[GRASS-SVN] r32778 - grass-addons/raster/r.rast4d/bin
Fri Aug 15 09:05:07 EDT 2008
Author: neteler
Date: 2008-08-15 09:05:07 -0400 (Fri, 15 Aug 2008)
New Revision: 32778
   grass-addons/raster/r.rast4d/bin/init_db.sh
don't generate replicated column names
Modified: grass-addons/raster/r.rast4d/bin/init_db.sh
--- grass-addons/raster/r.rast4d/bin/init_db.sh	2008-08-15 13:04:15 UTC (rev 32777)
+++ grass-addons/raster/r.rast4d/bin/init_db.sh	2008-08-15 13:05:07 UTC (rev 32778)
@@ -1,4 +1,5 @@
-#!/bin/sh -x
+#!/bin/sh
 #this script creates the database tables needed to store raster and temporal map informations
 #create the raster and temporal tables
@@ -9,8 +10,17 @@
 cat $GRAST4D_SQL_DIR/create_temporal_raster_metadata_table.sql | sed s/TABLE_NAME/$GTEMPORAL_RASTER_METADATA_TABLE_NAME/ | $GRAST4D_DBM $GRAST4D_DATABASE
 # create the raster view
-echo  "create view $GRASTER_VIEW_NAME as select * from $GRASTER_TABLE_NAME, $GRASTER_TIME_TABLE_NAME, $GRASTER_METADATA_TABLE_NAME where $GRASTER_TABLE_NAME.name = $GRASTER_TIME_TABLE_NAME.name AND $GRASTER_TABLE_NAME.name = $GRASTER_TIME_TABLE_NAME.name AND $GRASTER_METADATA_TABLE_NAME.name = $GRASTER_TIME_TABLE_NAME.name;" | $GRAST4D_DBM $GRAST4D_DATABASE
+## bug: replicates columns:
+#echo  "create view $GRASTER_VIEW_NAME as select * from $GRASTER_TABLE_NAME, $GRASTER_TIME_TABLE_NAME, $GRASTER_METADATA_TABLE_NAME \
+#       where $GRASTER_TABLE_NAME.name = $GRASTER_TIME_TABLE_NAME.name AND $GRASTER_TABLE_NAME.name = $GRASTER_TIME_TABLE_NAME.name \
+#       AND $GRASTER_METADATA_TABLE_NAME.name = $GRASTER_TIME_TABLE_NAME.name;" | $GRAST4D_DBM $GRAST4D_DATABASE
+echo  "CREATE VIEW raster_view AS SELECT rt.*, rtt.ctime,rtt.mtime,rtt.vtime_start,rtt.vtime_end,rtt.vtime_duration, \
+       rmt.projection, rmt.datatype, rmt.rows, rmt.cols, rmt.cell_num, rmt.north, rmt.south, rmt.west, rmt.east, rmt.ns_res, \
+       rmt.ew_res, rmt.min, rmt.max, rmt.creator, rmt.data_source, rmt.comments, rmt.description, rmt.additional_data \
+       from raster_table as rt, raster_time_table as rtt, raster_metadata_table as rmt \
+       WHERE rt.name = rtt.name AND rt.name = rtt.name AND rmt.name = rtt.name;" | $GRAST4D_DBM $GRAST4D_DATABASE
 #register trigger functions
 echo "SQL tables created"
