[GRASS-SVN] r32859 - in grass/branches/develbranch_6: raster/r.in.xyz vector/v.vol.rst
Mon Aug 18 13:22:00 EDT 2008
Author: neteler
Date: 2008-08-18 13:22:00 -0400 (Mon, 18 Aug 2008)
New Revision: 32859
   grass/branches/develbranch_6/raster/r.in.xyz/description.html
   grass/branches/develbranch_6/vector/v.vol.rst/description.html
url updated
Modified: grass/branches/develbranch_6/raster/r.in.xyz/description.html
--- grass/branches/develbranch_6/raster/r.in.xyz/description.html	2008-08-18 17:19:28 UTC (rev 32858)
+++ grass/branches/develbranch_6/raster/r.in.xyz/description.html	2008-08-18 17:22:00 UTC (rev 32859)
@@ -151,7 +151,7 @@
 <h2>EXAMPLE</h2>
-Import the <a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Jockey's
+Import the <a href="http://www.grassbook.org/data_menu2nd.phtml">Jockey's
 Ridge, NC, LIDAR dataset</a>, and process into a clean DEM:
 <div class="code"><pre>
Modified: grass/branches/develbranch_6/vector/v.vol.rst/description.html
--- grass/branches/develbranch_6/vector/v.vol.rst/description.html	2008-08-18 17:19:28 UTC (rev 32858)
+++ grass/branches/develbranch_6/vector/v.vol.rst/description.html	2008-08-18 17:22:00 UTC (rev 32859)
@@ -140,7 +140,7 @@
 <P>
 <i>Example
- (<based on <a href="http://mpa.itc.it/grasstutor/data_menu2nd.phtml">Slovakia3d dataset</a>):</i>
+ (<based on <a href="http://www.grassbook.org/data_menu2nd.phtml">Slovakia3d dataset</a>):</i>
 <P>
 v.info -c precip3d
