[GRASS-SVN] r32725 - in grass/branches/develbranch_6: db/base gui/wxpython/gui_modules include lib/gis scripts/db.dropcol scripts/db.droptable
Tue Aug 12 09:35:20 EDT 2008
Author: martinl
Date: 2008-08-12 09:35:20 -0400 (Tue, 12 Aug 2008)
New Revision: 32725
   grass/branches/develbranch_6/db/base/columns.c
   grass/branches/develbranch_6/db/base/connect.c
   grass/branches/develbranch_6/db/base/copy.c
   grass/branches/develbranch_6/db/base/describe.c
   grass/branches/develbranch_6/db/base/drivers.c
   grass/branches/develbranch_6/db/base/execute.c
   grass/branches/develbranch_6/db/base/select.c
   grass/branches/develbranch_6/db/base/tables.c
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
   grass/branches/develbranch_6/include/gis.h
   grass/branches/develbranch_6/lib/gis/parser.c
   grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
   grass/branches/develbranch_6/scripts/db.droptable/db.droptable
gislib: GISPROMPT_DBTABLE defined, various prompt, keywords fixes, wxGUI updated
Modified: grass/branches/develbranch_6/db/base/columns.c
--- grass/branches/develbranch_6/db/base/columns.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/columns.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -81,15 +81,15 @@
     driver = G_define_standard_option(G_OPT_DRIVER);
     driver->options = db_list_drivers();
     if ((drv = db_get_default_driver_name()))
-	driver->answer = drv;
+	driver->answer = (char *) drv;
     database = G_define_standard_option(G_OPT_DATABASE);
     if ((db = db_get_default_database_name()))
-	database->answer = db;
+	database->answer = (char *) db;
     /* Set description */
     module = G_define_module();
-    module->keywords = _("database, SQL");
+    module->keywords = _("database, attribute table");
     module->description = _("List all columns for a given table.");
     if (G_parser(argc, argv))
Modified: grass/branches/develbranch_6/db/base/connect.c
--- grass/branches/develbranch_6/db/base/connect.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/connect.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -42,7 +42,7 @@
 	_("Prints/sets general DB connection for current mapset and exits.");
@@ -58,17 +58,17 @@
-    driver->answer = db_get_default_driver_name();
+    driver->answer = (char *) db_get_default_driver_name();
-    database->answer = db_get_default_database_name();
+    database->answer = (char *) db_get_default_database_name();
     schema = G_define_option();
     schema->key = "schema";
     schema->type = TYPE_STRING;
     schema->required = NO;
     schema->multiple = NO;
-    schema->answer = db_get_default_schema_name();
+    schema->answer = (char *) db_get_default_schema_name();
     schema->label = _("Database schema");
     schema->description = _("Do not use this option if schemas "
 			    "are not supported by driver/database server");
@@ -78,7 +78,7 @@
     group->type = TYPE_STRING;
     group->required = NO;
     group->multiple = NO;
-    group->answer = db_get_default_group_name();
+    group->answer = (char*) db_get_default_group_name();
     group->description = _("Default group of database users to which "
 			   "select privilege is granted");
Modified: grass/branches/develbranch_6/db/base/copy.c
--- grass/branches/develbranch_6/db/base/copy.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/copy.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -31,73 +31,58 @@
+    module->keywords = _("database, attribute table, SQL");
+    module->label = _("Copy a table.");
-	_("Copy a table. Either 'from_table' (optionaly with 'where') can be used "
-	 "or 'select' option, but not 'from_table' and 'select' at the same time.");
+	_("Either 'from_table' (optionaly with 'where') can be used "
+	  "or 'select' option, but not 'from_table' and 'select' at the same time.");
-    from_driver = G_define_option();
+    from_driver = G_define_standard_option(G_OPT_DRIVER);
     from_driver->key = "from_driver";
-    from_driver->type = TYPE_STRING;
     from_driver->options = db_list_drivers();
-    from_driver->required = NO;
     from_driver->description = _("Input driver name");
-	from_driver->answer = drv;
+      from_driver->answer = (char *) drv;
-    from_database = G_define_option();
+    from_database = G_define_standard_option(G_OPT_DATABASE);
     from_database->key = "from_database";
-    from_database->type = TYPE_STRING;
-    from_database->required = NO;
     from_database->description = _("Input database name");
-	from_database->answer = db;
+      from_database->answer = (char *) db;
-    from_table = G_define_option();
+    from_table = G_define_standard_option(G_OPT_TABLE);
     from_table->key = "from_table";
-    from_table->type = TYPE_STRING;
-    from_table->required = NO;
     from_table->description =
 	_("Input table name (only, if 'select' is not used)");
-    to_driver = G_define_option();
+    to_driver = G_define_standard_option(G_OPT_DRIVER);
     to_driver->key = "to_driver";
-    to_driver->type = TYPE_STRING;
     to_driver->options = db_list_drivers();
     to_driver->required = NO;
     to_driver->description = _("Output driver name");
-	to_driver->answer = drv;
+      to_driver->answer = (char *) drv;
-    to_database = G_define_option();
+    to_database = G_define_standard_option(G_OPT_DATABASE);
     to_database->key = "to_database";
-    to_database->type = TYPE_STRING;
-    to_database->required = NO;
     to_database->description = _("Output database name");
-	to_database->answer = db;
+      to_database->answer = (char *) db;
-    to_table = G_define_option();
+    to_table = G_define_standard_option(G_OPT_TABLE);
     to_table->key = "to_table";
-    to_table->type = TYPE_STRING;
     to_table->required = YES;
     to_table->description = _("Output table name");
+    to_table->gisprompt = "new,dbtable,dbtable";
-    where = G_define_option();
-    where->key = "where";
-    where->type = TYPE_STRING;
-    where->required = NO;
-    where->description =
-	_("Optional where condition (without WHERE key word), e.g.:\n"
-	  "\t\tobec = 'Liptakov'");
+    where = G_define_standard_option(G_OPT_WHERE);
     select = G_define_option();
     select->key = "select";
     select->type = TYPE_STRING;
     select->required = NO;
-    select->description =
-	_("Full select statement (only, if 'from_table' and 'where' is not used), e.g.:\n"
-	 "\t\tSELECT dedek FROM starobince WHERE obec = 'Frimburg'");
+    select->label = _("Full select statement (only, if 'from_table' and 'where' is not used)");
+    select->description = _("E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'");
 	exit(EXIT_FAILURE);
Modified: grass/branches/develbranch_6/db/base/describe.c
--- grass/branches/develbranch_6/db/base/describe.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/describe.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -114,15 +114,15 @@
     module->description = _("Describes a table in detail.");
Modified: grass/branches/develbranch_6/db/base/drivers.c
--- grass/branches/develbranch_6/db/base/drivers.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/drivers.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -71,7 +71,7 @@
     module->description = _("List all database drivers.");
Modified: grass/branches/develbranch_6/db/base/execute.c
--- grass/branches/develbranch_6/db/base/execute.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/execute.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -103,7 +103,7 @@
     module->description = _("Executes any SQL statement.");
     input = G_define_standard_option(G_OPT_F_INPUT);
@@ -113,11 +113,11 @@
     i = G_define_flag();
     i->key = 'i';
Modified: grass/branches/develbranch_6/db/base/select.c
--- grass/branches/develbranch_6/db/base/select.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/select.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -176,12 +176,12 @@
     sql = G_define_option();
     sql->key = "sql";
@@ -227,7 +227,7 @@
     module->description = _("Selects data from table.");
Modified: grass/branches/develbranch_6/db/base/tables.c
--- grass/branches/develbranch_6/db/base/tables.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/db/base/tables.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -76,11 +76,11 @@
     p = G_define_flag();
     p->key = 'p';
@@ -92,7 +92,7 @@
     module->description = _("Lists all tables for a given database.");
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2008-08-12 13:35:20 UTC (rev 32725)
@@ -192,16 +192,17 @@
         if grassModule is not None:
             xml.sax.parseString( getInterfaceDescription( grassModule ) , processTask( self ) )
-    def get_param( self, aParam ):
-        Find and return a param by name.
+    def get_param(self, aParam, raiseError=True):
+        """Find and return a param by name."""
         for p in self.params:
             lparam = len(aParam)
             if p['name'] == aParam or \
                     p['name'][:lparam] == aParam:
                 return p
-        raise ValueError, _("Parameter not found: %s") % aParam
+        if raiseError:
+            raise ValueError, _("Parameter not found: %s") % aParam
+        else:
+            return None
     def set_param(self, aParam, aValue):
@@ -1125,7 +1126,7 @@
                 which_sizer.Add(item=txt, proportion=0,
                                 flag=wx.ADJUST_MINSIZE | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
                 # element selection tree combobox (maps, icons, regions, etc.)
-                if p.get('prompt','') not in ('color', 'dbcolumn') and \
+                if p.get('prompt','') not in ('color', 'dbcolumn', 'dbtable') and \
                        p.get('element', '') != 'file':
                     if p.get('multiple','no') == 'yes':
                         multiple = True
@@ -1148,17 +1149,24 @@
                     p['wxId'] = selection.GetChildren()[0].GetId()
                     selection.Bind(wx.EVT_TEXT, self.OnSetValue)
                 # dbcolumn entry
-                elif p.get('prompt','') == 'dbcolumn':
+                elif p.get('prompt','') in ('dbcolumn', 'dbtable'):
+                    if p.get('age', 'old') == 'old':
+                        style = wx.CB_SIMPLE | wx.CB_READONLY
+                    else:
                     columns = wx.ComboBox(parent=which_panel, id=wx.ID_ANY,
                                           size=globalvar.DIALOG_COMBOBOX_SIZE,
-                                          style=wx.CB_SIMPLE | wx.CB_READONLY,
+                                          style=style,
                                           choices=[])
                     p['wxId'] = columns.GetId()
                     p['wxGetValue'] = columns.GetStringSelection
-                    columns.Bind(wx.EVT_ENTER_WINDOW, self.OnDbColumn)
+                    if p.get('prompt', '') == 'dbcolumn':
+                        columns.Bind(wx.EVT_ENTER_WINDOW, self.OnDbColumn)
+                    else:
+                        columns.Bind(wx.EVT_ENTER_WINDOW, self.OnDbTable)
                     columns.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
                     which_sizer.Add(item=columns, proportion=0,
-                                   flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
+                                    flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
                 # color entry
                 elif p.get('prompt','') == 'color':
                     # Heuristic way of finding whether transparent is allowed
@@ -1374,28 +1382,40 @@
     def OnDbColumn(self, event):
         """Get list of table columns"""
         choices = []
-        mapName = utils.GetLayerNameFromCmd(self.task.getCmd(ignoreErrors=True))
-        if mapName !=  _('<required>'):
-            layer = 1
-            for p in self.task.params:
-                if p.get('name', '') == 'layer':
-                    value = p.get('value', '1')
-                    if value:
-                        layer = int(value)
-                    break
-            cmd = ['v.info',
-                   'map=%s' % mapName,
-                   'layer=%d' % layer,
-                   '-c', '--q']
+        p = self.task.get_param('table', raiseError=False)
+        if p and p.get('prompt', '') == 'dbtable':
+            cmd = ['db.columns',
+                   'table=%s' % p.get('value')]
             try:
-                for line in gcmd.Command(cmd).ReadStdOutput():
-                    type, name = line.split('|')
-                    choices.append(name.strip())
+                choices = gcmd.Command(cmd).ReadStdOutput()
             except gcmd.CmdError:
-                pass
+                choices = []
+        if not p:
+            p = self.task.get_param('map', raiseError=False)
+            if not p:
+                p = self.task.get_param('input', raiseError=False)
+            if p:
+                mapName = utils.GetLayerNameFromCmd(self.task.getCmd(ignoreErrors=True))
+                if mapName !=  _('<required>'):
+                    layer = 1
+                    p = self.task.get_param('layer')
+                    if p:
+                        value = p.get('value', '1')
+                        if value:
+                            layer = int(value)
+                    cmd = ['v.info',
+                           'map=%s' % mapName,
+                           'layer=%d' % layer,
+                           '-c', '--q']
+                    try:
+                        for line in gcmd.Command(cmd).ReadStdOutput():
+                            type, name = line.split('|')
+                            choices.append(name.strip())
+                    except gcmd.CmdError:
+                        choices = []
         win = self.FindWindowById(event.GetId())
@@ -1406,6 +1426,33 @@
         event.Skip()
+    def OnDbTable(self, event):
+        """Get list of tables"""
+        # TODO: add driver/database
+        cmd = ['db.tables',
+               '-p', '--q']
+        for p in self.task.params:
+            if p.get('name', '') == 'driver' and \
+               len(p.get('value', '')) > 0:
+                cmd.append('driver=%s' % p.get('value'))
+            elif p.get('name', '') == 'database' and \
+                cmd.append('database=%s' % p.get('value'))
+        try:
+            choices = []
+        win = self.FindWindowById(event.GetId())
+        win.SetItems(choices)
+        if len(choices) < 1:
+            win.SetValue('')
+        event.Skip()
     def createCmd( self, ignoreErrors = False ):
         Produce a command line string (list) or feeding into GRASS.
Modified: grass/branches/develbranch_6/include/gis.h
--- grass/branches/develbranch_6/include/gis.h	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/include/gis.h	2008-08-12 13:35:20 UTC (rev 32725)
@@ -103,8 +103,9 @@
 #define TYPE_STRING   3
 #define YES           1
 #define NO            0
-#define GISPROMPT_COLOR "color,grass,color"
-#define GISPROMPT_DBCOLUMN "dbcolumn,grass,dbcolumn"
+#define GISPROMPT_COLOR    "old,color,color"
+#define GISPROMPT_DBCOLUMN "old,dbcolumn,dbcolumn"
+#define GISPROMPT_DBTABLE  "old,dbtable,dbtable"
 /* File/directory name lengths */
 #define GNAME_MAX 256
Modified: grass/branches/develbranch_6/lib/gis/parser.c
--- grass/branches/develbranch_6/lib/gis/parser.c	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/lib/gis/parser.c	2008-08-12 13:35:20 UTC (rev 32725)
@@ -335,6 +335,7 @@
 	Opt->required = NO;
 	Opt->multiple = NO;
 	Opt->description = _("Table name");
+	Opt->gisprompt = GISPROMPT_DBTABLE;
 	break;
     case G_OPT_DRIVER:
 	Opt->key = "driver";
Modified: grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol
--- grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/scripts/db.dropcol/db.dropcol	2008-08-12 13:35:20 UTC (rev 32725)
@@ -32,6 +32,7 @@
 #% key_desc : name
 #% description: Table from which to drop attribute column
 #% required : yes
+#% gisprompt: old,dbtable,dbtable
 #%end
 #%option
@@ -39,6 +40,7 @@
 #% type: string
 #% description: Name of the column
 #% required : yes
+#% gisprompt: old,dbcolumn,dbcolumn
 #%end
Modified: grass/branches/develbranch_6/scripts/db.droptable/db.droptable
--- grass/branches/develbranch_6/scripts/db.droptable/db.droptable	2008-08-12 12:57:13 UTC (rev 32724)
+++ grass/branches/develbranch_6/scripts/db.droptable/db.droptable	2008-08-12 13:35:20 UTC (rev 32725)
@@ -15,7 +15,7 @@
 #%Module
-#%  description: Drops an attribute table
+#%  description: Drops an attribute table.
 #%  keywords: database, attribute table
 #%End
@@ -30,6 +30,7 @@
 #% key_desc : name
 #% description: Table to drop
 #% required : yes
 #%end
 if  [ -z "$GISBASE" ] ; then
