[GRASS-SVN] r32780 - grass/branches/develbranch_6/ps/ps.map
Fri Aug 15 09:08:55 EDT 2008
Author: martinl
Date: 2008-08-15 09:08:55 -0400 (Fri, 15 Aug 2008)
New Revision: 32780
   grass/branches/develbranch_6/ps/ps.map/main.c
   grass/branches/develbranch_6/ps/ps.map/r_colortable.c
glynn: Use G{NAME,MAPSET}_MAX
(merge from trunk, r32775)
Modified: grass/branches/develbranch_6/ps/ps.map/main.c
--- grass/branches/develbranch_6/ps/ps.map/main.c	2008-08-15 13:06:14 UTC (rev 32779)
+++ grass/branches/develbranch_6/ps/ps.map/main.c	2008-08-15 13:08:55 UTC (rev 32780)
@@ -73,7 +73,7 @@
 int main(int argc, char *argv[])
     char buf[1024];
-    char name[100], mapset[50];
+    char name[GNAME_MAX], mapset[GMAPSET_MAX];
     int i;
     int iflag;
     int can_reset_scale;
Modified: grass/branches/develbranch_6/ps/ps.map/r_colortable.c
--- grass/branches/develbranch_6/ps/ps.map/r_colortable.c	2008-08-15 13:06:14 UTC (rev 32779)
+++ grass/branches/develbranch_6/ps/ps.map/r_colortable.c	2008-08-15 13:08:55 UTC (rev 32780)
@@ -29,7 +29,7 @@
     char buf[1024];
     char *key, *data;
     int color, fontsize, cols, nodata, tickbar;
     double w, h, x, y;
     int range_override;
