[GRASS-SVN] r32773 - in grass/trunk: include/Make lib/cairodriver lib/db/sqlp lib/pngdriver lib/psdriver raster/r.colors.out tools tools/mkftcap visualization/nviz visualization/ximgview
Fri Aug 15 04:35:12 EDT 2008
Author: glynn
Date: 2008-08-15 04:35:11 -0400 (Fri, 15 Aug 2008)
New Revision: 32773
Added:
   grass/trunk/raster/r.colors.out/r.colors.out.html
   grass/trunk/visualization/ximgview/ximgview.html
   grass/trunk/include/Make/Html.make
   grass/trunk/lib/cairodriver/
   grass/trunk/lib/db/sqlp/
   grass/trunk/lib/pngdriver/
   grass/trunk/lib/pngdriver/Makefile
   grass/trunk/lib/psdriver/
   grass/trunk/tools/mkftcap/Makefile
   grass/trunk/tools/mkhtml.sh
   grass/trunk/visualization/nviz/
Clean up HTML generation rules
Add missing $(PGM).html files for r.colors.out and ximgview
Fix name of pngdriver.html
Modified: grass/trunk/include/Make/Html.make
--- grass/trunk/include/Make/Html.make	2008-08-15 06:16:42 UTC (rev 32772)
+++ grass/trunk/include/Make/Html.make	2008-08-15 08:35:11 UTC (rev 32773)
@@ -18,28 +18,27 @@
 else
-htmlgen = \
-	$(MODULE_TOPDIR)/tools/mkhtml.sh $(PGM) ; \
-	$(MKDIR) $(HTMLDIR) ; \
-	$(INSTALL_DATA) $(PGM).tmp.html $(HTMLDIR)/$(PGM).html ; \
-	for file in  *.png *.jpg ; do \
+$(HTMLDIR)/$(PGM).html: $(PGM).html $(PGM).tmp.html
+	-$(MKDIR) $(HTMLDIR)
+	$(MODULE_TOPDIR)/tools/mkhtml.sh $(PGM)
+	$(INSTALL_DATA) $(PGM).tmp.html $@
+	-for file in  *.png *.jpg ; do \
 		head -n 1 $$file | grep '^\#!' > /dev/null ; \
 		if [ $$? -ne 0 ] ; then \
 		   $(INSTALL_DATA) $$file $(HTMLDIR) ; \
 		fi \
 		done 2> /dev/null ; true
-htmldesc = \
-	GISRC=$(RUN_GISRC) \
-	GISBASE=$(RUN_GISBASE) \
-	PATH="$(BIN):$$PATH" \
-	$(LD_LIBRARY_PATH_VAR)="$(BIN):$(ARCH_LIBDIR):$($(LD_LIBRARY_PATH_VAR))" \
-	LC_ALL=C $(1) --html-description < /dev/null | grep -v '</body>\|</html>' > $(PGM).tmp.html ; true
+$(PGM).tmp.html: $(HTMLSRC)
+	if [ "$(HTMLSRC)" != "" ] ; then \
+		GISRC=$(RUN_GISRC) \
+		GISBASE=$(RUN_GISBASE) \
+		PATH="$(BIN):$$PATH" \
+		$(LD_LIBRARY_PATH_VAR)="$(BIN):$(ARCH_LIBDIR):$($(LD_LIBRARY_PATH_VAR))" \
+		LC_ALL=C \
+		$(HTMLSRC) --html-description < /dev/null | grep -v '</body>\|</html>' > $@ ; \
+	fi
-$(HTMLDIR)/$(PGM).html: $(HTMLSRC)
-	if [ "$(HTMLSRC)" != "" ] ; then $(call htmldesc,$<) ; fi
-	$(call htmlgen)
 # html rules for cmd commands
 htmlcmd:
 	$(MAKE) $(HTMLDIR)/$(PGM).html HTMLSRC=$(BIN)/$(PGM)$(EXE)
Property changes on: grass/trunk/lib/cairodriver
___________________________________________________________________
   - *OBJ*
   + *.tmp.html
*OBJ*
Property changes on: grass/trunk/lib/db/sqlp
   - *OBJ*
y.tab.h
y.output
lex.yy.c
y.tab.c
   + *.tmp.html
*OBJ*
y.tab.h
y.output
lex.yy.c
y.tab.c
Property changes on: grass/trunk/lib/pngdriver
   - *OBJ*
   + *.tmp.html
*OBJ*
Modified: grass/trunk/lib/pngdriver/Makefile
--- grass/trunk/lib/pngdriver/Makefile	2008-08-15 06:16:42 UTC (rev 32772)
+++ grass/trunk/lib/pngdriver/Makefile	2008-08-15 08:35:11 UTC (rev 32773)
@@ -6,7 +6,7 @@
 EXTRA_LIBS=$(DRIVERLIB) $(GISLIB) $(PNGLIB)
 LIB_NAME = $(PNGDRIVER_LIBNAME)
-PGM = cairodriver
+PGM = pngdriver
 LIB_OBJS =	\
 	Box.o			\
Property changes on: grass/trunk/lib/psdriver
   - *OBJ*
   + *.tmp.html
*OBJ*
Added: grass/trunk/raster/r.colors.out/r.colors.out.html
--- grass/trunk/raster/r.colors.out/r.colors.out.html	                        (rev 0)
+++ grass/trunk/raster/r.colors.out/r.colors.out.html	2008-08-15 08:35:11 UTC (rev 32773)
@@ -0,0 +1,18 @@
+<h2>DESCRIPTION</h2>
+<i>r.colors.out</i> allows the user to export the color table for a
+raster map layer to a file which is suitable as input to <em>
+<a href="r.colors.html">r.colors</a></em>.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.colors.html">r.colors</a>,
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p>
+<i>Last changed: $Date: 2008-08-15 07:16:42 +0100 (Fri, 15 Aug 2008) $</i>
Modified: grass/trunk/tools/mkftcap/Makefile
--- grass/trunk/tools/mkftcap/Makefile	2008-08-15 06:16:42 UTC (rev 32772)
+++ grass/trunk/tools/mkftcap/Makefile	2008-08-15 08:35:11 UTC (rev 32773)
@@ -10,3 +10,6 @@
 $(CAPFILE): $(SCRIPTDIR)/$(PGM)
+htmlscript:
+	@true
Modified: grass/trunk/tools/mkhtml.sh
--- grass/trunk/tools/mkhtml.sh	2008-08-15 06:16:42 UTC (rev 32772)
+++ grass/trunk/tools/mkhtml.sh	2008-08-15 08:35:11 UTC (rev 32773)
@@ -21,8 +21,6 @@
 if test -f ${PGM}.html ; then
     cat ${PGM}.html >> ${PGM}.tmp.html
-elif test -f description.html ; then
-    cat description.html >> ${PGM}.tmp.html
 fi
 if ! grep -i '<html>' ${PGM}.tmp.html > /dev/null ; then
Property changes on: grass/trunk/visualization/nviz
   + *.tmp.html
*OBJ*
Added: grass/trunk/visualization/ximgview/ximgview.html
--- grass/trunk/visualization/ximgview/ximgview.html	                        (rev 0)
+++ grass/trunk/visualization/ximgview/ximgview.html	2008-08-15 08:35:11 UTC (rev 32773)
@@ -0,0 +1,26 @@
+<i>ximgview</i> is a simple X11 image viewer for 32-bpp BMP images, as
+can be created with the <em><a href="pngdriver.html">PNG</a></em> and
+<em><a href="cairodriver.html">cairo</a></em> drivers. The display is
+continually refreshed.
+<h2>NOTES</h2>
+The display driver must be configure to map the file, with
+<em>GRASS_PNG_MAPPED=TRUE</em>. This ensures that the file will remain
+a constant size, rather than being truncated whenever it is updated.
+<h2>SEE ALSO</h2>
+<em>
+<a href="pngdriver.html">PNG driver</a>
+<a href="cairodriver.html">cairo driver</a>
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p>
