[GRASS-SVN] r32839 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Aug 17 10:55:39 EDT 2008
Author: martinl
Date: 2008-08-17 10:55:38 -0400 (Sun, 17 Aug 2008)
New Revision: 32839
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
wxGUI: fix bug in layering and rendering, update r32831
code removed from r32465 recovered
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-17 13:37:31 UTC (rev 32838)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-17 14:55:38 UTC (rev 32839)
@@ -644,8 +644,6 @@
         # render background image if needed
         if render:
-            # walk layer tree and update current layers
-            self.tree.ReorderLayers()
             # update display size
             self.Map.ChangeMapSize(self.GetClientSize())
             windres = False
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-17 13:37:31 UTC (rev 32838)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-17 14:55:38 UTC (rev 32839)
@@ -496,7 +496,7 @@
         """Rename layer"""
         self.EditLabel(self.layer_selected)
-    def AddLayer(self, ltype, lname=None, lchecked=None, \
+    def AddLayer(self, ltype, lname=None, lchecked=None,
                  lopacity=None, lcmd=None, lgroup=None, lnviz=None):
         """Add new item to the layer tree, create corresponding MapLayer instance.
         Launch property dialog if needed (raster, vector, etc.)
@@ -658,7 +658,23 @@
                                     'propwin' : None},
                                    None))
-            maplayer = self.Map.AddLayer(type=ltype, command=self.GetPyData(layer)[0]['cmd'], name=name,
+            # find previous map layer instance
+            prevItem = self.GetFirstChild(self.root)[0]
+            prevMapLayer = None
+            pos = -1
+            while prevItem and prevItem.IsOk() and prevItem != layer:
+                if self.GetPyData(prevItem)[0]['maplayer']:
+                    prevMapLayer = self.GetPyData(prevItem)[0]['maplayer']
+                prevItem = self.GetNextSibling(prevItem)
+                if prevMapLayer:
+                    pos = self.Map.GetLayerIndex(prevMapLayer)
+                else:
+                    pos = -1
+            maplayer = self.Map.AddLayer(pos=pos,
+                                         type=ltype, command=self.GetPyData(layer)[0]['cmd'], name=name,
                                          l_active=checked, l_hidden=False,
                                          l_opacity=opacity, l_render=render)
             self.GetPyData(layer)[0]['maplayer'] = maplayer
