[GRASS-SVN] r32857 - in grass/trunk: include/Make scripts/d.shadedmap scripts/r.in.aster scripts/r.out.xyz scripts/v.build.all scripts/v.centroids scripts/v.convert.all scripts/v.in.sites.all scripts/v.what.vect
Mon Aug 18 11:58:53 EDT 2008
Author: glynn
Date: 2008-08-18 11:58:53 -0400 (Mon, 18 Aug 2008)
New Revision: 32857
Added:
   grass/trunk/scripts/d.shadedmap/d.shadedmap.py
   grass/trunk/scripts/r.in.aster/r.in.aster.py
   grass/trunk/scripts/r.out.xyz/r.out.xyz.py
   grass/trunk/scripts/v.build.all/v.build.all.py
   grass/trunk/scripts/v.centroids/v.centroids.py
   grass/trunk/scripts/v.convert.all/v.convert.all.py
   grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
   grass/trunk/scripts/v.what.vect/v.what.vect.py
Removed:
   grass/trunk/scripts/r.in.aster/r_in_aster.py
   grass/trunk/include/Make/Script.make
Add Python versions of various scripts
Change Script.make to prefer Python versions over Bourne shell versions
Modified: grass/trunk/include/Make/Script.make
--- grass/trunk/include/Make/Script.make	2008-08-18 15:57:30 UTC (rev 32856)
+++ grass/trunk/include/Make/Script.make	2008-08-18 15:58:53 UTC (rev 32857)
@@ -17,11 +17,16 @@
 script: $(SCRIPT_ACTIONS)
-$(SCRIPT): $(PGM)
+$(SCRIPTDIR)/%: %.py
 	if [ ! -d $(SCRIPTDIR) ]; then $(MKDIR) $(SCRIPTDIR); fi
-	$(INSTALL) $(PGM) $(SCRIPT)
+	$(INSTALL) $< $@
 	$(MAKE) htmlscript scriptstrings
+$(SCRIPTDIR)/%: %
+	if [ ! -d $(SCRIPTDIR) ]; then $(MKDIR) $(SCRIPTDIR); fi
+	$(INSTALL) $< $@
+	$(MAKE) htmlscript scriptstrings
 $(BIN)/$(PGM).bat: $(MODULE_TOPDIR)/scripts/windows_launch.bat
 	sed -e "s#SCRIPT_NAME#$(PGM)#" $(MODULE_TOPDIR)/scripts/windows_launch.bat > $@
Added: grass/trunk/scripts/d.shadedmap/d.shadedmap.py
--- grass/trunk/scripts/d.shadedmap/d.shadedmap.py	                        (rev 0)
+++ grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,54 @@
+#!/usr/bin/env python
+# MODULE:	d.shadedmap
+# AUTHOR(S):	Unknown; updated to GRASS 5.7 by Michael Barton
+#		Converted to Python by Glynn Clements
+# PURPOSE:	Uses d.his to drape a color raster over a shaded relief map
+# COPYRIGHT:	(C) 2004,2008 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#% description: Drapes a color raster over a shaded relief map using d.his
+#%End
+#%option
+#% key: reliefmap
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Name of shaded relief or aspect map
+#% required : yes
+#%end
+#%option
+#% key: drapemap
+#% type: string
+#% description: Name of raster to drape over relief map
+#% required : yes
+#%end
+#%option
+#% key: brighten
+#% type: integer
+#% description: Percent to brighten
+#% options: -99-99
+#% answer: 0
+#%end
+import sys
+import grass
+def main():
+    drape_map = options['drapemap']
+    relief_map = options['reliefmap']
+    brighten = options['brighten']
+    ret = grass.run_command("d.his", h_map = drapemap,  i_map = relief_map, brighten = brighten)
+    sys.exit(ret)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/scripts/d.shadedmap/d.shadedmap.py
___________________________________________________________________
   + native
Copied: grass/trunk/scripts/r.in.aster/r.in.aster.py (from rev 32853, grass/trunk/scripts/r.in.aster/r_in_aster.py)
--- grass/trunk/scripts/r.in.aster/r.in.aster.py	                        (rev 0)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,203 @@
+# MODULE:    r_in_aster.py
+# AUTHOR(S): Michael Barton (michael.barton at asu.edu) and
+#               Glynn Clements (glynn at gclements.plus.com)
+#               Based on r.in.aster bash script for GRASS
+#               by Michael Barton and Paul Kelly
+# PURPOSE:   Rectifies, georeferences, & imports Terra-ASTER imagery
+#               using gdalwarp
+# COPYRIGHT: (C) 2008 by the GRASS Development Team
+#   for details.
+# Requires:
+#   gdalwarp
+#   gdal compiled with HDF4 support
+#%Module
+#%  description: Georeference, rectify, and import Terra-ASTER imagery and relative DEM's using gdalwarp.
+#%  keywords: raster, imagery, import
+#%End
+#%option
+#%  key: input
+#%  type: string
+#%  gisprompt: old_file,file,input
+#%  description: Input ASTER image to be georeferenced & rectified
+#%  required: yes
+#%end
+#%option
+#%  key: proctype
+#%  type: string
+#%  description: ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)
+#%  options: L1A,L1B,DEM
+#%  answer: L1B
+#%  required: yes
+#%end
+#%option
+#%  key: band
+#%  type: string
+#%  description: List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands
+#%  answer: all
+#%  required: yes
+#%end
+#%option
+#%  key: output
+#%  type: string
+#%  description: Base name for output raster map (band number will be appended to base name)
+#%  required: yes
+#%end
+#%flag
+#%  key: o
+#%  description: Overwrite existing file
+#%END
+import sys
+import os
+import subprocess
+import platform
+import grass
+bands = {
+    'L1A': {
+        '1':  "VNIR_Band1:ImageData",
+        '2':  "VNIR_Band2:ImageData",
+        '3n': "VNIR_Band3N:ImageData",
+        '3b': "VNIR_Band3B:ImageData",
+        '4':  "SWIR_Band4:ImageData",
+        '5':  "SWIR_Band5:ImageData",
+        '6':  "SWIR_Band6:ImageData",
+        '7':  "SWIR_Band7:ImageData",
+        '8':  "SWIR_Band8:ImageData",
+        '9':  "SWIR_Band9:ImageData",
+        '10': "TIR_Band10:ImageData",
+        '11': "TIR_Band11:ImageData",
+        '12': "TIR_Band12:ImageData",
+        '13': "TIR_Band13:ImageData",
+        '14': "TIR_Band14:ImageData"
+    'L1B': {
+        '1':  "VNIR_Swath:ImageData1",
+        '2':  "VNIR_Swath:ImageData2",
+        '3n': "VNIR_Swath:ImageData3N",
+        '3b': "VNIR_Swath:ImageData3B",
+        '4':  "SWIR_Swath:ImageData4",
+        '5':  "SWIR_Swath:ImageData5",
+        '6':  "SWIR_Swath:ImageData6",
+        '7':  "SWIR_Swath:ImageData7",
+        '8':  "SWIR_Swath:ImageData8",
+        '9':  "SWIR_Swath:ImageData9",
+        '10': "TIR_Swath:ImageData10",
+        '11': "TIR_Swath:ImageData11",
+        '12': "TIR_Swath:ImageData12",
+        '13': "TIR_Swath:ImageData13",
+        '14': "TIR_Swath:ImageData14"
+def _message(msg, *args):
+    subprocess.call(["g.message", "message=%s" % msg] + list(args))
+def debug(msg):
+    _message(msg, '-d')
+def message(msg):
+    _message(msg)
+def error(msg):
+    _message(msg, '-e')
+    sys.exit(1)
+def main():
+    #check whether gdalwarp is in path and executable
+    p = None
+    try:
+        p = subprocess.call(['gdalwarp', '--version'])
+    except:
+        pass
+    if p == None or p != 0:
+        error("gdalwarp is not in the path and executable")
+    #initialize variables
+    dataset = ''
+    srcfile = ''
+    proj = ''
+    band = ''
+    outfile = ''
+    bandlist = []
+    #create temporary file to hold gdalwarp output before importing to GRASS
+    tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() + '.tif'
+    #get projection information for current GRASS location
+    proj = grass.read_command('g.proj', flags = 'jf').strip()
+    #currently only runs in projected location
+    if "XY location" in proj:
+      error ("This module needs to be run in a projected location (found: %s)" % proj)
+    #process list of bands
+    allbands = ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
+    if options['band'].strip() == 'all':
+        bandlist = allbands
+    else:
+        bandlist = options['band'].split(',')
+    #initialize datasets for L1A and L1B
+    if options['proctype'] in ["L1A", "L1B"]:
+        for band in bandlist:
+            if band in allbands:
+                dataset = bands[options['proctype']][band]
+                srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (options['input'], dataset)
+                import_aster(proj, srcfile, tempfile, band)
+            else:
+                error('band %s is not an available Terra/ASTER band' % band)
+    elif options['proctype'] == "DEM":
+        srcfile=options['input']
+        import_aster(proj, srcfile, tempfile, "DEM")
+    # write cmd history: Not sure how to replicate this in Python yet
+    #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
+    #cleanup
+    message("Cleaning up ...")
+    os.remove(tempfile)
+    message("Done.")
+    return
+def import_aster(proj, srcfile, tempfile, band):
+    #run gdalwarp with selected options (must be in $PATH)
+    #to translate aster image to geotiff
+    message("Georeferencing aster image ...")
+    debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
+    if platform.system() == "Darwin":
+        cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile ]
+    else:
+        cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
+    p = subprocess.call(cmd)
+    if p != 0:
+        #check to see if gdalwarp executed properly
+        return
+    #p = subprocess.call(["gdal_translate", srcfile, tempfile])
+    #import geotiff to GRASS
+    message("Importing into GRASS ...")
+    outfile = options['output'].strip()+'.'+band
+    grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
+    return
+    main()
Property changes on: grass/trunk/scripts/r.in.aster/r.in.aster.py
   + native
Deleted: grass/trunk/scripts/r.in.aster/r_in_aster.py
--- grass/trunk/scripts/r.in.aster/r_in_aster.py	2008-08-18 15:57:30 UTC (rev 32856)
+++ grass/trunk/scripts/r.in.aster/r_in_aster.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -1,203 +0,0 @@
-#!/usr/bin/python
-# MODULE:    r_in_aster.py
-# AUTHOR(S): Michael Barton (michael.barton at asu.edu) and
-#               Glynn Clements (glynn at gclements.plus.com)
-#               Based on r.in.aster bash script for GRASS
-#               by Michael Barton and Paul Kelly
-# PURPOSE:   Rectifies, georeferences, & imports Terra-ASTER imagery
-#               using gdalwarp
-# COPYRIGHT: (C) 2008 by the GRASS Development Team
-#   This program is free software under the GNU General Public
-#   License (>=v2). Read the file COPYING that comes with GRASS
-#   for details.
-# Requires:
-#   gdalwarp
-#   gdal compiled with HDF4 support
-#%Module
-#%  description: Georeference, rectify, and import Terra-ASTER imagery and relative DEM's using gdalwarp.
-#%  keywords: raster, imagery, import
-#%End
-#%option
-#%  key: input
-#%  type: string
-#%  gisprompt: old_file,file,input
-#%  description: Input ASTER image to be georeferenced & rectified
-#%  required: yes
-#%end
-#%option
-#%  key: proctype
-#%  type: string
-#%  description: ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)
-#%  options: L1A,L1B,DEM
-#%  answer: L1B
-#%  required: yes
-#%end
-#%option
-#%  key: band
-#%  type: string
-#%  description: List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands
-#%  answer: all
-#%  required: yes
-#%end
-#%option
-#%  key: output
-#%  type: string
-#%  description: Base name for output raster map (band number will be appended to base name)
-#%  gisprompt: old,cell,raster
-#%  required: yes
-#%end
-#%flag
-#%  key: o
-#%  description: Overwrite existing file
-#%END
-import sys
-import os
-import subprocess
-import platform
-import grass
-bands = {
-    'L1A': {
-        '1':  "VNIR_Band1:ImageData",
-        '2':  "VNIR_Band2:ImageData",
-        '3n': "VNIR_Band3N:ImageData",
-        '3b': "VNIR_Band3B:ImageData",
-        '4':  "SWIR_Band4:ImageData",
-        '5':  "SWIR_Band5:ImageData",
-        '6':  "SWIR_Band6:ImageData",
-        '7':  "SWIR_Band7:ImageData",
-        '8':  "SWIR_Band8:ImageData",
-        '9':  "SWIR_Band9:ImageData",
-        '10': "TIR_Band10:ImageData",
-        '11': "TIR_Band11:ImageData",
-        '12': "TIR_Band12:ImageData",
-        '13': "TIR_Band13:ImageData",
-        '14': "TIR_Band14:ImageData"
-    'L1B': {
-        '1':  "VNIR_Swath:ImageData1",
-        '2':  "VNIR_Swath:ImageData2",
-        '3n': "VNIR_Swath:ImageData3N",
-        '3b': "VNIR_Swath:ImageData3B",
-        '4':  "SWIR_Swath:ImageData4",
-        '5':  "SWIR_Swath:ImageData5",
-        '6':  "SWIR_Swath:ImageData6",
-        '7':  "SWIR_Swath:ImageData7",
-        '8':  "SWIR_Swath:ImageData8",
-        '9':  "SWIR_Swath:ImageData9",
-        '10': "TIR_Swath:ImageData10",
-        '11': "TIR_Swath:ImageData11",
-        '12': "TIR_Swath:ImageData12",
-        '13': "TIR_Swath:ImageData13",
-        '14': "TIR_Swath:ImageData14"
-def _message(msg, *args):
-    subprocess.call(["g.message", "message=%s" % msg] + list(args))
-def debug(msg):
-    _message(msg, '-d')
-def message(msg):
-    _message(msg)
-def error(msg):
-    _message(msg, '-e')
-    sys.exit(1)
-def main():
-    #check whether gdalwarp is in path and executable
-    p = None
-    try:
-        p = subprocess.call(['gdalwarp', '--version'])
-    except:
-        pass
-    if p == None or p != 0:
-        error("gdalwarp is not in the path and executable")
-    #initialize variables
-    dataset = ''
-    srcfile = ''
-    proj = ''
-    band = ''
-    outfile = ''
-    bandlist = []
-    #create temporary file to hold gdalwarp output before importing to GRASS
-    tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() + '.tif'
-    #get projection information for current GRASS location
-    proj = grass.read_command('g.proj', flags = 'jf').strip()
-    #currently only runs in projected location
-    if "XY location" in proj:
-      error ("This module needs to be run in a projected location (found: %s)" % proj)
-    #process list of bands
-    allbands = ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
-    if options['band'].strip() == 'all':
-        bandlist = allbands
-    else:
-        bandlist = options['band'].split(',')
-    #initialize datasets for L1A and L1B
-    if options['proctype'] in ["L1A", "L1B"]:
-        for band in bandlist:
-            if band in allbands:
-                dataset = bands[options['proctype']][band]
-                srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (options['input'], dataset)
-                import_aster(proj, srcfile, tempfile, band)
-            else:
-                error('band %s is not an available Terra/ASTER band' % band)
-    elif options['proctype'] == "DEM":
-        srcfile=options['input']
-        import_aster(proj, srcfile, tempfile, "DEM")
-    # write cmd history: Not sure how to replicate this in Python yet
-    #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
-    #cleanup
-    message("Cleaning up ...")
-    os.remove(tempfile)
-    message("Done.")
-    return
-def import_aster(proj, srcfile, tempfile, band):
-    #run gdalwarp with selected options (must be in $PATH)
-    #to translate aster image to geotiff
-    message("Georeferencing aster image ...")
-    debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
-    if platform.system() == "Darwin":
-        cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile ]
-    else:
-        cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
-    p = subprocess.call(cmd)
-    if p != 0:
-        #check to see if gdalwarp executed properly
-        return
-    #p = subprocess.call(["gdal_translate", srcfile, tempfile])
-    #import geotiff to GRASS
-    message("Importing into GRASS ...")
-    outfile = options['output'].strip()+'.'+band
-    grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
-    return
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Added: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py	                        (rev 0)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,63 @@
+# MODULE:       r.out.xyz
+# AUTHOR:       M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
+#                 New Zealand
+# PURPOSE:      Export a raster map as x,y,z values based on cell centers
+#               This is a simple wrapper script for "r.stats -1ng"
+# COPYRIGHT:    (c) 2006 Hamish Bowman, and the GRASS Development Team
+#		(c) 2008 Glynn Clements, and the GRASS Development Team
+#               for details.
+#%Module
+#% description: Export a raster map to a text file as x,y,z values based on cell centers.
+#% keywords: raster, export
+#%End
+#%option
+#% key: input
+#% type: string
+#% key_desc: name
+#% description: Name of input raster map
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% description: Name for output file (if omitted or "-" output to stdout)
+#% required: no
+#%end
+#%option
+#% key: fs
+#% type: string
+#% key_desc: character
+#% description: Field separator
+#% answer: |
+#% required: no
+#%end
+import sys
+import grass
+def main():
+    # if no output filename, output to stdout
+    output = options['output']
+    if output == "" or output == "-":
+	outf = sys.stdout
+    else:
+	outf = file(output)
+    ret = grass.run_command("r.stats", flags = "1gn", input = options['input'], fs = options['fs'], stdout = outf)
+    sys.exit(ret)
+    main()
Property changes on: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
   + native
Added: grass/trunk/scripts/v.build.all/v.build.all.py
--- grass/trunk/scripts/v.build.all/v.build.all.py	                        (rev 0)
+++ grass/trunk/scripts/v.build.all/v.build.all.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,37 @@
+# MODULE:	v.build.all
+# AUTHOR(S):	Glynn Clements, Radim Blazek
+# PURPOSE:	Build all vectors in current mapset
+#		for details.
+#%Module
+#% description: Rebuilds topology on all vector maps in the current mapset.
+#% keywords: vector
+#%End
+import sys
+import grass
+def main():
+    env = grass.gisenv()
+    mapset = env['MAPSET']
+    ret = 0
+    for vect in grass.list_grouped('vect')[mapset]:
+	map = "%s@%s" % (vect, mapset)
+	grass.message("Build topology for vector '%s'" % map)
+	grass.message("v.build map=%s" % map)
+	if grass.run_command("v.build", map = map) != 0:
+	    ret = 1
+    sys.exit(ret)
+    main()
Property changes on: grass/trunk/scripts/v.build.all/v.build.all.py
   + native
Added: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py	                        (rev 0)
+++ grass/trunk/scripts/v.centroids/v.centroids.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,96 @@
+# MODULE:       v.centroids
+# AUTHOR:       Hamish Bowman
+# PURPOSE:      Add missing centroids  (frontend to v.category opt=add)
+#               for details.
+#%Module
+#% description: Adds missing centroids to closed boundaries.
+#% keywords: vector, centroid, area
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Name of input vector map
+#%required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,vector,vector
+#% key_desc: name
+#% description: Name for output vector map
+#% required: yes
+#%end
+#%option
+#% key: option
+#% type: string
+#% description: Action to be taken
+#% options: add
+#% answer: add
+#% required: no
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer number
+#% answer: 1
+#% required: no
+#%end
+#%option
+#% key: cat
+#% type: integer
+#% description: Category number starting value
+#% answer: 1
+#% required: no
+#%end
+#%option
+#% key: step
+#% type: integer
+#% description: Category increment
+#% answer: 1
+#% required: no
+#%end
+import sys
+import os
+import re
+import grass
+def main():
+    if options['option'] == 'add':
+	num_bound = 0
+	tenv = os.environ.copy()
+	tenv['LC_ALL'] = 'C'
+	lines = grass.read_command("v.info", map = options['input'], env = tenv).splitlines()
+	e = re.compile("Number of boundaries: +([0-9]+) +")
+	for line in lines:
+	    mo = e.search(line)
+	    if mo:
+		num_bound = int(mo.group(1))
+		break
+	if num_bound == 0:
+	    grass.fatal("Input vector map contains no boundaries.")
+	grass.exec_command("v.category", type = 'area', **options)
+    sys.exit(0)
+    main()
Property changes on: grass/trunk/scripts/v.centroids/v.centroids.py
   + native
Added: grass/trunk/scripts/v.convert.all/v.convert.all.py
--- grass/trunk/scripts/v.convert.all/v.convert.all.py	                        (rev 0)
+++ grass/trunk/scripts/v.convert.all/v.convert.all.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,49 @@
+# MODULE:	v.convert.all
+# AUTHOR(S):	Markus Neteler, converted to Python by Glynn Clements
+# PURPOSE:	converts all old GRASS < V5.7 vector maps to current format
+#		in current mapset
+# COPYRIGHT:	(C) 2004, 2008 by the GRASS Development Team
+#		for details.
+#%Module
+#%  description: Convert all old GRASS < Ver5.7 vector maps in current mapset to current format
+#%  keywords: vector, import
+#%end
+import sys
+import grass
+def main():
+    converted = 0
+    ret = 0
+    for vect in grass.list_grouped('oldvect')[mapset]:
+	inmap = "%s@%s" % (vect, mapset)
+	outmap = vect.replace(".", "_")
+	if grass.run_command("v.convert", input = inmap, output = outmap) == 0:
+	    converted += 1
+	else:
+	    grass.warning("Error converting map %s to %s" % (inmap, outmap))
+	    ret = 1
+	if converted < 1:
+	    grass.warning("No vector maps converted as no old vector maps present in current mapset.")
+	else:
+	    grass.message("Total %u vector maps in current mapset converted." % converted)
+	    grass.message("Please verify new vector map(s) before deleting old vector map(s).")
+	sys.exit(ret)
+    main()
Property changes on: grass/trunk/scripts/v.convert.all/v.convert.all.py
   + native
Added: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py	                        (rev 0)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,49 @@
+# MODULE:	v.in.sites.all
+# PURPOSE:	converts all old GRASS < V5.7 sites maps to vector maps
+#		for details.
+#%Module
+#% description: Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps.
+#% keywords: sites, vector, import
+#%End
+import sys
+import grass
+def main():
+    converted = 0
+    ret = 0
+    for site in grass.list_grouped('sites')[mapset]:
+	inmap = "%s@%s" % (site, mapset)
+	outmap = site.replace(".", "_") + "_points"
+	grass.message("Processing %s -> %s" % (inmap, outmap))
+	if grass.run_command("v.in.sites", input = inmap, output = outmap) == 0:
+	    converted += 1
+	else:
+	    ret = 1
+	if converted < 1:
+	    grass.warning("No sites maps converted as no old sites maps present in current mapset.")
+	else:
+	    grass.message("Total %u sites maps in current mapset converted to vector maps (original names extended by '_points')" % converted)
+	    grass.message("Please verify new vector map(s) before deleting old sites map(s).")
+	sys.exit(ret)
+    main()
Property changes on: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
   + native
Added: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py	                        (rev 0)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py	2008-08-18 15:58:53 UTC (rev 32857)
@@ -0,0 +1,88 @@
+# MODULE:       v.what.vect
+# PURPOSE:      Uploads attributes at the location of vector points to the table.
+# COPYRIGHT:    (C) 2005, 2008 by the GRASS Development Team
+#               for details.
+#%Module
+#%  description: Uploads vector values at positions of vector points to the table.
+#%  keywords: vector, database, attribute table
+#%End
+#%option
+#% key: vector
+#% type: string
+#% key_desc: name
+#% description: Points vector map to modify
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer in the vector to be modified
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Column to be updated with the query result
+#% required : yes
+#%end
+#%option
+#% key: qvector
+#% type: string
+#% key_desc: name
+#% description: Vector map to be queried
+#% required : yes
+#%end
+#%option
+#% key: qlayer
+#% type: integer
+#% description: Layer of the query vector containg data
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: qcolumn
+#% type: string
+#% description: Column to be queried
+#% required : yes
+#%end
+#%option
+#% key: dmax
+#% type: double
+#% description: Maximum query distance in map units
+#% answer: 0.0
+#% required: no
+#%end
+import sys
+import grass
+def main():
+	"v.distance",
+	fro = options['vector'],
+	to = options['qvector'],
+	column = options['column'],
+	to_column = options['qcolumn'],
+	upload = to_attr,
+	dmax = options['dmax'],
+	from_layer = options['layer'],
+	to_layer = options['qlayer '])
+    main()
Property changes on: grass/trunk/scripts/v.what.vect/v.what.vect.py
   + native
