[GRASS-SVN] r32750 - grass/branches/develbranch_6/vector/v.distance
Wed Aug 13 15:52:37 EDT 2008
Author: mlennert
Date: 2008-08-13 15:52:37 -0400 (Wed, 13 Aug 2008)
New Revision: 32750
   grass/branches/develbranch_6/vector/v.distance/description.html
   grass/branches/develbranch_6/vector/v.distance/main.c
added dmin (merge from trunk, r32748)
Modified: grass/branches/develbranch_6/vector/v.distance/description.html
--- grass/branches/develbranch_6/vector/v.distance/description.html	2008-08-13 19:51:39 UTC (rev 32749)
+++ grass/branches/develbranch_6/vector/v.distance/description.html	2008-08-13 19:52:37 UTC (rev 32750)
@@ -5,7 +5,7 @@
 information about the vectors' relationships (distance, category, etc.) may be uploaded
 to the attribute table attached to the first vector map, or printed to
 'stdout'.  A new vector map may be created where lines connecting
-nearest points on features are written.
+nearest points on features are written. <em>dmin</em> and/or <em>dmax</em> can be used to limit the search radius.
 <H2>NOTES</H2>
Modified: grass/branches/develbranch_6/vector/v.distance/main.c
--- grass/branches/develbranch_6/vector/v.distance/main.c	2008-08-13 19:51:39 UTC (rev 32749)
+++ grass/branches/develbranch_6/vector/v.distance/main.c	2008-08-13 19:52:37 UTC (rev 32750)
@@ -78,12 +78,12 @@
     struct GModule *module;
     struct Option *from_opt, *to_opt, *from_type_opt, *to_type_opt,
 	*from_field_opt, *to_field_opt;
-    struct Option *out_opt, *max_opt, *table_opt;
+    struct Option *out_opt, *max_opt, *min_opt, *table_opt;
     struct Option *upload_opt, *column_opt, *to_column_opt;
     struct Flag *print_flag, *all_flag;
     struct Map_info From, To, Out, *Outp;
     int from_type, to_type, from_field, to_field;
-    double max;
+    double max, min;
     struct line_pnts *FPoints, *TPoints;
     struct line_cats *FCats, *TCats;
     NEAR *Near, *near;
@@ -163,6 +163,13 @@
     max_opt->answer = "-1";
     max_opt->description = _("Maximum distance or -1 for no limit");
+    min_opt = G_define_option();
+    min_opt->key = "dmin";
+    min_opt->type = TYPE_DOUBLE;
+    min_opt->required = NO;
+    min_opt->answer = "-1";
+    min_opt->description = _("Minimum distance or -1 for no limit");
     upload_opt = G_define_option();
     upload_opt->key = "upload";
     upload_opt->type = TYPE_STRING;
@@ -226,6 +233,7 @@
     to_field = atoi(to_field_opt->answer);
     max = atof(max_opt->answer);
+    min = atof(min_opt->answer);
     if (all_flag->answer)
 	all = 1;
@@ -539,7 +547,7 @@
 		Vect_point_on_line(TPoints, tmp_talong, NULL, NULL, NULL,
 				   &tmp_tangle, NULL);
-		if (tmp_dist > max)
+		if (tmp_dist > max || tmp_dist < min)
 		    continue;	/* not in threshold */
 		/* TODO: more cats of the same field */
