[GRASS-SVN] r32800 - grass-web/trunk/grass63/binary/mswindows/cygwin
Fri Aug 15 20:15:34 EDT 2008
Author: hamish
Date: 2008-08-15 20:15:34 -0400 (Fri, 15 Aug 2008)
New Revision: 32800
   grass-web/trunk/grass63/binary/mswindows/cygwin/README.html
cosmetics
Modified: grass-web/trunk/grass63/binary/mswindows/cygwin/README.html
--- grass-web/trunk/grass63/binary/mswindows/cygwin/README.html	2008-08-16 00:13:03 UTC (rev 32799)
+++ grass-web/trunk/grass63/binary/mswindows/cygwin/README.html	2008-08-16 00:15:34 UTC (rev 32800)
@@ -29,20 +29,21 @@
 <a href="http://geni.ath.cx/grass.html#_Cygwin_setup_package">http://geni.ath.cx/grass.html#_Cygwin_setup_package</a>.
 The instructions given there can be used with slight modification.
+<ul>
+ <li>Due to a
+   <a href="http://cygwin.com/ml/cygwin-announce/2008-08/msg00001.html">recent
+   change within the Cygwin installer program</a> you must now start Cygwin's
+   <tt>setup.exe</tt> from the command line as "<tt>setup.exe -X</tt>".
-Due to a
-<a href="http://cygwin.com/ml/cygwin-announce/2008-08/msg00001.html">recent
-change within the Cygwin installer program</a> you must now start Cygwin's
-<tt>setup.exe</tt> from the command line as "<tt>setup.exe -X</tt>".
+ <li>At step #3 use
+   <tt>http://grass.ibiblio.org/grass63/binary/mswindows/cygwin/</tt>
+   (or a <a href="http://grass.ibiblio.org/mirrors.php">local mirror</a>)
+   instead of <tt>http://geni.ath.cx/grass</tt>.
-At step #3 use
-<tt>http://grass.ibiblio.org/grass63/binary/mswindows/cygwin/</tt>
-(or a <a href="http://grass.ibiblio.org/mirrors.php">local mirror</a>)
-instead of <tt>http://geni.ath.cx/grass</tt>.
+ <li>In step #5 the version is 6.3.0-2 instead of 6.0.cvs-1, and there's
+   no grass.bat script.
+</ul>
-Also, in step #5 the version is 6.3.0-2 instead of 6.0.cvs-1, and there's no
-grass.bat script.
 <h5>Required packages:</h5>
 These should all be selected for install automatically when you select
 the GRASS package (Database section).
