[GRASS-SVN] r32880 - grass/trunk/gui/wxpython/gui_modules
Tue Aug 19 06:10:16 EDT 2008
Author: martinl
Date: 2008-08-19 06:10:15 -0400 (Tue, 19 Aug 2008)
New Revision: 32880
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
cmbarton: Greatly speed up auto-rendering and make it nearly unbreakable even when rapidly doing drag and drop of layers.
(merge from devbr6, r32874, r32875, r32879)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-08-19 10:00:04 UTC (rev 32879)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-08-19 10:10:15 UTC (rev 32880)
@@ -643,6 +643,9 @@
         # render background image if needed
+        if self.tree.rerender == True:
+            self.tree.ReorderLayers()
         if render:
             # update display size
             self.Map.ChangeMapSize(self.GetClientSize())
@@ -2817,7 +2820,7 @@
         Re-render map composition (each map layer)
-        # detele tmp map layers (queries)
+        # delete tmp map layers (queries)
         qlayer = self.Map.GetListOfLayers(l_name=globalvar.QUERYLAYER)
         for layer in qlayer:
             self.Map.DeleteLayer(layer)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2008-08-19 10:00:04 UTC (rev 32879)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2008-08-19 10:10:15 UTC (rev 32880)
@@ -831,7 +831,7 @@
                 if not layer.Render():
                     continue
-            # update process bar
+            # update progress bar
             if mapWindow is not None:
                 mapWindow.onRenderCounter += 1
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-19 10:00:04 UTC (rev 32879)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-19 10:10:15 UTC (rev 32880)
@@ -91,6 +91,7 @@
         self.notebook = kargs['notebook']   # GIS Manager notebook for layer tree
         self.treepg = parent        # notebook page holding layer tree
         self.auimgr = kargs['auimgr']       # aui manager
+        self.rerender = False       # layer change requires a reordering and rerendering (if auto render)
         # init associated map display
         self.mapdisplay = mapdisp.MapFrame(self,
@@ -188,7 +189,21 @@
         #self.Bind(wx.EVT_TREE_END_LABEL_EDIT,   self.OnChangeLayerName)
         self.Bind(wx.EVT_KEY_UP,                self.OnKeyUp)
         # self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+        self.Bind(wx.EVT_IDLE,                  self.OnIdle)
+    def OnIdle(self, event):
+        Only re-order and re-render a composite map image from GRASS during
+        idle time instead of multiple times during layer changing.
+        if self.rerender:
+            if self.mapdisplay.autoRender.GetValue():
+                self.mapdisplay.MapWindow.UpdateMap(render=True)
+        event.Skip()
     def OnKeyUp(self, event):
         """Key pressed"""
         key = event.GetKeyCode()
@@ -479,8 +494,10 @@
                              layerbase + ' (opacity: ' + str(opacity_pct) + '%)')
             # redraw map if auto-rendering is enabled
-            if self.mapdisplay.autoRender.GetValue():
-                self.mapdisplay.OnRender(None)
+            self.rerender = True
+            #if self.mapdisplay.autoRender.GetValue():
+            #    print "*** Opacity OnRender *****"
+            #    self.mapdisplay.OnRender(None)
     def OnNvizProperties(self, event):
         """Nviz-related properties (raster/vector/volume)
@@ -843,8 +860,10 @@
             pass
+        #    print "*** Delete OnRender *****"
         if self.mapdisplay.toolbars['vdigit']:
             self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers (updateTool=True)
@@ -918,8 +937,10 @@
             self.mapdisplay.SetStatusText("", 0)
+        #    print "*** Checked OnRender *****"
     def OnCmdChanged(self, event):
         """Change command string"""
@@ -1048,11 +1069,13 @@
             pass
         # reorder layers in render.Map to match new order after drag and drop
-        self.ReorderLayers()
+        #self.ReorderLayers()
+        #    print "*** Drop OnRender *****"
         # select new item
         self.SelectItem(newItem)
@@ -1069,13 +1092,11 @@
         image   = self.GetItemImage(dragItem, 0)
         text    = self.GetItemText(dragItem)
         if self.GetPyData(dragItem)[0]['ctrl']:
-            # recreate spin/text control for layer
+            # recreate data layer
             btnbmp = Icons["layeropts"].GetBitmap((16,16))
             newctrl = buttons.GenBitmapButton(self, id=wx.ID_ANY, bitmap=btnbmp, size=(24, 24))
             newctrl.SetToolTipString(_("Click to edit layer settings"))
             self.Bind(wx.EVT_BUTTON, self.OnLayerContextMenu, newctrl)
-            opacity = self.GetPyData(dragItem)[0]['maplayer'].GetOpacity()
-            windval = self.GetPyData(dragItem)[0]['maplayer'].GetOpacity()
             data    = self.GetPyData(dragItem)
         elif self.GetPyData(dragItem)[0]['type'] == 'command':
@@ -1090,13 +1111,11 @@
                 pass
             newctrl.Bind(wx.EVT_TEXT_ENTER, self.OnCmdChanged)
             newctrl.Bind(wx.EVT_TEXT,       self.OnCmdChanged)
         elif self.GetPyData(dragItem)[0]['type'] == 'group':
-            #recreate group
+            # recreate group
             newctrl = None
-            windval = None
             data    = None
         # decide where to put recreated item
@@ -1139,7 +1158,7 @@
         else:
             self.GetPyData(newItem)[0]['ctrl'] = None
-        self.CheckItem(newItem, checked=checked)
+        self.CheckItem(newItem, checked=checked) # causes a new render
         # newItem.SetHeight(TREE_ITEM_HEIGHT)
@@ -1228,7 +1247,7 @@
             else:
                 vislayer = self.GetNextVisible(vislayer)
-        Debug.msg (4, "LayerTree.ReoderLayers(): items=%s" % \
+        Debug.msg (4, "LayerTree.ReorderLayers(): items=%s" % \
                    (itemList))
         # reorder map layers
@@ -1268,8 +1287,10 @@
             self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers(updateTool=True)
+        #    print "*** Change OnRender *****"
         # item.SetHeight(TREE_ITEM_HEIGHT)
