[GRASS-SVN] r32719 - in grass/trunk/raster: r.his r.out.mpeg r.support
Tue Aug 12 06:12:02 EDT 2008
Author: glynn
Date: 2008-08-12 06:12:02 -0400 (Tue, 12 Aug 2008)
New Revision: 32719
   grass/trunk/raster/r.his/main.c
   grass/trunk/raster/r.out.mpeg/main.c
   grass/trunk/raster/r.support/check.c
   grass/trunk/raster/r.support/front.c
   grass/trunk/raster/r.support/histo.c
   grass/trunk/raster/r.support/local_proto.h
Don't use explicit mapsets unnecessarily
Modified: grass/trunk/raster/r.his/main.c
--- grass/trunk/raster/r.his/main.c	2008-08-12 10:08:56 UTC (rev 32718)
+++ grass/trunk/raster/r.his/main.c	2008-08-12 10:12:02 UTC (rev 32719)
@@ -29,7 +29,6 @@
     unsigned char *sat_n, *sat_r;
     unsigned char *dummy;
     CELL *r_array, *g_array, *b_array;
-    char *mapset;
     char *name_h, *name_i, *name_s;
     int intensity;
     int saturation;
@@ -122,12 +121,8 @@
     /* Get name of layer to be used for hue */
     name_h = opt_h->answer;
-    mapset = G_find_cell2(name_h, "");
-    if (mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), opt_h->answer);
     /* Make sure map is available */
-    if ((hue_file = G_open_cell_old(name_h, mapset)) == -1)
+    if ((hue_file = G_open_cell_old(name_h, "")) == -1)
 	G_fatal_error(_("Unable to open raster map <%s>"), name_h);
     hue_r = G_malloc(window.cols);
@@ -138,7 +133,7 @@
     dummy = G_malloc(window.cols);
     /* Reading color lookup table */
-    if (G_read_colors(name_h, mapset, &hue_colors) == -1)
+    if (G_read_colors(name_h, "", &hue_colors) == -1)
 	G_fatal_error(_("Color file for <%s> not available"), name_h);
     int_used = 0;
@@ -146,23 +141,17 @@
     if (opt_i->answer != NULL) {
 	/* Get name of layer to be used for intensity */
 	name_i = opt_i->answer;
-	mapset = G_find_cell2(name_i, "");
-	if (mapset != NULL) {
-	    int_used = 1;
-	    /* Make sure map is available */
-	    if ((int_file = G_open_cell_old(name_i, mapset)) == -1)
-		G_fatal_error(_("Unable to open raster map <%s>"), name_i);
+	int_used = 1;
+	/* Make sure map is available */
+	if ((int_file = G_open_cell_old(name_i, "")) == -1)
+	    G_fatal_error(_("Unable to open raster map <%s>"), name_i);
-	    int_r = G_malloc(window.cols);
-	    int_n = G_malloc(window.cols);
+	int_r = G_malloc(window.cols);
+	int_n = G_malloc(window.cols);
-	    /* Reading color lookup table */
-	    if (G_read_colors(name_i, mapset, &int_colors) == -1)
-		G_fatal_error(_("Color file for <%s> not available"), name_i);
-	else
-	    G_fatal_error(_("Raster map <%s> not found"), name_i);
+	/* Reading color lookup table */
+	if (G_read_colors(name_i, "", &int_colors) == -1)
+	    G_fatal_error(_("Color file for <%s> not available"), name_i);
     sat_used = 0;
@@ -170,24 +159,18 @@
     if (opt_s->answer != NULL) {
 	/* Get name of layer to be used for saturation */
 	name_s = opt_s->answer;
-	mapset = G_find_cell2(name_s, "");
 	    sat_used = 1;
-	    if ((sat_file = G_open_cell_old(name_s, mapset)) == -1)
+	    if ((sat_file = G_open_cell_old(name_s, "")) == -1)
 		G_fatal_error(_("Unable to open raster map <%s>"), name_s);
 	    sat_r = G_malloc(window.cols);
 	    sat_n = G_malloc(window.cols);
-	    if (G_read_colors(name_s, mapset, &sat_colors) == -1)
+	    if (G_read_colors(name_s, "", &sat_colors) == -1)
 		G_fatal_error(_("Color file for <%s> not available"), name_s);
-	else
-	    G_fatal_error(_("Raster map <%s> not found"), name_s);
     r_used = 0;
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c	2008-08-12 10:08:56 UTC (rev 32718)
+++ grass/trunk/raster/r.out.mpeg/main.c	2008-08-12 10:12:02 UTC (rev 32719)
@@ -157,12 +157,12 @@
     void *voidc;
     int rtype;
     register int i, rowoff, row, col, vxoff, vyoff, offset;
-    int cnt, ret, fd, size, tsiz, coff;
+    int cnt, fd, size, tsiz, coff;
     int vnum;
     int y_rows, y_cols;
     char *pr, *pg, *pb;
     unsigned char *tr, *tg, *tb, *tset;
-    char *mpfilename, *mapset, name[BUFSIZ];
+    char *mpfilename, *name;
     char cmd[1000], *yfiles[MAXIMAGES];
     struct Colors colors;
@@ -208,36 +208,24 @@
 		vyoff = vnum > 1 ? vrows + 2 * BORDER_W : BORDER_W;
-	    strcpy(name, vfiles[vnum][cnt]);
+	    name = vfiles[vnum][cnt];
 	    if (!quiet)
 		G_message("\r%s <%s>", _("Reading file"), name);
-	    mapset = G_find_cell2(name, "");
+	    fd = G_open_cell_old(name, "");
+	    if (fd < 0)
 		G_fatal_error(_("Raster map <%s> not found"), name);
-	    fd = G_open_cell_old(name, mapset);
-	    if (fd < 0)
-		exit(EXIT_FAILURE);
+	    if (G_read_colors(name, "", &colors) < 0)
+		G_fatal_error(_("Unable to read color table for <%s>"), name);
-	    ret = G_read_colors(name, mapset, &colors);
-	    if (ret < 0)
 	    rtype = G_get_raster_map_type(fd);
-	    if (rtype == CELL_TYPE)
-		voidc = G_allocate_c_raster_buf();
-	    else if (rtype == FCELL_TYPE)
-		voidc = G_allocate_f_raster_buf();
-	    else if (rtype == DCELL_TYPE)
-		voidc = G_allocate_d_raster_buf();
-	    else
+	    voidc = G_allocate_raster_buf(rtype);
 	    for (row = 0; row < vrows; row++) {
 		if (G_get_raster_row(fd, voidc,
 				     (int)(row / vscale), rtype) < 0)
+		    G_fatal_error(_("Error reading row <%d>"), row);
 		rowoff = (vyoff + row) * ncols;
 		G_lookup_raster_colors(voidc, tr, tg, tb,
@@ -321,7 +309,7 @@
 static char **gee_wildfiles(char *wildarg, char *element, int *num)
     int n, cnt = 0;
-    char path[1000], *mapset, cmd[1000], buf[512];
+    char path[GPATH_MAX], *mapset, cmd[GPATH_MAX], buf[512];
     char *p, *tfile;
     static char *newfiles[MAXIMAGES];
     FILE *tf;
Modified: grass/trunk/raster/r.support/check.c
--- grass/trunk/raster/r.support/check.c	2008-08-12 10:08:56 UTC (rev 32718)
+++ grass/trunk/raster/r.support/check.c	2008-08-12 10:12:02 UTC (rev 32719)
@@ -9,7 +9,7 @@
  * RETURN: EXIT_SUCCESS / EXIT_FAILURE
-int check_stats(const char *name, const char *mapset)
+int check_stats(const char *name)
     RASTER_MAP_TYPE data_type;
     struct Histogram histogram;
@@ -20,12 +20,12 @@
     int cats_ok;
     int max;
-    data_type = G_raster_map_type(name, mapset);
+    data_type = G_raster_map_type(name, "");
     G_message(_("\n  Updating statistics for [%s]"), name);
-    if (!do_histogram(name, mapset))
+    if (!do_histogram(name))
 	return EXIT_SUCCESS;
-    if (G_read_histogram(name, mapset, &histogram) <= 0)
+    if (G_read_histogram(name, "", &histogram) <= 0)
     /* Init histogram range */
@@ -51,7 +51,7 @@
 	G_write_fp_range(name, &fprange);
     /* Get category status and max */
-    cats_ok = (G_read_cats(name, mapset, &cats) >= 0);
+    cats_ok = (G_read_cats(name, "", &cats) >= 0);
     max = (data_type == CELL_TYPE ? range.max : fprange.max);
     /* Further category checks */
Modified: grass/trunk/raster/r.support/front.c
--- grass/trunk/raster/r.support/front.c	2008-08-12 10:08:56 UTC (rev 32718)
+++ grass/trunk/raster/r.support/front.c	2008-08-12 10:12:02 UTC (rev 32719)
@@ -44,7 +44,7 @@
     struct Flag *stats_flag, *null_flag, *del_flag;
     int cellhd_ok;		/* Is cell header OK? */
     int is_reclass;		/* Is raster reclass? */
-    char *infile, *cmapset;
+    char *infile;
     char title[MAX_TITLE_LEN + 1], datasrc[RECORD_LEN + 1];
     struct History hist;
@@ -143,12 +143,11 @@
     /* Make sure raster exists and set mapset */
     infile = raster->answer;
     mapset = G_find_cell2(infile, G_mapset());	/* current mapset only for editing */
-	G_fatal_error(_("Raster map <%s> not found in current mapset"),
-		      infile);
+    if (!mapset || strcmp(mapset, G_mapset()) != 0)
+	G_fatal_error(_("Raster map <%s> not found in current mapset"), infile);
-    cellhd_ok = (G_get_cellhd(raster->answer, mapset, &cellhd) >= 0);
-    is_reclass = (G_is_reclass(raster->answer, mapset, rname, rmapset) > 0);
+    cellhd_ok = (G_get_cellhd(raster->answer, "", &cellhd) >= 0);
+    is_reclass = (G_is_reclass(raster->answer, "", rname, rmapset) > 0);
     if (title_opt->answer) {
 	strncpy(title, title_opt->answer, MAX_TITLE_LEN);
@@ -165,7 +164,7 @@
 	if (!fp)
 	    G_fatal_error(_("Unable to open output file <%s>"), save_opt->answer);
-	G_read_history(raster->answer, mapset, &hist);
+	G_read_history(raster->answer, "", &hist);
 	for (i = 0; i < hist.edlinecnt; i++)
 	    fprintf(fp, "%s\n", hist.edhist[i]);
@@ -180,7 +179,7 @@
 	if (!fp)
 	    G_fatal_error(_("Unable to open input file <%s>"), load_opt->answer);
 	for (i = 0; ; i++) {
 	    if (i >= MAXEDLINES) {
@@ -199,7 +198,7 @@
     if (history_opt->answer) {
 	if (hist.edlinecnt >= MAXEDLINES)
 	    G_fatal_error(_("Not enough room in history file"));
@@ -246,7 +245,7 @@
 	G_write_raster_vdatum(raster->answer, vdatum_opt->answer);
     if (datasrc1_opt->answer || datasrc2_opt->answer || datadesc_opt->answer) {
 	if (datasrc1_opt->answer) {
 	    strncpy(datasrc, datasrc1_opt->answer, RECORD_LEN);
@@ -281,16 +280,12 @@
 	int fd;
 	struct Categories cats;
-	cmapset = G_find_cell2(map_opt->answer, "");
-	if (cmapset == NULL)
-	    G_fatal_error(_("Raster map <%s> not found"), map_opt->answer);
-	if ((fd = G_open_cell_old(infile, mapset)) < 0)
+	if ((fd = G_open_cell_old(infile, "")) < 0)
 	    G_fatal_error(_("Unable to open raster map <%s>"), infile);
 	G_init_cats((CELL) 0, "", &cats);
-	if (0 > G_read_cats(map_opt->answer, cmapset, &cats))
-	    G_fatal_error(_("Unable to read category file of raster map <%s@%s>"),
-			  map_opt->answer, cmapset);
+	if (G_read_cats(map_opt->answer, "", &cats) < 0)
+	    G_fatal_error(_("Unable to read category file of raster map <%s>"),
+			  map_opt->answer);
 	if (G_write_cats(infile, &cats) >= 0)
 	    G_message(_("cats table for [%s] set to %s"), infile,
@@ -308,7 +303,7 @@
     /* Check the histogram and range */
     if (stats_flag->answer)
-	check_stats(raster->answer, mapset);
+	check_stats(raster->answer);
     /* null file */
     if (null_flag->answer) {
@@ -354,7 +349,7 @@
 	G_message(_("Removing null file for [%s]...\n"), raster->answer);
 	null_fd = G_open_new_misc("cell_misc", "null", raster->answer);
-	G__file_name_misc(path, "cell_misc", "null", raster->answer, mapset);
+	G__file_name_misc(path, "cell_misc", "null", raster->answer, G_mapset());
 	unlink(path);
 	close(null_fd);
Modified: grass/trunk/raster/r.support/histo.c
--- grass/trunk/raster/r.support/histo.c	2008-08-12 10:08:56 UTC (rev 32718)
+++ grass/trunk/raster/r.support/histo.c	2008-08-12 10:12:02 UTC (rev 32719)
@@ -1,13 +1,14 @@
 #include <stdlib.h>
 #include <grass/gis.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
  * do_histogram() - Creates histogram for CELL
-int do_histogram(const char *name, const char *mapset)
+int do_histogram(const char *name)
     CELL *cell;
     struct Cell_head cellhd;
@@ -16,12 +17,12 @@
     int row;
     int fd;
-    if (G_get_cellhd(name, mapset, &cellhd) < 0)
-	return EXIT_FAILURE;
+    if (G_get_cellhd(name, "", &cellhd) < 0)
+	G_fatal_error(_("Unable to read header for <%s>"), name);
     G_set_window(&cellhd);
-    if ((fd = G_open_cell_old(name, mapset)) < 0)
+    if ((fd = G_open_cell_old(name, "")) < 0)
+	G_fatal_error(_("Unable to open <%s>"), name);
     nrows = G_window_rows();
     ncols = G_window_cols();
Modified: grass/trunk/raster/r.support/local_proto.h
--- grass/trunk/raster/r.support/local_proto.h	2008-08-12 10:08:56 UTC (rev 32718)
+++ grass/trunk/raster/r.support/local_proto.h	2008-08-12 10:12:02 UTC (rev 32719)
@@ -1,5 +1,5 @@
 /* check.c */
-int check_stats(const char *, const char *);
+int check_stats(const char *);
 /* histo.c */
-int do_histogram(const char *, const char *);
+int do_histogram(const char *);
