('Query tool'))
+        query = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Query features'),
         toolMenu.AppendItem(query)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
-        zbulk = wx.MenuItem(toolMenu, wx.ID_ANY, _('Z bulk-labeling of 3D lines'))
+        zbulk = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                            text=_('Z bulk-labeling of 3D lines'),
         toolMenu.AppendItem(zbulk)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
-        typeconv = wx.MenuItem(toolMenu, wx.ID_ANY, _('Feature type conversion'))
+        typeconv = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                               text=_('Feature type conversion'),
         toolMenu.AppendItem(typeconv)
         self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
