[GRASS-SVN] r32707 - in grass/trunk: . include include/Make swig/python
Tue Aug 12 00:30:04 EDT 2008
Author: glynn
Date: 2008-08-12 00:30:04 -0400 (Tue, 12 Aug 2008)
New Revision: 32707
Added:
   grass/trunk/include/Make/Grass.make
   grass/trunk/swig/python/Makefile
Removed:
   grass/trunk/include/Make/Grass.make.in
   grass/trunk/include/winname.h.in
   grass/trunk/swig/python/Makefile.in
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Platform.make.in
Reduce the number of files generated by configure
 Move GRASS_VERSION_* from Grass.make[.in] to Platform.make[.in]
 Make Grass.make and swig/python/Makefile static files, not generated by configure
 Remove include/winname.h.in (no longer needed)
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-08-12 04:25:52 UTC (rev 32706)
+++ grass/trunk/configure	2008-08-12 04:30:04 UTC (rev 32707)
@@ -15344,7 +15344,7 @@
 ac_given_srcdir=$srcdir
 ac_given_INSTALL="$INSTALL"
-trap 'rm -fr `echo "include/Make/Grass.make include/Make/Platform.make include/version.h include/winname.h swig/perl/Makefile.PL swig/perl2/make.pl swig/python/Makefile grass.pc include/config.h" | sed "s/:[^ ]*//g"` conftest*; exit 1' 1 2 15
+trap 'rm -fr `echo "include/Make/Platform.make include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc include/config.h" | sed "s/:[^ ]*//g"` conftest*; exit 1' 1 2 15
 EOF
 cat >> $CONFIG_STATUS <<EOF
@@ -15591,7 +15591,7 @@
-CONFIG_FILES=\${CONFIG_FILES-"include/Make/Grass.make include/Make/Platform.make include/version.h include/winname.h swig/perl/Makefile.PL swig/perl2/make.pl swig/python/Makefile grass.pc"}
+CONFIG_FILES=\${CONFIG_FILES-"include/Make/Platform.make include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc"}
 EOF
 cat >> $CONFIG_STATUS <<\EOF
 for ac_file in .. $CONFIG_FILES; do if test "x$ac_file" != x..; then
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-08-12 04:25:52 UTC (rev 32706)
+++ grass/trunk/configure.in	2008-08-12 04:30:04 UTC (rev 32707)
@@ -1692,7 +1692,7 @@
 GRASS_HOME=${DSTDIR}
 AC_SUBST(GRASS_HOME)
-AC_OUTPUT(include/Make/Grass.make include/Make/Platform.make include/version.h include/winname.h swig/perl/Makefile.PL swig/perl2/make.pl swig/python/Makefile grass.pc)
+AC_OUTPUT(include/Make/Platform.make include/version.h swig/perl/Makefile.PL swig/perl2/make.pl grass.pc)
 LOC_MSG([Copying config.status to config.status.${ARCH}])
 cp -f config.status config.status.${ARCH}
Copied: grass/trunk/include/Make/Grass.make (from rev 32689, grass/trunk/include/Make/Grass.make.in)
--- grass/trunk/include/Make/Grass.make	                        (rev 0)
+++ grass/trunk/include/Make/Grass.make	2008-08-12 04:30:04 UTC (rev 32707)
@@ -0,0 +1,416 @@
+# to force make to use /bin/sh
+SHELL           = /bin/sh
+#                         Variable names
+# xxxINCDIR  directory(ies) including header files (example: /usr/include)
+# xxxINC  cc option(s) for include directory (example: -I/usr/inlude)
+# xxxLIBDIR  directory(ies) containing library (example: /usr/lib)
+# xxxLIBPATH cc option for library directory (example: -L/usr/lib)
+# xxx_LIBNAME library name (example: gis)
+# xxxLIB full static library path
+#        (example: /home/abc/grass63/dist.i686-pc-linux-gnu/lib/libgis.a)
+# xxxDEP dependency
+# GRASS_xxx GRASS specific (without ARCH_xxx)
+# ARCH_xxx platform specific dirs (without GRASS_xxx)
+# _xxx  GRASS_xxx + ARCH_xxx
+# ALLxxx all known for GRASS make system
+# GRASS global directories and constants
+# platform specific dirs
+ARCH_DISTDIR	= $(GRASS_HOME)/dist.$(ARCH)
+ARCH_BINDIR     = $(GRASS_HOME)/bin.$(ARCH)
+ERRORLOG        = $(GRASS_HOME)/error.log
+# include dirs
+ARCH_INCDIR     = $(ARCH_DISTDIR)/include/grass
+ARCH_INC	= -I$(ARCH_DISTDIR)/include
+INC		= $(ARCH_INC)
+VECT_INC        =
+# libraries
+ARCH_LIBDIR     = $(ARCH_DISTDIR)/lib
+ARCH_LIBPATH	= -L$(ARCH_LIBDIR)
+LIBPATH		= $(ARCH_LIBPATH)
+# object dir
+OBJDIR		= OBJ.$(ARCH)
+# these define the various directories which contain GRASS programs
+# or files used by GRASS programs
+GISBASE		= $(ARCH_DISTDIR)
+BIN             = $(ARCH_DISTDIR)/bin
+ETC             = $(ARCH_DISTDIR)/etc
+DRIVERDIR       = $(ARCH_DISTDIR)/driver
+DBDRIVERDIR     = $(ARCH_DISTDIR)/driver/db
+FONTDIR         = $(ARCH_DISTDIR)/fonts
+GRASS_VERSION_NUMBER  = $(GRASS_VERSION_MAJOR).$(GRASS_VERSION_MINOR).$(GRASS_VERSION_RELEASE)
+GRASS_VERSION_NAME    = $(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)$(GRASS_VERSION_RELEASE)
+GRASS_VERSION_FILE    = $(ETC)/VERSION
+GRASS_BUILD_FILE      = $(ETC)/BUILD
+##################### other #############################################
+CFLAGS      =  $(INC) $(COMPILE_FLAGS) $(USE_TERMIO)
+CXXFLAGS    =  $(INC) $(COMPILE_FLAGS_CXX) $(USE_TERMIO)
+LDFLAGS     =  $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH) $(USE_TERMIO)
+VECT_CFLAGS =  $(GDALCFLAGS)
+# Object with _fmode which must be linked to each executable on Windows
+ifdef MINGW
+  FMODE_OBJ = $(MODULE_TOPDIR)/lib/gis/$(OBJDIR)/fmode.o
+endif
+##################### library names #####################################
+ARRAYSTATS_LIBNAME        = grass_arraystats
+BITMAP_LIBNAME        = grass_bitmap
+BTREE_LIBNAME         = grass_btree
+CLUSTER_LIBNAME       = grass_cluster
+COORCNV_LIBNAME       = grass_coorcnv
+DATETIME_LIBNAME      = grass_datetime
+DBDIALOG_LIBNAME      = grass_dbdialog
+DISPLAY_LIBNAME       = grass_display
+DLG_LIBNAME           = grass_dlg
+DSPF_LIBNAME          = grass_dspf
+DRIVER_LIBNAME        = grass_driver
+PNGDRIVER_LIBNAME     = grass_pngdriver
+PSDRIVER_LIBNAME      = grass_psdriver
+CAIRODRIVER_LIBNAME   = grass_cairodriver
+HTMLDRIVER_LIBNAME    = grass_htmldriver
+EDIT_LIBNAME          = grass_edit
+G3D_LIBNAME	      = grass_g3d
+GIS_LIBNAME	      = grass_gis
+GMATH_LIBNAME         = grass_gmath
+GPDE_LIBNAME          = grass_gpde
+GPROJ_LIBNAME         = grass_gproj
+IBTREE_LIBNAME        = grass_ibtree
+ICON_LIBNAME          = grass_icon
+IMAGERY_LIBNAME       = grass_imagery
+IORTHO_LIBNAME        = grass_Iortho
+IOSTREAM_LIBNAME      = grass_iostream
+ISMAP_LIBNAME         = grass_ismap
+LINKM_LIBNAME         = grass_linkm
+LOCK_LIBNAME          = grass_lock
+MANAGE_LIBNAME        = grass_manage
+RASTER_LIBNAME        = grass_raster
+ROWIO_LIBNAME         = grass_rowio
+SEGMENT_LIBNAME       = grass_segment
+STATS_LIBNAME	      = grass_stats
+VASK_LIBNAME	      = grass_vask
+XGD_LIBNAME	      = grass_Xgd
+XGI_LIBNAME	      = grass_Xgi
+XPM_LIBNAME	      = grass_Xpm
+# Vector
+DIG_LIBNAME           = grass_dig
+DIG2_LIBNAME          = grass_dig2
+VECTR_LIBNAME         = grass_vect
+TRANS_LIBNAME         = grass_trans
+SHAPE_LIBNAME         = grass_shape
+GRAPH_LIBNAME         = grass_dgl
+RTREE_LIBNAME         = grass_rtree
+VEDIT_LIBNAME         = grass_vedit
+# Interpolation
+INTERPDATA_LIBNAME    = grass_interpdata
+INTERPFL_LIBNAME      = grass_interpfl
+QTREE_LIBNAME         = grass_qtree
+# NVIZ related
+OGSF_LIBNAME          = grass_ogsf
+NVIZ_LIBNAME          = grass_nviz
+# triangulation libraries
+SOS_LIBNAME           = grass_sos
+LIA_LIBNAME           = grass_lia
+OPTRI_LIBNAME         = grass_optri
+BASIC_LIBNAME         = grass_basic
+XDISPLAY_LIBNAME      = grass_Xdisplay
+# DBMI
+DBMI_LIBNAME          = grass_dbmi
+DBMIBASE_LIBNAME      = grass_dbmibase
+DBMICLIENT_LIBNAME    = grass_dbmiclient
+DBMIDRIVER_LIBNAME    = grass_dbmidriver
+SQLP_LIBNAME          = grass_sqlp
+DBSTUBS_LIBNAME       = grass_dbstubs
+# database forms
+FORM_LIBNAME          = grass_form
+# Symbols (icons, patterns)
+SYMB_LIBNAME          = grass_symb
+# Normality
+CDHC_LIBNAME          = grass_cdhc
+# Lidar
+LIDAR_LIBNAME         = grass_lidar
+# Raster/SIMWE
+SIM_LIBNAME           = grass_sim
+# Sites (legacy)
+SITES_LIBNAME         = grass_sites
+# LRS
+LRS_LIBNAME           = grass_lrs
+##################### library switches ##################################
+ARRAYSTATSLIB      = -l$(ARRAYSTATS_LIBNAME) $(GISLIB)
+BITMAPLIB     = -l$(BITMAP_LIBNAME) $(LINKMLIB)
+BTREELIB      = -l$(BTREE_LIBNAME)
+CLUSTERLIB    = -l$(CLUSTER_LIBNAME) $(IMAGERYLIB) $(GISLIB)
+COORCNVLIB    = -l$(COORCNV_LIBNAME)
+DATETIMELIB   = -l$(DATETIME_LIBNAME)
+DBDIALOGLIB   = -l$(DBDIALOG_LIBNAME)
+DISPLAYLIB    = -l$(DISPLAY_LIBNAME) $(GISLIB) $(RASTERLIB)
+DLGLIB        = -l$(DLG_LIBNAME)
+DSPFLIB       = -l$(DSPF_LIBNAME)
+DRIVERLIB     = -l$(DRIVER_LIBNAME) $(GISLIB) $(FTLIB) $(ICONVLIB)
+PNGDRIVERLIB  = -l$(PNGDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB) $(PNGLIB)
+PSDRIVERLIB   = -l$(PSDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
+CAIRODRIVERLIB = -l$(CAIRODRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
+HTMLDRIVERLIB = -l$(HTMLDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
+EDITLIB       = -l$(EDIT_LIBNAME) $(GISLIB) $(VASKLIB)
+G3DLIB        = -l$(G3D_LIBNAME) $(GISLIB)
+GISLIB        = -l$(GIS_LIBNAME) $(DATETIMELIB) $(XDRLIB) $(SOCKLIB) $(INTLLIB)
+GMATHLIB      = -l$(GMATH_LIBNAME) $(GISLIB)
+GPDELIB       = -l$(GPDE_LIBNAME) $(GISLIB) $(G3DLIB)
+GPROJLIB      = -l$(GPROJ_LIBNAME) $(GISLIB) $(PROJLIB) $(GDALLIBS)
+IBTREELIB     = -l$(IBTREE_LIBNAME)
+ICONLIB       = -l$(ICON_LIBNAME)
+IMAGERYLIB    = -l$(IMAGERY_LIBNAME) $(GISLIB)
+IORTHOLIB     = -l$(IORTHO_LIBNAME) $(IMAGERYLIB) $(GISLIB)
+IOSTREAMLIB   = -l$(IOSTREAM_LIBNAME)
+ISMAPLIB      = -l$(ISMAP_LIBNAME)
+LINKMLIB      = -l$(LINKM_LIBNAME)
+LOCKLIB       = -l$(LOCK_LIBNAME)
+MANAGELIB     = -l$(MANAGE_LIBNAME)
+RASTERLIB     = -l$(RASTER_LIBNAME) $(PNGDRIVERLIB) $(PSDRIVERLIB) $(DRIVERLIB) $(GISLIB)
+ROWIOLIB      = -l$(ROWIO_LIBNAME)
+SEGMENTLIB    = -l$(SEGMENT_LIBNAME) $(GISLIB)
+STATSLIB      = -l$(STATS_LIBNAME) $(GISLIB)
+VASKLIB       = -l$(VASK_LIBNAME)
+XGDLIB        = -l$(XGD_LIBNAME)
+XGILIB        = -l$(XGI_LIBNAME)
+XPMLIB        = -l$(XPM_LIBNAME)
+# DBMI
+DBMIBASELIB   = -l$(DBMIBASE_LIBNAME) $(GISLIB)
+DBMICLIENTLIB = -l$(DBMICLIENT_LIBNAME) $(DBMIBASELIB) $(GISLIB)
+DBMIDRIVERLIB = -l$(DBMIDRIVER_LIBNAME) $(DBMIBASELIB) $(DBSTUBSLIB) $(GISLIB)
+SQLPLIB       = -l$(SQLP_LIBNAME)
+DBSTUBSLIB    = -l$(DBSTUBS_LIBNAME) $(DBMIBASELIB) $(GISLIB)
+DBMILIB       = $(DBMICLIENTLIB) $(DBMIBASELIB) $(DBMIEXTRALIB)
+# Vector
+DIGLIB        = -l$(DIG_LIBNAME)
+DIG2LIB       = -l$(DIG2_LIBNAME) $(GISLIB) $(RTREELIB)
+VECTRLIB      = -l$(VECTR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GRAPHLIB) $(DIG2LIB) $(GISLIB) $(LINKMLIB) $(RTREELIB)
+TRANSLIB      = -l$(TRANS_LIBNAME)
+SHAPELIB      = -l$(SHAPE_LIBNAME)
+GRAPHLIB      = -l$(GRAPH_LIBNAME)
+RTREELIB      = -l$(RTREE_LIBNAME)
+VEDITLIB      = -l$(VEDIT_LIBNAME) $(GISLIB) $(VECTRLIB)
+VECTLIB       = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS)
+# Interpolation
+INTERPDATALIB = -l$(INTERPDATA_LIBNAME)
+INTERPFLLIB   = -l$(INTERPFL_LIBNAME) $(BITMAPLIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(INTERPDATALIB) $(QTREELIB) $(VECTRLIB)
+QTREELIB      = -l$(QTREE_LIBNAME)
+# NVIZ related
+OGSFLIB       = -l$(OGSF_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(SITESLIB) $(VECTRLIB)
+NVIZLIB       = -l$(NVIZ_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(VECTRLIB)
+SOSLIB        = -l$(SOS_LIBNAME)
+LIALIB        = -l$(LIA_LIBNAME)
+OPTRILIB      = -l$(OPTRI_LIBNAME)
+BASICLIB      = -l$(BASIC_LIBNAME)
+GEOMLIB       = $(OPTRILIB) $(SOSLIB) $(LIALIB) $(BASICLIB)
+# misc
+XDISPLAYLIB   = -l$(XDISPLAY_LIBNAME)
+FORMLIB       = -l$(FORM_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB)
+SYMBLIB       = -l$(SYMB_LIBNAME) $(GISLIB)
+# Normality
+CDHCLIB       = -l$(CDHC_LIBNAME)
+# Lidar
+LIDARLIB      = -l$(LIDAR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(VECTRLIB)
+# Raster/SIMWE
+SIMLIB        = -l$(SIM_LIBNAME) $(GISLIB) $(SITESLIB)
+# Sites (legacy)
+SITESLIB      = -l$(SITES_LIBNAME) $(DATETIMELIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(VECTRLIB)
+# LRS
+LRSLIB        = -l$(LRS_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB)
+##################### library dependencies ##############################
+# These always static
+ISMAPDEP    = $(ARCH_LIBDIR)/$(STLIB_PREFIX)$(ISMAP_LIBNAME)$(STLIB_SUFFIX)
+MANAGEDEP   = $(ARCH_LIBDIR)/$(STLIB_PREFIX)$(MANAGE_LIBNAME)$(STLIB_SUFFIX)
+IOSTREAMDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IOSTREAM_LIBNAME)$(STLIB_SUFFIX)
+ARRAYSTATSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ARRAYSTATS_LIBNAME)$(LIB_SUFFIX)
+BITMAPDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(BITMAP_LIBNAME)$(LIB_SUFFIX)
+BTREEDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(BTREE_LIBNAME)$(LIB_SUFFIX)
+COORCNVDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(COORCNV_LIBNAME)$(LIB_SUFFIX)
+CLUSTERDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CLUSTER_LIBNAME)$(LIB_SUFFIX)
+DATETIMEDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DATETIME_LIBNAME)$(LIB_SUFFIX)
+DBDIALOGDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBDIALOG_LIBNAME)$(LIB_SUFFIX)
+DISPLAYDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DISPLAY_LIBNAME)$(LIB_SUFFIX)
+DLGDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DLG_LIBNAME)$(LIB_SUFFIX)
+DRIVERDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DRIVER_LIBNAME)$(LIB_SUFFIX)
+PNGDRIVERDEP= $(ARCH_LIBDIR)/$(LIB_PREFIX)$(PNGDRIVER_LIBNAME)$(LIB_SUFFIX)
+PSDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(PSDRIVER_LIBNAME)$(LIB_SUFFIX)
+CAIRODRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CAIRODRIVER_LIBNAME)$(LIB_SUFFIX)
+HTMLDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(HTMLDRIVER_LIBNAME)$(LIB_SUFFIX)
+DSPFDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DSPF_LIBNAME)$(LIB_SUFFIX)
+EDITDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(EDIT_LIBNAME)$(LIB_SUFFIX)
+G3DDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(G3D_LIBNAME)$(LIB_SUFFIX)
+GISDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GIS_LIBNAME)$(LIB_SUFFIX)
+GMATHDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GMATH_LIBNAME)$(LIB_SUFFIX)
+GPDEDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GPDE_LIBNAME)$(LIB_SUFFIX)
+GPROJDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GPROJ_LIBNAME)$(LIB_SUFFIX)
+IBTREEDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IBTREE_LIBNAME)$(LIB_SUFFIX)
+ICONDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ICON_LIBNAME)$(LIB_SUFFIX)
+IMAGERYDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IMAGERY_LIBNAME)$(LIB_SUFFIX)
+IORTHODEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IORTHO_LIBNAME)$(LIB_SUFFIX)
+LINKMDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LINKM_LIBNAME)$(LIB_SUFFIX)
+LOCKDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LOCK_LIBNAME)$(LIB_SUFFIX)
+RASTERDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(RASTER_LIBNAME)$(LIB_SUFFIX)
+ROWIODEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ROWIO_LIBNAME)$(LIB_SUFFIX)
+SEGMENTDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SEGMENT_LIBNAME)$(LIB_SUFFIX)
+STATSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(STATS_LIBNAME)$(LIB_SUFFIX)
+VASKDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VASK_LIBNAME)$(LIB_SUFFIX)
+XGDDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XGD_LIBNAME)$(LIB_SUFFIX)
+XGIDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XGI_LIBNAME)$(LIB_SUFFIX)
+XPMDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XPM_LIBNAME)$(LIB_SUFFIX)
+# DBMI
+DBMIBASEDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBMIBASE_LIBNAME)$(LIB_SUFFIX)
+DBMICLIENTDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBMICLIENT_LIBNAME)$(LIB_SUFFIX)
+DBMIDRIVERDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBMIDRIVER_LIBNAME)$(LIB_SUFFIX)
+DBMIDEP         = $(DBMICLIENTDEP) $(DBMIBASEDEP)
+SQLPDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SQLP_LIBNAME)$(LIB_SUFFIX)
+DBSTUBSDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBSTUBS_LIBNAME)$(LIB_SUFFIX)
+# Vector
+DIGDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DIG_LIBNAME)$(LIB_SUFFIX)
+DIG2DEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DIG2_LIBNAME)$(LIB_SUFFIX)
+VECTRDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VECTR_LIBNAME)$(LIB_SUFFIX)
+TRANSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(TRANS_LIBNAME)$(LIB_SUFFIX)
+SHAPEDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SHAPE_LIBNAME)$(LIB_SUFFIX)
+GRAPHDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GRAPH_LIBNAME)$(LIB_SUFFIX)
+RTREEDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(RTREE_LIBNAME)$(LIB_SUFFIX)
+VEDITDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VEDIT_LIBNAME)$(LIB_SUFFIX)
+VECTDEP     = $(VECTRDEP) $(DIG2DEP) $(GRAPHDEP) $(RTREEDEP) $(LINKMDEP) $(DBMIDEP)
+# Interpolation
+INTERPDATADEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(INTERPDATA_LIBNAME)$(LIB_SUFFIX)
+INTERPFLDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(INTERPFL_LIBNAME)$(LIB_SUFFIX)
+QTREEDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(QTREE_LIBNAME)$(LIB_SUFFIX)
+# NVIZ related
+OGSFDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(OGSF_LIBNAME)$(LIB_SUFFIX)
+NVIZDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(NVIZ_LIBNAME)$(LIB_SUFFIX)
+SOSDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SOS_LIBNAME)$(LIB_SUFFIX)
+LIADEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LIA_LIBNAME)$(LIB_SUFFIX)
+OPTRIDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(OPTRI_LIBNAME)$(LIB_SUFFIX)
+BASICDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(BASIC_LIBNAME)$(LIB_SUFFIX)
+GEOMDEP     = $(OPTRIDEP) $(SOSDEP) $(LIADEP) $(BASICDEP)
+# misc
+XDISPLAYDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XDISPLAY_LIBNAME)$(LIB_SUFFIX)
+FORMDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(FORM_LIBNAME)$(LIB_SUFFIX)
+SYMBDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SYMB_LIBNAME)$(LIB_SUFFIX)
+# Normality
+CDHCDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CDHC_LIBNAME)$(LIB_SUFFIX)
+# Lidar
+LIDARDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LIDAR_LIBNAME)$(LIB_SUFFIX)
+# Raster/SIMWE
+SIMDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SIM_LIBNAME)$(LIB_SUFFIX)
+# Sites (legacy)
+SITESDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SITES_LIBNAME)$(LIB_SUFFIX)
+# LRS
+LRSDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LRS_LIBNAME)$(LIB_SUFFIX)
+##################### rules #############################################
+# first found target
+first: pre default
+	@if test -n "$(INST_NOW)" ; then \
+		$(MAKE) inst_now ; \
+	fi
+# This helps compile and install modules directly into $(INST_DIR)
+# without having to install whole distribution even after modifying only
+# one module. It will update both $(GRASS_HOME)/dist.$(ARCH) and $(INST_DIR).
+# Usage:
+#	INST_NOW=y make
+# alias gmake='INST_NOW=y make' will be useful.
+ifdef INST_NOW
+ARCH_DISTDIR = $(INST_DIR)
+ARCH_BINDIR = $(UNIX_BIN)
+endif
+inst_now:
+	INST_NOW= $(MAKE)
+# create platform dirs
+pre: $(ARCH_BINDIR) $(ARCH_INCDIR) $(ARCH_LIBDIR) \
+	$(BIN) $(ETC) \
+	$(DRIVERDIR) $(DBDRIVERDIR) $(FONTDIR)
+$(ARCH_BINDIR):
+	mkdir -p $(ARCH_BINDIR)
+$(ARCH_INCDIR):
+	mkdir -p $(ARCH_INCDIR)
+$(ARCH_LIBDIR):
+	mkdir -p $(ARCH_LIBDIR)
+$(BIN):
+	mkdir -p $(BIN)
+$(ETC):
+	mkdir -p $(ETC)
+$(DRIVERDIR):
+	mkdir -p $(DRIVERDIR)
+$(DBDRIVERDIR):
+	mkdir -p $(DBDRIVERDIR)
+$(FONTDIR):
+	mkdir -p $(FONTDIR)
Deleted: grass/trunk/include/Make/Grass.make.in
--- grass/trunk/include/Make/Grass.make.in	2008-08-12 04:25:52 UTC (rev 32706)
+++ grass/trunk/include/Make/Grass.make.in	2008-08-12 04:30:04 UTC (rev 32707)
@@ -1,431 +0,0 @@
-# to force make to use /bin/sh
-SHELL           = /bin/sh
-#                         Variable names
-# xxxINCDIR  directory(ies) including header files (example: /usr/include)
-# xxxINC  cc option(s) for include directory (example: -I/usr/inlude)
-# xxxLIBDIR  directory(ies) containing library (example: /usr/lib)
-# xxxLIBPATH cc option for library directory (example: -L/usr/lib)
-# xxx_LIBNAME library name (example: gis)
-# xxxLIB full static library path
-#        (example: /home/abc/grass63/dist.i686-pc-linux-gnu/lib/libgis.a)
-# xxxDEP dependency
-# GRASS_xxx GRASS specific (without ARCH_xxx)
-# ARCH_xxx platform specific dirs (without GRASS_xxx)
-# _xxx  GRASS_xxx + ARCH_xxx
-# ALLxxx all known for GRASS make system
-#generate static (ST) or shared (SH)
-#LIB_PREFIX=$(STLIB_PREFIX)
-#LIB_SUFFIX=$(STLIB_SUFFIX)
-#LIB_PREFIX=$(SHLIB_PREFIX)
-#LIB_SUFFIX=$(SHLIB_SUFFIX)
-LIB_PREFIX=@GRASS_LIB_PREFIX@
-LIB_SUFFIX=@GRASS_LIB_SUFFIX@
-GRASS_LIBRARY_TYPE=@GRASS_LIBRARY_TYPE@
-# GRASS global directories and constants
-# platform specific dirs
-ARCH_DISTDIR	= $(GRASS_HOME)/dist.$(ARCH)
-ARCH_BINDIR     = $(GRASS_HOME)/bin.$(ARCH)
-ERRORLOG        = $(GRASS_HOME)/error.log
-# include dirs
-ARCH_INCDIR     = $(ARCH_DISTDIR)/include/grass
-ARCH_INC	= -I$(ARCH_DISTDIR)/include
-INC		= $(ARCH_INC)
-VECT_INC        =
-# libraries
-ARCH_LIBDIR     = $(ARCH_DISTDIR)/lib
-ARCH_LIBPATH	= -L$(ARCH_LIBDIR)
-LIBPATH		= $(ARCH_LIBPATH)
-# object dir
-OBJDIR		= OBJ.$(ARCH)
-# these define the various directories which contain GRASS programs
-# or files used by GRASS programs
-GISBASE		= $(ARCH_DISTDIR)
-BIN             = $(ARCH_DISTDIR)/bin
-ETC             = $(ARCH_DISTDIR)/etc
-DRIVERDIR       = $(ARCH_DISTDIR)/driver
-DBDRIVERDIR     = $(ARCH_DISTDIR)/driver/db
-FONTDIR         = $(ARCH_DISTDIR)/fonts
-GRASS_VERSION_MAJOR   = @GRASS_VERSION_MAJOR@
-GRASS_VERSION_MINOR   = @GRASS_VERSION_MINOR@
-GRASS_VERSION_RELEASE = @GRASS_VERSION_RELEASE@
-GRASS_VERSION_DATE    = @GRASS_VERSION_DATE@
-GRASS_VERSION_NUMBER  = $(GRASS_VERSION_MAJOR).$(GRASS_VERSION_MINOR).$(GRASS_VERSION_RELEASE)
-GRASS_VERSION_NAME    = $(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)$(GRASS_VERSION_RELEASE)
-GRASS_VERSION_FILE    = $(ETC)/VERSION
-GRASS_BUILD_FILE      = $(ETC)/BUILD
-##################### other #############################################
-CFLAGS      =  $(INC) $(COMPILE_FLAGS) $(USE_TERMIO)
-CXXFLAGS    =  $(INC) $(COMPILE_FLAGS_CXX) $(USE_TERMIO)
-LDFLAGS     =  $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH) $(USE_TERMIO)
-VECT_CFLAGS =  $(GDALCFLAGS)
-# Object with _fmode which must be linked to each executable on Windows
-ifdef MINGW
-  FMODE_OBJ = $(MODULE_TOPDIR)/lib/gis/$(OBJDIR)/fmode.o
-endif
-##################### library names #####################################
-ARRAYSTATS_LIBNAME        = grass_arraystats
-BITMAP_LIBNAME        = grass_bitmap
-BTREE_LIBNAME         = grass_btree
-CLUSTER_LIBNAME       = grass_cluster
-COORCNV_LIBNAME       = grass_coorcnv
-DATETIME_LIBNAME      = grass_datetime
-DBDIALOG_LIBNAME      = grass_dbdialog
-DISPLAY_LIBNAME       = grass_display
-DLG_LIBNAME           = grass_dlg
-DSPF_LIBNAME          = grass_dspf
-DRIVER_LIBNAME        = grass_driver
-PNGDRIVER_LIBNAME     = grass_pngdriver
-PSDRIVER_LIBNAME      = grass_psdriver
-CAIRODRIVER_LIBNAME   = grass_cairodriver
-HTMLDRIVER_LIBNAME    = grass_htmldriver
-EDIT_LIBNAME          = grass_edit
-G3D_LIBNAME	      = grass_g3d
-GIS_LIBNAME	      = grass_gis
-GMATH_LIBNAME         = grass_gmath
-GPDE_LIBNAME          = grass_gpde
-GPROJ_LIBNAME         = grass_gproj
-IBTREE_LIBNAME        = grass_ibtree
-ICON_LIBNAME          = grass_icon
-IMAGERY_LIBNAME       = grass_imagery
-IORTHO_LIBNAME        = grass_Iortho
-IOSTREAM_LIBNAME      = grass_iostream
-ISMAP_LIBNAME         = grass_ismap
-LINKM_LIBNAME         = grass_linkm
-LOCK_LIBNAME          = grass_lock
-MANAGE_LIBNAME        = grass_manage
-RASTER_LIBNAME        = grass_raster
-ROWIO_LIBNAME         = grass_rowio
-SEGMENT_LIBNAME       = grass_segment
-STATS_LIBNAME	      = grass_stats
-VASK_LIBNAME	      = grass_vask
-XGD_LIBNAME	      = grass_Xgd
-XGI_LIBNAME	      = grass_Xgi
-XPM_LIBNAME	      = grass_Xpm
-# Vector
-DIG_LIBNAME           = grass_dig
-DIG2_LIBNAME          = grass_dig2
-VECTR_LIBNAME         = grass_vect
-TRANS_LIBNAME         = grass_trans
-SHAPE_LIBNAME         = grass_shape
-GRAPH_LIBNAME         = grass_dgl
-RTREE_LIBNAME         = grass_rtree
-VEDIT_LIBNAME         = grass_vedit
-# Interpolation
-INTERPDATA_LIBNAME    = grass_interpdata
-INTERPFL_LIBNAME      = grass_interpfl
-QTREE_LIBNAME         = grass_qtree
-# NVIZ related
-OGSF_LIBNAME          = grass_ogsf
-NVIZ_LIBNAME          = grass_nviz
-# triangulation libraries
-SOS_LIBNAME           = grass_sos
-LIA_LIBNAME           = grass_lia
-OPTRI_LIBNAME         = grass_optri
-BASIC_LIBNAME         = grass_basic
-XDISPLAY_LIBNAME      = grass_Xdisplay
-# DBMI
-DBMI_LIBNAME          = grass_dbmi
-DBMIBASE_LIBNAME      = grass_dbmibase
-DBMICLIENT_LIBNAME    = grass_dbmiclient
-DBMIDRIVER_LIBNAME    = grass_dbmidriver
-SQLP_LIBNAME          = grass_sqlp
-DBSTUBS_LIBNAME       = grass_dbstubs
-# database forms
-FORM_LIBNAME          = grass_form
-# Symbols (icons, patterns)
-SYMB_LIBNAME          = grass_symb
-# Normality
-CDHC_LIBNAME          = grass_cdhc
-# Lidar
-LIDAR_LIBNAME         = grass_lidar
-# Raster/SIMWE
-SIM_LIBNAME           = grass_sim
-# Sites (legacy)
-SITES_LIBNAME         = grass_sites
-# LRS
-LRS_LIBNAME           = grass_lrs
-##################### library switches ##################################
-ARRAYSTATSLIB      = -l$(ARRAYSTATS_LIBNAME) $(GISLIB)
-BITMAPLIB     = -l$(BITMAP_LIBNAME) $(LINKMLIB)
-BTREELIB      = -l$(BTREE_LIBNAME)
-CLUSTERLIB    = -l$(CLUSTER_LIBNAME) $(IMAGERYLIB) $(GISLIB)
-COORCNVLIB    = -l$(COORCNV_LIBNAME)
-DATETIMELIB   = -l$(DATETIME_LIBNAME)
-DBDIALOGLIB   = -l$(DBDIALOG_LIBNAME)
-DISPLAYLIB    = -l$(DISPLAY_LIBNAME) $(GISLIB) $(RASTERLIB)
-DLGLIB        = -l$(DLG_LIBNAME)
-DSPFLIB       = -l$(DSPF_LIBNAME)
-DRIVERLIB     = -l$(DRIVER_LIBNAME) $(GISLIB) $(FTLIB) $(ICONVLIB)
-PNGDRIVERLIB  = -l$(PNGDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB) $(PNGLIB)
-PSDRIVERLIB   = -l$(PSDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
-CAIRODRIVERLIB = -l$(CAIRODRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
-HTMLDRIVERLIB = -l$(HTMLDRIVER_LIBNAME) $(DRIVERLIB) $(GISLIB)
-EDITLIB       = -l$(EDIT_LIBNAME) $(GISLIB) $(VASKLIB)
-G3DLIB        = -l$(G3D_LIBNAME) $(GISLIB)
-GISLIB        = -l$(GIS_LIBNAME) $(DATETIMELIB) $(XDRLIB) $(SOCKLIB) $(INTLLIB)
-GMATHLIB      = -l$(GMATH_LIBNAME) $(GISLIB)
-GPDELIB       = -l$(GPDE_LIBNAME) $(GISLIB) $(G3DLIB)
-GPROJLIB      = -l$(GPROJ_LIBNAME) $(GISLIB) $(PROJLIB) $(GDALLIBS)
-IBTREELIB     = -l$(IBTREE_LIBNAME)
-ICONLIB       = -l$(ICON_LIBNAME)
-IMAGERYLIB    = -l$(IMAGERY_LIBNAME) $(GISLIB)
-IORTHOLIB     = -l$(IORTHO_LIBNAME) $(IMAGERYLIB) $(GISLIB)
-IOSTREAMLIB   = -l$(IOSTREAM_LIBNAME)
-ISMAPLIB      = -l$(ISMAP_LIBNAME)
-LINKMLIB      = -l$(LINKM_LIBNAME)
-LOCKLIB       = -l$(LOCK_LIBNAME)
-MANAGELIB     = -l$(MANAGE_LIBNAME)
-RASTERLIB     = -l$(RASTER_LIBNAME) $(PNGDRIVERLIB) $(PSDRIVERLIB) $(DRIVERLIB) $(GISLIB)
-ROWIOLIB      = -l$(ROWIO_LIBNAME)
-SEGMENTLIB    = -l$(SEGMENT_LIBNAME) $(GISLIB)
-STATSLIB      = -l$(STATS_LIBNAME) $(GISLIB)
-VASKLIB       = -l$(VASK_LIBNAME)
-XGDLIB        = -l$(XGD_LIBNAME)
-XGILIB        = -l$(XGI_LIBNAME)
-XPMLIB        = -l$(XPM_LIBNAME)
-# DBMI
-DBMIBASELIB   = -l$(DBMIBASE_LIBNAME) $(GISLIB)
-DBMICLIENTLIB = -l$(DBMICLIENT_LIBNAME) $(DBMIBASELIB) $(GISLIB)
-DBMIDRIVERLIB = -l$(DBMIDRIVER_LIBNAME) $(DBMIBASELIB) $(DBSTUBSLIB) $(GISLIB)
-SQLPLIB       = -l$(SQLP_LIBNAME)
-DBSTUBSLIB    = -l$(DBSTUBS_LIBNAME) $(DBMIBASELIB) $(GISLIB)
-DBMILIB       = $(DBMICLIENTLIB) $(DBMIBASELIB) $(DBMIEXTRALIB)
-# Vector
-DIGLIB        = -l$(DIG_LIBNAME)
-DIG2LIB       = -l$(DIG2_LIBNAME) $(GISLIB) $(RTREELIB)
-VECTRLIB      = -l$(VECTR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GRAPHLIB) $(DIG2LIB) $(GISLIB) $(LINKMLIB) $(RTREELIB)
-TRANSLIB      = -l$(TRANS_LIBNAME)
-SHAPELIB      = -l$(SHAPE_LIBNAME)
-GRAPHLIB      = -l$(GRAPH_LIBNAME)
-RTREELIB      = -l$(RTREE_LIBNAME)
-VEDITLIB      = -l$(VEDIT_LIBNAME) $(GISLIB) $(VECTRLIB)
-VECTLIB       = $(VECTRLIB) $(DIG2LIB) $(GRAPHLIB) $(RTREELIB) $(LINKMLIB) $(DBMILIB) $(GDALLIBS)
-# Interpolation
-INTERPDATALIB = -l$(INTERPDATA_LIBNAME)
-INTERPFLLIB   = -l$(INTERPFL_LIBNAME) $(BITMAPLIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(INTERPDATALIB) $(QTREELIB) $(VECTRLIB)
-QTREELIB      = -l$(QTREE_LIBNAME)
-# NVIZ related
-OGSFLIB       = -l$(OGSF_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(SITESLIB) $(VECTRLIB)
-NVIZLIB       = -l$(NVIZ_LIBNAME) $(BITMAPLIB) $(G3DLIB) $(GISLIB) $(VECTRLIB)
-SOSLIB        = -l$(SOS_LIBNAME)
-LIALIB        = -l$(LIA_LIBNAME)
-OPTRILIB      = -l$(OPTRI_LIBNAME)
-BASICLIB      = -l$(BASIC_LIBNAME)
-GEOMLIB       = $(OPTRILIB) $(SOSLIB) $(LIALIB) $(BASICLIB)
-# misc
-XDISPLAYLIB   = -l$(XDISPLAY_LIBNAME)
-FORMLIB       = -l$(FORM_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB)
-SYMBLIB       = -l$(SYMB_LIBNAME) $(GISLIB)
-# Normality
-CDHCLIB       = -l$(CDHC_LIBNAME)
-# Lidar
-LIDARLIB      = -l$(LIDAR_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(GMATHLIB) $(VECTRLIB)
-# Raster/SIMWE
-SIMLIB        = -l$(SIM_LIBNAME) $(GISLIB) $(SITESLIB)
-# Sites (legacy)
-SITESLIB      = -l$(SITES_LIBNAME) $(DATETIMELIB) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB) $(VECTRLIB)
-# LRS
-LRSLIB        = -l$(LRS_LIBNAME) $(DBMIBASELIB) $(DBMICLIENTLIB) $(GISLIB)
-##################### library dependencies ##############################
-# These always static
-ISMAPDEP    = $(ARCH_LIBDIR)/$(STLIB_PREFIX)$(ISMAP_LIBNAME)$(STLIB_SUFFIX)
-MANAGEDEP   = $(ARCH_LIBDIR)/$(STLIB_PREFIX)$(MANAGE_LIBNAME)$(STLIB_SUFFIX)
-IOSTREAMDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IOSTREAM_LIBNAME)$(STLIB_SUFFIX)
-ARRAYSTATSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ARRAYSTATS_LIBNAME)$(LIB_SUFFIX)
-BITMAPDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(BITMAP_LIBNAME)$(LIB_SUFFIX)
-BTREEDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(BTREE_LIBNAME)$(LIB_SUFFIX)
-COORCNVDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(COORCNV_LIBNAME)$(LIB_SUFFIX)
-CLUSTERDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CLUSTER_LIBNAME)$(LIB_SUFFIX)
-DATETIMEDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DATETIME_LIBNAME)$(LIB_SUFFIX)
-DBDIALOGDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBDIALOG_LIBNAME)$(LIB_SUFFIX)
-DISPLAYDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DISPLAY_LIBNAME)$(LIB_SUFFIX)
-DLGDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DLG_LIBNAME)$(LIB_SUFFIX)
-DRIVERDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DRIVER_LIBNAME)$(LIB_SUFFIX)
-PNGDRIVERDEP= $(ARCH_LIBDIR)/$(LIB_PREFIX)$(PNGDRIVER_LIBNAME)$(LIB_SUFFIX)
-PSDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(PSDRIVER_LIBNAME)$(LIB_SUFFIX)
-CAIRODRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CAIRODRIVER_LIBNAME)$(LIB_SUFFIX)
-HTMLDRIVERDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(HTMLDRIVER_LIBNAME)$(LIB_SUFFIX)
-DSPFDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DSPF_LIBNAME)$(LIB_SUFFIX)
-EDITDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(EDIT_LIBNAME)$(LIB_SUFFIX)
-G3DDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(G3D_LIBNAME)$(LIB_SUFFIX)
-GISDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GIS_LIBNAME)$(LIB_SUFFIX)
-GMATHDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GMATH_LIBNAME)$(LIB_SUFFIX)
-GPDEDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GPDE_LIBNAME)$(LIB_SUFFIX)
-GPROJDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GPROJ_LIBNAME)$(LIB_SUFFIX)
-IBTREEDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IBTREE_LIBNAME)$(LIB_SUFFIX)
-ICONDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ICON_LIBNAME)$(LIB_SUFFIX)
-IMAGERYDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IMAGERY_LIBNAME)$(LIB_SUFFIX)
-IORTHODEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(IORTHO_LIBNAME)$(LIB_SUFFIX)
-LINKMDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LINKM_LIBNAME)$(LIB_SUFFIX)
-LOCKDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LOCK_LIBNAME)$(LIB_SUFFIX)
-RASTERDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(RASTER_LIBNAME)$(LIB_SUFFIX)
-ROWIODEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(ROWIO_LIBNAME)$(LIB_SUFFIX)
-SEGMENTDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SEGMENT_LIBNAME)$(LIB_SUFFIX)
-STATSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(STATS_LIBNAME)$(LIB_SUFFIX)
-VASKDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VASK_LIBNAME)$(LIB_SUFFIX)
-XGDDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XGD_LIBNAME)$(LIB_SUFFIX)
-XGIDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XGI_LIBNAME)$(LIB_SUFFIX)
-XPMDEP	    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XPM_LIBNAME)$(LIB_SUFFIX)
-# DBMI
-DBMIBASEDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBMIBASE_LIBNAME)$(LIB_SUFFIX)
-DBMICLIENTDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBMICLIENT_LIBNAME)$(LIB_SUFFIX)
-DBMIDRIVERDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBMIDRIVER_LIBNAME)$(LIB_SUFFIX)
-DBMIDEP         = $(DBMICLIENTDEP) $(DBMIBASEDEP)
-SQLPDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SQLP_LIBNAME)$(LIB_SUFFIX)
-DBSTUBSDEP  = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DBSTUBS_LIBNAME)$(LIB_SUFFIX)
-# Vector
-DIGDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DIG_LIBNAME)$(LIB_SUFFIX)
-DIG2DEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(DIG2_LIBNAME)$(LIB_SUFFIX)
-VECTRDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VECTR_LIBNAME)$(LIB_SUFFIX)
-TRANSDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(TRANS_LIBNAME)$(LIB_SUFFIX)
-SHAPEDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SHAPE_LIBNAME)$(LIB_SUFFIX)
-GRAPHDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(GRAPH_LIBNAME)$(LIB_SUFFIX)
-RTREEDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(RTREE_LIBNAME)$(LIB_SUFFIX)
-VEDITDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(VEDIT_LIBNAME)$(LIB_SUFFIX)
-VECTDEP     = $(VECTRDEP) $(DIG2DEP) $(GRAPHDEP) $(RTREEDEP) $(LINKMDEP) $(DBMIDEP)
-# Interpolation
-INTERPDATADEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(INTERPDATA_LIBNAME)$(LIB_SUFFIX)
-INTERPFLDEP   = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(INTERPFL_LIBNAME)$(LIB_SUFFIX)
-QTREEDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(QTREE_LIBNAME)$(LIB_SUFFIX)
-# NVIZ related
-OGSFDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(OGSF_LIBNAME)$(LIB_SUFFIX)
-NVIZDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(NVIZ_LIBNAME)$(LIB_SUFFIX)
-SOSDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SOS_LIBNAME)$(LIB_SUFFIX)
-LIADEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LIA_LIBNAME)$(LIB_SUFFIX)
-OPTRIDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(OPTRI_LIBNAME)$(LIB_SUFFIX)
-BASICDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(BASIC_LIBNAME)$(LIB_SUFFIX)
-GEOMDEP     = $(OPTRIDEP) $(SOSDEP) $(LIADEP) $(BASICDEP)
-# misc
-XDISPLAYDEP = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(XDISPLAY_LIBNAME)$(LIB_SUFFIX)
-FORMDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(FORM_LIBNAME)$(LIB_SUFFIX)
-SYMBDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SYMB_LIBNAME)$(LIB_SUFFIX)
-# Normality
-CDHCDEP     = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(CDHC_LIBNAME)$(LIB_SUFFIX)
-# Lidar
-LIDARDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LIDAR_LIBNAME)$(LIB_SUFFIX)
-# Raster/SIMWE
-SIMDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SIM_LIBNAME)$(LIB_SUFFIX)
-# Sites (legacy)
-SITESDEP    = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(SITES_LIBNAME)$(LIB_SUFFIX)
-# LRS
-LRSDEP      = $(ARCH_LIBDIR)/$(LIB_PREFIX)$(LRS_LIBNAME)$(LIB_SUFFIX)
-##################### rules #############################################
-# first found target
-first: pre default
-	@if test -n "$(INST_NOW)" ; then \
-		$(MAKE) inst_now ; \
-	fi
-# This helps compile and install modules directly into $(INST_DIR)
-# without having to install whole distribution even after modifying only
-# one module. It will update both $(GRASS_HOME)/dist.$(ARCH) and $(INST_DIR).
-# Usage:
-#	INST_NOW=y make
-# alias gmake='INST_NOW=y make' will be useful.
-ifdef INST_NOW
-ARCH_DISTDIR = $(INST_DIR)
-ARCH_BINDIR = $(UNIX_BIN)
-endif
-inst_now:
-	INST_NOW= $(MAKE)
-# create platform dirs
-pre: $(ARCH_BINDIR) $(ARCH_INCDIR) $(ARCH_LIBDIR) \
-	$(BIN) $(ETC) \
-	$(DRIVERDIR) $(DBDRIVERDIR) $(FONTDIR)
-$(ARCH_BINDIR):
-	mkdir -p $(ARCH_BINDIR)
-$(ARCH_INCDIR):
-	mkdir -p $(ARCH_INCDIR)
-$(ARCH_LIBDIR):
-	mkdir -p $(ARCH_LIBDIR)
-$(BIN):
-	mkdir -p $(BIN)
-$(ETC):
-	mkdir -p $(ETC)
-$(DRIVERDIR):
-	mkdir -p $(DRIVERDIR)
-$(DBDRIVERDIR):
-	mkdir -p $(DBDRIVERDIR)
-$(FONTDIR):
-	mkdir -p $(FONTDIR)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2008-08-12 04:25:52 UTC (rev 32706)
+++ grass/trunk/include/Make/Platform.make.in	2008-08-12 04:30:04 UTC (rev 32707)
@@ -40,6 +40,11 @@
 UNIX_BIN            = @BINDIR@
 INST_DIR            = @INSTDIR@
+GRASS_VERSION_MAJOR = @GRASS_VERSION_MAJOR@
+GRASS_VERSION_MINOR = @GRASS_VERSION_MINOR@
+GRASS_VERSION_RELEASE = @GRASS_VERSION_RELEASE@
+GRASS_VERSION_DATE  = @GRASS_VERSION_DATE@
 PLAT_OBJS           = @PLAT_OBJS@
 STRIPFLAG           = @STRIPFLAG@
 CC_SEARCH_FLAGS     = @CC_SEARCH_FLAGS@
@@ -47,6 +52,11 @@
 LD_LIBRARY_PATH_VAR = @LD_LIBRARY_PATH_VAR@
 LIB_RUNTIME_DIR     = $(ARCH_LIBDIR)
+#generate static (ST) or shared (SH)
+LIB_PREFIX          = @GRASS_LIB_PREFIX@
+LIB_SUFFIX          = @GRASS_LIB_SUFFIX@
+GRASS_LIBRARY_TYPE  = @GRASS_LIBRARY_TYPE@
 #static libs:
 STLIB_LD            = @STLIB_LD@
 STLIB_PREFIX        = lib
Deleted: grass/trunk/include/winname.h.in
--- grass/trunk/include/winname.h.in	2008-08-12 04:25:52 UTC (rev 32706)
+++ grass/trunk/include/winname.h.in	2008-08-12 04:30:04 UTC (rev 32707)
@@ -1 +0,0 @@
-#define WIN_NAME "@GRASS_VERSION_NUMBER@"
Copied: grass/trunk/swig/python/Makefile (from rev 32689, grass/trunk/swig/python/Makefile.in)
--- grass/trunk/swig/python/Makefile	                        (rev 0)
+++ grass/trunk/swig/python/Makefile	2008-08-12 04:30:04 UTC (rev 32707)
@@ -0,0 +1,32 @@
+MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+CFLAGS=-c -fpic -I./ -I$(ARCH_DISTDIR)/include $(GDALCFLAGS) $(PYTHONCFLAGS)
+LDFLAGS=-shared -L$(ARCH_LIBDIR) $(GDALLIBS) $(PYTHONLDFLAGS) -lgrass_I -lgrass_Iortho -lgrass_bitmap -lgrass_btree -lgrass_cdhc -lgrass_datetime -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dbmidriver -lgrass_dbstubs -lgrass_dgl -lgrass_display -lgrass_dspf -lgrass_edit -lgrass_form -lgrass_g3d -lgrass_gis -lgrass_gmath -lgrass_gproj -lgrass_interpdata -lgrass_interpfl -lgrass_linkm -lgrass_qtree -lgrass_raster -lgrass_rowio -lgrass_rtree -lgrass_segment -lgrass_shape -lgrass_sites -lgrass_symb -lgrass_trans -lgrass_vask -lgrass_vect -lgrass_psdriver
+# TODO: build the NumPtr module. See NumPtr/README.GRASS
+#SUBDIRS = NumPtr
+#include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: python_grass7.so
+clean:
+	-rm -f *.o *.so python_grass7_wrap.c python_grass7.pyc python_grass7.py
+python_grass7_wrap.c: python_grass7.i
+	$(MAKE) -C interfaces
+	$(SWIG) -python -shadow $<
+python_grass7_wrap.o: python_grass7_wrap.c
+	$(CC) $(CFLAGS) $(INCLUDE_DIRS) $<
+python_grass7.so: python_grass7_wrap.o
+	$(LD) $(LDFLAGS) $< -o _python_grass7.so
+# doxygen:
+DOXNAME=
+DOXINPUT=grasspython.dox
Deleted: grass/trunk/swig/python/Makefile.in
--- grass/trunk/swig/python/Makefile.in	2008-08-12 04:25:52 UTC (rev 32706)
+++ grass/trunk/swig/python/Makefile.in	2008-08-12 04:30:04 UTC (rev 32707)
@@ -1,35 +0,0 @@
-MODULE_TOPDIR = ../..
-include $(MODULE_TOPDIR)/include/Make/Lib.make
-include $(MODULE_TOPDIR)/include/Make/Doxygen.make
-CFLAGS=-c -fpic -I./ -I$(ARCH_DISTDIR)/include $(GDALCFLAGS) $(PYTHONCFLAGS)
-LDFLAGS=-shared -L$(ARCH_LIBDIR) $(GDALLIBS) $(PYTHONLDFLAGS) -lgrass_I -lgrass_Iortho -lgrass_bitmap -lgrass_btree -lgrass_cdhc -lgrass_datetime -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dbmidriver -lgrass_dbstubs -lgrass_dgl -lgrass_display -lgrass_dspf -lgrass_edit -lgrass_form -lgrass_g3d -lgrass_gis -lgrass_gmath -lgrass_gproj -lgrass_interpdata -lgrass_interpfl -lgrass_linkm -lgrass_qtree -lgrass_raster -lgrass_rowio -lgrass_rtree -lgrass_segment -lgrass_shape -lgrass_sites -lgrass_symb -lgrass_trans -lgrass_vask -lgrass_vect -lgrass_psdriver
-# TODO: build the NumPtr module. See NumPtr/README.GRASS
-#SUBDIRS = NumPtr
-#include $(MODULE_TOPDIR)/include/Make/Dir.make
-default: python_grass7.so
-clean:
-	-rm -f *.o *.so python_grass7_wrap.c python_grass7.pyc python_grass7.py
-distclean: clean
-	-rm -f Makefile
-python_grass7_wrap.c: python_grass7.i
-	$(MAKE) -C interfaces
-	$(SWIG) -python -shadow $<
-python_grass7_wrap.o: python_grass7_wrap.c
-	$(CC) $(CFLAGS) $(INCLUDE_DIRS) $<
-python_grass7.so: python_grass7_wrap.o
-	$(LD) $(LDFLAGS) $< -o _python_grass7.so
-# doxygen:
-DOXNAME=
-DOXINPUT=grasspython.dox
